Audi a8 d5 soft close coding
vytosa
Lithuania
C?ID=356403
Hi guys, anyone has coding for soft closing?
I changed door control units door locks added soft close motors and 4 wires to all door. Added power lach installed in all doors, but still get invalid data fault and soft close isnt working
TFSI
Maryland, USA
C?ID=66650
Hi young user, we call something autoscan or full vehicle diagnosis report. Can you provide that so we can make meaning contribution to help?
vytosa
Lithuania
C?ID=356403
Ok in 10min i will do it :)
vytosa
Lithuania
C?ID=356403
Monday,25,July,2022,19:58:13:31322
VCDS Version: 22.3.0.1 (x64)  HEX-V2 CB: 0.4613.4
Data version: 20220225 DS336.1
Workshop Code: 123 02345 023456
VIN: WAUZZZF83JN011008   License Plate: VAIDO
Mileage: 90246km-56076mi   Repair Order:
Chassis Type: F8-AU65 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 19 29 36 39 42 44 46 47 48 52 5B
          5F 61 6C 6D 74 81 A5 AC BA BB BC C4 CC CD D6 D7 DE E0
VIN: WAUZZZF83JN011008   Mileage: 90246km-56076miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
AC-Reductant Control -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Malfunction 0010
BC-Door Rear Pass -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: Cannot be reached 0100
E0-Auxiliary Display 1 -- Status: OK 0000
Address 01: Engine (J623-DDVC)       Labels: None
   Part No SW: 4N0 907 401     HW: 059 907 309 L
   Component: 3.0l V6 TDI   H25 0002
   Revision: CAH25---    CVN: 2A53D53800000000755A2113755A211300000000D6C3ECFE
   Coding: 0A2A4032056E050334086000000400000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114N0907401 001007
   ROD: EV_ECM30TDI0114N0907401.rod
   VCID: 678BB9E76FEA71936E8-8032
   VINID: 9D196AAAA5880DA780041000203F64EABB
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:47:33
                    Engine RPM: 0.00 /min
                    Coolant temperature: 67 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 11.980 V
                    Com st X Set2 Val1-Bits 0-7: 0
                    Com st X Set2 Val2-Bits 0-7: 0
                    Com st X Set2 Val3-Bits 0-7: 220
                    Com st X Set2 Val3-Bits 0-7: 0
                    Com st X Set2 Val4-Bits 0-7: 0
                    Com st X Set2 Val5-Bits 0-7: 0
                    Com st X Set2 Val6-Bits 0-7: 0
                    Com st X Set2 Val7-Bits 0-7: 1
                    Com st X Set2 Val7-Bits 0-7: 0
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 4N0 927 158 C    HW: 0D5 927 156 P
   Component: 0D5  30TDIRdW H05 1004
   Revision: --H05---    CVN: 9E4436B400009238
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002014
   ROD: EV_TCMALX52011_AU65.rod
   VCID: 353723AF65C6D3032C4-8060
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component: V552 ATFP  H01 0705
   Serial number: 180316000030
   Part No SW: 4N0 907 379 AC    HW: 4N0 907 379 P
   Component: ESP9 Premium  H06 0850
   CVN: DB590663
   Coding: 1CAA309D31A30B97119E48911885D2E2F5B9C1380C8CD08812184B47AF9D83
   Shop #: WSC 20893 181 00000
   ROD: EV_ESP9BOSCHCMP_AU58.rod
   VCID: 79AFEF9F095EF76388C-802C
337664 - Databus
          U1121 00 [047] - Missing Message
          [ComScl:_Signal_Group_SG_ACC_07_-_Timeout_error]
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:47:33
                    79 00 00 00 C2 24 00 50 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 28
271360 - Databus
          [ComScl:_Signal_Group_SG_ACC_10-_Timeout_error]
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:47:33
0288 - Databus
          [ComScl:_Signal_Group_SG_ACC_17-_Timeout_error]
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:47:33
                    79 00 00 00 C2 24 00 00 00 00
12618240 - FlexRay Databus 2
          U008A 00 [047] - No Communication
          [FlexRay_controller_channel_B_Global_Timeout]
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:47:33
450048 - Databus
          U1122 00 [175] - Implausible Message
          [Signal_FT_Tuer_Status_invalid_(0)_or_Signal_FT_Tuer_Status_QBit_invalid_(1)]
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:47:39
