- May 27, 2015
- 202
- 132
- Nipomo, CA
- C?ID=149231
Hello folks. Do you have any information on enabling Audi Rest Recommendation? I have entered the green menu and enabled it under device list and set menuoperation to 5. Bussassignment is already factory set to CAN/Komfort. It shows up in the MMI but is grayed out and says it is unavailable. As far as I know I don't believe any additional hardware needs to be added to the vehicle. Any coding ideas?
Heres my autoscan.
Gateway Block Map
Gateway Adaptation Map
Heres my autoscan.
Chassis Type: FP (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 36 3C 42 44 46 47 52
53 56 5C 5F 62 69 6C 6D 72 AC
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CPNB) Labels: 059-907-311-CLA.clb
Part No SW: 8K5 907 401 S HW: 4G0 907 401 E
Component: 3.0TDI EDC17 H14 0001
Revision: 58H14---
Coding: 2A2A4012057603050000
Shop #: WSC 55440 001 1048576
ASAM Dataset: EV_ECM30TDI0118K5907401S 001003
ROD: EV_ECM30TDI0118K5907401S.rod
VCID: 408F6B65DB83AB212EF-8015
8812 - Cylinder 2 Internal Pressure Sensor
P13D1 00 [109] - Short to Plus
Mileage: 17382 km
Date: 2015.05.26
Time: 01:38:04
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 8R0 927 158 Q HW: 0BK 927 156 AM
Component: 0BK 30 TDIUSA H19 1003
Revision: --H19---
ROD: EV_TCMAL551211_AU48.rod
VCID: 4B954C49E2C57879CBD-801E
Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS
Component: ESP8 quattro H09 0020
Coding: 23AD1C03
VCID: 11299E21C86912A9F11-8044
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP
Component: BCM2 2.0 H15 0711
Coding: 0DA54040000000000000
Shop #: WSC 06335 000 00000
VCID: 081FB345BB33536126F-805D
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01190920141164
Coding: 3621228080
VCID: 77FDC0B9C6CD2C995F5-8022
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000893404802
Coding: 26000091867CAFF21100488300003D0D4F9CE708A6090221000008004000010200040034000000
VCID: 7AFBD98DF5DF31F120B-802F
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 140827 H12 0050
Coding: 01DD13
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02005C
Component: E1 - LDS H03 0031
Component: USHL4.2 H30 0030
Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 6 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Address 13: Auto Dist. Reg (J428) Labels: Redir Fail!
Part No SW: 8R0 907 561 A HW: 8R0 907 561 A
Component: ACC3 H11 0100
Coding: 008157
VCID: 377D00B9864DEC999F5-8062
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H51 0812
Serial number: 003NED12HYXB
Coding: 303334313432383132304A55304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4C974F55E7CB7F41C27-8019
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R140000GX4R
Serial number: 6334MSME480E2C00D
Serial number: 6344MSME4879646DV
Serial number: 6352QSME5C460456J
Serial number: 6362QSME4747316EO
Serial number: 63732SME40443466U
Serial number: 63832SME64424D44+
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Revision: -------- Serial number: 90372NIG000A4
Coding: 0000FF
VCID: 44876775C79BB7010A7-8011
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 982 B HW: 8R0 920 982 B
Component: KOMBIINSTR. H35 0564
Revision: 00400000 Serial number: ZDC27399F
Coding: 8BBF22006F01D705020000
