- Jul 27, 2022
- 8
- 1
- Manchester, UK
- C?ID=518359
Hello All
I recently purchased a hex-net cable, installed and all modules read and error codes cleared. Great. However I want to change the car to chirp on lock and unlock.
I went to module 9 but I get a message saying this module cant be coded and there are all zeros 000000000000000000000000 for the coding sequence. See here Pic 1
It then says this may be changed through adaptations here Pic 2
Does anyone know how to do this? as I cannot seem to find anything on the web.
Please see Autoscan below.
Wednesday,27,July,2022,19:40:56:40455
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
VIN: TRUZZZFV1K1006218
Mileage: 33475km-20800mi Repair Order:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A9
VIN: TRUZZZFV1K1006218 Mileage: 33475km-20800miles
Address 01: Engine (J623-DKZB) Labels: None
Part No SW: 8S0 907 115 HW: 06K 907 309 B
Component: R4 2.0l TFSI H60 0003
Revision: O1H60000 CVN: 3E9843E6
Coding: 022540122424050B24000000000000000000000000000000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0118S0907115 001005
ROD: EV_ECM20TFS0118S0907115.rod
VCID: 72BDD4205426C1EBC9B-8026
VINID: 92296AAAA5A605B04000608120B52CFC51
Readiness: 0010 0001
Part No SW: 0GC 300 044 J HW: 0GC 927 711 H
Component: GSG DQ381 H06 2402
Revision: 00H06V08 CVN: AE09ED6E
ROD: EV_TCMDQ381061.rod
VCID: 2F3B1D548794AC03665-807A
No subsystems:
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8S0 907 379 K HW: 8S0 907 379 F
Component: ESC H42 0542
Revision: 00000000 Serial number: 60289000000022
Coding: 11AAA08D1A9915AF41930065C299970EB3880558A8820043E970CD
ASAM Dataset: EV_Brake1UDSContiMK100IPB 060017
ROD: EV_Brake1UDSContiMK100IPB_060.rod
VCID: 49CF53CC1930E233581-801C
Part No SW: 3Q0 959 435 F HW: 3Q0 959 435 F
Component: VWKESSYMQB 027 0907
Revision: 00027000 Serial number: 0506190730
Coding: 000F0F1720
ROD: EV_KessyHellaMQBAB.rod
VCID: 3D27371C5DF84E93E49-8068
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8S0 820 047 HW: 8S0 820 047
Component: AC Manuell el H05 0040
Revision: 20010000 Serial number: 19190000009000
Coding: 410040000011100100
ASAM Dataset: EV_AirCondiMAPrehAU33x 003011
ROD: EV_AirCondiMAPrehAU33x.rod
VCID: 70B9DE285A2AF3FB3FF-8024
Rear A/C Control Head 1:
Subsystem 1 - Part No SW: 8S0 820 374 A HW: 8S0 820 374 A
Component: E774 BuA_1 H06 0010
Serial number: 00000000000000011262
Rear A/C Control Head 2:
Subsystem 2 - Part No SW: 8S0 820 360 D HW: 8S0 820 360 D
Component: E775 BuA_2 H06 0010
Rear A/C Control Head 3:
Subsystem 3 - Part No SW: 8S0 820 360 C HW: 8S0 820 360 C
Component: E776 BuA_3 H06 0010
Rear A/C Control Head 4:
Subsystem 4 - Part No SW: 8S0 820 360 E HW: 8S0 820 360 E
Component: E777 BuA_4 H06 0010
Rear A/C Control Head 5:
Subsystem 5 - Part No SW: 8S0 820 374 B HW: 8S0 820 374 B
Component: E778 BuA_5 H06 0010
Part No SW: 5Q0 937 084 DC HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H38 0273
Serial number: 00001905404375
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7CA1FA180662879B937-8028
Subsystem 1 - Part No SW: 8S2 955 119 B HW: 8S2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: 43x RL 030718 038 0371
Serial number: 00000001806280308445
Coding: 1BC7F7
Subsystem 2 - Part No SW: 81A 955 559 A HW: 81A 955 559
Component: G397_RLS H06 0002
Serial number: 20188574X81A955559A0
Coding: 00005D
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 11 10 2018 20001419
Subsystem 4 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY190020G35
Serial number: 00000000000046516366
204546 - Remote key 2
B147A 18 [009] - Current Too Low
Reset counter: 66
Mileage: 33451 km
Date: 2022.07.26
Time: 20:01:41
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: OFF