                    78 00 00 00 C2 24 00 00 00 00
Address 06: Seat Mem. Pass (J521)       Labels:* None
   Part No SW: 4M4 959 760 D    HW: 4M4 959 760 D
   Component: MEM-BFS       009 0042
   Serial number: 00000310905848
   Coding: 0018B6400085BEA148438181A101A10081A100070700878700000000000600
   ROD: EV_SCMPasseSideCONTIAU736.rod
   VCID: 3D273B8F5DF60B43E44-8068
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ800123021840258733
   Coding: BF2F00
   Valve block 2 in front seat passenger side:
   Subsystem 2 - Part No SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Component: N478 VB2 BFSv  H04 0010
   Serial number: SJ80010403181147009F
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V1.clb
   Part No SW: 4N0 907 063 CG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0635
   Coding: 07500143C13900CD270E870818AD8C68131BB31100060493A1000800200096800845013A02560508000003030045001B380000104001F107000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 013006
   ROD: EV_BCM1BOSCHAU651_013.rod
   VCID: 75B7E3AF25469303EC4-8020
   Wiper motor control module:
   Subsystem 1 - Part No SW: 4N1 955 119     HW: 4N1 955 119
   Component: WWS651 180202  052 0913
   Serial number: 904753F0401803301670
   Coding: 7DC727
   Serial number: 21237129X81A955555A0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4N1 941 501 C    HW: 4N1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 19S20.03.1800300074
   Automatic dimming interior mirror:
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE128121723810792
   Interior Light Module:
   Subsystem 5 - Part No SW: 4N0 947 135 BL    HW: 4N0 947 135 BL
   Component: Dachelektroni  H42 0056
   Serial number: 00000120570000000000
   Coding: 100000
   Adjustable Steering Column Control Module:
   Subsystem 6 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA131380000045879143
   Coding: 020100
   Blower 1 for left front backrest:
   Subsystem 7 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V512 LLR1SLvL  H01 0012
   Serial number: L84AI00600396
   Blower 1 for left front seat cushion:
   Subsystem 8 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V514 LLR1SKvL  H01 0012
   Serial number: L84AI00600540
   Blower 1 for right front backrest:
   Subsystem 9 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V516 LLR1SLvR  H01 0012
   Serial number: L84AI00600392
   Blower 1 for right front seat cushion:
   Subsystem 10 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V518 LLR1SKvR  H01 0012
   Serial number: L84AI00600523
   Front windshield washer pump:
   Subsystem 11 - Part No SW: 4N0 907 605     HW: 4N0 907 605
   Component: J1100/SWP  H09 0004
   Serial number: 00000000001803000165
   Coding: 020000
   Interior Light Module 2:
   Subsystem 12 - Part No SW: 4N0 947 111 E    HW: 4N0 947 111 E
   Component: Dachelektroni  H42 0055
   Serial number: 00000119830000000000
65914 - Databus
          [Distance regulation control module: no signal/communication]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:50
                    average_Voltage_terminals: 12.00 V
                    Outside air temperature sensor-Resistance: 0.00 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 25.50 °C
                    interior_temperature: 26.50 °C
                    Vehicle speed: 0.00 km/h
                    Terminal activation-Terminal 75 status: On
                    Terminal activation-Terminal 15 status signal: On
                    Terminal activation-Terminal 15 via CAN: On
                    Terminal activation-Term 75: qualification: OFF
405507 - Functional Limitation due to Energy Management
          B10CD 00 [009] - -
          [Function limitation due to energy management system]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:58
                    System run time-Terminal 15 on: 0 s
Address 13: Auto Dist. Reg
Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
   Part No SW: 4N0 959 655 Q    HW: 4N0 959 655 G
   Component: AirbagVW31    H34 2710
   Serial number: 003PUM009PJ4
   Coding: AAFCF0C30CC00000985400FFF00D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001028