VCID: 3A7B198DB55FF1F160B-806F
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z149050B6E
Coding: 80CF07FF00
VCID: 4C974F55EFCB7F41C27-8019
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 M HW: 8K0 907 144 M
Component: DYNAMIKLENK. H06 0730
Revision: 52001005 Serial number: --------------
Coding: 020100
VCID: 39790681B059FAE9691-806C
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02019164747464545425363E00
Shop #: WSC 06325 000 00000
VCID: 7CF7DF95FFEB0FC1327-8029
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000114744385
Coding: 01581B00000000000000
VCID: 428B616DDD8FB93138B-8017
Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0346139735
Coding: 010221
ROD: EV_LaneChangAssis.rod
VCID: 3F8D6899A67DD4D9575-806A
Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000116313843
Coding: 011D13215E00440004
VCID: 4FAD58591EDD4459A75-801A
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8R0 909 144 J HW: 8R0 909 144 B
Component: RCEPS H41 0509
Revision: 00001000 Serial number: 0030925634
Coding: 010001010001
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X.rod
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0347056755
Coding: 0126063A20FA709584A0053600040047
Component: GTO BF H01 0080
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813034061406
VCID: 2D5122D174115649F59-8078
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000117929946
VCID: 4E93455D19D74D51AC3-801B
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 30000000264223
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A7B198DBD5FF1F160B-806F
Revision: AB001007 Serial number: 156I20E8065591
Coding: 020007010000000001
VCID: 2447C7F527DB97012A7-8071
Address 5C: Lane Maintain. Labels: None
Part No SW: 8T0 907 217 A HW: 4E0 907 217 C
Component: J759 HC 0040
Revision: 00H08006 Serial number: 600213910000FA
Coding: 0102104
VCID: 377D00B9464DEC999F5-8062
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 746 F HW: 8R1 035 746 D
Component: H-BNT-NA H41 0812
Revision: -------- Serial number: 204I10E7679622
Coding: 160200060005E9EF7D02AF5E00000403140000000000000000
Subsystem 1 - Part No: 8R0 060 884 CA
Component: NAR 2014 1002
Component: DU7 High H42 0104
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000117821679
Coding: 010C13204000240004
VCID: 46837D7DF1A78511143-8013
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H09 0100
Revision: 1A001001 Serial number: 00008200724693
Coding: 0200000000000000
VCID: 36630DBD81471591843-8063
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-J47A2YG
Coding: 1031010
VCID: 346737B5573B0781BA7-8061
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D711291A471C6C9459-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000116472682
Address AC: Reductant Control (J880) Labels: None
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 142460205
ROD: EV_RDCMA00100.rod
VCID: 2D5122D17C115649F59-8078
Gateway Block Map
;SW:8R0-907-468-P HW:8R0-907-468-D --- CAN Gateway
;Component:GW-BEM 5CAN-M H11 0060, Coding:80CF07FF00
;Monday,22,June,2015,22:07:27:00104
;VCDS Version: Release 14.10.2 Data version: 20150311
;VCID: 4C974F55EFCB7F41C27-8019
Group,Field 1,Data type,Field 2,Data type,Field 3,Data type,Field 4,Data type,
