All tests return "system not ok"
Zygoat
Colorado, USA
C?ID=518805
Hi all,
Just looking for a little sanity check here. I have run several tests on the car. (09 Audi A4 2.0t Quattro) However, every single test I run returns the same result "system not ok" It says this in cheerful green letters, which makes me think "GOOD" but the text tells me "BAD" is this really good or bad? If it genuinely is failing, what do I do about it?
view
view
view
https://drive.google.com/file/d/1rIBmEWtXc4eCeSsxuwDDigww9A5F2aP9/view?usp=sharing
Westbury, UK
Can't see the images(?) you've posted they just appear as a tiny question mark on a blue square...
Zygoat
Colorado, USA
C?ID=518805
Hi all,
view
view
view
i know, I don't know what the deal is. I have posted photos before without any problems, now I'm on the struggle bus. If you follow the link, you can see an example.
VCDS doesn't try to interpret those results as "good" or "bad". The text in that box will always be green if it (or rather the numeric 'pointer' to the text) came from the car. Red in that box would indicate the control module outright refused something.
Zygoat
Colorado, USA
C?ID=518805
Ok, thanks for the insight on the text color. Any wisdom you care to impart on the status message itself?
If you would like some feedback , please post a complete and unedited Auto-Scan. Not sue how to post one? See the blue tool bar at the top of this page ; it is a pull down menu of "How-to" .......
Zygoat
Colorado, USA
C?ID=518805
Sunday,07,August,2022,16:30:34:52885
VIN: WAULF78K99N01XXXX   License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 65 72 77
VIN: WAULF78K99N01XXXX   Mileage: 392170km-243683miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF X12 0001
   Revision: E1X12---    CVN: E32C0E59
   Coding: 0104010A190F0160
   Shop #: WSC 04919 000 00000
   ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: 79AFE31C1955BB93881-802C
   VINID: 9D195C58721B249780047180003585F66D
4695 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:12:46
                    Engine RPM: 0.00 /min
                    Coolant temperature: 32 °C
                    Intake air temperature: 36 °C
                    Ambient air pressure: 850 mbar
                    Voltage terminal 30: 11.709 V
          U1113 00 [032] - -
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:12:46
          U1113 00 [032] - -
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:12:46
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [038] - -
          [Diagnostic interface for databus -J533-please read DTC]
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:16:28
                    Engine RPM: 1932.50 /min
                    Normed load value: 19.2 %
                    Vehicle speed: 25 km/h
                    Coolant temperature: 60 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 12.698 V
5671 - Boost Pressure Regulation
          P0299 00 [039] - Control Range Not Reached
                    Mileage: 392166 km
                    Date: 2022.08.07
                    Time: 16:19:51
                    Engine RPM: 4731.50 /min
                    Normed load value: 52.2 %
                    Vehicle speed: 141 km/h
                    Coolant temperature: 88 °C
                    Intake air temperature: 35 °C
                    Ambient air pressure: 840 mbar
                    Voltage terminal 30: 12.415 V
Readiness: 0110 0100
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 C    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H04 0030
   Revision: --H04---
   Coding: 001002
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: 3635282068CB94EB253-8062
   Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
   Component: ESP8 quattro  H04 0060
   Coding: 150500
   Shop #: WSC 02399 823 56573
   VCID: 79AFE31C19D5BB93881-802C
                    Reset counter: 0
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:12:07
                    Hex Value: 0x0000
                    Hex Value: 0x00A2
                    Hex Value: 0x000C
                    Hex Value: 0xB993
                    Hex Value: 0x00FF
                    Fault Status: 00101101
                    Reset counter: 0
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:12:07
                    Hex Value: 0x0000
                    Hex Value: 0x22A2
                    Hex Value: 0x0013
                    Hex Value: 0x0293
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
   Component: BCM2 1.1      H70 0134
   Coding: 090100
   VCID: 333311347B3981C302D-8066
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Serial number: 0508000035831017
   Component: ELVAUDIB8  H36 0041
   Serial number: 0208000035482011
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:12:08
   Part No SW: 8T1 820 043 AA    HW: 8T1 820 043 AA
   Component: KLIMA 1 ZONE  H06 0140
   Revision: A1000000    Serial number: 0119.07.080149
   Coding: 64002000
   VCID: 70B9DE384AAFFADB3FF-8024
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:12:07
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000079700
   Coding: 69000031053C06010000080300007F5F0F14520800000001000000
   VCID: 30391E388A2FBADB7FF-8064
   Component: WWS 190708  H06 0070
   Serial number: SWFBIE 0005106
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 T    HW: 8K0 941 531 T
   Component: E1 - LDS  H07 0090
   Serial number: 00000000000904090334
                    Fault Status: 01101100
                    Reset counter: 0
                    Mileage: 391846 km
                    Date: 2022.08.04
                    Time: 06:54:00
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:12:00
   Part No SW: 8K0 959 655 C    HW: 8K0 959 655 C
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0039GD129UYV
   Coding: 303836354230303030304A55304C384B3053
   VCID: 3D27370C4DFD47B3E49-8068
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Serial number: 5810000R0800000ZCM
   Serial number: 6334MSME3D716664J
   Serial number: 6344MSME3F21625EM
   Serial number: 6352QSME792B7653R
   Serial number: 6362QSME6C59417F.
