Autoscan of my 2014 Touareg TDI - trying to figure out what some of these fault codes are.
silverbulletwagon
Surrey, BC, Canada
C?ID=419231
This is an Autoscan of my 2014 Touareg TDI
I have looked through the Ross Tech wiki page and could not find all of the codes.
I am not sure about these codes. Any ideas?
Address 01 Engine
Address 08 HVAC
Address 47 sound system, left front speaker, have not checked speaker or wiring yet. Any common speaker problems?
The ones below I have found info on/figured out:
Address 09 Right Fog. Lense and bulb were broken, fixed.
01964 steering control module - due to changing front seats.
Address 19 also from changing seats
Address 36 again front seats
Address 42 front seats
Address 52 front seats
Thank you in advance!
Tim
Saturday,30,July,2022,15:34:08:63819
VIN: WVGDP9BP6ED006814   License Plate: JG165B
Mileage: 96356km-59872mi   Repair Order: 1-2022-07-30
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
          62 65 69 6C 6D 72
VIN: WVGDP9BP6ED006814   Mileage: 96356km-59872miles
36-Seat Mem. Drvr -- Status: Cannot be reached 0100
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 K    HW: 7P0 907 401 K
   Component: 3.0TDI FSA    X21 0011
   Revision: 56X21---    CVN: E7FCBDE438D3FF8238D3FF820E1FC39E
   Coding: 292A4012233600050000
   ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
   ROD: EV_ECM30TDI0117P0907401K.rod
   VCID: 372B2F124FC210033E5-8062
   VINID: 9E65D48094A0195500006201106E644EF3
8675 - Exhaust Gas Temp Bank 1 Sensor 1 (G235)
          P2080 00 [096] - Implausible Signal
                    Mileage: 95444 km
                    Date: 2022.07.09
                    Time: 19:26:16
                    Engine RPM: 2061.00 /min
                    Normed load value: 49.8 %
                    Vehicle speed: 125 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 14.840 V
                    Unlearning counter according OBD: 8
                    Exhaust gas model temperature 0: 627.7 °C
                    Exhaust gas model temperature 1: 343.9 °C
                    Exhaust gas temperature sensor 1: 441.1 °C
                    Exhaust gas temperature sensor 2: 300.0 °C
                    Exhaust gas temperature sensor 3: 300.0 °C
                    Exhaust gas temperature sensor 4: 300.0 °C
                    Ambient temperature: 20.5 °C
Readiness: 0 0 0 1 X
   Part No SW: 0C8 927 750 CF    HW: 0C8 927 750 CF
   Component: AL1000 AISIN  002 3376
   Serial number:                CVN: 187C4FCF
   Coding: 00B168
   Shop #: WSC 26498 002 104857
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002_VW52.rod
   VCID: 72BDDE066420B52BC9B-8026
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 424930010EC010
   Coding: 5B7613C349242559DAFCC89492D6A4407700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4ACD66E62C309DEB51B-801E
   Part No SW: 4H0 907 064 DK    HW: 4H0 907 064 DK
   Component: BCM2 2.0      H35 0510
   Coding: 0D860016000000000000
   VCID: 75B7E51A15CEA213EC9-8020
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 0213000331264008
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
   Component: Klima 2 Zonen H21 1306
   Coding: B686000A80
   VCID: 055795DA45AEB293FC9-8050
0278 - Coolant Shut-Off Valve
          B10C8 13 [009] - Open Circuit
                    Reset counter: 129
                    Mileage: 90856 km
                    Date: 2022.04.21
                    Time: 15:20:11
0320 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 205
                    Mileage: 90737 km
                    Date: 2022.04.16
                    Time: 12:08:59
0402 - Coolant Circulation Pump
          B10D0 13 [008] - Open Circuit
                    Reset counter: 173
                    Mileage: 96216 km
                    Date: 2022.07.27
                    Time: 14:06:33
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001653195
   Coding: 26001012D73C5D010020180780005D0C431C660882010261800000020000
   VCID: 6C81C07E468463DB037-8038
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    131029  033 0021
   Serial number: 90243400131030190322
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20211093
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Serial number: 00000000000811130103
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R6Y9N02
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA106971000004943053
   Coding: 010300
                    Fault Status: 00101100
                    Reset counter: 142
                    Mileage: 95265 km
                    Date: 2022.07.03
                    Time: 14:30:00
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 205
                    Mileage: 90737 km
                    Date: 2022.04.16
                    Time: 12:03:00
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0026
   Revision: --------    Serial number: 28231330803885
   Coding: 318501
   ASAM Dataset: EV_VW526ParkiAssis2 001012
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 43D34BC20B1A4CA392D-8016
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 D    HW: 7P0 959 655 D
   Component: VW10Airbag02B H06 0026
   Revision: --------    Serial number: 003L5003BHJ-
   Coding: 000000000000000000000000000000003242
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 42DD4EC6140045AB99B-8016
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R136250EHU9