1,11.80 V,,11.80 V,, ,, ,,
2,0x0519,,0x0019,,0.00,, ,,
3,0x00FF,, 1,,0x0403,,0x03FF,,
4,MOST active,, ,, ,, ,,
5,C-CAN active,,P-CAN active,,S-CAN active,,E-Can active,,
6,Generator 1,,BDM 1,,Volt.Stab.1,, ,,
7,250,,0,,0,,0x0000,,
9,8.45 V,,No,, ,, ,,
10,3.50 V,,3.40 V,,No,, ,,
11,117 Ah,,92 Ah,,1,, ,,
13,00000000 00001001,,00000000 00000000,,00000000 00000000,,00000000 00000000,,
14,10.60 V,,0.0 %,,0.000 A,,6.00 s,,
15,OK,,OK,,OK,,OK,,
16,OK,,1,,11,,4,,
17,OK,,2,,11,,No,,
18,11.800 V,,-23.8 A,,23.0°C,,23.0°C,,
19,51.0 %,,50.0 %,,82.0 %,,91.0 %,,
20,3.4 mOhm,,3.2 mOhm,,25 Ah,,12.10 V,,
21,Inactive,,Inactive,,StatCurStg 0,,Yes,,
22,0.00,,0.00,,9997 Ah,,1725 Ah,,
23,Invalid,,Test Complete,,1906,,1861,,
24,OFF,,Inactive,,Inactive,,Overrun,,
25,11111111 11111011,,00000000 00010000,,Inactive,,Inactive,,
26,0.0 A,,0.0 A,,0.0 Nm,,0 W,,
27,1,,Inactive,,Inactive,,Inactive,,
28,00000000 00000000,,00000000 00000000,,00000000 00000000,, ,,
29,1,,0,,10.00 s,,30.0 A,,
30,0300000000000000000000000000000000000000,,
31,0C0C0C0C0C0C0C0C64006400640064006400640064006400,,
32,0A000A000A000A0000000000280028002800280028002800000000000A000A000A000A000A000A00,,
33,0000000000000000000000000000080708075A000B0003006D070D00030070173C003C003C003C00,,
35,33010EFFFFFFBC17391C7E27014B0B00FFFFFFC1030000FFFFFFC1030000020400000304000002040000,,
36,5D010F21220413055D004B0B0003040000010400000104000001040000FFFFFFC1030000,,
37,FFFFFFD2030FFFFFFF8400260972FFFFFF9F014B0B0001040000010400000204000001040000FFFFFFC1030000,,
38,FFFFFFDE030FFFFFFFA41E2E19FFFFFFB318004B0B00FFFFFFC103000003040000020400000304000003040000,,
39,FFFFFFE6030FFFFFFFD4170B11156D024B0B000104000000040000FFFFFFC10300000204000002040000,,
40,0EFFFFFF990D0F22FFFFFFB304FFFFFF9E0300000000,,
41,FFFFFFDA10FFFFFFB30403000200FFFFFF850900001400FFFFFF89021C080000FFFFFFBB003C07000025000000FFFFFFF24400000000FFFFFFF2440000,,
43,0000000000000000000000000000000000000000,,
44,0000000000000000000000000000000000000000,,
45,00000000000000000000000000000000000000000000000000000000000000000000000000000000,,
46,00000000000000000000000000000000,,
47,0000000000000000000000000000000000000000000000000000000000000000,,
48,00000000000000000000,,
49,0000000040000000000012000000FFFFFFB402FFFFFF89000000,,
50,01000100000000000000000000000000000000000000000000000000000000000000000000000000,,
51,0000000000000000000000000000000000000000,,
52,0000000000000000000000000000000000000000,,
53,00000000000000000000000000000000000000000000000000000000000000000000000000000000,,
54,00000000000000000000000000000000,,
55,0000000000000000000000000000000000000000000000000000000000000000,,
56,00000000000000000000,,
57,00000000000000000000000000000000000000000000000000,,
58,0000000000000000000000000000000000000000000000,,
59,000000000000000000000000000000000000000000000000000000000000000000,,
60,0711040401FFFFFF820100,,
61,0000000000000000,,
62,0000000000000000,,
70,FFFFFFB2040F662B3325FFFFFFCE07000204,,
71,FFFFFFB2040F662B3326FFFFFFCE07000204,,
72,FFFFFFB2040F662B3326FFFFFFCE07000204,,
73,FFFFFFB2040F662B3327FFFFFFCF07000204,,
74,FFFFFFB2040F662B3327FFFFFFCF07000204,,
75,FFFFFFB2040F662B3405FFFFFFE807000104,,
76,FFFFFFB2040F662B3406FFFFFFE907000104,,
