Tuesday,02,August,2022,18:04:59:60603
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 22.3.1.4 (x64)
VIN: WVWZZZ1KZBW216729 License Plate:
Chassis Type: 1K-VW36 (1K0)
VIN: WVWZZZ1KZBW216729 Mileage: 210460km-130773miles
03- Brakes -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MN HW: 03L 907 425 C
Component: 1,6l R4 td H43 8892
Revision: --H43--- Serial number: 00000000000000 : FAF0D86D
Coding: 08114014030501080000
Shop #: 01357 011 00200
Dataset: EV_ECM16TDI02103L906023MN 003004
: EV_ECM16TDI02103L906023ND.
VCID: 7EF8858EE11BCE7FBD-802A
VINID: 9E69EAAAA05BA929C20461C2245666D1C5
7330 - Mass Air Flow Sensor (G70)
P0101 00 [232] - Implausible Signal
Mileage: 113003 km
Date: 2022.08.01
Time: 22:02:27
Engine RPM: 1660.25 /min
Vehicle speed: 45 km/h
Coolant temperature: 77 °C
Intake air temperature: 30 °C
Voltage terminal 30: 14.118 V
Sensor for temp after charge air cooler: raw value-TBA_MES: 39 °C
Charge air pressure: actual value-MAP_MMV: 1061.68 hPa
Air mass: actual value (mg/stroke)-MAF_MES: 538.305 mg/stroke
Air mass: specified value-MAF_SP_MMV: 539.94 mg/stroke
Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 96.001 %
Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 77.652 %
7196 - Function Restriction due to Faults in Other Modules
U1113 00 [101] - -
Fault Frequency: 11
Mileage: 113001 km
Date: 2022.08.01
Time: 19:16:48
Engine RPM: 0.00 /min
Intake air temperature: 48 °C
Voltage terminal 30: 12.649 V
Engine RPM: 0 /min
Accelerator position: normalized-Accelerator position: 0.00 %
Battery voltage: 13.3 V
7078 - Supply Voltage for Fuel Injector Group A
P2147 00 [032] - Short to Ground
Mileage: 113006 km
Date: 2022.08.02
Time: 15:57:18
Engine RPM: 637.75 /min
Normed load value: 47.5 %
Coolant temperature: 25 °C
Intake air temperature: 26 °C
Voltage terminal 30: 14.005 V
Error information regarding selected piezo output stage-LF_STATE_PPS_SPI[0]: 2
Injection valve 1: voltage-V_INJ_MAIN[0]: 130.74 V
Injection valve 2: voltage-V_INJ_MAIN[1]: 128.09 V
Supply voltage of analog output 1-VCC_1: 4.99 V
Supply voltage of analog output 2-VCC_2: 5.02 V
Injection valve 3: voltage-V_INJ_MAIN[2]: 135.06 V
Injection valve 4: voltage-V_INJ_MAIN[3]: 78.34 V
10453 - Output for Starter Relay
P0615 00 [047] - Open Circuit
Mileage: 113001 km
Date: 2022.08.01
Time: 19:16:48
Intake air temperature: 47 °C
Engine RPM: 0 /min
Battery voltage: 12.6 V
Starter activation: status-FRF_ST_RL: 1
Sensor for engine block temperature: raw value-Coolant temperature: 77 °C
Number of resets of main unit-CTR_RST_MC: 0
10457 - Control Circuit for Starter Relay 2
P3049 00 [047] - Open Circuit
Mileage: 113001 km
Date: 2022.08.01
Time: 19:16:48
Engine RPM: 0 /min
10446 - Neutral Gear Sensor
P15A0 00 [047] - Electrical Malfunction
Mileage: 113001 km
Date: 2022.08.01
Time: 19:16:48
Battery voltage: 13.2 V
Neutral position sensor: current transmission angle-ANG_NEUT_GEAR: 18.539 °
Neutral position sensor: adapted transmission angle-ANG_NEUT_GEAR_AD_NEUT: -0.500 °
Engaged gear: calculated-DRI_MT_BAS: 0
Clutch Position Sensor-Starter control: clutch switch: 00000000
Starter control: clutch switch-Starter control: interlock switch: 00000000
Readiness: 0010 0000
Address 03: Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
VCID: 78F49396CB3FF04FF7-802C
Reset counter: 228
Date: 2021.08.02
Time: 20:00:57
Count: 7
Count: 2
Count: 29184
Count: 195
Count: 48128
Count: 65280
01486 - System Function Test Activated
Fault Frequency: 49
Reset counter: 91
Mileage: 204142 km
Date: 2021.08.02
Time: 20:00:56
Count: 3
Count: 2
Count: 29184
Count: 320
Count: 48640
Fault Status: 01100101
Fault Frequency: 20
Reset counter: 96
Mileage: 204142 km
Date: 2021.08.02
Time: 20:00:56
Count: 3
Count: 2
Count: 29184
Count: 279
Count: 48640
Fault Frequency: 20
Reset counter: 96
Mileage: 204142 km
Date: 2021.08.02
Time: 20:00:56
Count: 3
Count: 2
Count: 29184
Count: 295
Count: 48640
Fault Frequency: 20
Reset counter: 96
Mileage: 204142 km
Date: 2021.08.02
Time: 20:00:56
Count: 3
Count: 2
Count: 29184
Count: 270
Count: 48640
Part No SW: 3C8 907 336 AB HW: 3C8 907 336 AB
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000002
Dataset: EV_Climatic A01005
: EV_ClimaBasis_VW36.