   Serial number: 3575LRB405923HNE91HB
   Serial number: 3585LRB405723HNEA0A3
   Serial number: 3515RRB401C50OC8H9VU
   Serial number: 3525RRB401C50OC84H61
   Serial number: 3555NRB400E50OV0AHU%
   Serial number: 3565NRB400E50OV0AHJW
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Revision: --------    Serial number: 99999MK8000SP
   Coding: 000C35
   VCID: 38292C2E425C1F7B37F-806C
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0019637 TRW 20131023
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 882 M    HW: 7P6 920 882 M
   Component: Kombi         H13 0419
   Revision: 13240270    Serial number: 658081113592065
   Coding: 0B3733012B000008020004
   ASAM Dataset: EV_KombiUDSRBVW526 001020
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 47CB5FD23F2260834E5-8012
   Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6032
   Revision: --------    Serial number: 00000001156659
   Coding: 000103AD00
   GVL: FB4F40455D7F000000
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3FDB473267F22843F65-806A
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 30306K25525701340828
5274 - Seat/Mirror Postion Control Module - Driver
          U0208 00 [009] - No Communications
                    Reset counter: 205
                    Mileage: 90737 km
                    Date: 2022.04.16
                    Time: 12:02:50
                    Voltage terminal 30: 12.0 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 21 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
Address 36: Seat Mem. Drvr
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000081968617
   Coding: 011D17205E00453005080000
   VCID: 7AADF6263CD0CD6B81B-802E
                    Fault Frequency: 66
                    Reset counter: 132
                    Mileage: 90737 km
                    Date: 2022.04.16
                    Time: 12:03:24
   Revision: 00002001    Serial number: 0317209739
   Coding: 01861E3A68B9509580A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 297136517
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO25136393
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO2522590%
   Coding: 191100
   Part No SW: 7P6 035 466     HW: 7P6 035 466
   Component: DSP Prem      H01 0090
   Revision: 00001001    Serial number: 10811002736707
                    Fault Status: 00101011
                    Reset counter: 167
                    Mileage: 92171 km
                    Date: 2022.04.28
                    Time: 12:38:56
                    Voltage: 11.60 V
                    Temperature: 13.0°C
                    Temperature: 15.0°C
                    Bin. Bits: 00000100
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000081731168
   VCID: 48C95CEE32BC6FFB47F-801C
                    Fault Frequency: 58
                    Reset counter: 131
                    Mileage: 90737 km
                    Date: 2022.04.16
                    Time: 12:03:24
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C13B0801320
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: 3635221648C8E90B253-8062
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 010A00010F000400
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CA1F03E3664F35B937-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0003
   Coding: 130000
   Revision: AB001007    Serial number: 156KA0D7932389
   Coding: 020007010000000001
   VCID: 2411E85EEED46B9B8B7-8070
   Part No SW: 7P6 035 664 E    HW: 7P6 035 664 A
   Component: H-BN-NA       H40 0783
   Revision: --------    Serial number: 273K90D7506985
   Coding: 020200050040E1EF41022B0E00000003F00001030000000000
   VCID: 3A2D36267C500D6BC1B-806E
   Subsystem 1 - Part No: 7P6 060 884 F
   Component: NAR 2016/2017  1402
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9NA30029N
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  5571
                    Reset counter: 205
                    Mileage: 90733 km
                    Date: 2022.04.15
                    Time: 20:10:01
                    Text: DUA001,Front,M,0,0,6
                    Fault Frequency: 26
                    Reset counter: 172
                    Mileage: 96335 km
                    Date: 2022.07.29
                    Time: 09:21:00
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000001
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 173
                    Mileage: 90733 km
                    Date: 2022.04.16
                    Time: 09:56:22
                    Voltage: 13.00 V
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000081405898
   Coding: 011817200000253005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000116581
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H11 0110
   Revision: 5A001001    Serial number: 00000194715399
   Coding: 020D000000000000
   VCID: 3B233322736A3463DAD-806E
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H08000    Serial number: 525 PA8J3X1247
   Coding: 0130001
   VCID: 372B2F12434210033E5-8062
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 293300169
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000081404610
End----------(Elapsed Time: 02:20, VBatt start/end: 14.2V/14.3V)-----------
          62 65 69 6C 6D 72
   Coding: 00B168
   Coding: B686000A80
                    Reset counter: 133
                    Mileage: 96356 km
                    Date: 2022.07.30