77,FFFFFFB2040F662B3323FFFFFFCB07000204,,
78,FFFFFFB2040F662B3324FFFFFFCC07000204,,
79,FFFFFFB2040F662B3325FFFFFFCD07000204,,
80,FFFFFFB2040F662B13042700000004,,
81,FFFFFFAF040F36112A080C02000204,,
82,FFFFFFAF040F36112C31FFFFFFAC02000204,,
83,FFFFFFB0040F361135232600000004,,
84,FFFFFFB1040F361301312900000004,,
85,FFFFFFB1040F361302265A00000104,,
86,FFFFFFB1040F3613062C5401000204,,
87,FFFFFFB1040F361307016501000204,,
88,FFFFFFB1040F361307177B01000304,,
89,FFFFFFB1040F36130803FFFFFFA301000304,,
90,FFFFFFAF040F36112B14590200010400004B,,
91,FFFFFFAF040F36112C10FFFFFF910200010400004B,,
92,FFFFFFB1040F36130211490000010400004B,,
93,FFFFFFB1040F36130724FFFFFF8D0100030400004B,,
94,FFFFFFB1040F3613081DFFFFFFC10100FFFFFFC10300004B,,
95,FFFFFFB1040F36130912FFFFFFF20100030400004B,,
96,FFFFFFB1040F3613093A190200FFFFFFC10300004B,,
97,FFFFFFB1040F36130B01590200010400004B,,
98,FFFFFFB1040F562921116A1600010400004B,,
99,FFFFFFAF040F3611283AFFFFFFCA0100010400004B,,
100,FFFFFFB1040F361B0C01FFFFFFC10200,,
101,FFFFFFB1040F66293A39FFFFFFCC2A00,,
102,FFFFFFA1040F2611370B752400,,
103,FFFFFFAB040F262B0001FFFFFF8A0000,,
104,FFFFFFAB040F36111637441400,,
105,6C040FFFFFFFE51B3113000A0000001D00100002000A000A000100,,
106,72040FFFFFFFF51D0F20FFFFFFE4010000001D00150002002F000A000100,,
107,7C040F160A3B32FFFFFFE5120000001E00150002000C000A000100,,
108,FFFFFF80040F3610122DFFFFFF9917000D003F00120002000D0002000100,,
109,FFFFFF9E040FFFFFFFF6121C384B010000001D00140002002A000A000100,,
110,00000000000000000000000000000000000000000000000000,,
111,00000000000000000000000000000000000000000000000000,,
112,00000000000000000000000000000000000000000000000000,,
113,00000000000000000000000000000000000000000000000000,,
114,00000000000000000000000000000000000000000000000000,,
115,0000000000000000000000000000000000000000000000,,
116,0000000000000000000000000000000000000000000000,,
117,0000000000000000000000000000000000000000000000,,
118,0000000000000000000000000000000000000000000000,,
119,0000000000000000000000000000000000000000000000,,
120,Distance 1,,Lanechag.as 1,,Dir.stab.as 1,,Driv.lt.as. 1,,
125,Engine 1,,Airbag 1,,Transm. 1,, ,,
127, ,,SCR Mod 1,, ,, ,,
130,2-Wire,,Cent. Elect. 1,,Central 1,,HVAC 1,,
131,Dr. Door 1,,Pas. Door 1,,RL Door 1,,RR Door 1,,
132,Memory 1,, ,, ,, ,,
133,St. Wheel 1,,El.Ign.Lock 1,, ,,BackupCam 1,,
134,Trailer 1,, ,,Rear lid 1,, ,,
140,Radio 1,,Dig.Soundp. 1,, ,, ,,
143, ,, ,,Info.1 1,, ,,
148,0.00 V,,2000:08:00,,0:00 h,,0 km,,
149,000000000000000000000000000000,,
150,Instruments 1,,ABS 1,,Steer. ang. 1,,Park Brake 1,,
151, ,,Act. Steer 1,, ,, ,,
152,Steering 1,, ,, ,, ,,
195,1.0,,0.0,,0.0,,00000000 00000010,,
196,0.0,,2000:00:00,,00:00,,0,,
197, ,,1000,,13360,,13402,,
200, ,,MOST active,, 1,,OK,,
201,2,,45.0 %,, ,,0x0000,,
203,0.0,,0.0,,0,,255,,
204,000000000000000000000000000000,,
205,--------,,
206,ERROR -- String too Long,,
210, ,,N/A,,N/A,,N/A,,
211,0377,,
212,555F5709,,
213,Active,,1.0,,0.0,, ,,
230,Inactive,,00000000 00000000,,16.0°C,, ,,
236,00000000 00001000,,00000000 00110000,,3,, ,,
;Monday,22,June,2015,22:08:00:00104
Channel,,Field 1,Field 2,Field 3,Field 4,
01,0,N/A,N/A,N/A,N/A,
02,- -,N/A,N/A,N/A,N/A,
03,0,Invalid,Test Complete,N/A,N/A,
04,4F0915105E JCB 240922M1MW,N/A,N/A,N/A,N/A,
