2010 Audi a6 Quattro Brake change
Cobie90
C?ID=311736
Hey, i was wondering if someone can help me out. I changed my front and rear brakes i followed ross tech instructions open and closed the rear caliper like i was told when i replace the brakes did basic settings after replacement. Basic settings was on and was green but now its red and saying off. I have no fault codes at all thats why i didnt post any. My pedal goes to the floor because no brake fluid is going through my system at all and when i put the car and reverse are drive my car dont move at all. Its like something is wrong with my system without seeing any fault codes. Ill post my scan if needed. Thanks!
EuroX
Northern NJ USA
C?ID=208579
Post auto scan. Also what was changed exactly??
Cobie90
C?ID=311736
Yes, please do.
I change my brakes because the brakes was bad. It stop sending brake fluid to my brakes lines so i thought it was the master cylinder i just replace the master cylinder and it still doing the same thing. When i try to pump them its not getting pressure also my abs light comes on when i press the brakes but my abs module is not showing any codes. The scan is now attached.
Wednesday,27,July,2022,05:39:09:05661
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
VIN: WAUKGAFB7AN036515 License Plate:
Mileage: 238780km-148371mi Repair Order:
Chassis Type: FB-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 47 4C 4F 52 53 55
56 5F 62 6C 72
VIN: WAUKGAFB7AN036515 Mileage: 238780km-148371miles
4C-Tire Pressure II -- Status: Cannot be reached 1100
Address 01: Engine (CCA) Labels:. 06E-907-551-CAJ.clb
Part No SW: 4F1 910 551 D HW: 4F1 907 551
Component: 3.0l V6 TFSI 0050
Revision: --H06--- Serial number:
Coding: 0105000A190F0120
Shop #: WSC 08175 444 103843
VCID: 2412E4F0D2DA9EFB8B7-8070
VINID: 9D195B5D15921D17800C614114B21EF9A6
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 - - Intermittent
Mileage: 238788 km
Date: 2022.07.27
Time: 13:52:28
RPM: 1664 /min
Mass Air / Rev.: 152.6 mg/str
Temperature: 57.0C
Bin. Bits: 00000010
Load: 12.9 %
Readiness: 1110 1001
Part No SW: 4F9 910 156 A HW: 09L 927 156 C
Component: AG6 09L 3,0TFSI USA 0010
Revision: --H04--- Serial number: 4539555
Shop #: WSC 02325 785 00200
VCID: 2A0E0AC8B0FE488BB1B-807E
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AL HW: 4F0 614 517 BA
Component: ESP8 quattro H03 0060
Coding: 0020921
VCID: 6E86C6D84C9664AB2D3-803A
Fault Frequency: 60
Reset counter: 101
Mileage: 238788 km
Date: 2022.07.24
Time: 20:39:07
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0021
Hex Value: 0x418F
Hex Value: 0x00FF
Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602501421794
Coding: 0000007
Shop #: WSC 02324 785 00200
VCID: 2514F9F4D9E067F39C9-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Part No SW: 4F0 910 043 B HW: 4F1 820 043 AL
Component: KLIMABETAETIGUNGH30 0080
Revision: 00000076 Serial number: 00000030563599
Coding: 0524326
Shop #: WSC 02335 785 00200
VCID: 1D64D114F1B0AF33C49-8048
Part No SW: 4F0 910 279 Q HW: 4F0 907 279 A
Component: ILM Fahrer H24 0340
Coding: 0139123
VCID: 372823BC734CE5633E5-8062
Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
01494 - Bulb for Parking Lamps; Left (M1)
Fault Status: 01101011
Reset counter: 101
Mileage: 238788 km
Date: 2022.07.24
Time: 20:39:00
01498 - Bulb for Parking Lamps; Right (M3)
Reset counter: 101
Mileage: 238788 km
Date: 2022.07.24
Time: 20:39:00
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4F0 035 110 A HW: 4F0 035 110
Component: CDC-MP3-Alp H44 0140
Revision: AA001001
VCID: 1574C9340580F7730C9-8040
Address 15: Airbags (J234) Labels:* 4F0-910-655-10.clb
Part No SW: 4F0 910 655 R HW: 4F0 959 655 H
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FA0012RDS
Coding: 303142373034303030314A55304C34463053
ROD: EV_Airba10AURB4.rod
VCID: 36362EB878C61C6B253-8062
Subsystem 1 - Part No SW: 4F0 910 339 B HW: 4F0 959 339 B
Component: BF-Gewichtss. H03 0060
Serial number: 5810000R0000003W4J
