Hi
does anyone know how to enable fob with engine running in Audi a6 MIB2 using VCDS .
thank you in advance
This does not belong in Product Support. Moving to Tweaks.
An Audi A6, eh? Audi has made cars called the "A6" since 1994. There have been four generations of them since then.
Would you be so kind as to post an Auto-Scan so people can see exactly what A6 you have and how it is equipped and configured?
lol , would you be kind enough to tell howoooh,,you're gonna get the big chief mad, he already suggested that you post an auto-scan in your other post about the same car/same question.
Enable fob with engine running
Hi does anyone know how to enable fob with engine running in Audi a6 MIB2 using VCDS . thank you in advanceforums.ross-tech.com
HiHow to post autoscan
https://forums.ross-tech.com/index.php?threads/101/
DO NOT START A NEW THREAD with your autoscan...
Hi
the link is not working
I have the auto scan already but I don't know how to upload it
Wednesday,29,June,2022,18:39:34:39004
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
VIN: WAUZZZFC4JN029358 License Plate: 127877
Mileage: 47439km-29477mi Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3B 42 44 46 52 53 5F 62
72 47
VIN: WAUZZZFC4JN029358 Mileage: 47439km-29477miles
Address 01: Engine (J623-CVPA) Labels: None
Part No SW: 4G0 907 552 L HW: 4G0 907 552 D
Component: 2.8l V6 FSI H07 0002
Revision: --H07--- CVN: D69F4B3E
Coding: 0A250034042601020000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM28FSI0214G0907552L 001004
ROD: EV_ECM28FSI021.rod
VCID: 333316186BBCED5302D-8066
VINID: 9D196AAAA59311A7800890C5209C6C44F2
Part No SW: 4G0 927 166 HW: 0B5 927 156 K
Component: 0B5 28 FSIRdW H06 0008
Revision: --H06--- CVN: 0000827B
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 6A8DCB7C7CF66C9B71B-803E
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 12A69641486569829B00
ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
VCID: 41DF4CD021004FC3801-8014
Part No SW: 4H0 907 064 JT HW: 4H0 907 064 JT
Component: BCM2 2.0 H44 0582
Coding: 01A8700E000000000000
VCID: 045185C47E129AEBEB7-8050
Part No SW: 4G0 820 043 CC HW: 4G0 820 043 CC
Serial number: 18071700041064
Coding: 46013178090000
VCID: 629DA35C84C634DBB9B-8036
Part No SW: 4H0 907 063 GH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0368
Revision: 1502003S Serial number: 00001720920202
Coding: 2600001501349FE00181408080001D0C0F9CC20826090201000008206101150200400024030000
VCID: 74B1D5042EB2AA6BDB7-8020
Component: WWS57X 170611 H38 0080
Serial number: 170629100914
Coding: 0045F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 20376125X81A955547A0
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 24 07 2017 00000754
Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 55D15BB800PAG0MUFU03
Component: Airbag10.43 H82 0092
Revision: -------- Serial number: 003P100ECSLI
Coding: 30333130313730333033554A304C34473053
VCID: 3B233E3843EC2513DAD-806E
Serial number: 3575HRB401E59O0GAQ9L
Serial number: 3585HRB400M59O0KA8AG
Serial number: 3515JRB400K5BCU0EA49
Serial number: 3525JRB401859NS6H9V+
Serial number: 3554VRB401C5BCTQ9P8D
Serial number: 3564VRB401C5BCTQ812Q
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 91560QGO000ML
Coding: 000034
VCID: 3B233E38436C2513DAD-806E
Subsystem 1 - Part No SW: 4G0 951 528 E HW: 4G0 951 528 E
Component: E221 - MFL H09 0010
Serial number: 23 06 2017 D0031917
Part No SW: 4G8 920 934 P HW: 4G8 920 934 P
Component: TBenRdw H17 0225
Revision: 18001312 Serial number: 658250717592046
Coding: 53AF08000B410008190000
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 3E25372C50FE303BFD3-806A
9459739 - Fuel Level Sensor 2
B1058 1B [008] - Resistance Too High
Reset counter: 110
Mileage: 47218 km
Date: 2022.06.25
Time: 18:58:09
9460251 - Covering for fuel level indicator sensor 2
B105A 1B [008] - Resistance Too High
[Geber 2 für Kraftstoffvorratsanzeige: Übergangswiderstand zu groß]
Reset counter: 110
Mileage: 47032 km
Date: 2022.06.19
Time: 10:58:30
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G8 907 468 J HW: 4G8 907 468 A
Component: J533--Gateway H15 0110
Revision: -------- Serial number: 00000002668460
Coding: C0CD073010
GVL: FD81C848D820600100040000
ASAM Dataset: EV_GatewPkoUDS 002011
VCID: 3FDB4A2857F43933F65-806A
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 2195134704
Voltage stabilizer:
Serial number: 1705100000000000072D
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0113
Serial number: 21081700042200
Coding: 20
VCID: 3D2730205DF82B23E49-8068
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000265915669