VCID: 6DDAB2C2BC7D45E714-8038
9477489 - Motor for Air Distribution Flap
B109D 71 [008] - Actuator Stuck
Reset counter: 141
Mileage: 210452 km
Date: 2022.08.02
Time: 16:37:04
B10AB F0 [009] - Too Low
Reset counter: 183
Mileage: 105629 km
Date: 2021.03.24
Time: 00:25:44
Address 09: Cent. Elect. (J519) Labels:.
Part No SW: 1K0 937 085 D HW: 1K0 937 085 D
Component: PQ35 B+ 103 0575
Revision: 00103 AG
Coding: 48180A3A9833189044000080200000EC47610088525D8160648000200000
VCID: 30646BB663CFE80F7F-8064
Subsystem 1 - Part No SW: 1K2 955 119 B HW: 1K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 12 0401
Coding: 00FFD5
01800 - Light Switch (E1)
Reset counter: 113
Mileage: 210222 km
Date: 2022.07.23
Time: 13:05:28
Term 15 Off
Voltage: 12.25 V
Term 50 Off
01179 - Incorrect Key Programming
Reset counter: 174
Mileage: 202777 km
Date: 2021.03.24
Time: 01:03:08
Voltage: 12.00 V
Term 50 Off
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRA4TF1
Coding: 00003133
Dataset: EV_AirbaVW10SMEVW360 A01011
: EV_AirbaVW10SMEVW360.
VCID: 3B7E4C9AB2891B57DA-806E
Serial number: 3572MSME10256661ZZZK
Serial number: 3582MSME6A2C4151ZZZZ
Serial number: 3512QSME3400502CZZZH
Serial number: 3522QSME341A5077ZZZT
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000004
VCID: 030EF47A42F9A397D2-8056
Part No SW: 5K0 920 971 A HW: 5K0 920 971 A
Component: KOMBI H20 0420
Coding: 470800
Shop #: 12345 999 12345
Dataset: EV_Kombi_UDS_VDD_RM09 A04089
: EV_Kombi_UDS_VDD_RM09_004_VW36.
VCID: 2D5A72C27CFD85E754-8078
10485824 - Internal Control Module Memory Check Sum Error
B2000 41 [137] - General Checksum Failure
[New feature! Extended fault detail is only supported by current gen. interfaces]
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 080310F1001173
Coding: E9801F06000202000003
VCID: 69D2C6D2409559C778-803C
Component: IMMO H20 0420
Shop #: 00000 000 00000
Dataset: EV_Immo_UDS_VDD_RM09 A03008
: EV_Immo_UDS_VDD_RM09_VW21.
VCID: 6AD0B9DE8D9352DF71-803E
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 202777 km
Date: 2021.03.24
Time: 00:49:33
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2114
Coding: 0000564
VCID: 31626EB2A8C5E10770-8064
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
03803 - Steering Angle Sensor for Steering
Fault Status: 11100101
Mileage: 204142 km
Date: 2021.08.02
Time: 20:01:00
Battery Volts: 13.6 V
DU
Temperature: 33.0°C
Count: 3
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0000564
VCID: 326061BEADC3DA1F09-8066
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 G HW: 3C8 035 195 G
Component: Radio RCD510 052 0208
Revision: 00000001 Serial number: VWZ1Z3L1550757
Coding: 01000400040005
VCID: 2C5C7FC64FE78CEF43-8078
Reset counter: 99
Mileage: 210439 km
Date: 2022.08.01
Time: 15:14:02
Reset counter: 99
Mileage: 210439 km
Date: 2022.08.01
Time: 15:14:02
00856 - Radio Antenna
Reset counter: 99
Mileage: 210439 km
Date: 2022.08.01
Time: 14:44:26
Reset counter: 99
Mileage: 210439 km
Date: 2022.08.01
Time: 14:44:26
End-------------------------(Elapsed Time: 02:01)--------------------------