   Serial number: 63732SME7E5A26235
   Serial number: 63832SME7C2B2D27D
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90304HGG000KG
   Coding: 000014
   VCID: 3D27370C4D7D47B3E49-8068
   Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
   Component: KOMBIINSTR.   H16 0221
   Revision: 00200000    Serial number: 98U30JN78
   Coding: 831F09000300D705020000
   VCID: 2D07074C9D1DD733549-8078
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:12:08
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0091
   Revision: GB102039    Serial number: 3900G0871284DD
   Coding: 000303
   VCID: 46D558E018AB046BB53-8012
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 180304CF080708
16347 - Control Module - EEPROM Error
                    Fault Status: 00101110
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:11:08
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:12:08
02252 - Generator
                    Reset counter: 41
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:17:06
   Part No SW: 8K0 959 793 B    HW: 8K0 959 793
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007459525
   Coding: 011C03204000410001
   VCID: 3FDB4D04477155A3F65-806A
   Revision: 00002001    Serial number: 0113098126
   Coding: 0106063A007A0004003001
   Subsystem 2 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:12:08
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S1900000
   Coding: 0203010102
   VCID: 6E85C040509BEC2B2D3-803A
   Part No SW: 8K0 959 792 B    HW: 8K0 959 792
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007469975
   VCID: 3E253000407B5CABFD3-806A
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 00000000167618
   VCID: 313F1B3C8125B3D3701-8064
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:12:07
                    Voltage: 11.90 V
                    Count: 64
                    Hex Value: 0x0263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Mileage: 390460 km
                    Date: 2022.07.21
                    Time: 20:53:16
                    Voltage: 12.10 V
                    Count: 58
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 195 L    HW: 8T1 035 195 L
   Component: Symph3 Sirius H02 0211
   Revision: 00000004    Serial number: AUZ5Z4H1034724
   Coding: 05020002010185004559070000
   VCID: 40D94EF83A8F2A5B8FF-8014
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
                    Reset counter: 0
                    Mileage: 390460 km
                    Date: 2022.07.21
                    Time: 20:53:26
                    Mileage: 392164 km
                    Date: 2022.08.07
                    Time: 16:12:12
   Part No SW: 8K0 959 795     HW: 8K0 959 795
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000007442801
   Coding: 010C03204000210001
   VCID: 7F5B0D0407F195A3B65-802A
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140785999163
   Coding: 0CD154
   Part No SW: 8K0 959 794     HW: 8K0 959 795
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000007450604
   VCID: 7EA5F00000FB9CABBD3-802A
                    Mileage: 391597 km
                    Date: 2022.08.02
                    Time: 11:40:14
   Part No SW: 8T0 862 336 A    HW: 8T0 862 336 A
   Component: FSE_256x BT     H33 0520
   Revision: 00000000    Serial number: 00000005006888
   Coding: 0010370
   VCID: 392F231C55557B93C81-806C
End----------(Elapsed Time: 01:30, VBatt start/end: 12.7V/13.6V)-----------
Is the software in this ECU stock, or has it been "tuned"?
What other history does this engine have at 243,000 miles?
Zygoat
Colorado, USA
C?ID=518805
The car has been tuned.
The maintenance history is extensive and meticulous.
At around 80k. the car was warranted by Audi for oil consumption
New postings/rings
New turbo
Tensioner
Etc
I have done huge amounts of work also. Mechanically it is a much, much younger car.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
So 163k after engine done , then most likely you have stretched chain.
Go to Advanced Measuring Values and type on top " phase" it will be camshaft adaptation intake bank1 and look value . When is chain New it will be 0-1 , if is more then 3.5 then needs to be replaced . If is over 5.0 it is critical level and every time you start that car there is a chance it will jump timing .
Zygoat
Colorado, USA
C?ID=518805
New chain, tensioner, guides etc. About 5k ago. I'll check it again just for fun.