Coding: 0058130000006001000001010101102030303232203232
VCID: 77ABE2083FC4C173FE5-8022
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720YGUFC
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011C17015E00620002080002
VCID: 47CB52C80FA471F34E5-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000063566
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2D3B3C4CD61C1BC1B-806E
Revision: 00002001 Serial number: 0448251222
Coding: 0104063800B900848330088400010E470000000000000000000000000000
Subsystem 1 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST001P8W6000000
Coding: 901E02
Subsystem 2 - Part No SW: 4G0 947 135 F HW: 4G0 947 135
Serial number: 0000000AP00036437961
Coding: 090000
Component: TSG BF H03 0511
VCID: 46D55FCC08AE68FBB53-8012
Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
Component: EPB-4 H01 0018
Revision: -------- Serial number: 00000002259746
ASAM Dataset: EV_ParkiBrake 001033
ROD: EV_ParkiBrake_VW51.rod
VCID: 323D131C94A6E45B09B-8066
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 045 J HW: 4G1 035 045 D
Component: MU-H-N-RW 054 0910
Serial number: A738G0HS004172
Coding: 0175010CFF0A000013110001000A00002F0006E4F17001025E
VCID: 270BF248AF6491F3AE5-8072
Subsystem 1 - Part No SW: V03 959 801 PT HW: -----------
Component: ROW 2017/2018 --- 0065
Multimedia System 1:
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9HY808G2C
Serial number: 90349QGP000HQ
Compact disc data bank:
Component: Gracenote2 --- 4012
12 Faults Found:
1585 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for ASAM/ODX MUX]
Reset counter: 8
Mileage: 45494 km
Date: 2022.05.14
Time: 16:52:35
Voltage terminal 30: 14.3 V
1586 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for speed shutoff thresholds]
Reset counter: 8
Mileage: 45494 km
Date: 2022.05.14
Time: 16:52:35
1587 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for language]
Reset counter: 8
Mileage: 45494 km
Date: 2022.05.14
Time: 16:52:35
Voltage terminal 30: 14.4 V
1588 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for visible MMI system languages]
Reset counter: 8
Mileage: 45494 km
Date: 2022.05.14
Time: 16:52:35
1589 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for power management timer]
Reset counter: 8
Mileage: 45494 km
Date: 2022.05.14
Time: 16:52:35
1590 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for sound audio parameters]
Reset counter: 8
Mileage: 45494 km
Date: 2022.05.14
Time: 16:52:35
1592 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for DAB frequency tables]
Reset counter: 8
Mileage: 45494 km
Date: 2022.05.14
Time: 16:52:35
1595 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for audio management HMI constants]
Reset counter: 8
Mileage: 45494 km
Date: 2022.05.14
Time: 16:52:35
1655 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for sound announcement audio parameters (optional)]
Reset counter: 8
Mileage: 45494 km
Date: 2022.05.14
Time: 16:52:35
1656 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for sound cabriolet audio parameters (optional)]
Reset counter: 8
Mileage: 45494 km
Date: 2022.05.14
Time: 16:52:35
1657 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for sound configuration audio parameters (optional)]
Reset counter: 8
Mileage: 45494 km
Date: 2022.05.14
Time: 16:52:35
1603 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for speech signal enhancement - telephone/voice recognition signal processing (SSE)]
Reset counter: 8
Mileage: 45494 km
Date: 2022.05.14
Time: 16:52:35
Component: TSG HL H03 0511
Coding: 010815004000620002080002
VCID: 49CF54F019B08783581-801C
Component: TSG HR H03 0511
End----------(Elapsed Time: 01:41, VBatt start/end: 13.5V/13.6V)-----------
Yes, of course.Will an admin kebap wrap this scan ?
so, have you tried kebap /shawarma ? Chicken or beef ? I prefer beef, is cut "halal" .Yes, of course.
thx for your replyPart of me wonders what Byte 5, labeled Central Locking via Advance Key (Terminal S ON) active in address 46 might do.. but that did not appear to work based on this feedback:
2014 SQ5 - Central Locking with Advance Key when Ignition is On
Looking to find a way for the Advance Key to lock/unlock the doors when the ignition is on and motor running. I've attached an Auto-Scan and tried setting several bits in certain bytes high with no success. I also have a Controller Channel Map as well if that may help, I lack the experience so...forums.ross-tech.com
If that didn't work for users with the same MLB BCM2 unit I don't think it will work in this A6.