05,0,N/A,N/A,N/A,N/A,
06,0,N/A,N/A,N/A,N/A,
07,030000,N/A,N/A,N/A,N/A,
08,0C0C0C0C0C0C0C0C64006400640064006400640064006400,N/A,N/A,N/A,N/A,
09,0A000A000A000A0000000000280028002800280028002800000000000A000A000A000A000A000A00,N/A,N/A,N/A,N/A,
10,0000000000000000000000000000080708075A000B0003006D070D00030070173C003C003C003C00,N/A,N/A,N/A,N/A,
11,,ERROR:,Channel 11,Not,Available,
12,,ERROR:,Channel 12,Not,Available,
13,,ERROR:,Channel 13,Not,Available,
14,,ERROR:,Channel 14,Not,Available,
15,,ERROR:,Channel 15,Not,Available,
16,--,N/A,N/A,N/A,N/A,
17,0,N/A,N/A,N/A,N/A,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
20,,ERROR:,Channel 20,Not,Available,
21,,ERROR:,Channel 21,Not,Available,
22,,ERROR:,Channel 22,Not,Available,
23,,ERROR:,Channel 23,Not,Available,
24,,ERROR:,Channel 24,Not,Available,
25,,ERROR:,Channel 25,Not,Available,
26,,ERROR:,Channel 26,Not,Available,
27,,ERROR:,Channel 27,Not,Available,
28,,ERROR:,Channel 28,Not,Available,
29,,ERROR:,Channel 29,Not,Available,
30,,ERROR:,Channel 30,Not,Available,
31,,ERROR:,Channel 31,Not,Available,
32,,ERROR:,Channel 32,Not,Available,
33,,ERROR:,Channel 33,Not,Available,
34,,ERROR:,Channel 34,Not,Available,
35,,ERROR:,Channel 35,Not,Available,
36,,ERROR:,Channel 36,Not,Available,
37,- - - -,N/A,N/A,N/A,N/A,
38,,ERROR:,Channel 38,Not,Available,
39,,ERROR:,Channel 39,Not,Available,
40,,ERROR:,Channel 40,Not,Available,
41,57856,N/A,N/A,N/A,N/A,
42,,ERROR:,Channel 42,Not,Available,
43,,ERROR:,Channel 43,Not,Available,
44,,ERROR:,Channel 44,Not,Available,
45,,ERROR:,Channel 45,Not,Available,
46,,ERROR:,Channel 46,Not,Available,
47,,ERROR:,Channel 47,Not,Available,
48,10240,N/A,N/A,N/A,N/A,
49,1,1.0,N/A,N/A,N/A,
50,,ERROR:,Channel 50,Not,Available,
51,,ERROR:,Channel 51,Not,Available,
52,,ERROR:,Channel 52,Not,Available,
53,,ERROR:,Channel 53,Not,Available,
54,,ERROR:,Channel 54,Not,Available,
55,,ERROR:,Channel 55,Not,Available,
56,,ERROR:,Channel 56,Not,Available,
57,,ERROR:,Channel 57,Not,Available,
58,,ERROR:,Channel 58,Not,Available,
59,,ERROR:,Channel 59,Not,Available,
60,,ERROR:,Channel 60,Not,Available,
61,,ERROR:,Channel 61,Not,Available,
62,,ERROR:,Channel 62,Not,Available,
63,,ERROR:,Channel 63,Not,Available,
64,,ERROR:,Channel 64,Not,Available,
65,,ERROR:,Channel 65,Not,Available,
66,,ERROR:,Channel 66,Not,Available,
67,,ERROR:,Channel 67,Not,Available,
68,,ERROR:,Channel 68,Not,Available,
69,,ERROR:,Channel 69,Not,Available,
70,,ERROR:,Channel 70,Not,Available,
71,,ERROR:,Channel 71,Not,Available,
72,,ERROR:,Channel 72,Not,Available,
73,,ERROR:,Channel 73,Not,Available,
74,,ERROR:,Channel 74,Not,Available,
75,,ERROR:,Channel 75,Not,Available,
76,,ERROR:,Channel 76,Not,Available,
77,,ERROR:,Channel 77,Not,Available,
78,,ERROR:,Channel 78,Not,Available,
79,,ERROR:,Channel 79,Not,Available,
80,,ERROR:,Channel 80,Not,Available,
81,,ERROR:,Channel 81,Not,Available,
82,,ERROR:,Channel 82,Not,Available,
83,,ERROR:,Channel 83,Not,Available,
84,,ERROR:,Channel 84,Not,Available,
85,,ERROR:,Channel 85,Not,Available,
86,,ERROR:,Channel 86,Not,Available,
87,,ERROR:,Channel 87,Not,Available,
88,,ERROR:,Channel 88,Not,Available,
89,,ERROR:,Channel 89,Not,Available,
90,,ERROR:,Channel 90,Not,Available,
