Gateway + BCM upgrade for 2015 Golf Sportwagen TDI S
brendan_
Boston, MA, USA
C?ID=516305
Like the title states, I want to upgrade both my current gateway (5Q0 907 530 L) and BCM (5Q0 937 087 Q). I assume that these are both the LOW versions that do not support heated seats, fog lights, etc. I plan on doing a few of those retrofits, so I would like to prepare by upgrading those two modules I previously mentioned. I'm having trouble getting a clear explanation as to what would be the HIGH equivalent version part numbers, so if anyone has some ideas, it would be greatly appreciated. I will provide a recent scan of my vehicle as well.
Wednesday,03,August,2022,18:21:26:55940
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)(Parallels)
VCDS Version 22.3.1.4 (arm64)  HEX-V2 CB: 0.4615.4
VIN: 3VWCA7AU3FM515369   License Plate:
Mileage: 166597km-103518mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
VIN: 3VWCA7AU3FM515369   Mileage: 166597km-103518miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 N    HW: 04L 907 309
   Component: R4 2.0l TDI   H23 9459
   Revision: 85H23---    CVN: B5ADD45238D3FF82B866C2AD
   Coding: 021D0012032410081000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TDI01104L997022N 004002
   ROD: EV_ECM20TDI01104L997022N.rod
   VCID: 3B23395723E80893DAD-806F
   VINID: 0E69D34474650D67450450C624EBB8C5E7
17158 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 166597 km
                    Date: 2022.08.03
                    Time: 18:19:36
                    Engine RPM: 772.00 /min
                    Normed load value: 31.4 %
                    Coolant temperature: 91 ∞C
                    Intake air temperature: 75 ∞C
                    Voltage terminal 30: 13.600 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 17
                    Acceleration: 0.000 m/s≤
Readiness: 0 0 0 1 1
   Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 05853104    Serial number: TFK01503163011 CVN: 0000EF4F
   Shop #: WSC 00066 790 00218
   ROD: EV_TCMDQ250021.rod
   VCID: 2313E137BB585053F2D-8077
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 51085000000641
   Coding: 04FA6AA124210971007A020681CC2520562490004081A4B200630050C002
   VCID: 47CB55A76F205C734E5-8013
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [009] - -
          [FCAN: Coding of ESP and TSK does not fit together]
                    Reset counter: 55
                    Date: 2022.08.03
                    Time: 18:19:34
   Revision: 00021000    Serial number: 0365009729
   Coding: 030C0C
   VCID: 3A2D3C532CD2319BC1B-806F
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 02020104202100000000000000000000
   Shop #: WSC 01383 790 50316
   VCID: 05579FAF15AC8E63FC9-8051
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 087 Q    HW: 5Q0 937 087 Q
   Revision: --------    Serial number: 86582903150149
   Coding: 0001184240C1804169E44000000403001808000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 49CF539F7934AA03581-801D
   Component: WWS    150327  043 0581
   Serial number:         150518181529
565764 - LED Light Bar
          B1664 31 [009] - No Signal
                    Reset counter: 55
                    Mileage: 166597 km
                    Date: 2022.08.03
                    Time: 18:19:33
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 13.5 V
                    Outside temperature: 33.5 ∞C
   Serial number: 003GCR01MTC-
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J150002Q8BT0I
   Coding: 303138
   Subsystem 2 - Part No SW: -----------    HW: 480 002 403 15
   Serial number: 3570000000053D41831A
   Subsystem 3 - Part No SW: -----------    HW: 480 002 403 15
   Serial number: 35800000000870718318
   Subsystem 4 - Part No SW: -----------    HW: 480 403 103 15
   Serial number: 3510002C71941315012E
   Subsystem 5 - Part No SW: -----------    HW: 480 403 103 15
   Serial number: 3520002A31A87850C1E5
   Subsystem 6 - Part No SW: -----------    HW: 480 402 603 15
   Serial number: 3550002C3194131211EO
   Subsystem 7 - Part No SW: -----------    HW: 480 402 603 15
   Serial number: 3560002C31941313D38Y
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150407400739
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 045182AB1E96B76BEB7-8051
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA5121A2180CF0502087E001000000000000000
   VCID: 6597BF2FF5EC6E635C9-8031
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 30041510000436
   Coding: 0901000800087300EF0000081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07030
   GVL: 01503C0000000600400C00008000C80000000000000000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 71BFDB7F3124B2C3301-8025
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150000777580105164
   Coding: 31FFFF
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0056486
   Revision: 00000000    Serial number: 15000072186002
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431126B0EB6C7EB1B7-8061
   Serial number: 01071506050371
   Coding: 003113205000040000000000
   VCID: 43D341B75B18705392D-8017
   Serial number: 00000000000001068099
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   Serial number: 141016060509XD
   Coding: 003113205C00040000000000
   VCID: 42DD44B34402795B99B-8017
   Serial number: 00000000000001127988
   Coding: 091000
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 02730200FF00000051220001001808001F0100D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 6C81CA0B16065F2B037-8039
   Subsystem 1 - Part No SW: 7C0 919 606     HW: 7C0 919 606
   Component: ABT_HIGH  H54 1031
   Serial number: VWZ8Z9SGY00Q5E
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C2821A017F1E06000000
   Shop #: WSC 00066 790 00322
   ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:19, VBatt start/end: 13.7V/13.8V)-----------
Cuzoe
C?ID=279487
I have the high version of both BCM and Gateway that you are looking for... oddly enough removed from my TDI S. I upgraded from the same modules you currently have. And I later upgraded to a facelift BCM and 3Q0 gateway.
brendan_
Boston, MA, USA
C?ID=516305
Do you have the lighting package? That could be a possible explanation. What new capabilities does the facelift BCM + gateway have?
Cuzoe
C?ID=279487
I probably wasn't that clear, haha. My car is a golf TDI S. Plain Jane base model no options, no lighting package no fog lights none of that. My car came with the same modules that you have right now.
I started doing retrofits so I updated to the high modules of both BCM and Gateway. That seems to be what you are doing now. Among other things I did fog lights, heated seats, adaptive cruise control, etc.
I was happy with that for a long while but in the last six months decided I wanted full RGB interior lighting and the MK-8 touch steering wheel. Those required me to upgrade BCM and Gateway again, to modules that would have come in the Mk7.5 "facelift" cars.
So I first upgraded to the modules that you are now looking for. And then I upgraded again, from those modules.
Cuzoe
C?ID=279487
What I'm basically saying is, if you want to PM me you can have my old (highline) modules for the cost of shipping a USPS flat rate box, haha.
