2016 Audi SQ5 Side Assist behavior with Trailer module active
SteveD12
Sammamish, WA, USA
C?ID=520660
Is there any way to change the programming of the Side Assist to work when the trailer module is active?
I thought i saw an option when i programmed the hitch, but can't find it now. :(
We only use our hitch to power the lights and turn signals on the bike rack.
Westbury, UK
Have you already posted an Auto-Scan here after coding for the trailer hitch?
If you have can you link to it please.
But if not please post an Auto-Scan.
SteveD12
Sammamish, WA, USA
C?ID=520660
Address 01: Engine (J623-CTUD)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8R0 907 551 G    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0007
   Revision: --H07---    CVN: 8B77F6E0
   Coding: 2A2A0034053600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218R0907551G 001007
   ROD: EV_ECM30TFS0218R0907551G.rod
   VCID: 3C2139DAC6EE7E3BD37-8068
   VINID: 9D10534D15A0A174401062050C9A671540
20136 - PCV Valve Malfunction
          P052E 00 [109] - -
                    Mileage: 97319 km
                    Date: 2022.07.30
                    Time: 09:57:33
                    Engine RPM: 704.00 /min
                    Normed load value: 12.9 %
                    Coolant temperature: 94 °C
                    Intake air temperature: 48 °C
                    Voltage terminal 30: 13.507 V
                    Engine speed: actual: 672 /min
                    MAF_ENVD: 152.51764 mg/stroke
                    Coolant temperature (unfiltered): 69.75 °C
                    Engine: operating status: IS
                    Engine load: 15.234375 %
                    Vehicle speed: actual: 0 km/h
   Part No SW: 8R0 927 158 AB    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H19 1003
   Revision: --H19---    CVN: DEE0EE05
   VCID: 7DA7F4DE9D74B733A49-8028
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 309D1801
   Shop #: WSC 06335 000 00000
   VCID: 117FB86EB16CA353501-8044
   Part No SW: 8K0 907 064 KP    HW: 8K0 907 064 KP
   Component: BCM2 2.0      H15 0711
   Coding: 0D854040000000000000
   VCID: 0849950AC236E29B87F-805C
   Serial number: 3215000137000001
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01170820150367
   Coding: 6601228000
   VCID: 77ABE6F6BFC89D63FE5-8022
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00001147356302
   Coding: 26000091863CAFE0010048C300003D0D0F9CE708A2090221000008004000030100000034000000
   VCID: 78A9E5CAB2D6921BF7F-802C
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 150812  H12 0050
   Serial number: 90243014150810083232
   Coding: 01DD13
   Serial number: 20512092
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000003107151414
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z02031CF7
   Serial number: 99480FB7000000000001
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H53 0812
   Serial number: 003NED159V8L
   Coding: 303635313832383132304A55304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4CC1691A964ECEBB637-8018
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R150000N5VZ
   Serial number: 6334MSME531852748
   Serial number: 6344MSME537B542DO
   Serial number: 6352QSME7F582166R
   Serial number: 6362QSME395014628
   Serial number: 63732SME7958005A0
   Serial number: 63832SME79584B66D
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862OHF00055
   Coding: 000037
   VCID: 48C9550A82B6229B47F-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 982 C    HW: 8R0 920 982 C
   Component: KOMBIINSTR.   H35 0567
   Revision: 00200000    Serial number: 03T53V48G
   Coding: 8BB722000301D705020000
   VCID: 3B233AC6C3607903DAD-806E
   Part No SW: 8R0 907 468 AA    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0070
   Revision: 1Z130032    Serial number: 3241Z1571901C2
   Coding: 80C103FF00
   VCID: 7EA5F3D290F2AC2BBD3-802A
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 1632197503
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000160305814
   Coding: 00581B00000000000000
   VCID: 42DD4722A48A08CB99B-8016
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0375937069
   Coding: 010221
   Shop #: WSC 06334 000 00000
   VCID: 3FDB4ED6D7F86523F65-806A
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0376516473
   Coding: 010221
   Component: TSG FA        H02 0511
   Revision:             Serial number: 0000161718982
   Coding: 011D13215E00440004
   VCID: 4FFB7E1667D8F5A3065-801A
   Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0031090954
   Coding: 100000010000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 45D75C3EB5243FF3BC9-8010
   Revision: 00002001    Serial number: 0376431297
   Coding: 0126023A20FA709584B0053220040000
   Component: GTO BF  H01 0080
   Serial number: 00000000000001040362
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
   Revision: 00005001    Serial number: 94813048571507
   VCID: 2D07049E0D14E7B3549-8078
   Component: TSG BF        H02 0511
   Revision:             Serial number: 0000161557672
   VCID: 4EC5631260D2FCAB0D3-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000664554
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D3FC2CCDA400BC1B-806E
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156HS0F8303300
   Coding: 020007010000000001
   VCID: 2411E1BA5EDE26FB8B7-8070
   Part No SW: 8R1 035 746 H    HW: 8R1 035 746 G
   Component: H-BNT-NA      H43 0937
   Revision: --------    Serial number: 523H90F7584298
   Coding: 1A0200060205A1EF55028B5E00000403140000000000000000
   VCID: 3C2139DAC66E7E3BD37-8068
   Subsystem 1 - Part No: 8R0 060 884 CS
   Component: NAR 2015  1201
   Component: DU7 High  H42 0104
   Serial number: A130HV0F3433636
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000002338588
   Component: CD-Database  6208
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000160498196
   Coding: 010C13204000240004
   VCID: 46D55B3288A234EBB53-8012
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: Anhaenger     H12 0100
   Revision: 1A001001    Serial number: 00000506534100
   Coding: 0200000000000000
   VCID: 36352BF2F842A46B253-8062
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-JA6A0QS
   Coding: 1010010
   VCID: 343111FAE23EB67B1B7-8060
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D2734DEDD747733E49-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000160498312
   Part No SW: 8R0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 150701201957
End----------(Elapsed Time: 02:11, VBatt start/end: 11.9V/11.9V)-----------
I don't see anything explicit for that in the 3C module, but I see it is coded to for a trailer hitch.
What happens if you tell the 3C module that you do not have a trailer hitch?
SteveD12
Sammamish, WA, USA
C?ID=520660
Yeah i was thinking of trying that, will try at the weekend. Thanks.