91,,ERROR:,Channel 91,Not,Available,
92,,ERROR:,Channel 92,Not,Available,
93,,ERROR:,Channel 93,Not,Available,
94,,ERROR:,Channel 94,Not,Available,
95,,ERROR:,Channel 95,Not,Available,
96,,ERROR:,Channel 96,Not,Available,
97,,ERROR:,Channel 97,Not,Available,
98,,ERROR:,Channel 98,Not,Available,
99,,ERROR:,Channel 99,Not,Available,
100,,ERROR:,Channel 100,Not,Available,
101,,ERROR:,Channel 101,Not,Available,
102,,ERROR:,Channel 102,Not,Available,
103,,ERROR:,Channel 103,Not,Available,
104,,ERROR:,Channel 104,Not,Available,
105,,ERROR:,Channel 105,Not,Available,
106,,ERROR:,Channel 106,Not,Available,
107,,ERROR:,Channel 107,Not,Available,
108,,ERROR:,Channel 108,Not,Available,
109,,ERROR:,Channel 109,Not,Available,
110,,ERROR:,Channel 110,Not,Available,
111,,ERROR:,Channel 111,Not,Available,
112,,ERROR:,Channel 112,Not,Available,
113,,ERROR:,Channel 113,Not,Available,
114,,ERROR:,Channel 114,Not,Available,
115,,ERROR:,Channel 115,Not,Available,
116,,ERROR:,Channel 116,Not,Available,
117,,ERROR:,Channel 117,Not,Available,
118,,ERROR:,Channel 118,Not,Available,
119,,ERROR:,Channel 119,Not,Available,
120,,ERROR:,Channel 120,Not,Available,
121,,ERROR:,Channel 121,Not,Available,
122,,ERROR:,Channel 122,Not,Available,
123,,ERROR:,Channel 123,Not,Available,
124,,ERROR:,Channel 124,Not,Available,
125,,ERROR:,Channel 125,Not,Available,
126,,ERROR:,Channel 126,Not,Available,
127,,ERROR:,Channel 127,Not,Available,
128,,ERROR:,Channel 128,Not,Available,
129,,ERROR:,Channel 129,Not,Available,
130,,ERROR:,Channel 130,Not,Available,
131,,ERROR:,Channel 131,Not,Available,
132,,ERROR:,Channel 132,Not,Available,
133,,ERROR:,Channel 133,Not,Available,
134,,ERROR:,Channel 134,Not,Available,
135,,ERROR:,Channel 135,Not,Available,
136,,ERROR:,Channel 136,Not,Available,
137,,ERROR:,Channel 137,Not,Available,
138,,ERROR:,Channel 138,Not,Available,
139,,ERROR:,Channel 139,Not,Available,
140,,ERROR:,Channel 140,Not,Available,
141,,ERROR:,Channel 141,Not,Available,
142,,ERROR:,Channel 142,Not,Available,
143,,ERROR:,Channel 143,Not,Available,
144,,ERROR:,Channel 144,Not,Available,
145,,ERROR:,Channel 145,Not,Available,
146,,ERROR:,Channel 146,Not,Available,
147,,ERROR:,Channel 147,Not,Available,
148,,ERROR:,Channel 148,Not,Available,
149,,ERROR:,Channel 149,Not,Available,
150,,ERROR:,Channel 150,Not,Available,
151,,ERROR:,Channel 151,Not,Available,
152,,ERROR:,Channel 152,Not,Available,
153,,ERROR:,Channel 153,Not,Available,
154,,ERROR:,Channel 154,Not,Available,
155,,ERROR:,Channel 155,Not,Available,
156,,ERROR:,Channel 156,Not,Available,
157,,ERROR:,Channel 157,Not,Available,
158,,ERROR:,Channel 158,Not,Available,
159,,ERROR:,Channel 159,Not,Available,
160,,ERROR:,Channel 160,Not,Available,
161,,ERROR:,Channel 161,Not,Available,
162,,ERROR:,Channel 162,Not,Available,
163,,ERROR:,Channel 163,Not,Available,
164,,ERROR:,Channel 164,Not,Available,
165,,ERROR:,Channel 165,Not,Available,
166,,ERROR:,Channel 166,Not,Available,
167,,ERROR:,Channel 167,Not,Available,
168,,ERROR:,Channel 168,Not,Available,
169,,ERROR:,Channel 169,Not,Available,
170,,ERROR:,Channel 170,Not,Available,
171,,ERROR:,Channel 171,Not,Available,
172,,ERROR:,Channel 172,Not,Available,
173,,ERROR:,Channel 173,Not,Available,