   ROD: EV_AirbaVW31SMEAU65x_001.rod
   VCID: 4ACD60531C38ACFB516-801E
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4N0 980 945 A    HW: 4N0 980 945 A
   Component: BeltPretRevFL  H10 0115
   Serial number: 00AI2018025000100000
   Coding: 0A0301
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4N0 980 946 A    HW: 4N0 980 946 A
   Component: BeltPretRevFR  H10 0115
   Serial number: 00AI2018066004200000
   Coding: 0A0301
   Subsystem 3 - Part No SW: -----------    HW: 480 001 103 18
   Serial number: 3570000000075295DC2R
   Subsystem 4 - Part No SW: -----------    HW: 480 001 103 18
   Serial number: 35800000000B3031FC2K
   Subsystem 5 - Part No SW: -----------    HW: 480 030 903 18
   Serial number: 351001C08C59F210ED2H
   Subsystem 6 - Part No SW: -----------    HW: 480 030 903 18
   Serial number: 352001C08C51F2A0E9DQ
   Subsystem 7 - Part No SW: -----------    HW: 480 031 403 18
   Component: FrontSensor_D  002 0149
   Serial number: 355001C0C328A8D158FP
   Subsystem 8 - Part No SW: -----------    HW: 480 031 403 18
   Component: FrontSensor_P  002 0149
   Serial number: 356001C0C328691139C7
   Driver's side crash data pedestrian protection:
   Subsystem 9 - Part No SW: -----------    HW: 480 032 702 18
   Component: PedP_Sensor_D  002 0149
   Serial number: 228001C0C6E881104834
   Passenger's side crash data pedestrian protection:
   Subsystem 10 - Part No SW: -----------    HW: 480 032 702 18
   Component: PedP_Sensor_P  002 0149
   Serial number: 229001C0C6E84A015BDO
   Center pedestrian protection crash sensor:
   Subsystem 11 - Part No SW: -----------    HW: 480 032 802 18
   Component: PedP_Sensor_C  002 0149
   Serial number: 230001C0CE7391A0889D
   Driver's side crash data pedestrian protection 2:
   Subsystem 12 - Part No SW: -----------    HW: 480 000 703 18
   Serial number: I0M0000000063B1506A$
   Passenger's side crash data pedestrian protection 2:
   Subsystem 13 - Part No SW: -----------    HW: 480 000 703 18
   Serial number: I0N0000000073B1506A+
   Central crash sensor X/Y:
   Subsystem 14 - Part No SW: -----------    HW: 480 021 603 18
   Component: CentrSensorXY  000 0148
   Serial number: I0O00019D2920091F66T
1070336 - Databus
          [NWD: 0x12E ACC_07 Timeout]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:48
1064192 - Databus
          [NWD: 0x2A9 ACC_15 Timeout]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:50
   Part No SW: 4N0 907 129 BQ    HW: 4N0 907 129 BQ
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 015F877F618EAFA3C0C-8054
   Part No SW: 4N0 920 790 D    HW: 4N0 920 790 D
   Component: FBenRDWACC--- H10 0153
   Coding: 858400C07C80000800A3E1609080480008000000
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 313F17BF91AEFF2370C-8064
16777089 - Databus
          [ACC_12 communication error can_error_timeout]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:48
   Part No SW: 4N2 907 468 AB    HW: 4N2 907 468 B
   Component: Gateway       H12 0037
   Revision: 7N010003    Serial number: 0387N787718312
   Coding: 060100050004064073960000005B01325C98004018000000097D078E10000000
   GVL: 71503C000844000002BC88000002C800810B0010000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003150
   ROD: EV_CGateCONTIAU491_003_AU58.rod
   Subsystem 1 - Part No SW: 4N0 951 523     HW: 4N0 951 523
   Component: E221__MFL  H06 0003
   Serial number: 00000000000000000000
   Subsystem 2 - Part No SW: 4N0 915 181 A    HW: 4N0 915 181 A
   Serial number: 75885402001803120161
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 4N0 907 155     HW: 4N0 907 155
   Component: U13  DCAC  H13 0017
   Serial number: 00000000000000000180
131589 - Control Module for Brake Electronics
          U13BF 00 [009] - No Communication on 2nd Bus
          [Timeout_Node_0x05_DiagAdress_03_ESP]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:48
8519683 - Energy Management Active
          U140B 00 [009] - -
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:48
                    EM_vehicle_state: 22 1C
                    Static current shut-off stage: Deactivation stage 1
