Resolved AC OFF CURRENT SHUT OFF CONDITION 26
Resolved
thanosxx
Greece
C?ID=298538
Hello I have current shut off contition for a/c sustem 26 but there is description only until 20 reason.Do you know what is 26 reason
Friday,05,August,2022,11:20:27:57658
VCDS Version: 22.3.1.4  HEX-V2 CB: 0.4615.4
VIN: TRUZZZ8J8A1013336   License Plate: NIO2070
Mileage: 305800km-190015mi   Repair Order:
Chassis Type: 8J-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56
VIN: TRUZZZ8J8A1013336   Mileage: 305800km-190015miles
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 8J0 907 115 K    HW: 8P0 907 115 Q
   Component: 1.8l R4/4V TFSI     0070
   Revision: AAH11---    Serial number: AUX7Z0IDFNA0P2
   Coding: 0113000C18070060
   Shop #: WSC 01236 785 00200
   VCID: 3432160852357C0B1B7-8060
   VINID: 92296AAAA21A2110400430C3183B827753
001287 - Idle Control System RPM
               P0507 - 000 - Higher than Expected. - Intermittent
                    Fault Frequency: 95
                    Mileage: 304250 km
                    Date: 2022.06.28
                    Time: 18:15:58
                    RPM: 887 /min
                    Load: 7.8 %
                    Temperature: 96.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.716 V
008825 - Leak in Air Intake System
               P2279 - 000 -
                    Mileage: 304204 km
                    Date: 2022.06.26
                    Time: 23:36:33
                    RPM: 822 /min
                    Load: 8.2 %
                    Temperature: 97.0°C
                    Temperature: 51.0°C
                    Voltage: 13.462 V
000369 - Fuel Trim; Bank 1
               P0171 - 000 - System Too Lean - MIL ON
                    Fault Status: 11100000
                    Mileage: 304204 km
                    Date: 2022.06.26
                    Time: 23:36:37
                    RPM: 819 /min
                    Load: 8.2 %
                    Temperature: 98.0°C
                    Temperature: 51.0°C
                    Voltage: 13.589 V
001089 - EVAP Emission Control Sys
               P0441 - 000 - Incorrect Flow - MIL ON
                    Mileage: 304206 km
                    Date: 2022.06.26
                    Time: 23:42:11
                    RPM: 777 /min
                    Load: 7.4 %
                    Temperature: 98.0°C
                    Temperature: 57.0°C
                    Voltage: 13.462 V
004688 - Fuel Level too Low
               P1250 - 000 -
                    Mileage: 305791 km
                    Date: 2022.07.31
                    Time: 05:42:06
                    RPM: 872 /min
                    Load: 8.6 %
                    Temperature: 97.0°C
                    Temperature: 45.0°C
                    Voltage: 13.716 V
Readiness: 0000 0001
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 614 517 D    HW: 8J0 614 517 D
   Component: ESP MK60E1          0030
   Revision: 00H60001
   Coding: 0083216
   VCID: 2E060460BC1956DB6D3-807A
Address 08: Auto HVAC        Labels: 8J0-820-043.clb
   Part No SW: 8J0 820 043 AP    HW: 8J0 820 043 AP
   Component: J255  Klima 1 Zone  0090
   Revision: 00H08006    Serial number: 00000001145608
   Coding: 1572868
   VCID: 74B2D60812B53C0BDB7-8020
01273 - Fresh Air Blower (V2)
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 242
                    Mileage: 305806 km
                    Date: 2022.08.01
                    Time: 20:49:13
                    Temperature: 34.0°C
                    (no units): 212.0
                    (no units): 27.0
00710 - Defroster Flap Positioning Motor (V107)
                    Fault Status: 00100011
                    Reset counter: 27
                    Mileage: 305442 km
                    Date: 2022.07.28
                    Time: 01:44:52
                    Voltage: 14.30 V
                    Temperature: 43.0°C
                    (no units): 231.0
                    (no units): 27.0
                    Temperature: 33.0°C
01272 - Positioning Motor for Central Flap (V70)
                    Reset counter: 242
                    Mileage: 305447 km
                    Date: 2022.07.28
