Hello all,
I go out to start my Touareg up and the dash starts flashing. Almost like it's not getting any power. I test the battery, and it's reading 7.5V. Should be around 12V. I hook up cables to get power and I plug in VCDS to scan. Attached you will find the log. The engine runs fine but will not go into a shift position. The radiator fan is on full blast even though the engine isn't even warm yet. When I shut if off the engine stops hard. Overnight the battery loses voltage.
A few things:
- I just put in a brand new alternator about a month ago and a new battery
- I also just put on a new serpentine belt and pulleys.
I did some research and found this:
wiki.ross-tech.com
I tried replacing the power supply relay but that didn't help.
Any ideas?
A few things:
P068A/001674 - Ross-Tech Wiki
Any ideas?
Wednesday,03,August,2022,17:06:00:14085
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
VIN: WVGFK7A9XAD003598 License Plate:
Mileage: 223790km-139056mi Repair Order:
Chassis Type: A9 (6N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2E 37 46 47 55 56 65 68 6C
6D 6E 76 77
VIN: WVGFK7A9XAD003598 Mileage: 223790km-139056miles
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
22-AWD -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
68-Wiper Electr. -- Status: Malfunction 0010
6E-Ctrl Head Roof -- Status: Malfunction 0010
Address 01: Engine (CAT) Labels:. 059-907-401-CAT1.clb
Part No SW: 7L0 997 401 HW: 7L0 907 401 K
Component: 3.0TDI FSA G000AG 0010
Revision: 33H02--- Serial number: VWX3Z0J6907992
Coding: 0421002A590F0168
Shop #: WSC 61139 003 1048576
VCID: 71BFD3280DBA6AD3301-5160
VINID: 9E65D66C7449A115000031492072934890
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Voltage: 0.00 V
Bin. Bits: 00000000
Bin. Bits: 0
Temperature: -90.0°C
Bin. Bits: 00000000
Bin. Bits: 000 0
049441 - No Communication with ABS Brake Control Module
U0121 - 007 - - MIL ON
Fault Status: 11100111
Mileage: 223798 km
Voltage: 12.31 V
(no units): 0.0
Bin. Bits: 00000001
049446 - No Communications with Steering Angle Sender (G85)
U0126 - 000 -
Mileage: 223798 km
Voltage: 12.31 V
(no units): 0.0
Bin. Bits: 00000001
049409 - No Communication with Transmission Control Module
U0101 - 001 - - MIL ON
Fault Status: 11100001
Mileage: 223798 km
Voltage: 12.24 V
(no units): 0.0
Bin. Bits: 00000001
049428 - Control Module for All Wheel Drive Clutch
U0114 - 001 - No Communication
Fault Status: 01100001
Mileage: 223798 km
Voltage: 12.24 V
(no units): 0.0
Bin. Bits: 00000001
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 006 - Implausible Signal
Fault Status: 01100110
Mileage: 223798 km
Date: 2022.07.29
Time: 00:29:55
RPM: 819 /min
Speed: 4.5 km/h
Fuel Consump.: 2.17 l/h
Temperature: 27.9°C
Temperature: 27.9°C
Temperature: 27.0°C
Temperature: 27.9°C
Readiness: 1 2 0 0 0
Address 02: Auto Trans
Address 03: ABS Brakes
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 C HW: 7L0 909 137 C
Component: 2G Kessy 6850
Revision: 00H22072 Serial number: VWX3Z0J6907992
Coding: 0147688
Shop #: WSC 31414 790 00001
VCID: 33331920377618C302D-8066
Component: ELV XXXX
12 Faults Found:
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
001 - Upper Limit Exceeded
Fault Frequency: 0
Reset counter: 56
Date: 2021.06.22
Time: 14:31:46
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
Fault Status: 00101011
Fault Frequency: 0
Reset counter: 58
Date: 2021.06.22
Time: 14:31:46
00183 - Interior Access/Start Authorization Antenna 1 (R138)
Fault Frequency: 14
Reset counter: 58
Date: 2022.02.05
Time: 10:26:00
Fault Frequency: 14
Reset counter: 41
Date: 2022.04.02
Time: 15:11:08
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
Fault Frequency: 0
