Old unit total failure. Full diagnostics listed below
Wednesday,27,July,2022,14:23:37:44551
VCDS Version: 22.3.1.4
Dealer/Shop Name: Autolec
VIN: WVWZZZ3CZCE088220 License Plate: FV61WXD
Mileage: 257520km-160015mi Repair Order: 000128
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 4F 52 53 56 61 62
72
VIN: WVWZZZ3CZCE088220 Mileage: 257520km-160015miles
25-Immobilizer -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 BG HW: 03L 907 309 N
Component: R4 2.0l TDI H25 9978
Revision: 41H25--- Serial number: 00000000000000 CVN: 49D706BA
Coding: 001D0012040501080000
Shop #: WSC 43093 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018BG 003010
ROD: EV_ECM20TDI01103L906018BG.rod
VCID: 70EB9A93AB0D140F3F-8024
VINID: 9E69EAAAA0D3A9354020808200BABAF3FA
4815 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [175] - -
Mileage: 257433 km
Date: 2022.05.27
Time: 00:25:52
Engine RPM: 0.00 /min
Coolant temperature: 6 °C
Intake air temperature: 7 °C
Voltage terminal 30: 14.480 V
Requested transmission torque: 1000.0 Nm
Limitation: accelerator pedal: 126.6 Nm
Cruise Control System (CCS): status-Bits 0-7: 6
selected gear-Bits 0-7: 0
Transmission torque intervention status-Bits 0-7: 80
Transmission torque intervention status-Bits 0-7: 0
Calculated reducing transmission intervention torque: 1000.0 Nm
14413 - Implausible Data Received from ABS Control Module
U0415 00 [047] - -
Mileage: 257433 km
Coolant temperature: 5 °C
Voltage terminal 30: 11.900 V
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [047] - -
Mileage: 257433 km
Date: 2022.05.27
Time: 00:25:47
Voltage terminal 30: 11.960 V
ACC specified acceleration: 0.000 m/s²
ACC control module: received status-Bits 0-7: 0
Status of ACC/CCS acceleration interface-Bits 0-7: 0
Acceleration: 0.000 m/s²
Engine status: COENG_READY
Part No SW: 02E 300 057 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2708
Revision: 05351113 Serial number: 00001109250145
Shop #: WSC 05311 000 00000
VCID: 1739810F2623A3371E-8042
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Fault Frequency: 255
Reset counter: 1
Mileage: 257433 km
Date: 2016.10.17
Time: 00:02:17
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AB HW: 3AA 614 109 AB
Component: J104 C2 450M V4D7 0022
Revision: --H07--- Serial number: 00000004832985
Coding: 0010000
VCID: 6DD583E7743FF9E714-8038
Fault Frequency: 97
Reset counter: 215
Mileage: 257452 km
Date: 2016.11.13
Time: 19:08:08
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 14.25 V
Bin. Bits: 00000010
Count: 216
Hex Value: 0x0000
03201 - Adaptation Overboost
Fault Frequency: 97
Reset counter: 215
Mileage: 257452 km
Date: 2016.11.13
Time: 19:08:08
Fault Frequency: 97
Reset counter: 215
Mileage: 257452 km
Date: 2016.11.13
Time: 19:08:08
Fault Frequency: 97
Reset counter: 215
Mileage: 257452 km
Date: 2016.11.13
Time: 19:08:08
Fault Frequency: 97
Reset counter: 215
Mileage: 257452 km
Date: 2016.11.13
Time: 19:08:08
Fault Frequency: 97
Reset counter: 215
Mileage: 257452 km
Date: 2016.11.13
Time: 19:08:08
Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
Component: AC Manuell H19 0304
Revision: 00001016
Coding: 0000004003
Shop #: WSC 00015 115 00000
ROD: EV_ACManueBHBVW36X_VW46.rod
VCID: 7F0949AFE6537B77B6-802A
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 C HW: 3AA 937 087 C
Component: BCM PQ47 M 413 0455
Revision: BA413001
Coding: 000000000000000000180080100000E403010088404C81606480C7200041
Shop #: WSC 05311 000 08193
VCID: 3A7F78BBB5F19E5FC1-806E
Subsystem 1 - Part No: 3AC 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 27091 26 0612
Coding: 00B795
01598 - Drive Battery Voltage
Fault Status: 00101011
Reset counter: 0
Mileage: 257433 km
Date: 2016.10.17
Time: 00:02:50
Voltage: 14.25 V
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__102 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PLEUV7M
Coding: 0012338
VCID: 4C932E632F6510EF63-8018
Subsystem 1 - Serial number: 6332MTS645692521
Subsystem 2 - Serial number: 6342MTS645772521
Subsystem 3 - Serial number: 6351HTS68AQPCAKJ
Subsystem 4 - Serial number: 6361HTS6MPI97AKJ
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BF HW: 5K0 953 569 S
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110927301893
Coding: 0992050000
VCID: 6ADF88FB8DD1EEDF71-803E
Component: E221__MFL-TK6 H06 0022
Coding: E30000
Part No SW: 3AA 920 970 E HW: 3AA 920 970 E
Component: KOMBI H03 0607
Coding: 160F00
Shop #: WSC 99999 999 83333
VCID: 35656B8794EF71272C-8060
12674816 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 0
Mileage: 257433 km
Date: 2022.05.27
Time: 00:00:11
