2012 Seat Ibiza 1.6TDi Power Steering Pump - correct coding
FStech
Moray, UK
C?ID=518341
My daughter's 62 plate Seat Ibiza 1.6TDi had a power steering failure. I checked all power etc and suspected PAS pump required changing, so purchased a spares recovered pump and fitted, only to find that this too didn't work. Time to hit the internet to find pump would require coding, so purchased VCDS. Initial scan showed pump was coded:
Coding: 10251
Shop #:WSC 00046
But also Fault coded 01656 - Crash Signal 35-00 - - .
After searching the internet again found Ross Tech post for
"01656 - Crash Signal; Short to Ground
Possible Causes
When found in AIRBAG VW71 vehicles such as the 1Y New Beetle Cabriolet the following may apply:
Short circuit in wiring to/from Airbag Control Module (J234) and ground.
Faulty Fuel Pump Relay (J17) and/or faulty Central Conv. Module (J393)
Airbag Control Module (J234) defective
Possible Solutions
Use the factory level wiring diagrams to check for a short circuit in wiring to/from Airbag Control Module (J234) and ground on the A125 "Crash Data" circuit. Note, all components must be unplugged before connecting a DVOM!
Remove the Fuel Pump Relay (J17) and faulty Central Conv. Module (J393) to see if this DTC will clear. If the fault clears, reinstall one of the components at a time to determine the cause.
Replace Airbag Control Module (J234) only after the wiring and all components on the A125 spliced circuit are ruled out as possible causes."[/I]
After much searching and ripping car apart, a re-seat of Fuel Pump relay recovered the PAS Pump and cleared the fault code, however steering seem to be lighter than what it was before.
Can anyone give me the correct coding for the pump?
Wednesday,27,July,2022,16:06:02:41739
VIN: VSSZZZ6JZDR044623   License Plate: YR62KWZ
Mileage: 120750km-75030mi   Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZDR044623   Mileage: 120750km-75030miles
   Part No SW: 03L 906 023 LE    HW: 03L 906 023 Q
   Component: R4 1.6l TDI   H33 9978
   Revision: --H33---    Serial number:                CVN: A20C3AD5
   Coding: 00114016000500080000
   ASAM Dataset: EV_ECM16TDI02103L906023LE 003011
   ROD: EV_ECM16TDI02103L906023LC_SE25.rod
   VCID: 74B1D2388E311F1BDB7-8020
   VINID: 9A38EAAAA19AA948801041820CDC00B8F4
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379 AD    HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0001
   Revision: --------
   Coding: 100200DB007100B6082B00E400D400000000
   Shop #: WSC 04941 000 00000
   VCID: 00598EE8CA4933BBCFF-8054
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045 A    HW: 6J0 820 045 A
   Component: J301  Klimaanlage   0330
   Revision: 00 26 08    Serial number: 0000002497733-
   Shop #: WSC 06402 785 00200
   VCID: 2411E27872D1CF9B8B7-8070
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0254
   Revision: BF046001    Serial number: 0434 125120537
   Coding: 24882BE888612500922008F06E0B0CC80000422F608C0000200000000000
   Shop #: WSC 64564 324 38760
   VCID: 45D75FFC95ABD693BC9-8010
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3110
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3110
   Coding: 020000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 5 - Part No: 1K8 951 171 A
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagA0D H10 0020
   Revision: --------    Serial number: 003GX017MW2U
   Coding: 003044
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD6CC0BC3539EB51B-801E
   Serial number: 3495RRB405P17NPAE8QJ
   Serial number: 3505RRB405318U1C50M/
   Part No SW: 6J0 920 904 L    HW: 6J0 920 904 L
   Component: KOMBI         H03 0507
   Coding: 410A00
   VCID: 34311238CEB15F1B1B7-8060
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0254
   Revision: BF046001
   Coding: 022300
   VCID: 70B9DE28FAA9233B3FF-8024
   Component: IMMO          H03 0507
   VCID: 6A8DCC40DCF5D9EB71B-803E
   Part No: 6R0 423 156 B
   Coding: 11251
   Shop #: WSC 00046
   VCID: 2F3B1D542E577CC3665-807A
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Coding: 0000001
   Shop #: WSC 77005 000 00000
   VCID: 70B9DE28F6A9233B3FF-8024
Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
   Part No SW: 6J2 035 153 G    HW: 6J2 035 153 G
   Component: Radio         H15 0204
   Revision: R0000000    Serial number: SEZAZ2M1967219
   Coding: 0503020002
   VCID: 2A0D0C401CF519EBB1B-807E
End----------(Elapsed Time: 01:32, VBatt start/end: 12.1V/12.1V)-----------
Do you have data from the original pump?
Have try adjusting the second-to-last digit of the coding, currently '5'?
1 = Heavy Vehicle (Normal)
2 = Sporty Vehicle (GTI/RS)
3 = Heavy Vehicle (increased Steering Aid at Vehicle Low Speeds)
4 = Light Vehicle (Normal)
5 = Light Vehicle (increased Steering Aid at Vehicle Low Speeds)
6 = Handicap Setting (heavily increased Steering Aid)
FStech
Moray, UK
C?ID=518341
Thanks Uwe for your response. That had crossed my mind, but not had the chance to reconnect as yet. I expect the original pump is fully serviceable and could be refitted as the fault was the crash signal disabling the PAS pump.