                    Time: 01:49:13
                    Voltage: 14.20 V
                    Temperature: 41.0°C
                    (no units): 161.0
                    (no units): 41.0
                    Temperature: 33.0°C
   Part No SW: 8P0 907 063 B    HW: 8P0 907 063 B
   Component: BCM PQ35  H   105 0575
   Revision: 00105 AK
   Coding: 06000A2FB0051A202070C8E000000944531E56AA3000D9295C0008400040
   Shop #: WSC 01236 758 00200
   VCID: 333015145B3B7B3302D-8066
   Subsystem 1 - Part No SW: 8J1 955 119 A    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer AU354  H07 0070
   Coding: 00FD10
                    Fault Status: 00101010
                    Reset counter: 25
                    Mileage: 288566 km
                    Date: 2021.03.21
                    Time: 07:22:20
                    Voltage: 14.25 V
                        Term 50 Off
                    Fault Frequency: 156
                    Reset counter: 25
                    Mileage: 301430 km
                    Date: 2022.03.05
                    Time: 00:35:26
                    Voltage: 13.95 V
                        Term 50 Off
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: -s Airbag 9.43  H03 0020
   Revision: 93H03002    Serial number: 0036K00439FH
   Coding: 0011635
   VCID: 79ACE73C35D74163881-802C
   Subsystem 1 - Serial number: 6332DRB40A5D0E91Z
   Subsystem 2 - Serial number: 6342DRB40A52051EL
   Subsystem 3 - Serial number: 63747RB4052AD286T
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0002011
   VCID: 46D65CC034A9FE9BB53-8012
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 930 H    HW: 8J0 920 930 H
   Component: KOMBIINSTR. VDO H03 0490
   Revision: D0H03005    Serial number: 224DI005007530
   Coding: 0004128
   Shop #: WSC 80093 222 69422
   VCID: 313C1F1CAD274923701-8064
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 223527 km
                    Date: 2016.09.30
                    Time: 10:29:08
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0232
   Revision:   H16       Serial number: 4440K09B278019
   Coding: E9811F06100202004100
   VCID: 698CB77C4577F1E3781-803C
   Revision: D0H03005    Serial number: AUX7Z0IDFNA0P2
   Part No SW: 8J8 959 801 E    HW: 8J8 959 801 E
   Component: Tuer-SG         H03 0080
   Coding: 0000053
   VCID: 3FD849246B73AF53F65-806A
00912 - Window Regulator Switch; Front Left (E40)
00913 - Window Regulator Switch; Front Right Driver (E81)
   Part No: 8J0 909 144 J
   Component: EPS_ZFLS Kl. 235    3001
   Revision: 00H17000
   VCID: 37282104434397133E5-8062
Address 47: Sound System (J525)       Labels:* 8J0-035-223.lbl
   Part No SW: 8J0 035 223 F    HW: 8J0 035 223 F
   Component: Audi TT Amp5K H05 0170
   Revision: --------    Serial number: BP208393367335
   Coding: 060101060001
   ASAM Dataset: EV_AudioAmpli5ChannBNO1 003011
   ROD: EV_AudioAmpli5ChannBNO1_003.rod
   VCID: 2708F1449F630793AE5-8072
   Part No SW: 8J8 959 802 E    HW: 8J8 959 802 E
   Coding: 0000052
   VCID: 40DA4AD8168DD0AB8FF-8014
   Part No: 8P3 907 357
   Coding: 0000009
   VCID: 7AAEF83030D14A7B81B-802E
   Part No SW: 8J0 035 186 M    HW: 8J0 035 186 M
   Component: R Concert2+     H07 0270
   Revision: 00H07000    Serial number: AUZ1Z3I9712024
   Coding: 0310101
   VCID: 36362C0044496E1B253-8062
End----------(Elapsed Time: 00:57, VBatt start/end: 13.6V/13.8V)-----------
Address 17: DTCs cleared
Address 01: DTCs cleared
Address 08: DTCs cleared
26 = "Fehlerspeichereintrag"
So it's due to one or more of the fault codes in that module. My guess would be the blower fault.
EuroX
Northern NJ USA
C?ID=208579
Please post MVB or IDE channel with shutoff conditions as well as pressure readings.
Jef
HQ
If the HVAC can't trust that the blower motor is working, then I can see the logic in shutting off the AC so the evaporator doesn't freeze over.
  • Agree
thanosxx
Greece
C?ID=298538
Yes I change the blower motor and now it is o.k
Jef
HQ
Please give us a clean follow up Auto-Scan and we'll slap this thread as resolved!
thanosxx
Greece
C?ID=298538
I haven't the car for the moment, so I can't take a new autoscan
