Resolved ECU coding not accepted
Resolved
khaledabdulaziz
Israel
C?ID=394371
VW Bora 2002 automatic transmission replaced with manual
trying to decode the ecu but it shows nothing when i change the coding from 00033 to 00031
doesn't show accepted nor refuse
anyone got this problem before can guide me?
Thursday,04,August,2022,18:48:12:04619
VIN: WVWZZZ1JZ2W050179   License Plate:
          76
VIN: WVWZZZ1JZ2W050179   Mileage: 216150km-134309miles
Address 01: Engine        Labels: 06A-906-018-AQY.lbl
   Part No: 06A 906 018 GP
   Component: 2.0l R4/2V  MOTR AT V01
   Coding: 00033
   Shop #: WSC 01317
   VCID: 76B5E0E3B1D61D0BE53-4B3C
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 J
   Component: ABS FRONT MK60      0103
   Coding: 0004097
   Shop #: WSC 00767 551 00000
   VCID: 313F13FF1D387A33701-5160
   Part No: 1J5 920 826 A
   Component: KOMBI+WEGFAHRSP VDO V04
   Coding: 02602
   Shop #: WSC 00222
   VCID: 2C01028B3F1A17DB437-513C
   WVWZZZ1JZ2W050179     VWZ7Z0A3671320
            49-00 - No Communications
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 01317
   VCID: 70B9D6FBD3B2333B3FF-513C
   Part No: 1C0 959 799 B
   Component: 0Z Komfortger�t HLO 0001
   Coding: 00259
   Shop #: WSC 00028
   VCID: 363520E3F1565D0B253-4B1E
   Component: 18 T�rsteuer.FS KLO 0003
   Component: 18 T�rsteuer.BF KLO 0002
   Component: 18 T�rsteuer.HL KLO 0001
   Component: 18 T�rsteuer.HR KLO 0001
            80-10 - Single-Wire Operation - Intermittent
            37-00 - Faulty
00913 - Window Regulator Switch; Front Right Driver (E81)
            27-00 - Implausible Signal
End----------(Elapsed Time: 05:03, VBatt start/end: 12.5V/12.5V)-----------
Check parts catalog to see if that ECU was ever used on MT cars. Quite a few ECUs have software in them that is transmission-specific and won't accept coding for a different type of transmission.
Jef
HQ
JMR
Romania
C?ID=432218
assuming ( making an ass out of you and me , ass /you/me ) :) , that the coding won't be accepted , what s your beef with the car ? Does it run? Has malfunction lamps lit in the cluster ? Might as well ignore the scan and errors if the car runs good and no instrument cluster lights are on...If i find an 1.8t 178 hp engine from an Mk4 , complete, i'd drop that in my 1.6i Mk4 in a heart beat , care less for any lamps in the instrument cluster
Jef
HQ
Please post a follow up Auto-Scan.
