- Jun 21, 2021
- 3
- 1
- Wisconsin, USA
- C?ID=524457
Hello guys!
I've used my 2011 Q7 TDI to tow a 5800 lbs travel trailer regularly for three years, with no issues. Last year, I deleted the emissions gear and installed a Malone Stage 2 tune. On my first towing trip (200 miles each way) since the delete, 1h into towing at 72 MPH in manual mode, the cruise dropped off and the trans temps began to climb and I was down to ~4 gears. A key cycle restores normal transmission function....until the issue comes up again. The issue has continued, but only happens when towing.
I've attached a full vehicle scan from the end of the towing season last year and have chronicled my troubles on Audiworld. I've talked to Malone and they haven't had any other customers with similar issues. The thing that is confusing to me is that the 0C8 transmission supposedly has a captive clutch (i.e always engaged) in the torque convertor, so the error of "Torque Convertor Clutch Stuck OFF / No Power being transferred" doesn't make much sense.
Peter from Ross Tech provided the following information:
As per the Official Factory Repair Manuals, the fault code P0741 will
set when, "The Engine RPM vs. Input RPM is greater that 100 RPM for 2.0
seconds." This could be a concern with the [N443-Pressure Control Valve
7], wiring or connection concerns, internal transmission concerns, etc.
(see wiki page linked below).
Also these conditions need to exist to set the fault(as per repair
manuals):
- Engine speed greater than 400 RPM and less than 4,000 RPM
- Shift lever is in [D] or
- Estimated engine torque greater than or equal to 0 Nm
- Vehicle is moving forward
- [N443] target current > 1,000.0 mA
- Model oil temp. >= 20° C
We have a Ross-Tech wiki page for this fault code that lists some
'Possible Causes and Possible Solutions'.
P0741-Torque Converter Clutch: Stuck OFF / No Power being transferred
http://wiki.ross-tech.com/wiki/index.php/17125/P0741/001857
We recommend to use the official factory repair manual and wiring
diagrams to locate and test the [N443-Pressure Control Valve 7], it's
wiring and connections.
I'll be checking into the N443, perhaps replacing the entire valve body since that's where the N443 is located. Has anyone else experienced this issue on the 0C8 transmission? The way the problem manifested itself makes me think this is some sort of corner case in the software....or perhaps that's wishful thinking.
manuals):
Monday,25,October,2021,16:08:34:22376
VCDS Version: 21.3.0.0 (x64)
VIN: WA1VMAFE2BD005838 License Plate:
Mileage: 231020km-143549mi Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
56 5F 62 69 6C 6D 6F 72 76
VIN: WA1VMAFE2BD005838 Mileage: 231020km-143549miles
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 HW: 4L0 907 401 D
Component: 3.0TDI FSA X18 0009
Revision: 54X18--- Serial number:
Coding: 2A2A4012253600050000
ASAM Dataset: EV_ECM30TDI0114L2910401 002008
ROD: EV_ECM30TDI0114L2910401_002.rod
VCID: 61C82F71701EC283AC-8034
2937 - Please Check Fault Codes in Transmission Control Module
U1026 00 [040] - -
Mileage: 229724 km
Date: 2021.10.16
Time: 08:58:51
Engine RPM: 1923.00 /min
Normed load value: 43.1 %
Vehicle speed: 110 km/h
Coolant temperature: 100 ∞C
Intake air temperature: 17 ∞C
Voltage terminal 30: 14.680 V
Unlearning counter according OBD: 37
Accelerator pedal: sensor voltage 1: 742.6 mV
Accelerator pedal: sensor voltage 2: 371.2 mV
Accelerator pedal: switch positions-Bits 0-7: 1
Starter control: Interlock- or P/N-signal-Bits 0-7: 1
Limitation: torque: 573.7 Nm
Control Module temperature: 24.1 ∞C
10577 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [044] - -
Mileage: 229761 km
Date: 2021.10.16
Time: 09:19:52
Engine RPM: 2905.50 /min
Normed load value: 85.9 %
Vehicle speed: 116 km/h
Coolant temperature: 98 ∞C
Intake air temperature: 20 ∞C
Voltage terminal 30: 14.640 V
Engine status: COENG_RUNNING
Readiness: 0 0 0 1 X
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 S HW: 0C8 927 750 S
Component: AL1000 AISIN 001 3408
Coding: 00B178
Shop #: WSC 29134 003 104857
ROD: EV_TCMAL991031_002.rod
VCID: 3C76BE05B73CCF6BDF-8068
12860 - Torque Converter Clutch
P0741 00 [040] - Stuck OFF / No Power being transferred
Reset counter: 39
Engine RPM: 1920.0 /min
Transmission input speed: 1830 /min
Transmission output speed: 2670 /min
Engine torque: 520 Nm
ATF temperature: 86 ∞C
Accelerator pedal position: 92.4 %
Clutch_C1: Open
Clutch_C2: closed
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: closed
Clutch_B2: Open
Lock Up Clutch: closed
EOP target revolution: 65534 /min
EOP actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
EOP failure status with EOP without HV 1: Motor normal stop
EOP target current: 65278 mA
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099473
Shop #: WSC 31414 790 00001
VCID: 34669625576C072B17-8060
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10602901711193
Coding: 0000135
VCID: 25407B61ECB66EA390-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H03 0020
Component: FBSAUDIC6 KSG H03 0020
00191 - Passenger's Door Handle Touch Sensor (G416)
007 - Short to Ground
Fault Status: 01110111
Reset counter: 179
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AF
Component: KLIMA 4 ZONEN H13 0060
Revision: 00---022 Serial number: 00000030172395
Coding: 0004A036
VCID: 25407B612CB66EA390-8070
Subsystem 1 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Component: SLR-B8 H05 0006
