Hi,
i have a issue with my car’s Ac system. After winter i tried tu put ac on but it blow warm air. I cant see that compressor engaging at all. Car went to eork shop and didnit found the issue. The compressor is varian displacement version with regulator valve. Steady pressure with gauges was 5.5 bar without any leakage tested in workshop and there is no faulty code scanned. There is a few data of live data with OBDELEVEN in the following if someone knows what is wrong with AC system.
Refrigerant pressure: 6.bar
AC compressor valve target: 699 mA
AC compressor valve actual: 700 mA
Test program control: 69%
Compressor specified value: 0.7 A
Compressor actual value: 0.7 A
Compressor shut-off requirement: No shut-off condition is present.
Compressor shut-off requirement, last: Shut-off from ECM via CAN.
Thanks in advance.
Thanks in advance.
