Color in infotainment
Lieberkind
Denmark
C?ID=511675
Hi,
I have just bought a VCDS and have changed the variant and color(orange) of the instrument. and I am very happy. :-)
Now i have problem!
i would like to have the same color in my radio/infotainment. it sill have the blue color here, but if I soft reset the infotainment, it gets orange for 5 sec and then it turns blue.
Can somebody help what I needs to do to make the infortainment orange?
BR
EDIT: added scan
Thursday,04,August,2022,17:38:42:18270
VIN: WVWZZZ3CZJE130524   License Plate:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 42 44 52 5F 69 6C A5
VIN: WVWZZZ3CZJE130524   Mileage: 176017km-109371miles
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 KD    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 4798
   Revision: B4H25---    CVN: CFB81915B866C2ADB866C2AD
   Coding: 0125041203741D083000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906026KD 005005
   ROD: EV_ECM20TDI01104L906026KD_005.rod
   VCID: 76B5E8EE1843485BE53-8022
   VINID: 9E69EAAAA0D3A9A5410C0142101018DF36
   Part No SW: 0GC 300 042 H    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1427
   Revision: 00H06V09    CVN: ED4B3409
   ROD: EV_TCMDQ381061.rod
   VCID: 2B03099A938145B34AD-807E
   No subsystems:
   Part No SW: 5Q0 614 517 DA    HW: 5Q0 614 517 AH
   Component: ESC           H62 0753
   Revision: 00000000    Serial number: 63437000002806
   Coding: 0FEC6A8F34230B6C477C060260C749F0562CD0E2600692713862F078C222420B00000012121212B835351919323200
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_037_VW41.rod
   VCID: 73B3D1FA0B315D73C2D-8026
   Part No SW: 3Q0 959 435 F    HW: 3Q0 959 435 F
   Component: VWKESSYMQB    027 0907
   Revision: 00027000    Serial number: 0463688526
   Coding: 102F0F0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3D2737C27DF5DB03E49-8068
   Part No SW: 5G0 907 044 DP    HW: 5G0 907 044 DP
   Component: Climatronic   H04 2001
   Revision: 00001K10
   Coding: 12020104202110011115100000101822
   VCID: 78A9E6D612573E2BF7F-802C
   Air quality sensor:
   Humidity sensor: exterior:
   Part No SW: 5Q0 937 086 BL    HW: 5Q0 937 086 BG
   Component: BCM PQ37BOSCH 034 0245
   Revision: --------    Serial number: 8658261117000X
   ROD: EV_BCMBOSCH_018.rod
   VCID: 05579F2255A553C3FC9-8050
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    171105  042 0607
   Serial number:         171116194235
   Component: RLHS  047 0105
   Serial number: S8Y17M12D07H23M45S43
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 31 07 2017  10000607
   Humidity sensor: interior:
          B1263 01 [009] - Electrical Failure
                    Reset counter: 74
                    Mileage: 176017 km
                    Date: 2022.08.04
                    Time: 17:26:36
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 11.7 V
                    Outside temperature: 35.5 °C
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418917340
   Coding: 0471151911
   Shop #: WSC 14059 003 1048576
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4BC3691A334165B36AD-801E
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H04 0195
   Coding: 3218776A5DFFCC28949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 35372FE245C503432C9-8060
1127 - Databus
          [FAULT_TIMEOUT_PSD_04]
                    Reset counter: 114
                    Mileage: 176017 km
                    Date: 2022.08.04
                    Time: 17:21:03
                    Control Module temperature: 58 °C
                    Voltage terminal 15: 11.7 V
1218 - Databus
          [FAULT_TIMEOUT_PSD_05]
                    Reset counter: 114
                    Mileage: 176017 km
                    Date: 2022.08.04
                    Time: 17:21:03
1219 - Databus
          [FAULT_TIMEOUT_PSD_06]
                    Reset counter: 114
                    Mileage: 176017 km
                    Date: 2022.08.04
                    Time: 17:21:03
   Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W6PQTY1YI
   Coding: 88CCC000000000005C5400CF000800000065
   Shop #: WSC 05311 000 08193
   VCID: 0849961662B74EAB87F-805C
   Left seat belt tensioner:
   Serial number: 3G1857705G0332R00762
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 3G1857706G0335R01113
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 002 211 17
   Serial number: 3570000000042B38DA2P
   Subsystem 4 - Part No SW: -----------    HW: 454 002 711 17
   Serial number: 35800000000C358D5A2V
   Subsystem 5 - Part No SW: -----------    HW: 454 802 411 17
   Serial number: 35100678A9612000000F
   Subsystem 6 - Part No SW: -----------    HW: 454 802 611 17
   Serial number: 352009EA84512000000K
   Subsystem 7 - Part No SW: -----------    HW: 454 801 711 17
   Serial number: 3550060015B12000000$
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20171201100668
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 3G0 920 791 C    HW: 3G0 920 791 C
   Component: KOMBI         407 3195
   Coding: 07A409086784000801887B031001000000000000
   VCID: 290FF392997D57A3B81-807C
   Component: GW MQB High   518 5323
   Serial number: 25111710521013
   Coding: 030300345F087300FB00025C1C0F00010001070000000000000000000000
   GVL: 01543C0000000400C08C80000002C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 382926D652D7FE2B37F-806C
   Generator:
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29170002477000097435
   Coding: 2DFFFF
   Serial number: 75886000001711270040
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Serial number: 280917EIR27906
   Coding: 00350B20D000028000001000
   VCID: 43D3413A1B11ADF392D-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000007689901
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 760001 00
   Coding: 0100001100400010
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
   Serial number: 031117EK324327
   Coding: 00350120DE00028000001000
   VCID: 42DD443E040BA4FB99B-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000007696675
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    851 0867
   Coding: 02840201FF0000005111010100880A001F0104E4012000008F
   Shop #: WSC 05311 115 00061
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323D14FEB4AB147B09B-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHT3402210
   Subsystem 2 - Part No SW: 5NA 919 866 CA    HW: -----------
   Component: ECE AS 22/23  --- 1810
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0204
   Revision: 8C001003    Serial number: 0444534779
   Coding: 0100000202000000
   VCID: 3E2530CE70F3C01BFD3-806A
   Coding: 0184020163002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW41.rod
   VCID: 392F23D269DDE723C81-806C
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 27111712K20540
   Coding: 0004080200000401002213458140A90098000E000020
   VCID: 3C213AC666EFD20BD37-8068
1122664 - Databus
          [TIMEOUT_PSD_04]
                    Reset counter: 114
                    Mileage: 176017 km
                    Date: 2022.08.04
                    Time: 17:21:03
                    Control Module temperature: 60 °C
                    Outside temperature: 34.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 2542.8 s
                    Voltage terminal 15: 11.8 V
                    mid: 01 F0
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
End----(Elapsed Time: 02:06, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
Westbury, UK
We have no idea what car you have or how it equipped and configured, which makes it impossible to help until you give us more information.
You can do this if you post an Auto-Scan (that's a link).
Lieberkind
Denmark
C?ID=511675
Will do :-)
Cuzoe
C?ID=279487
Post adaptation map of BCM as well.
