- Jul 7, 2021
- 20
- 14
- Midwest, USA
- C?ID=433554
I replaced all the struts, the front left wheel bearing, and all front upper control arms on my vehicle a few months ago.
In the process of that work, I found that both front upper control arm pinch bolts had completely fused with the knuckles. I had to drill them out, somewhat crudely, to accomplish my tasks... and I eventually determined that the knuckles were compromised, so I replaced both knuckles as well.
All of these new parts were cheap aftermarket parts. (I could not justify OEM on an almost 200k Audi.)
The wiring to the front wheel speed sensors undoubtedly took a beating throughout this process.
After doing this work, I had warning lights, beeps, and code 00285 - ABS Wheel Speed Sensor; Front Right (G45) 003 - Mechanical Failure. After awhile of driving, the parking brake and engine modules would also throw codes, basically just saying to check the ABS memory for faults.
Driving the car around with VCDS on, and watching the speed sensors, I found that the reported front right wheel speed mostly matched the other wheels, but would briefly drop every second or two. So for example, if I was driving at 20 mph, all wheels would read 20 (or 19, or 21), but every second or two the front right would flicker and drop to, say, 5 or something. And then it would recover to match the other wheel speeds.
I'd already replaced the front left bearing. And I knew that I'd bashed the bearings enough during the suspension work that I might have messed up the tone ring on the front right, as well. So I ordered another wheel bearing (from same provider as the one I put on the front left). I also ordered a cheap ABS sensor.
I put the new wheel bearing on the front right. It went in fine. (The old bearing's tone ring did look fairly rough.) I also put the new ABS sensor in the front right. Unfortunately, I'm still having the same problems.
Here's all that I've done to troubleshoot this:
1. Replaced front right wheel bearing. It's cheap, but from same place the other (working) bearing came from, and it seems sound when I inspect it
2. Replaced front right wheel speed sensor. Again: cheap, but it's getting about the same readings as the previous one did
3. Cut away the connector to the ABS sensor, and wired it directly in, thinking that the connector or the wire right near the sensor was the issue. Didn't change anything
4. Unplugged the wheel speed sensor entirely, to verify that the code changes. It does indeed change to an Open Circuit instead of Mechanical Failure code when unplugged. (Though shorting the wires doesn't seem to make it report as a short. I'm thinking that's just due to some detail of how the sensor works.)
5. Removed the new bearing again, and cleaned the tone ring, the wheel speed sensor, the hole the sensor goes in, and everything around it in case there were metal shavings or some such interfering with the sensor. It was fairly dirty, but the cleaning solved nothing.
So... at this point, I'm kind of losing my mind. I realize that installing OEM parts will be a suggestion, but I can't justify it on a vehicle with this age and mileage. But I *would* like to make this work, safely, because the body and interior of the car are still great.
It seems to me that a bad sensor would be most likely to either show no wheel speed, or infinite wheel speed, or just be *wrong* most of the time, instead of being *mostly* right, but then giving these intermittent speed drops.
Same for wiring... I'd expect it to maybe drop out periodically if a wire is twisting around and losing connection... but not with this sort of consistency.
The regular drops in reported wheel speed *still* seem consistent with a tone ring problem. (The reported speed would logically drop when the damaged part of the tone ring moves past the sensor.) But, man... what are the odds that I'd have the exact same problem with the new bearing/tone ring, as I had with the old bearing/tone ring?
I considered that the cheap knuckles might possibly be making the sensor sit wrong, in relation to the bearing, if the positions of the holes are a little off. But, if that were the case, I wouldn't expect the speed numbers to be mostly right. (And the bearing should be presenting about the same distance from the sensor, regardless of where the wheel is in its actual rotation, so this cyclical fluctuation in wheel speed wouldn't make sense to me.)
I considered that the ABS control module is somehow damaged... but is it likely that control module problems would be confined to a single speed sensor? (And, again... that sensor mostly reports the correct wheel speeds... and it correctly changes the code if the sensor is unplugged... so it seems unlikely to me that the main guts of the ABS are involved?)
Is there something related to the ABS that can be reset, or relearned, or tweaked with VCDS?
Does anyone have any ideas for narrowing the problem down to the wiring, the bearing, the sensor, or some larger part of the ABS system?
At this point I will gladly entertain any and all suggestions.
Thanks!
Thanks!
