Resolved 2011 Jetta 2.0 TDI ABS Coding Lost (MK60EC1)
Resolved
maumaumau
C?ID=21355
Hi everyone,need help with this vehicle,customer stated that he installed a test instrument cluster and after that, all kind of warning lights came on and of course engine didn't start most probably because immo,so he installed the original cluster back,need help to find the right coding for abs unit,thanks in advance for any input or help
Options from spare tire sticker X9A CK4 G0K M4B J1D K8B 4UM D91 U5C 1ZP V0A 0A2 0M9 1AT 1C2 1G4 2ZM 2JG 5RR 7K6 2UA 5SN 7KK 4X3 7GB 3L3 3Q6 QG0 8YR 4A3 8ES L13 G18 8AX B0D 1M3 3FE 4K0 4R4 8Y0 8L6 9AB
so far,already tried few codings,have them attached here,none of them worked,abs unit keep rejecting the coding and reporting invalid coding
A13B600D092400FF850E06E4901B0042240000
A13B200D092400FF850E04E4901B0042200400
A13B400D092400FF850E02E4901B0042200400
A13B200D092400FF850E04E4901B0042200010
A13B200D092400FF850E04E4901B0042200000
A13B400D092400FF850E02E4901B0042200000
A13B600D092400FF850E06E4901B0042200400
A13B200D092400FF850E04E4901B0042240400
A13B400D092400FF850E02E4901B0072250D10
Thursday,04,August,2022,21:54:41:37170
VCDS Version: 22.3.1.4 (x64)  HEX-NET2 CB: 0.4615.4
VIN: 3VW3L7AJ5BM025302   License Plate:
Mileage: 270860km-168304mi   Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 77
VIN: 3VW3L7AJ5BM025302   Mileage: 270860km-168304miles
   Part No SW: 03L 906 022 KB    HW: 03L 906 019 DA
   Component: R4 2,0L EDC G000SG  7972
   Revision: 12H10---    Serial number:
   Coding: 0050072
   Shop #: WSC 02257 002 1048576
   VCID: 6FB0B8E44B941F53265-803A
   VINID: 0E69C370745A1527400850C008DBD17ECB
7 Faults Found:
000115 - Sensor for Ambient Air Temperature (G17)
               P0073 - 000 - Signal too High - Intermittent
                    Fault Frequency: 104
                    Mileage: 268840 km
                    Date: 2016.05.04
                    Time: 00:55:54
                    RPM: 828 /min
                    Voltage: 14.06 V
                    Temperature: 62.1°C
                    Temperature: 24.3°C
                    Temperature: 22.5°C
                    Temperature: -90.0°C
050211 - Implausible Data Received from Instrument Panel Control Module
               U0423 - 003 -  - Intermittent
                    Fault Status: 00100011
                    Fault Frequency: 9
                    Mileage: 269779 km
                    Date: 2016.06.18
                    Time: 22:20:07
                    RPM: 1380 /min
                    Speed: 68.0 km/h
                    Voltage: 14.21 V
                    Temperature: 77.4°C
                    Temperature: 15.3°C
                    Temperature: 19.8°C
009315 - Particle Filter
               P2463 - 000 - Excessive Soot Accumulation - MIL ON
                    Fault Status: 11100000
                    Mileage: 269179 km
                    Date: 2016.05.20
                    Time: 21:08:13
                    RPM: 1863 /min
                    Speed: 110.0 km/h
                    Pressure: 62 mbar
                    Hex Value: 0xFF02
                    Temperature: 270.0°C
                    (no units): 239.7
                    Mileage: 760 km
009304 - Diesel Particulate Filter
               P2458 - 000 - Regeneration Duration - MIL ON
                    Mileage: 269188 km
                    Date: 2016.05.20
                    Time: 21:40:21
                    RPM: 1058 /min
                    Speed: 1.0 km/h
                    Mileage: 770 km
                        4.5
                        40.2
                    Pressure: 0 mbar
                    milliliters: 0 ml
001025 - EGR System
               P0401 - 001 - Insufficient Flow - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 14
                    Mileage: 269234 km
                    Date: 2016.05.20
                    Time: 23:14:41
                    RPM: 1955 /min
                    Speed: 76.0 km/h
                    Voltage: 14.29 V
                    Load: 95.7 %
                    Load: 100.0 %
                    Mass Air / Rev.: 370.0 mg/str
                    Mass Air / Rev.: 505.0 mg/str
009231 - Exhaust Gas Recirculation System
               P240F - 000 - Response too Slow
                    Mileage: 269744 km
                    Date: 2016.06.18
                    Time: 01:29:35
                    RPM: 1541 /min
                    Speed: 76.0 km/h
                    Load: 83.5 %
