volkswagon
New member here! I just notice that i'm missing the street names at left upper corner, but when i turn off the ignition, the information appears for 3 sec and after that the unit shut down. Any suggestions?
Friday,27,May,2022,18:14:17:45157
VCDS Version: 22.3.1.4 (x64)
VIN: WVWZZZ3CZGE****** License Plate:
Chassis Type 3C-VW48 (5QE)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 55 5F
69 6C 75 8C A9 BB BC C6 CA
VIN: WVWZZZ3CZGE****** Mileage: 95320km-59229miles
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CUKC) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 AH HW: 04E 907 309 F
Component: R4 1.4l TFS H21 3379
Revision: X3H21--- CVN: 861A8C11
Coding: 011D0032647405083000
Shop #: WSC 00126 211 12345
ASAM Dataset: EV_ECM14TFS01104E906023AH 006006
ROD: EV_ECM14TFS01104E906023AH_006.rod
VCID: 66C4363199D7A8BF55-8032
VINID: 9E69EAAAA0D3A97540202083002E4701C1
Part No SW: 0DD 300 045 T HW: 0DD 927 770 B
Component: GSG DQ400E H31 1601
Revision: 00031033 Serial number: TFK01508250029 CVN: F52AF510
Shop #: WSC 00126 211 00000
ROD: EV_TCMDQ400021.rod
VCID: 3878A84983E3EE4F37-806C
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 3Q0 907 379 S HW: 3Q0 907 379 G
Component: ESC H42 0823
Revision: 00000000 Serial number: 62435000000471 CVN: 03BBAF11
Coding: 0FEC408F3828336E0779060341C349F0021CCCE0608292F158A1F078C202
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_Brake1UDSContiMK100OMG 002001
ROD: EV_Brake1UDSContiMK100OMG_002.rod
VCID: 4A9CE281ED0F6CDF51-801E
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0710
Revision: 00026000 Serial number: 0380968293
Coding: 000F0F0703
Shop #: WSC 05311 115 00302
ROD: EV_KessyHellaMQBAB.rod
VCID: 397EAD4DB8E9F747C8-806C
Part No SW: 5GE 907 044 D HW: 5GE 907 044 D
Component: Climatronic H04 1301
Revision: 00001K07
Coding: 12021024200100010015500100101802
ASAM Dataset: EV_ACClimaBHBVW37X 005137
VCID: 3D76B95DACC1CB67E4-8068
Subsystem 3 - Part No SW: 3Q0 963 231 A HW: 3Q0 963 231 A
Component: J848 HV-PTC 200 0202
Serial number: -00103.8S.5A20340096
Air quality sensor:
Humidity sensor: exterior:
A/C compressor sub:
H02
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 86580109151398
Coding: 00971A66C3D102F76B8C5084B11407181880000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 03020FA58AA57D97D2-8056
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150805 042 0607
Serial number: 150902100135
Component: RLHS 037 0059
Serial number: S5Y15M09D22H12M33S49
Coding: 14A8DD
Subsystem 3 - Part No SW: 3G0 941 633 J HW: 3G0 941 633 J
Component: E1 - LDS MQB H01 0032
Serial number: 18 06 2015 10000783
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 006 0326
Serial number: 000000000ZY152170WTX
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000063587464
Humidity sensor: interior:
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0045
Serial number: 000308417618083
Coding: 1271161951
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000.rod
VCID: 50A8F0E90B53560F1F-8004
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Coding: 5200670B51FFC428949C804D
Shop #: WSC 50105 001 104857
ROD: EV_ACCBOSCHVW48X.rod
VCID: 34609C799F8B0A2F1B-8060
Part No SW: 5Q0 959 655 S HW: 5Q0 959 655 S
Component: AirbagVW20 010 0870
Serial number: 003MFR018ZN5
Coding: 88CCC000002000005C5400CF004800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
Left seat belt tensioner:
Serial number: 3G1857705G0261P01265
Coding: 80000D
Right seat belt tensioner:
Serial number: 3G1857706G0261P00303
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 000 809 15
Serial number: 3570000000024AE4661J
Subsystem 4 - Part No SW: ----------- HW: 480 000 809 15
Serial number: 35800000000959E4661R
Subsystem 5 - Part No SW: ----------- HW: 480 403 108 15
Serial number: 3510002AD1C1EFA4B26O
Subsystem 6 - Part No SW: ----------- HW: 480 403 108 15
Serial number: 3520002C31CF2D82C31A
Subsystem 7 - Part No SW: ----------- HW: 480 400 709 15
Serial number: 35500029B1CB0C238198
Part No SW: 3Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20150916500766
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 3G0 920 794 HW: 3G0 920 794
Component: KOMBI 411 1460
Coding: 07A40B182FC0000800887F111201002000000000
Shop #: WSC 00046 000 00000
VCID: 69DE3D0D88C987C778-803C
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 5QE 907 530 D HW: 5QE 907 530 A
Component: GW MQB EV 312 3226
Revision: -------- Serial number: 04091510800213
Coding: 020300172EF21000FB00527C5C1F00000001070100010000000300000000
GVL: 01543C1000000608D00C90008002C81810000000000000000000000000000000
ASAM Dataset: EV_GatewEVConti 013020
ROD: EV_GatewEVConti_013.rod
VCID: 479ADBB5FE1D91B74E-8012
Subsystem 1 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0040
Serial number: 27150001714240025354
Coding: 2DFFFF
Subsystem 2 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 9019807503
Analog clock:
Subsystem 3 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 D HW: 5QE 909 059 B