Serial number: 3574SRB400009FDD0ABV
Serial number: 3584SRB400009F94E27L
Serial number: 3516HRB402VC0AS50SV6
Serial number: 3526HRB402VC0AS4OKNE
Serial number: 3554NRB40000517EBB79
Serial number: 3564NRB4000051197E1Z
12583424 - Powertrain Databus
U0002 00 [008] - No Communications
[High Speed CAN Communication Bus no signal/communication]
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0530
Revision: 00H05000 Serial number: 90026092900003
Coding: 0012141
VCID: 2708F3FCA3EC75E3AE5-8072
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels:. 4F0-920-xxx-17.clb
Part No SW: 4F0 920 983 H HW: 4F0 920 983 H
Component: KOMBIINSTR. H08 0144
Revision: 00000000 Serial number: CN450YEA9
Coding: 8BD60A050B00CF05020201
Shop #: WSC 02391 823 56573
VCID: 313C1DA491283B53701-8064
Reset counter: 97
Mileage: 238788 km
Date: 2022.07.24
Time: 20:39:29
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0035
Revision: LB100029 Serial number: 2900L09A1700BA
Coding: 000303
VCID: 392C25844958F313C81-806C
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000005650459629
03109 - Tire Pressure Monitoring Control Module 2 (J793)
Reset counter: 100
Mileage: 238788 km
Date: 2022.07.25
Time: 15:10:56
Bin. Bits: 11111
Voltage: 11.90 V
Count: 7
Bin. Bits: 10011
Time: 25.40 s
Fault Frequency: 15
Reset counter: 101
Mileage: 238788 km
Date: 2022.07.25
Time: 15:12:29
Bin. Bits: 10111
Voltage: 11.00 V
Count: 7
Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
Component: MEM-FS H08 0062
Revision: AA000000 Serial number: 00001010017085
Coding: 00581B00004011110000
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000102168472
Coding: 011F57204E40410001
VCID: 46D65E7808A68CEBB53-8012
Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
Component: Komfortgeraet H29 0250
Revision: 02500029 Serial number: 01229654010000
Coding: 4618269
VCID: 353429B4694017732C9-8060
01134 - Alarm Horn (H12)
Fault Status: 01101100
Reset counter: 101
Mileage: 208933 km
Date: 2020.06.29
Time: 14:18:38
02743 - Bulb for Brake/Turn Signal Light; Right
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 99
Mileage: 238788 km
Date: 2022.07.25
Time: 12:51:49
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 035 223 P HW: 4F0 035 223 P
Component: BOSE G3 C6 H01 0100
Revision: AG001300 Serial number: 00000000041814
Coding: 05000000
VCID: 290CF5C4B9F84393B81-807C
Address 4C: Tire Pressure II
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H13 0100
Revision: Serial number: 00000000509539
Coding: 0002014
VCID: 5EE69618BC36F42B9D3-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000102131826
VCID: 45D4597435A087F3BC9-8010
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000222
Shop #: WSC 02145 785 00200
VCID: 211CEDE4CDC88BD3E01-8074
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0060
Coding: 0000026
VCID: 698CB5C475788393781-803C
Subsystem 1 - Part No: -----------
Component: AFS-Modul links
Subsystem 2 - Part No: -----------
Component: AFS-Modul rechts
02071 - Local Databus
Fault Status: 11100100
Reset counter: 97
Mileage: 238788 km
Date: 2022.07.24
Time: 20:39:40
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335J-097535137
Coding: 020000010000000000
VCID: 1D64D114FDB0AF33C49-8048
02788 - Internal Communications Error
Reset counter: 97
Mileage: 238788 km
Date: 2022.07.24
Time: 20:40:44
Bin. Bits: 00000001
Part No SW: 4E0 035 664 A HW: 4E0 035 664 A
Component: H-BN-NA H45 0042
Revision: -------- Serial number: 488J/097520192
Coding: 010200000002E1FE41000304EF6300030000
VCID: 221EE2E8C4CE90CBF9B-8076
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356JX091091752
Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F1 919 611 T
Component: Bedienteil MM H01 0060
Serial number: 00000001422512
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
02244 - Button in Control Head is Stuck
Reset counter: 139
Mileage: 238788 km
Date: 2022.07.25
Time: 12:39:13
Voltage: 11.60 V
Bin. Bits: 10000000 00000000