                    Mass Air / Rev.: 0.0 mg/str
                    Mass Air / Rev.: 35.0 mg/str
                    Mass Air / Rev.: 440.0 mg/str
                    Mass Air / Rev.: 510.0 mg/str
000618 - Charge Air Cooler
               P026A - 000 - Efficiency Below Threshold
                    Mileage: 270843 km
                    Date: 2016.12.21
                    Time: 22:46:02
                    RPM: 1725 /min
                    Speed: 103.0 km/h
                    Temperature: 29.7°C
                    Temperature: -1.8°C
                    (no units): 122.4
                    Temperature: 72.0°C
                    (no units): 40.0
Readiness: 1 5 0 0 0
   Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
   Component: ESP MK60EC1   H30 0106
   Revision: 00H30001
   Shop #: WSC 00066 000 00000
   VCID: 74BAB7882EB23C8BDB7-8020
                    Fault Status: 00101100
                    Reset counter: 26
                    Mileage: 270867 km
                    Count: 16391
                    Count: 16896
                    Count: 72
                    Count: 42240
03306 - Coding Not Valid
                    Reset counter: 241
                    Mileage: 270867 km
                    Date: 2016.12.22
                    Time: 09:36:05
                    Count: 3
                    Count: 2
                    Count: 4096
                    Count: 4161
                    Count: 41472
                    Reset counter: 240
                    Mileage: 270867 km
                    Count: 16391
                    Count: 16896
                    Count: 195
                    Count: 42240
                    Fault Status: 01100101
                    Reset counter: 240
                    Mileage: 270867 km
                    Date: 2016.12.22
                    Time: 09:34:07
                    Count: 3
                    Count: 2
                    Count: 4096
                    Count: 279
                    Count: 41472
                    Reset counter: 240
                    Mileage: 270867 km
                    Date: 2016.12.22
                    Time: 09:34:07
                    Count: 3
                    Count: 2
                    Count: 4096
                    Count: 295
                    Count: 41472
                    Reset counter: 240
                    Mileage: 270867 km
                    Date: 2016.12.22
                    Time: 09:34:07
                    Count: 3
                    Count: 2
                    Count: 4096
                    Count: 270
                    Count: 41472
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 Q    HW: 5C0 820 047 Q
   Component: J301  Klimaanlage   0103
   Revision: 2000908S    Serial number: 00000000104396
   VCID: 2E0E65E08C1E565B6D3-807A
                    Fault Status: 00101101
                    Fault Frequency: 142
                    Reset counter: 26
                    Mileage: 268701 km
                    Date: 2015.02.24
                    Time: 22:25:20
00229 - Refrigerant Pressure
                    Fault Frequency: 41
                    Reset counter: 24
                    Mileage: 268833 km
                    Date: 2015.05.27
                    Time: 00:00:01
                    Fault Status: 00101001
                    Reset counter: 25
                    Mileage: 270867 km
                    Date: 2016.12.22
                    Time: 03:46:34
03934 - Control Circuit for Seat Heating; Front Left
                    Fault Status: 00111011
                    Reset counter: 254
                    Mileage: 269311 km
                    Date: 2016.06.11
                    Time: 17:29:27
   Part No SW: 5C0 937 087 C    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0226
   Revision: B2066001    Serial number: 03311279100384
   Coding: 7B994B9A08A30B0008382000240884C50082502E60000000300000000000
   VCID: 2D0C62EC8D182D43549-8078
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3463
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3463
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.019  H08 0006
   Serial number:     WRH0000ILPY
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0137786
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3463
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3463
   Coding: 800000
00975 - Heated Rear Window (Z1)
            006 - Short to Plus
                    Fault Status: 01100110
                    Reset counter: 241