                    Auxiliary heater activation restriction request-Parking heater: Permitted
                    Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
131721 - Laser Sensor for Adaptive Cruise
          U139B 00 [009] - No Communication
          [Timeout_Node_0x89_DiagAdress_CD_Laserscanner]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:48
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
          [Timeout_Node_0x57_DiagAdress_13_ACC]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:48
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 80A 907 397 D    HW: 80A 907 397 D
   Component: LCM_MLBevo    H07 0022
   ROD: EV_LCMLeftCONTIAU426_VW53.rod
   VCID: 303912BB9AA4F62B7F2-8064
   Component: MEM-FS        009 0042
   Serial number: 00000310906355
   Coding: 00189EC00085BEA1480301012101210081A100070700878700000000004600
   ROD: EV_SCMDriveSideCONTIAU736_006.rod
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ800123021840258731
   Coding: BF2F00
   Valve block 2 in front seat driver side:
   Component: N476 VB2 FSv  H04 0010
   Serial number: SJ8001040318114700A2
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 4M1 959 793 C    HW: 4M1 959 793 B
   Component: TSG FS006 0848
   Serial number: YE007REH36862
   Coding: 001FCA00520004C2A009B006
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 3FDB418757FA1953F68-806A
196692 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:48
196676 - Door Warning / Entry Lighting
          B1775 01 [009] - Electrical Failure
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:54
   Part No SW: 4N0 909 144 C    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H20 0503
   Coding: B4000101010000
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
3149825 - Databus
          [COMI_TIMEOUT_ACC10]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:47:33
                    FreezeFrame_mw_120C_Timeout-Engine RPM: 0.00 /min
                    FreezeFrame_mw_120C_Timeout-System status: 0
                    FreezeFrame_mw_120C_Timeout-Terminal 30 power supply: 12.09 V
                    FreezeFrame_mw_120C_Timeout-Terminal 15 status measured: On
                    FreezeFrame_mw_120C_Timeout-Engine steering torque sensor: average value: 0.00 Nm
                    FreezeFrame_mw_120C_Timeout-Terminal 15 resulting: On
                    FreezeFrame_mw_120C_Timeout-Terminal 15 status signal: On
                    FreezeFrame_mw_120C_Timeout-Steering pinion angle: offset corrected: -6.33 °
                    FreezeFrame_mw_120C_Timeout-ARA_signal_red_cyclic: 00
                    FreezeFrame_mw_120C_Timeout-PLA_signal_red_cyclic: 00
                    FreezeFrame_mw_120C_Timeout-SCU state: System OK
                    FreezeFrame_mw_120C_Timeout-Steering_angle_sender_status: System OK
   Part No SW: 4N0 907 064 AG    HW: 4N0 907 064 G
   Component: BCM2 MLBevo H14 0128
   Coding: 013400000FB000606309A0040C00090E0B004000844F06502F0400200504823F001F0100010001
   ASAM Dataset: EV_BCM2CONTIAU651 007005
   ROD: EV_BCM2CONTIAU651_007.rod
   VCID: 74B1DEAB2E3C8A0BDBA-8020
   ID - sensor:
   Component: ID-Geber  0231
   Subsystem 2 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY180232EUP
   Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000099942468
   Subsystem 4 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58408092
   Rear spoiler control module:
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAJKC007UEF
   Coding: 0156010000AAAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001011
   VCID: 2411EEEBDE5C5A8B8BA-FFFE
Address 48: Seat, Rear, DS (J876)       Labels:* None
   Part No SW: 4M1 959 760 C    HW: 4M1 959 760 C
   Component: MEM-FS-Fond   009 0042
   Serial number: 00000301821556
   Coding: 000892800080B0A14A0099B9009900000000009F9F00000000000000001000
   ASAM Dataset: EV_SCMRearDriveCONTIAU651 001003
   ROD: EV_SCMRearDriveCONTIAU651_AU58.rod
   VCID: 392F2F9F49DE3763C8C-806C
   Driver side rear seat switch module:
   Subsystem 1 - Part No SW: 4N0 959 819 A    HW: 4N0 959 819 A
   Component: E683 - SBM  H04 0054
   Serial number: G11S24.02.1800100014