Bin. Bits: 00000000 00000000
Reset counter: 97
Mileage: 238788 km
Date: 2022.07.24
Time: 20:40:01
Bin. Bits: 00000000 10000000
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000009496373
Coding: 010E57204040220001
VCID: 43D0476C3B94B9C392D-8016
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 D HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H03--- Serial number: 525PA8-J9925BW
Coding: 1000304
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000009496374
End----(Elapsed Time: 01:45, VBatt start/end: 11.6V/11.6V. VIgn 11.5V)-----
Cobie90
C?ID=311736
Ibe posted the scan above this response and what i changed. The traction light is on but when i press the brakes it goes off and the abs light comes on.
JMR
Romania
C?ID=432218
your abs brakes shows a fault code ( System test activated ) .We shall get to that shortly after you explain the following : the fact that you say you have no pressure in the brake pedal you say ? In your abs MVB do you see where it says brake pedal pressure measurement? I can t remember on what channel your brake pessure sensor measures is because i'm too old and can't keep up with all info , but you should start with MVB 001 and go up and see values.When you get to brake pressure, tell us how many bars you see there before you press brake pedal and while you press brake pedal. Perhaps the bleeding of the brakes is not complete.
Please post those values. Also, despite the fact that your abs light is blinking ( we'll get to that later) , you should still have a good mechanical brake at your wheels.
Cobie90
C?ID=311736
Please post those values. Also, despite the fact that your abs light is blinking ( we'll get to that later) , you should still have a good mechanical break at your wheels.
Sytem test is now gone i was able to drive my car down the street and turn 90 degree angle it cleared the test. I did it because i thought that was holding the system from not working properly but the brake system is not coming to a stop immediately and they are brand new brakes on front and rear.
My brake pressure reads -33 bar without pressing them in.
When i press the brakes in it get to about 62.30 bar
Brake pressure(G518) Front Left: N/A
Brake pressure(G519) Front Right: N/A
Reactions: JMR
EuroX
Northern NJ USA
C?ID=208579
Did you bench bleed the master before installing it??
Cobie90
C?ID=311736
No i didn't i installed the master cylinder and just bled the brakes as normal. I thought that would get all the air out that way didnt know i had to bench bleed the master cylinder before hand but want that still let air in the system once i go to put it on after the bench bleed?
JMR
Romania
C?ID=432218
New brakes ( rotors and pads ) tend to be mushy when brand new , they will not freeze the car right away. Pressures seems to be ok..but you will need to grind in those brakes for about 200 kms or so ...then they will have the stopping power. So if brake assembly new , i d suggest you take it easy on the brakes for now and wait for them to grind in
EuroX
Northern NJ USA
C?ID=208579
If you didn't bench bleed the master I would start there and try to get all the air out of the master first. Normally the best the approach is to just crack one of the 2 lines at a time, coming from the master to the abs unit and bleed all the air out.
Cobie90
C?ID=311736
Noted 💯
Cobie90
C?ID=311736
Ok ill give it a try tomorrow i went brought a bleeder kit so i should be able to get all the air out the system now
NZDubNurd
New Zealand
C?ID=230482
Lots of VW/Audi cars have a pressure bleeder recommended. It's intended to be used when using the bleed procedure for the ABS unit on MK5 based cars. I did it on my Touran and the pressure and the automatic fluid replenishment make it get plenty of fluid flowing out of the bleed nipples. The constant flow means the bubbles don't get a chance to float back up brake lines anywhere either... but I think I used about 4 litres of fluid!