Reset counter: 157
Date: 2022.04.02
Time: 19:14:32
Fault Frequency: 0
Reset counter: 78
Date: 2064.00.00
Time: 00:00:14
00087 - Terminal 30 for Starting Relevant Consumers
Fault Frequency: 0
Reset counter: 78
Date: 2064.00.00
Time: 00:00:14
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 0
Reset counter: 38
Date: 2064.00.00
Time: 00:00:14
Reset counter: 41
Date: 2064.00.00
Time: 00:00:14
Reset counter: 41
Date: 2064.00.00
Time: 00:00:14
00576 - Terminal 15
Fault Frequency: 0
Reset counter: 38
Date: 2064.00.00
Time: 00:00:14
013 - Check DTC Memory
Fault Status: 01101101
Fault Frequency: 0
Reset counter: 41
Date: 2064.00.00
Time: 00:00:14
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 AL
Component: CLIMAtronic R/L 4537
Coding: 0023030
VCID: 7AADF404509C298B81B-802E
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2004
Revision: -0004--- Serial number: --------------
Coding: 230008002F00BC000000000000000000
VCID: 005986EC3640735BCFF-8054
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 A HW: 7L0 959 655 A
Component: J234__0D VW8T 0270
Revision: 92013027 Serial number: 003C6001DAJL
Coding: 0012356
VCID: 3B2331001F26D083DAD-806E
Subsystem 1 - Part No: 7L0 959 339 F
Component: BF-Gewichtsens. 007 0010
Subsystem 2 - Serial number: 51Z93
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ
Subsystem 4 - Serial number: 000000ÿ
Mileage: 220194 km
Date: 2022.05.28
Time: 14:18:58
Fault Frequency: 11
Reset counter: 214
Mileage: 223798 km
Date: 2022.07.29
Time: 00:25:02
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 G
Component: J527 3601
Coding: 0010211
VCID: 43D349E067D6A84392D-8016
00908 - Control Module for Wiper Motor
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 990 P HW: 7L6 920 990 P
Component: J285 KOMBI-INST. 9833
Revision: KHH06V44
Coding: 0007201
VCID: 46D550F454A49D6BB53-8012
12 Faults Found:
01304 - Radio
Reset counter: 162
Mileage: 205014 km
Date: 2021.06.22
Time: 14:25:34
Reset counter: 162
Mileage: 205014 km
Date: 2021.06.22
Time: 14:25:34
Fault Frequency: 17
Reset counter: 193
Mileage: 217942 km
Date: 2022.04.01
Time: 18:06:57
Reset counter: 196
Mileage: 217945 km
Date: 2022.04.02
Time: 13:35:54
Reset counter: 253
Mileage: 223798 km
Date: 2022.07.29
Time: 00:00:01
Reset counter: 253
Mileage: 223798 km
Date: 2022.07.29
Time: 00:10:44
Reset counter: 213
Mileage: 223798 km
Date: 2022.07.29
Time: 00:25:02
Reset counter: 213
Mileage: 223798 km
Date: 2022.07.29
Time: 00:25:02
Reset counter: 213
Mileage: 223798 km
Date: 2022.07.29
Time: 00:25:02
01324 - Control Module for All Wheel Drive (J492)
Reset counter: 213
Mileage: 223798 km
Date: 2022.07.29
Time: 00:25:02
Reset counter: 213
Mileage: 223798 km
Date: 2022.07.29
Time: 00:25:08
Fault Status: 01101010
Reset counter: 213
Mileage: 223798 km
Date: 2022.07.29
Time: 00:29:50
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 990 P
Component: J533 GW-K-CAN TP20 9833
Coding: 77E2F7D9CB846002
VCID: 70B9D62C06A063DB3FF-8024
10 Faults Found:
01304 - Radio
Reset counter: 162
Mileage: 205014 km
Date: 2021.06.22
Time: 14:25:34
Reset counter: 162
Mileage: 205014 km
Date: 2021.06.22
Time: 14:25:34
Fault Frequency: 17
Reset counter: 193
Mileage: 217942 km
Date: 2022.04.01
Time: 18:06:57
Reset counter: 196
Mileage: 217945 km
Date: 2022.04.02
Time: 13:35:54
Reset counter: 253
Mileage: 223798 km
Date: 2022.07.29
Time: 00:10:44
Reset counter: 213
Mileage: 223798 km
Date: 2022.07.29
Time: 00:25:02
Reset counter: 213
Mileage: 223798 km
Date: 2022.07.29
Time: 00:25:02
Reset counter: 213
Mileage: 223798 km
Date: 2022.07.29
Time: 00:25:02
Reset counter: 213
Mileage: 223798 km
Date: 2022.07.29
Time: 00:25:02
Reset counter: 213
Mileage: 223798 km