   Valve block 1 in rear seat driver side:
   Subsystem 2 - Part No SW: 4N0 907 182 C    HW: 4N0 907 182 C
   Component: N479 VB1 FSh  H04 0011
   Serial number: SJ800124011840258439
   Coding: AC2F00
   Valve block 2 in rear seat driver side:
   Subsystem 3 - Part No SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Component: N480 VB2 FSh  H04 0010
   Serial number: SJ80010403181147011F
   Part No SW: 4M1 959 792 C    HW: 4M1 959 792 B
   Component: TSG BFS006 0848
   Serial number: YE007RDJ26236
   Coding: 001FCA005E0004C2A009B004
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   VCID: 3E253C8350F0105BFDE-806A
          B2005 00 [009] - -
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:48:14
196660 - Motor for Window Regulator
          B1487 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:48:14
196739 - Lamp for Interior Door Handle Illumination
          B11FB 13 [009] - Open Circuit
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:48:17
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:48:17
196721 - Lamp for Ambient Illumination
          B1325 13 [009] - Open Circuit
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:48:17
196889 - Dimming for Switch Illumination
          B132B 13 [009] - Open Circuit
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:48:20
Address 5B: Seat,Rear,PS (J877)       Labels:* None
   Component: MEM-BFS-Fond  009 0042
   Serial number: 00000301830003
   Coding: 000896800080B0A14A0099B99B99BB000000009F9F00000000000000001000
   ASAM Dataset: EV_SCMRearPasseCONTIAU651 001003
   Passenger side rear seat switch module:
   Component: E688 - SBM  H04 0054
   Valve block 1 in rear seat passenger side:
   Component: N481 VB1 BFSh  H04 0011
   Serial number: SJ80011502184025835D
   Coding: AC2F00
   Valve block 2 in rear seat passenger side:
   Component: N482 VB2 BFSh  H04 0010
   Serial number: SJ800104031811470118
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4K0 035 064 D    HW: 4N0 035 064 A
   Component: MU-H-LN-EU    045 2711
   Coding: 0156010100000000C3110002000800302F0001E401F008008E
   ROD: EV_MUHigGen2pALPI_AU27.rod
   VCID: 2517F3EFD566A3839C4-8070
   Data carrier:
   Subsystem 1 - Part No: V03 959 807 SD
   Component: MIB2P_EU_Q320  0480
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4N0 919 605 K    HW: 4N0 919 605
   Component: DU AU651 Top  H42 0147
   Serial number: INX00109021800040178
   Compact disc data bank:
   Component: Gracenote2  1006
   Volume Control 1:
   Subsystem 4 - Part No SW: 4N1 919 616 B    HW: 4N1 919 616
   Component: LSR-D5/C8  H33 0110
   Serial number: 00004418000045475036
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4N0 919 603 C    HW: 4N0 919 603
   Component: DU AU651 Bot  H41 0147
   Serial number: INX00116011800050416
   Media Player 1:
   Subsystem 6 - Part No SW: 4N0 035 123     HW: 4N0 035 123
   Component: DISC PLAYER  H06 0006
   Serial number: AUZ8ZCHKJ005D6
   Media socket:
   Subsystem 7 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051800136220005
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:50
                    Voltage terminal 30: 11.8 V
                    BAP-BAP_Function_ID: 02
Address 61: Battery Regul. (J1120)       Labels: 4N0-915-105.clb
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 290FFFDFB97E87E3B8C-807C
Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
   Part No SW: 4M0 980 556 A    HW: 4M0 980 556 A
   Component: RVC Compact   H18 0250
   Coding: 0235060102002001C20040
   Shop #: WSC 31414 032 00001
   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
   ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
   VCID: 33331DB76BB2CD33020-8066
   Part No SW: 8W5 959 107 B    HW: 8W5 959 107
   Component: HDSG-Modul    H13 0163
   Revision: --------    Serial number: 31813083200000
   Coding: 1430
   ASAM Dataset: EV_DeckLidCONTIAU736 001015
   ROD: EV_DeckLidCONTIAU736_VW27.rod
   VCID: 45D7536F35264383BC4-8010
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4N0 907 777 AE    HW: 4N0 907 777 B
   Component: Fahrwerk-SG   H51 2016
   Serial number: 1103180443