13631488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 0
Mileage: 257433 km
Date: 2022.05.27
Time: 00:00:12
Part No SW: 7N0 907 530 K HW: 1K0 907 951
Component: J533 Gateway H40 1620
Revision: H40 Serial number: 170911F1001091
Coding: 461007
Shop #: WSC 05314 000 00000
VCID: 387B62B38BFD8C4F37-806C
Fault Status: 00110100
Reset counter: 0
Mileage: 257433 km
Date: 2016.10.17
Time: 00:00:11
Reset counter: 0
Mileage: 257433 km
Date: 2016.10.17
Time: 00:00:11
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0400
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 76E7AC8B01693A3FE5-8022
Component: ELV 029 0380
3C0905861J ELV 029 0380
02827 - Wake-Up request via ESP
Fault Status: 00111000
Reset counter: 0
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Reset counter: 0
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661912465
VCID: 295DB7F7405725C7B8-807C
Part No SW: 3AA 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0534
Revision: 13110009 Serial number: 0003466360
Coding: 0202B5
Shop #: WSC 05311 115 00000
VCID: 74E39683DF15282FDB-8020
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0408
Serial number: 00000002486261
Coding: 000290
B11EC 54 [008] - Missing Calibration / Basic Setting
Reset counter: 0
131584 - Motor for Rear Window Regulator
B11EE 54 [008] - Missing Calibration / Basic Setting
Reset counter: 0
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 196 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 346356835795682F1B-8060
Fault Status: 11100101
Mileage: 257433 km
Date: 2016.10.17
Time: 00:23:25
Battery Volts: 14.6 V
DD
Temperature: 13.0°C
Count: 3
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Component: KSG PQ47 ELV 043 0634
Coding: 01910A0002860E7630049D1D7C085FCE107801
Shop #: WSC 18798 439 169929
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS No Answer
Subsystem 3 - Component: IRUE No Answer
Fault Frequency: 32
Reset counter: 215
Mileage: 257433 km
Date: 2016.10.17
Time: 00:23:26
00332 - Control Circuit for Tank Flap
Fault Status: 00110111
Fault Frequency: 13
Reset counter: 0
Mileage: 257433 km
Date: 2016.10.17
Time: 00:25:14
00957 - Key 3
Fault Status: 00110101
Reset counter: 0
Mileage: 257433 km
Date: 2016.10.17
Time: 00:01:47
Fault Status: 00110000
Reset counter: 0
Mileage: 257433 km
Date: 2016.11.12
Time: 00:00:08
Fault Frequency: 12
Reset counter: 215
Mileage: 257433 km
Date: 2016.11.12
Time: 00:03:14
00323 - Vehicle Inclination Sensor (G384)
Fault Frequency: 12
Reset counter: 215
Mileage: 257433 km
Date: 2016.11.12
Time: 00:03:14
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1620
Coding: 00000008
VCID: 6FE999EFBE330BF726-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0003
Part No SW: 3AA 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0534
Revision: 15110009 Serial number: 0003426422
Coding: 0202B4
VCID: 75E5AB87D46F3127EC-8020
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0408
Serial number: 00000002481468
Coding: 000290
Reset counter: 0
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000290620
Coding: 0010000
VCID: 35656B875CEF71272C-8060
02434 - Supply Voltage for Control Module for Left Channel
Fault Status: 00101001
Reset counter: 215
Mileage: 257433 km
Date: 2016.10.17
Time: 00:28:38
Voltage: 14.00 V
Count: 15
Hex Value: 0x1250
Hex Value: 0x0001
Hex Value: 0x0101
Fault Status: 01110000
Reset counter: 215
Mileage: 257383 km
Date: 2016.08.29
Time: 22:17:59
Voltage: 11.80 V
Count: 98
Hex Value: 0x1453
Hex Value: 0x0008
Hex Value: 0x1010
Reset counter: 215
Mileage: 257383 km
Date: 2016.08.29
Time: 22:17:59
Voltage: 11.80 V
Count: 41
Hex Value: 0x1453
Hex Value: 0x0008
Hex Value: 0x1010
Fault Status: 01110101
Reset counter: 215
Mileage: 257383 km
Date: 2016.08.29
Time: 22:17:59
Voltage: 11.80 V
Count: 99
Hex Value: 0x1453
Hex Value: 0x0008
Hex Value: 0x1010
013 - Check DTC Memory
Fault Status: 01111101
Fault Frequency: 16
Reset counter: 215
Mileage: 257383 km
Date: 2016.08.29
Time: 00:43:39
Voltage: 11.50 V
Count: 69
Hex Value: 0x1253
Hex Value: 0x0001
Hex Value: 0x1010
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: RCD310 EU H03 5004
Revision: -----04S Serial number: VWZ4Z2L1401826
Coding: 01000400040010
VCID: 72EF909BAD01261FC9-8026
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H40 1620
Coding: 030B185A
VCID: 71ED9F97A8071D0730-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900690838
02256 - Quiescent Current
Fault Status: 00110001
Fault Frequency: 14
Reset counter: 0
Mileage: 257439 km
Date: 2016.11.12
Time: 10:19:50
End-------------------------(Elapsed Time: 03:09)--------------------------