174,,ERROR:,Channel 174,Not,Available,
175,,ERROR:,Channel 175,Not,Available,
176,,ERROR:,Channel 176,Not,Available,
177,,ERROR:,Channel 177,Not,Available,
178,,ERROR:,Channel 178,Not,Available,
179,,ERROR:,Channel 179,Not,Available,
180,,ERROR:,Channel 180,Not,Available,
181,,ERROR:,Channel 181,Not,Available,
182,,ERROR:,Channel 182,Not,Available,
183,,ERROR:,Channel 183,Not,Available,
184,,ERROR:,Channel 184,Not,Available,
185,,ERROR:,Channel 185,Not,Available,
186,,ERROR:,Channel 186,Not,Available,
187,,ERROR:,Channel 187,Not,Available,
188,,ERROR:,Channel 188,Not,Available,
189,,ERROR:,Channel 189,Not,Available,
190,,ERROR:,Channel 190,Not,Available,
191,,ERROR:,Channel 191,Not,Available,
192,,ERROR:,Channel 192,Not,Available,
193,,ERROR:,Channel 193,Not,Available,
194,,ERROR:,Channel 194,Not,Available,
195,,ERROR:,Channel 195,Not,Available,
196,,ERROR:,Channel 196,Not,Available,
197,,ERROR:,Channel 197,Not,Available,
198,,ERROR:,Channel 198,Not,Available,
199,,ERROR:,Channel 199,Not,Available,
200,,ERROR:,Channel 200,Not,Available,
201,,ERROR:,Channel 201,Not,Available,
202,,ERROR:,Channel 202,Not,Available,
203,,ERROR:,Channel 203,Not,Available,
204,,ERROR:,Channel 204,Not,Available,
205,,ERROR:,Channel 205,Not,Available,
206,,ERROR:,Channel 206,Not,Available,
207,,ERROR:,Channel 207,Not,Available,
208,,ERROR:,Channel 208,Not,Available,
209,,ERROR:,Channel 209,Not,Available,
210,,ERROR:,Channel 210,Not,Available,
211,,ERROR:,Channel 211,Not,Available,
212,,ERROR:,Channel 212,Not,Available,
213,,ERROR:,Channel 213,Not,Available,
214,,ERROR:,Channel 214,Not,Available,
215,,ERROR:,Channel 215,Not,Available,
216,,ERROR:,Channel 216,Not,Available,
217,,ERROR:,Channel 217,Not,Available,
218,,ERROR:,Channel 218,Not,Available,
219,,ERROR:,Channel 219,Not,Available,
220,,ERROR:,Channel 220,Not,Available,
221,,ERROR:,Channel 221,Not,Available,
222,,ERROR:,Channel 222,Not,Available,
223,,ERROR:,Channel 223,Not,Available,
224,,ERROR:,Channel 224,Not,Available,
225,,ERROR:,Channel 225,Not,Available,
226,,ERROR:,Channel 226,Not,Available,
227,,ERROR:,Channel 227,Not,Available,
228,,ERROR:,Channel 228,Not,Available,
229,,ERROR:,Channel 229,Not,Available,
230,,ERROR:,Channel 230,Not,Available,
231,,ERROR:,Channel 231,Not,Available,
232,,ERROR:,Channel 232,Not,Available,
233,,ERROR:,Channel 233,Not,Available,
234,,ERROR:,Channel 234,Not,Available,
235,,ERROR:,Channel 235,Not,Available,
236,,ERROR:,Channel 236,Not,Available,
237,,ERROR:,Channel 237,Not,Available,
238,,ERROR:,Channel 238,Not,Available,
239,,ERROR:,Channel 239,Not,Available,
240,,ERROR:,Channel 240,Not,Available,
241,,ERROR:,Channel 241,Not,Available,
242,,ERROR:,Channel 242,Not,Available,
243,,ERROR:,Channel 243,Not,Available,
244,,ERROR:,Channel 244,Not,Available,
245,,ERROR:,Channel 245,Not,Available,
246,,ERROR:,Channel 246,Not,Available,
247,,ERROR:,Channel 247,Not,Available,
248,,ERROR:,Channel 248,Not,Available,
249,,ERROR:,Channel 249,Not,Available,
250,,ERROR:,Channel 250,Not,Available,
251,,ERROR:,Channel 251,Not,Available,
252,,ERROR:,Channel 252,Not,Available,
253,,ERROR:,Channel 253,Not,Available,
254,,ERROR:,Channel 254,Not,Available,
255,,ERROR:,Channel 255,Not,Available,