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 22.3.1(x64) Data version: 20220407 DS337.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Tuesday,26,July,2022,10:49:25:45339
VIN: WAUDH74F08N176317 License Plate: AU
Mileage: 311360km-193470mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F
52 53 55 56 61 62 65 72 77
VIN: WAUDH74F08N176317 Mileage: 311360km-193470miles
Self-Diagnosis Log
Page 2
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 H HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0040
Revision: --H21--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 02665 444 100746
VCID: 313F1FE8ED224B33701-8064
VINID: 9D19546071160087811C60C11C2832A8AF
005494 - Right Engine Mount Solenoid Valve (N145)
P1576 - 007 - Short to Ground
Mileage: 311361 km
Date: 2007.05.17
Time: 12:54:48
RPM: 864 /min
Mass Air / Rev.: 125.4 mg/str
Temperature: 88.5°C
Idle
Load: 17.6 %
008304 - Intake Manifold Tuning Valve (Bank 1)
P2070 - 006 - Stuck Open
Fault Status: 00100001
Mileage: 311361 km
Date: 2007.05.17
Time: 12:54:50
RPM: 672 /min
Mass Air / Rev.: 114.5 mg/str
Temperature: 87.0°C
Idle
Absolute Pres.: 351.1 mbar
Self-Diagnosis Log
Page 3
Mileage: 311361 km
Date: 2007.05.17
Time: 13:01:57
RPM: 672 /min
Mass Air / Rev.: 103.6 mg/str
Temperature: 91.5°C
Idle
Load: 16.5 %
Readiness: 0110 0101
Part No SW: 4F5 910 156 HW: 09L 927 156 C
Component: AG6 09L 3.2 FSI USA 0010
Revision: --H04--- Serial number: 4474780
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 6597BBB8E96AD7935C9-8030
Self-Diagnosis Log
Page 4
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Coding: 0020895
VCID: 6695BCB4146CDC8B553-8032
Fault Status: 00100011
Reset counter: 197
Mileage: 311361 km
Date: 2007.05.17
Time: 13:01:00
Hex Value: 0x04C0
Hex Value: 0x4282
Hex Value: 0x0007
Hex Value: 0xA8A2
Hex Value: 0x00FF
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601151373
Coding: 0000003
Shop #: WSC 02324 785 00200
VCID: 2517FBB8A9EA17939C9-8070
Subsystem 1 - Part No: 4F0 910 132 J
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
Self-Diagnosis Log
Page 5
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 303HQ087564271
Coding: 0000003
Shop #: WSC 02335 785 00200
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001141567
Subsystem 3 - Serial number: 0105.08.080000000100010279ÿ
Subsystem 4 - Serial number: 010279ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000054 Serial number: 00000000557674
Coding: 0524326
VCID: 1C61DE5C9AA0D65B337-8048
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H21 0310
Coding: 0012123
VCID: 343116FC12307E1B1B7-8060
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H06 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00146221
Shop #: WSC 02335
Self-Diagnosis Log
Page 6
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
VCID: 2B030D80C30E21E34AD-807E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7H0380827
Coding: 0000100
Reset counter: 156
Mileage: 311361 km
Date: 2007.05.17
Time: 12:20:31
Self-Diagnosis Log
Page 7
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 6N AIRBAG AUDI8RH30 0320
Revision: 16H30000 Serial number: 00359D0J26S%
Coding: 0013902
VCID: 2A0D0884C0F438EBB1B-807E
Subsystem 1 - Part No: 4F0 910 339 B
Component: BF-Gewichtsens. H03 0060
Subsystem 2 - Serial number: 6332CSME3E1561674
Subsystem 3 - Serial number: 6342CSME38704C758
Subsystem 4 - Serial number: 6352QSME1302072C4
Subsystem 5 - Serial number: 6362QSME7C531447L
Subsystem 6 - Serial number: 63734SME73595333$
Subsystem 7 - Serial number: 63834SME6D7B2D01C
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H04000 Serial number: 90026082140181
Coding: 0002241
VCID: 270BF1B0D3E60583AE5-8072
Component: E0221 H02 0030
Part No SW: 4F0 910 930 C HW: 4F0 920 983
Component: KOMBIINSTR. M73 H23 0240
Revision: 00000000 Serial number: 72X328R78
Coding: 2065288
Shop #: WSC 12345 111 45725
VCID: 2313E5A0A7DEE9A3F2D-8076
Self-Diagnosis Log
Page 8
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B08720006B
Coding: E5D59E77703A0600
Shop #: WSC 02145 785 00200
VCID: 2D070398F11A2FD3549-8078
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H47 0350
Revision: 00047008 Serial number: AUZ5ZBH8525188
VCID: 1869C24C6E98BA7B17F-804C
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: 619FAFA8FD42BBB3A01-8034
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H51 1100
Revision: 00000000 Serial number: 395HU087521127
Shop #: WSC 02101 444 54276
VCID: 382922CC0E589A7B37F-806C
Self-Diagnosis Log
Page 9
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Coding: 0035563
Shop #: WSC 02327 785 00200
VCID: 2C010E9CCA0026DB437-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01132720810000
Coding: 4618269
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000105805
Coding: 0000016
Fault Status: 00111011
Reset counter: 197
Mileage: 311361 km
Date: 2007.05.17
Time: 12:29:47
Self-Diagnosis Log
Page 10
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000238259
Coding: 0002014
VCID: 5EE59454CC3C844B9D3-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Coding: 0035563
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0005022
VCID: 2019EAACB6C8F2BBEFF-8074
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Coding: 0000003
VCID: 3FDB49D02B76AD43F65-806A
Self-Diagnosis Log
Page 11
Part No SW: 4E0 910 541 T HW: 4F0 035 541 N
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 379HT087520503
Coding: 0000002
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000133121
VCID: 2411E6BCA2D0EE9B8B7-8070
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2808143863
Coding: 344630393135313035442056413032383038313433383633
Shop #: WSC 00000 512 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0035370
VCID: 2E050494FC1C54CB6D3-807A
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700080076
Coding: 0062221
VCID: 221DE0A4B8C4E0ABF9B-8076
Self-Diagnosis Log
Page 12
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0035370
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005054771
Coding: 0010900
VCID: 2809F28CDEF80AFBA7F-807C
End----------(Elapsed Time: 01:56, VBatt start/end: 12.1V/12.2V)-----------
