Resolved Touran 1T2 xenon headlights
Resolved
ligas
Greece
C?ID=496406
hello, this is the first time I'm writing
to you about a problem
I have with the car
(sorry for my English,
it's from a translation)
I have a Touran 1T2 2008,
after a front impact,
the xenon headlights were destroyed,
halogen headlights were installed,
everything works but
I have the following faults in the
55 headlight range
Address 55: Headlight Range       Labels: 5M0-907-357-V2.clb
Control Module Part Number: 5M0 907 357 A    HW: 5M0 907 357 A
  Component and/or Version: AFS-Steuergeraet    0001
           Software Coding: 3293188
            Work Shop Code: WSC 01324 785 00200
           Additional Info: ID-L fehlt  AFS-Lst.-Modul l    ....   ID-R fehlt  AFS-Lst.-Modul r    ....
                      VCID: 323C19CC6823C18B09B-8066
02233 - Left Headlight Power Output Stage (J667)
                    Fault Status: 11100100
                    Reset counter: 73
                    Mileage: 134503 km
                    Time: 00:08:39
                    Voltage: 11.36 V
                        ABS 1
02234 - Right Headlight Power Output Stage (J668)
                    Reset counter: 73
                    Mileage: 134503 km
                    Time: 00:08:39
                    Voltage: 11.36 V
                        ABS 1
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 73
                        Invalid
                        Invalid
                        Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 - - - MIL ON
                    Reset counter: 73
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 - - - MIL ON
                    Reset counter: 73
                        Invalid
                        Invalid
                        Invalid
                    Fault Status: 11100101
                    Reset counter: 73
                        Invalid
                        Invalid
                        Invalid
if possible I should do a new coding so that it doesn't show the faults
thanks
ligas
Greece
C?ID=496406
Monday,01,August,2022,13:22:25:51713
VCDS Version: 22.3.1.4 HEX-V2 CB: 0.4615.4
Dealer/Shop Name: li
Gateway Installation List: 1K0 907 530 L
vin WVGZZZ1TZ8W128546
langers2k
C?ID=224085
55-Headlight Range only works with xenon headlights...
If halogens are fitted, it can be removed (or the fuse pulled) and taken out of the installation list.
ligas
Greece
C?ID=496406
I will try and tell you thanks
ligas
Greece
C?ID=496406
Hello again
I want to thank you for your help with my problem
the problem was solved, the 5М0907357А unit was removed and I removed it from the gateway list and everything is working normally without errors
thanks again