   Coding: 105C483BFA40
   ASAM Dataset: EV_ChassContrContiAU651 001011
   ROD: EV_ChassContrContiAU651_001_AU58.rod
   VCID: 7DA7FB8F1D76CB43A44-8028
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130267349
   Coding: 303030
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 4N1 713 041 E    HW: 4N1 713 041 E
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 18022246120242
   ASAM Dataset: EV_GSMWaehlZFAU736 001017
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 2809FADBA274BEEBA72-807C
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* 4N0-907-107-V2.clb
   Part No SW: 4KE 907 107 AB    HW: 4N0 907 107 G
   Component: zFAS Var B    H08 0291
   Coding: 0401840000000000000C060000D0442C181F56000000000000000000000000000019000000000000000000000000000000000000000000000000400000000000000078D0008000B000800080000000000080400000A0
   ASAM Dataset: EV_ZFASAU516 001005
   ROD: EV_ZFASAU516_001.rod
   VCID: 7F5B0187177AD953B68-802A
10 Faults Found:
2113539 - FlexRay Databus 2
          U008A 00 [008] - No Communication
          [Fr_NoCommunicationBEvent]
                    Reset counter: 114
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:47
                    Supply voltages-Supply voltage Terminal 30 - internal: 0.00 V
                    Supply voltages-Terminal 30: 12.00 V
                    Supply voltages-Terminal 30 local: 12.00 V
2114714 - Databus
          [TIMEOUT_LRR1_WZO]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:48:38
                    Supply voltages-Terminal 30: 11.80 V
                    Supply voltages-Terminal 30 local: 11.90 V
2114719 - Databus
          [TIMEOUT_TCI_PS]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:48:38
2114850 - Databus
          [TIMEOUT_ACC_17]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:48:37
2114895 - Databus
          [TIMEOUT_LRR1_SensorHeader_H]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:48:38
2113695 - Databus
          [TIMEOUT_LRR1_SensorHeader]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:48:37
2113742 - Databus
          [TIMEOUT_LS1_SensorHeader]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:48:42
                    Supply voltages-Terminal 30: 11.90 V
2114802 - Databus
          [TIMEOUT_LRR1_SensorHeader_02]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:48:47
2114803 - Databus
          [TIMEOUT_LS1_SensorPos]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:48:47
2113665 - Databus
          [TIMEOUT_ACC_06]
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:48
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0006
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736_VW53.rod
   VCID: 323D18B394A8C43B096-8066
0003 - Control Module for Reductant Metering System; Voltage Suppy
          P21CA 00 [013] - Electrical Malfunction
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:47:34
                    Terminal 30A voltage: 0.00 V
                    Terminal 30B voltage: 11.94 V
                    Supply voltage for external components: 4.98 V
                    Reducing agent quality sensor: voltage terminal 31: 0.00 V
                    Pump for reducing agent: speed: 0 /min
                    Pump for reducing agent: current: 0.00 A
                    Reducing agent pump: operating state: OFF
                    Reducing agent pump: activation: 0.00 %
                    Reducing agent pump: end stage activation status: not active
                    Reducing agent pump: end stage temperature: 27 °C
                    Heating circuit 1 f. red. agent metering sys.: end stage temp.: 23 °C
                    Sensor for reducing agent tank temperature: temperature: 23 °C
                    Pressure sensor for reducing agent: voltage: 0.73 V
                    Sensor for reducing agent fill level: fill level height: 92 mm
                    Reducing agent quality sensor: urea concentration: 106.50 %
                    Sensor 2 for temp. reducing agent: act. value: 82.00 °C
                    Heating circuit 1 for reducing agent: power: 0 W
                    Heating circuit 1 for reducing agent: power set value: 0 W