Component: EBKV H14 0182
Serial number: 085430010590
Coding: 05720100431900030002060500
Shop #: WSC 05311 115 00179
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
ROD: EV_BrakeBoostBoschMQBOMG_003.rod
VCID: 4FAAF395166D49F706-801A
Brake pressure reservoir:
Subsystem 1 - Part No SW: 5QE 909 057 C HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0152
Serial number: 05802861110915004847
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 15000075006017
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71EE556DA0197F0730-8024
Component: TSG FS 020 0041
Serial number: 260815BHP05674
Coding: 003F0F20D000028000001000
VCID: 4382CFA5CA25BD9792-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 K HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2033
Revision: 00000000 Serial number: 0000382926
Coding: 01010010005100
Shop #: WSC 00015 115 00302
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_008_VW48.rod
VCID: 3B72B745B2D5C557DA-806E
Address 51: Electric Drive
Component: TSG BFS 020 0041
Serial number: 100915BIA03313
Coding: 003F0120DC00028000001000
VCID: 428CCAA1D53FB49F99-8016
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 03DA000009010000
Shop #: WSC 05311 000 08193
VCID: 75E6617DD4715327EC-8020
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 043 D HW: 3G0 035 043
Component: MU-H-N-EU H42 1427
Serial number: A599I0FB015791
Coding: 02840201FF00000051110001000808231F0209E441200000DF
VCID: 1D3659DD0C01AB67C4-8048
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZHT2553255
Subsystem 2 - Part No SW: V03 959 809 P HW: -----------
Component: ECE 2021/2022 --- 0192
Compact disc data bank:
Component: Gracenote2--- --- 1011
6179 - Display Module 1 for Multimedia System
B1297 F6 [008] - Cable for Video Signal; Open Circuit
Reset counter: 195
Mileage: 95200 km
Date: 2022.05.24
Time: 08:31:26
Voltage terminal 30: 13.2 V
6665 - No Communcation with Front Display/Control Module
U0257 00 [008] - -
Reset counter: 195
Mileage: 95129 km
Date: 2022.05.21
Time: 13:10:38
Voltage terminal 30: 14.8 V
Part No SW: 5Q0 907 383 E HW: 5Q0 907 383 B
Component: Anhaenger H14 0137
Revision: 8C001002 Serial number: 0372363955
Coding: 0100000200000000
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H07 0100
Coding: 0184020162002017000041
Shop #: WSC 05311 115 00084
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
VCID: 77FA6B75CE7D2137FE-8022
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 284 C HW: 5QE 035 284 C
Component: OCULowMQBEU 012 0715
Coding: 028472011082BA0300F800000000
ROD: EV_OCULowMQB.rod
VCID: 4480CCB9CF2BBAAFAB-8010
Address 8C: HV Battery (J840) Labels: 5QE-915-227.clb
Part No SW: 3Q0 915 227 P HW: 3Q0 915 227 K
Component: K8C H05 0520
Serial number: 31081512010115 CVN: 8BE8FA63B95EF858DC659A657E764ED97E764ED97E764ED97E764ED97E764ED9
ASAM Dataset: EV_BECM09620213Q0915227P 002009
ROD: EV_BECM09620213Q0915227P.rod
VCID: 3E74BE51A1C7D07FFD-806A
Battery interrupt switch:
Subsystem 1 - Part No SW: 3Q0 915 227 J HW: 3Q0 915 227 J
Component: A2 HVSMBJBECU H08 0410
Serial number: 00000021071513010092
Cell module control module 1:
Subsystem 2 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC1 H04 0442
Serial number: 15624ZKK311A01040234
Cell module control module 2:
Subsystem 3 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC2 H04 0442
Serial number: 15624ZKK311A01040451
Cell module control module 3:
Subsystem 4 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC3 H04 0442
Serial number: 15624ZKK311A01040073
Cell module control module 4:
Subsystem 5 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC4 H04 0442
Serial number: 15624ZKK311A01040424
Cell module control module 5:
Subsystem 6 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC5 H04 0442
Serial number: 15623ZKK311A01040257
Cell module control module 6:
Subsystem 7 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC6 H04 0442
Serial number: 15624ZKK311A01040369
Cell module control module 7:
Subsystem 8 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC7 H04 0442
Serial number: 15621ZKK311A01040616
Cell module control module 8:
Subsystem 9 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC8 H04 0442
Serial number: 15621ZKK311A01040172
Part No SW: 3G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0005
Serial number: 150825200368
Component: TSG HFS 020 0041
Serial number: 270815BHR01003
Coding: 000E01200100028000001000
Shop #: WSC 50106 001 1048576
VCID: 4586D1BDC41183A7BC-8010
Component: TSG HBFS 020 0041
Serial number: 270815BHR01008
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 M HW: 5QE 915 682 M
Component: OBC KOSTAL H22 4006
Revision: -------- Serial number: 2808150HE000R7
Coding: 115068222000
ASAM Dataset: EV_OBCSinglPhaseKLOMQB11P 004001
ROD: EV_OBCSinglPhaseKLOMQB11P.rod
VCID: 57BA0BF52EBD0137DE-8002
Address CA: Sunroof
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
End-------------------------(Elapsed Time: 06:38)--------------------------