Serial number: 1002174597
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Serial number: 1002174503
Coding: 070000
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H29 0390
Coding: 0139123
VCID: 6ED2444D79C06DFB21-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H17 0100
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD09M7MO
Coding: 0014131
VCID: 2B548D598A5258D346-807E
Subsystem 1 - Part No: 4L0 910 339 A
Component: BF-Gewichtsens. H03 0030
Subsystem 2 - Serial number: 6332QSME097A1734G
Subsystem 3 - Serial number: 6342QSME427750304
Subsystem 4 - Serial number: 6352QSME637A093CR
Subsystem 5 - Serial number: 6362QSME086B040CJ
Subsystem 6 - Serial number: 63734SME7D742C3AG
Subsystem 7 - Serial number: 63834SME00754718Y
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0530
Revision: 00H06000 Serial number: 90026103190092
Coding: 0012242
VCID: 275C716996BA7CB3A2-8072
Component: E0221 H02 0100
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 984 A HW: 4L0 920 984 A
Component: KOMBIINSTR. H10 0209
Revision: 00000000 Serial number: FLR20DTCA
Coding: 83DF64040900CF05020201
VCID: 31689F31687E32037C-8064
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 Q HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0047
Revision: MB300033 Serial number: 3300M10A28009D
Coding: 00C303
VCID: 3D70B301A426C663E8-8068
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790250316
Reset counter: 43
Mileage: 228942 km
Date: 2021.10.02
Time: 05:00:00
Bin. Bits: 00000
Voltage: 12.60 V
Count: 18
02256 - Quiescent Current
Fault Status: 00100001
Reset counter: 29
Mileage: 230174 km
Date: 2021.10.17
Time: 22:18:00
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AB
Revision: 00---010 Serial number: 00000030172577
Coding: 0000006
VCID: 68DE32555B24B3CB6B-803C
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00001002175896
Coding: 00581B00000011110000
VCID: 326A903D6D78091B05-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E52844DB9402DFB61-807A
Subsystem 3 - Serial number: 5F04.11.1000H010003C911996ˇ
Subsystem 4 - Serial number: 911996ˇ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0361
Revision: Serial number: 0008000127363
Coding: 011F57205E40440004
VCID: 489ED2D5FBE493CB4B-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 H HW: 4L0 907 289 H
Component: Komfortgeraet H10 0110
Revision: 0110 --- Serial number: 01384746180000
Coding: 3569821
VCID: 3560AB215C161E2320-8060
Part No SW: 4L0 035 223 G HW: 4L0 035 223 G
Component: BOSE G3 Q7 H03 0040
Revision: CH003000 Serial number: 00000000015959
VCID: 26427C6D51B065BB99-8072
Reset counter: 21
Mileage: 227254 km
Date: 2021.09.15
Time: 16:34:09
Bin. Bits: 00000001
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H03 0110
Revision: 00000276 Serial number: 00002760042093
Coding: 0758477
VCID: 23446579E2829093FE-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H14 0100
Revision: Serial number: 00000000077835
Coding: 0012001
VCID: 5EB2148D8960FD7B91-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0361
Revision: Serial number: 0008000127771
VCID: 479CD1E9F6FA9CB342-8012
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000031
Fault Status: 00110010
Reset counter: 225
Mileage: 229338 km
Date: 2021.10.07
Time: 16:44:15
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471KW0A7543122
Coding: 020007010000000000
VCID: 5DB013814466E66388-8008
Part No SW: 4L0 035 664 B HW: 4L0 035 664 A
Component: H-BN-NA H49 0116
Revision: -------- Serial number: 489K20A7542154
Coding: 010200060004E3EF51002305EF6300030000
VCID: 2A5A885D45A841DBBD-807E
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Serial number: 9466K-0A0260358
Subsystem 3 - Part No SW: 4L0 910 609 HW: 4L0 919 611 C
Component: E0380 Bedient H05 0060
Serial number: 00000001726800
Component: CD-Database 1886
00658 - Control Head
Reset counter: 38
Time Indication: 15
Voltage: 12.30 V
02244 - Button in Control Head is Stuck
Fault Frequency: 35
Reset counter: 45
Mileage: 227197 km
Date: 2021.09.15
Time: 07:05:23
Voltage: 14.50 V
Bin. Bits: 00000000 00010010
Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0361
Revision: Serial number: 0004000164665
Coding: 010E57204040230004
VCID: 4682DCEDF1F085BBB9-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H08 0100
Revision: 2A001001 Serial number: 00000137341226
Coding: 0200000000000000
02539 - Terminal 30 from Control Module
Fault Status: 00101110
Reset counter: 43
Mileage: 228111 km
Date: 2021.09.19
Time: 13:16:30
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H04--- Serial number: 525PA8-J0Y40G6
Coding: 1021201
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H55 0500
Revision: --H55001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD64E454FDC9FEB0F-8038
Subsystem 3 - Serial number: RD23.11.10--H55001001B0215ˇ
Subsystem 4 - Serial number: 1B0215ˇ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0070
Revision: AAH05061 Serial number: 109568864-----
Coding: 0003595
VCID: 26427C6D91B065BB99-8072
Component: J_245_EE16_SKB10H11 0220
Component: J_394_EE16_SKB10H11 0220
Component: J_392_EE16_SKB10H11 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0361
Revision: Serial number: 0004000164554
Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
Component: Parkhilfe 8-Kan H03 0500
Revision: 00H03000 Serial number: 37331031904207
Coding: 0231266
VCID: 2A5A885D85A841DBBD-807E
End-------------------------(Elapsed Time: 04:22)--------------------------