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   012 0805
   Serial number: 003END08664Y
   Coding: 00003232
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01017
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FB0B8E447141F53265-803A
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y10000012930Q
   Coding: 303143
   Serial number: 3572MSME33273156ZZZN
   Serial number: 3582MSME4A2A1157ZZZY
   Component: S.Sens.Fahr.H  H01 ----
   Serial number: 3516KSME4918100DZZZP
   Component: S.Sens.Beif.H  H01 ----
   Serial number: 3526KSME4C57070DZZZ
   Component: F.Sens.Fahr  H01 ----
   Serial number: 3556LSME371A1709ZZZW
   Component: F.Sens.Beif  H01 ----
   Serial number: 3566LSME0F0E1709ZZZ+
   Part No SW: 5C6 920 950 E    HW: 5C6 920 950 E
   Component: KOMBI         H07 0406
   Coding: 270A01
   Shop #: WSC 00066 000 00086
   VCID: 2C0A6FE8B682244B437-8078
9453330 - Outside temperature sensor
          B103F 1B [008] - Resistance Too High
                    Fault Frequency: 156
                    Reset counter: 26
                    Mileage: 268701 km
                    Date: 2020.10.03
                    Time: 22:25:18
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 0226
   Coding: 102200
   VCID: 70B2BB985AAA00AB3FF-8024
   Component: IMMO          H07 0406
   VCID: 6A86A9F07CF6FA7B71B-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668660242
   VCID: 270090C4AFE40713AE5-8072
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H31 0263
   Serial number: VWZAZ2L8449559
   Coding: 040004210200060000008000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 231884D4DB5CEB33F2D-8076
   Component: NAR_V2  0002
1048596 - Rear Right Bass Speaker
          B1067 13 [008] - Open Circuit
          [woofer rear right open load]
                    Reset counter: 25
                    Mileage: 268875 km
                    Date: 2021.12.15
                    Time: 16:23:33
1048632 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Reset counter: 180
                    Mileage: 268834 km
                    Date: 2021.05.08
                    Time: 04:03:56
1048582 - GPS Antenna
          B1054 13 [009] - Open Circuit
          [GPS antenna open load]
                    Reset counter: 175
                    Mileage: 268701 km
                    Date: 2020.10.03
                    Time: 22:25:19
          B11CF 53 [009] - Deactivated
                    Reset counter: 175
                    Mileage: 268701 km
                    Date: 2020.10.03
                    Time: 22:25:19
1048642 - Internal Control Module Memory Check Sum Error
          B2000 42 [009] - General Memory Failure
          [ECU defect data memory failure]
                    Mileage: 269687 km
                    Date: 2022.01.25
                    Time: 22:09:33
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 31347E9C9D2049A3701-8064
                    Fault Status: 11100101
                    Battery Volts: 12.1 V
                        DD
                    Temperature: 13.0°C
                    Count: 3
                    Steering Angle: -13.30°
                        SteerAng n.Init
                    Fault Frequency: 20
                    Reset counter: 25
                    Mileage: 270867 km
                    Date: 2016.12.22
                    Time: 03:54:49
                    Voltage: 11.50 V
                        DD
                    Temperature: 38.0°C
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668448196
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 3236719094A672BB09B-8066
End----(Elapsed Time: 01:31, VBatt start/end: 12.1V/12.2V. VIgn 11.9V)-----
wojciech300
Poland
C?ID=147841
Hi, try:
B14B400D492400FF8DOE02E4921B0042A70000
Jef
HQ
B14B400C492400FF8D0E02E4921B0042A70000
EuroX
Northern NJ USA
C?ID=208579
Above coding is correct for the vin.
etz2k
C?ID=69430
I thought the coding from @wojciech300 is OK, because i don't look for the (easy) vin-bytes, but he made some strange mistakes at these bytes, "AK" instead of "AJ" for the VIN-letters and "O" insteed of "0".:rolleyes:
But, the important bytes are right :thumbs:.
EuroX
Northern NJ USA
C?ID=208579
Only coding that Jef posted is correct. Other coding from above has some weird mistakes in it.
wojciech300
Poland
C?ID=147841
i didnt look carefully, O and 0 was missclick :D C and D mistake :)
maumaumau
C?ID=21355
coding posted by Jef worked perfect,problem solved,thanks Jef,thanks to everyone for help !