                    Time: 15:37:17
          U1111 00 [009] - -
                    Reset counter: 133
                    Mileage: 96356 km
                    Date: 2022.07.30
                    Time: 15:37:16
   Coding: 004DBD
   Coding: 025223
   Coding: 010300
                    Reset counter: 133
                    Mileage: 96356 km
                    Date: 2022.07.30
                    Time: 15:37:00
   Coding: 318501
   Coding: 000C35
   Coding: 000103AD00
                    Reset counter: 133
                    Mileage: 96356 km
                    Date: 2022.07.30
                    Time: 15:37:16
                    Voltage terminal 30: 11.9 V
                    Voltage terminal 15: 11.9 V
                    Control Module temperature: 39 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
                    Reset counter: 133
                    Mileage: 96356 km
                    Date: 2022.07.30
                    Time: 15:37:15
   Coding: 191100
   Coding: 191100
                    Reset counter: 133
                    Mileage: 96356 km
                    Date: 2022.07.30
                    Time: 15:37:14
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   Slave 3:
   Coding: 130000
   Coding: 130000
                    Reset counter: 133
                    Mileage: 96356 km
                    Date: 2022.07.30
                    Time: 15:37:19
                    Reset counter: 133
                    Mileage: 96356 km
                    Date: 2022.07.30
                    Time: 15:37:19
   Coding: 0130001
   Coding: 0533314003
End----------(Elapsed Time: 02:23, VBatt start/end: 12.2V/12.1V)-----------
Address 01 Engine
Address 08 HVAC
* = my comments
Address 01 Engine:
Intermittent - Not Confirmed - Tested Since Memory Clear (*Intermittent, as Uwe has stated in the past, take with a grain of salt)
Address08 HVAC:
Confirmed - Tested Since Memory Clear (*check fuse(s) and wiring , possible component failure)
Address 5F Information Elect. :
(*you may have to visit the dealer for this one, if I recall correctly from past posts here on the forum)
Address 47 Sound system:
011 - Open Circuit - Intermittent (*may have a speaker starting to fail or failing connection; but it is Intermittent)
If you wish to monitor these, clear all the codes ; note, they (this Auto-Scan) have been automatically saved to your computer in the Ross Tech scans / Logs file. (Also, , if you ever decide to scrap your pc be sure to get a copy of that file before you dispose of the PC ) .
Then, do a new Auto-Scan and see if any of the codes you are concerned with return (like the intermittent codes noted here) ; as they may come and go. The ones that "stick" are most likely positive. Keep in mind many faults are not always the part mentioned ; a bad connection, wire, or fuse can generate the same message. So, try to test as much as possible before replacing any parts. And, if electrical, always use genuine oem components - new if possible or practical.
Other forum members comments to follow.
Only if it's "Intermittent" and "Not confirmed". It's also worth looking at the Gateway's status for that module. If the Gateway still shows "OK", then the module hasn't found it serious enough to make the Gateway aware of it. But in this case, the Gateway shows "Malfunction". Then there's also the fact that EGT sensor faults can prevent the DPF from getting regenerated as it should, so if this were mine, I'd skip the salt and investigate further.
Nah.
http://wiki.ross-tech.com/wiki/index.php/03276
In addition, there will be an Adaptation channel in that module (in this case number 015). You read the value there, XOR it with some fixed value, and write the results back to make that DTC go away. There are a number of threads about it. Here's one (although this is for a UDS module, the same concepts apply):
https://forums.ross-tech.com/index.php?threads/18798/
But none of this is really necessary unless you're OCD; this one can be safely ignored.
silverbulletwagon
Surrey, BC, Canada
C?ID=419231
Address 01 Engine
Address 08 HVAC
Tim
          62 65 69 6C 6D 72
                    Mileage: 95444 km
                    Date: 2022.07.09
                    Time: 19:26:16
I forgot to mention, the Touareg has Malone Stage 2 with dpf and scr deletes.
Address08 HVAC:
I have no idea where that component would be or what it looks like.
I'm no VW guy, but if you want to get more involved in repair , see the pull down menu at the top of the page "how-to" get more repair info . For under 50 bucks you can get a considerable amount of information about your exact vehicle!
If you do decide to get the Erwin information, there is a strategy to use so that you maximize your visit on that site: you download all the information regarding your vehicle and review / and or print it later.
But IIRC you need to download a save to pdf file first as you can not print off the Erwin web-site. (that's a general explanation). For 35.00 USD (24 hr time subscription period) and being prepared you can easily download all the info on your vehicle in a hour or two.
well i hope you don't travel anytime soon in US :cool:
Why? It's not like there's an emissions inspection at the border.
  • Haha
Reactions: JMR
JMR
Romania
C?ID=432218
Ooooohh...they didn t implement that yet ? Lol. I m gonna call EPA ...
  • Haha