                    Heating circuit 1 for reducing agent: power limitation: 130 W
                    Heating circuit 3 for reducing agent: power: 0 W
                    Heating circuit 3 for reducing agent: power set value: 0 W
                    Heating circuit 3 for reducing agent: power limitation: 78 W
                    Heating circuit 2 for reducing agent metering: power: 0 W
                    Heating circuit 2 for reducing agent metering: activation: not active
                    Dataset_Elements: F81049
Address BA: Motor Mounts (J931)       Labels: None
   Part No SW: 4M0 907 145 E    HW: 4M0 907 145 B
   Component: AEMevo        H10 0132
   ASAM Dataset: EV_AEMZFAU736 006014
   ROD: EV_AEMZFAU736_006.rod
   Part No SW: 4M1 959 795 C    HW: 4M1 959 795 B
   Component: TSG HFS006 0848
   Serial number: YL006TIE20307
   Coding: 000FCA00020004C2A008B004
   VCID: 41DF477F210E6FA380C-8014
          B2005 00 [009] - -
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:48
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:47
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:50
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:55
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:50
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:54
   Component: TSG HBFS006 0848
   Serial number: YL006TIE20282
   Shop #: WSC 02345 123 23456
          B2005 00 [009] - -
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:48
196738 - Motor for Child Safety Lock
          B14FF 29 [009] - Signal Implausible
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:48
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:51
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:52
                    Reset counter: 74
                    Mileage: 90246 km
                    Date: 2022.07.25
                    Time: 19:46:51
Address C4: DC/DC Converter (A7)       Labels: 4M0-959-663.clb
   Part No SW: 4M0 959 663 C    HW: 4M0 959 663 C
   Component: PCU10         022 0324
   ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
   ROD: EV_DCDC48V210ABOSCHAU736.rod
   VCID: 3A2D30934CD83C7BC16-806E
Address CC: Starter-Generator (----)       Labels:* None
   Part No SW: 4N0 903 028 H    HW: 4N0 903 028 H
   Component: BSG-HP1-65    H16 0523
   Serial number: 16031800010094
   Coding: 28000000000000
   ASAM Dataset: EV_Start48VAU651 001006
   ROD: EV_Start48VAU651_001.rod
Address CD: Laser Scanner
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 BA    HW: 7PP 941 592 B
   Component: LED1L         H09 4002
   ROD: EV_LEDModLeftMELCOAU736_VW51.rod
   VCID: 1869CA1B12140E6B172-804C
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H09 4002
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502     HW: 4N0 035 502
   Component: WLC Front     H06 0042
   Coding: 800000
   ROD: EV_Charg1MobilDevicAU651.rod
   VCID: 619FA7FF81CE0FA3A0C-8034
Address E0: Auxiliary Display 1 (E857)       Labels: None
   Part No SW: 4N0 035 705 A    HW: 4N0 035 705
   Component: E859          H41 0019
   Serial number: KE0 MK900073419
   ASAM Dataset: EV_SCC1AU651 001004
   ROD: EV_SCC1AU651.rod
   VCID: 270BF9E7AF6AB193AE8-8072
End----------(Elapsed Time: 03:05, VBatt start/end: 11.9V/14.3V)-----------
vytosa
Lithuania
C?ID=356403
VCDS doesnt show coding bit information, so i changed with vcp in all 4 doors power latching coding installed
and in 46 added easy close active. still i dont make them work
siLc
Tallinn, Estonia
C?ID=330192
Brand new door modules? They need to be parameterized, which you can do with VCP. Then you can get rid of "invalid data record" DTC-s and perhaps things will start working.
vytosa
Lithuania
C?ID=356403
Thanks will try tomorrow to upload zdc files
vytosa
Lithuania
C?ID=356403
VCP doesnt has 4m1959792c only with letter j and its for q5.
siLc
Tallinn, Estonia
C?ID=330192
Is this a VCP support forum? ;)
vytosa
Lithuania
C?ID=356403
Maybe anyone has a8 coding with soft close? Wont to check if i did all good with coding
vytosa
Lithuania
C?ID=356403
All done and working :) if anyone will need info write :)