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.6 V
Outside temperature: 28.5 °C
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39231903702893
Coding: 0000040011
VCID: 3C213A1846E2479BD37-8068
Part No SW: 5Q0 959 655 P HW: 5Q0 959 655 P
Component: AirbagVW20 010 0870
Serial number: 003M7R02S8GR
Coding: 88CCF0C00C8000005C5000CFC0C800000065
VCID: 4DC767DCED58FE13749-8018
Subsystem 1 - Part No SW: ----------- HW: 480 001 402 19
Serial number: 3570000000084380693D
Subsystem 2 - Part No SW: ----------- HW: 480 001 402 19
Serial number: 35800000000A4380693G
Subsystem 3 - Part No SW: ----------- HW: 480 010 201 19
Component: SideSensor_Dr 005 0108
Serial number: 351001A0DE8B29E4BC1X
Subsystem 4 - Part No SW: ----------- HW: 480 402 501 19
Component: FrontSensor_D 004 6149
Serial number: 3550001282BFB78495CM
Subsystem 5 - Part No SW: ----------- HW: 480 401 402 19
Component: FrontSensor_P 003 6149
Serial number: 3560001BB2E4B1B4825D
Subsystem 6 - Part No SW: ----------- HW: 480 400 502 19
Component: PedP_Sensor_C 004 6149
Serial number: 2300001042B7F1C4920U
Subsystem 7 - Part No SW: ----------- HW: 480 000 102 19
Serial number: I0M00000000803D0483-
Subsystem 8 - Part No SW: ----------- HW: 480 000 102 19
Serial number: I0N00000000F1321E731
Part No SW: 8S0 907 129 AG HW: 8S0 907 129 AG
Component: Lenks. Modul H07 0150
Revision: -------- Serial number: 91335SB600171
Coding: 201C
ASAM Dataset: EV_SMLSKLOMQB 050001
ROD: EV_SMLSKLOMQB_050.rod
VCID: 7F5B0D1417749C83B65-802A
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8S0 920 790 D HW: 8S0 920 790 D
Component: FBenRDW H45 0359
Coding: 24A50150298006000100E8C09000800000000000
ASAM Dataset: EV_DashBoardBOSCHAU33X 001032
ROD: EV_DashBoardBOSCHAU33X.rod
VCID: 3A2D3C004CD679ABC1B-806E
Part No SW: 8S0 907 468 J HW: 8S0 907 468 E
Component: GW MQB TT3 023 0366
Serial number: 17021910802195
Coding: 030100042F025B004B0002681C0B00000000000000000000000000000001
GVL: 01543C1000000600400C10000000C80000000000000000000000000000000000
ASAM Dataset: EV_GatewContiAU33X 013025
ROD: EV_GatewContiAU33X_013.rod
VCID: 47CB55F40F2414434E5-8012
Generator:
Component: 1-01-0d-01-04
Subsystem 2 - Part No SW: 8S0 951 523 C HW: 8S0 951 523 C
Component: J453 MFL H07 0002
Serial number: 20190130002134 00031
Subsystem 3 - Part No SW: 8W0 915 181 HW: 8W0 915 181
Serial number: 1045930405
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000421071006
Coding: 0900000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 333311246BBC88E302D-8066
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007SAJ3463B
Coding: 001042225001000100001402
VCID: 44D142F83E123F5BAB7-8010
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 811F0000
ROD: EV_SteerAssisMQB_015.rod
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007SAH31376
Coding: 001042225C01000100001402
VCID: 43D341E43B1C386392D-8016
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 039E000001000000
VCID: 75B7EF3C2548D6D3EC9-8020
Part No SW: 8S0 035 021 M HW: 8S0 035 021 K
Component: MU-H-LND-EU 055 1339
Serial number: A710B0KS011927
Coding: 01330401FF00000011111101000A00312F0000E300700000DE
ASAM Dataset: EV_MUHig4CGen2HBAS 001115
ROD: EV_MUHig4CGen2HBAS_AU37.rod
Subsystem 1 - Part No SW: V03 959 802 DD HW: -----------
Component: ECE 2018/2019 --- 0169
Subsystem 2 - Part No SW: 8S0 919 614 M HW: 8S0 919 614 M
Component: ControlUnit_H H30 0206
Serial number: APVAK112121800010316
Compact disc data bank:
Component: Gracenote2 --- 1017
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8S0 907 159 E HW: 81A 907 159 A
Component: SAS-GEN 2.5 H08 0001
Serial number: 190122201351
VCID: 3FDB4D1457F45C83F65-806A
End----------(Elapsed Time: 01:20, VBatt start/end: 12.7V/12.7V)-----------