Date: 2022.07.29
Time: 00:25:08
Address 22: AWD
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003 Serial number: 7667771673
Coding: 020000
VCID: 2615F074F8E47D6B953-8072
01304 - Radio
Reset counter: 141
Mileage: 204560 km
Date: 2021.06.11
Time: 17:59:32
Reset counter: 253
Reset counter: 253
Mileage: 223798 km
Date: 2022.07.29
Time: 00:13:11
Address 37: Navigation
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L6 959 933 A
Component: 4M HSG 0601
Coding: 0000085
VCID: 40D946EC7690B35B8FF-4B1E
Subsystem 1 - Component: TSG FT No Answer
Subsystem 2 - Part No: 7L0 959 702 P
Component: Tuersteuergeraet BF 6304
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
7 Faults Found:
00576 - Terminal 15
00330 - Signal Rear Wiper Interval
01312 - Powertrain Data Bus
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No SW: 7L6 035 456 C HW: 7L6 035 456 C
Component: 08K Audioverst. 0001
Revision: 00001000 Serial number: 00000000223341
VCID: 33331920373618C302D-8066
00419 - Left Front DSP Midrange Speaker (R103)
Address 55: Headlight Range
Address 56: Radio
Address 65: Tire Pressure Labels:. 7L6-907-273.lbl
Part No SW: 7L6 907 273 E HW: 7L6 907 273 E
Component: J0502 RDK 0006
Revision: 00004006 Serial number: 00000600013603
Coding: 0040008D8D0000000000000000
VCID: 3A2D3404101CE98BC1B-806E
Reset counter: 214
Mileage: 223798 km
Date: 2022.07.29
Time: 00:54:19
(no units): 27.0
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119 B
Component: J400__ Front Wiper 5301
Coding: 0001397
VCID: 392F2B08155AE293C81-806C
Component: RLS 020210 054 0403
Coding: 00208941
Shop #: WSC 31414
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 B HW: 7L6 907 441 B
Component: J772__Rearview 0033
Revision: 00H13000 Serial number: PA8 J010668
Coding: 0100001
VCID: 34311A3C32381FFB1B7-8060
Reset counter: 253
Mileage: 223798 km
Date: 2022.07.29
Time: 22:02:58
Reverse OFF
Count: 3
Reset counter: 253
Mileage: 223798 km
Date: 2022.07.29
Time: 00:06:02
Term 15 Off
Reverse OFF
Count: 3
Reset counter: 214
Mileage: 223798 km
Date: 2022.07.29
Time: 00:54:15
Reverse OFF
Count: 3
Reset counter: 214
Mileage: 223798 km
Date: 2022.07.29
Time: 00:25:08
Reverse OFF
Count: 3
Address 6D: Trunk Elect. Labels: 7L6-959-107.clb
Part No SW: 7L6 959 107 B HW: 7L6 959 107 B
Component: J605 HECKKLAPPE 1310
Revision: --H05--- Serial number: --------051221
Coding: 0122110
Reset counter: 196
Mileage: 217945 km
Date: 2022.04.02
Time: 15:11:07
03234 - Functionality Limited due to Critical Electrical Condition
Reset counter: 253
Mileage: 223798 km
Date: 2022.07.29
Time: 09:03:02
Reset counter: 253
Mileage: 223798 km
Date: 2022.07.29
Time: 22:04:12
Address 6E: Ctrl Head Roof Labels: None
Part No SW: 7L6 919 044 AD HW: 7L6 919 044 AD
Component: J702 Dachdisplay 0401
Revision: 1030006S Serial number: 00000000150198
VCID: 79AFEB0855DA2293881-802C
Reset counter: 253
Mileage: 223798 km
Date: 2022.07.29
Time: 22:03:19
00464 - Control Module with Display for Radio and Navigation (J503)
Reset counter: 162
Mileage: 205014 km
Date: 2021.06.22
Time: 14:28:37
Reset counter: 253
Mileage: 223798 km
Date: 2022.07.29
Time: 22:05:19
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0L Einparkhilfe 1108
VCID: 392F2B08151AE293C81-806C
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 E HW: 1Z0 035 729 E
Component: FSE_2P8x H40 0190
Revision: 00000000 Serial number: 00000005188762
Coding: 0012077
VCID: 3A2D3404105CE98BC1B-806E
Reset counter: 253
Mileage: 223798 km
Date: 2022.07.29
Time: 22:03:35
01523 - Microphone for Telephone (R38)
Reset counter: 162
Mileage: 205014 km
Date: 2021.06.22
Time: 14:28:47
End----(Elapsed Time: 03:25, VBatt start/end: 11.9V/11.8V. VIgn 0.0V)------
