A/C doesn't work
awdemers2
C?ID=497269
A couple of weeks ago I was driving at freeway speed and the serpentine belt mysteriously snapped (broke, not slipped off). This was accompanied by a blue/green ish colored oil (not wiper fluid, it was thick, like oil). I replaced the belt and was on my way. Ever since, the A/C has not worked in my car. I'm not sure if these things are related or not, but I see that there are some hvac related trouble codes so hopefully someone can assist.
Sunday,24,July,2022,16:28:21:45990
VIN: WAULC68E04A024271   License Plate:
          67 69 75 76 77
VIN: WAULC68E04A024271   Mileage: 156810km-97437miles
Address 01: Engine        Labels: 06B-909-518-AMB.lbl
   Part No SW: 8E0 909 518 AK    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0003
   Coding: 0016751
   Shop #: WSC 63351 000 00000
   VCID: 79AFE55915C268A3881-5160
   VINID: 9D195C4C621500444008408704FD408823
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
            P1103 - 008 - Performance too Low - Intermittent
18043 - Powertrain Data Bus
            P1635 - 008 - Missing Message from A/C Controller - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
            P1297 - 002 -
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 8E0 927 156 S
   Component: AG5 01V 1.8l5VT USA 1212
   Coding: 0001002
   VCID: 3E2536454C6C8F9BFD3-5160
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      3429
   Coding: 04277
   Shop #: WSC 12345
   VCID: 2615FE25B1FC375B953-51F2
   Part No: 8E0 820 043 AD
   Component:   A4 Klimaautomat   1219
   Coding: 00000
   Shop #: WSC 63351
   VCID: 6393A731824E8273B2D-513C
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  USA 0517
   Coding: 00003
   Shop #: WSC 63351
   VCID: 353729697C5A4CC32C9-4B00
01800 - Light Switch (E1)
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 C
   Component: Airbag 8.4EP        3000
   Coding: 0010607
   VCID: 372B23616356BED33E5-5184
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0308
   Coding: 00041
   Shop #: WSC 63351
   VCID: 3E253645496C8F9BFD3-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 950 L
   Component: KOMBI+WEGFAHRS. RB4 D36
   Coding: 03200
   Shop #: WSC 00001
   VCID: 323D12758D345BFB09B-5160
   WAULC68E04A024271     AUZ6Z0C0126781
01304 - Radio
   Part No: 8E0 959 433 BB
   Component: Komfortgerát T7B    1311
   Coding: 11788
   Shop #: WSC 63351
   VCID: 72BDD2754DB41BFBC9B-4B00
   Subsystem 1 - Part No: 8E1959801
   Component: Tõrsteuer.FS BRM 0003
   Component: Tõrsteuer.BF BRM 0003
            29-00 - Short to Ground
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 - -
01562 - Rear right door
            59-10 - Can't Unlock - Intermittent
   Part No: 8E0 035 195 H
   Component: symphony II NP2    0260
   Coding: 01201
   Shop #: WSC 02048
   VCID: 2C010C0DAF200D0B437-5042
End----------(Elapsed Time: 05:43, VBatt start/end: 12.3V/12.3V)-----------
chillout1983
C?ID=162783
Sounds a bit like you have lost your gas the green liquid is likely uv dye (tracer) possibly it has blown the (PRV) pressure relief valve this would blow on excessive discharge pressure , as for the belt snapping the compressor could have locked up or was the system overcharged originally. I would force your Radiator fans on and then have the Refrigerant charge checked.
Not sure what the "blue/green ish colored oil" would be. I don't think A/C compressor oil is that color, but what else could it have been? Have you done a visual inspection of the A/C compressor and all the A/C related plumbing?
Your HVAC module seems to think you have too little pressure in the system. Take a look at what you have in MVB 001.4 (which should be the pressure reading from that sensor) and MVB 002 (Compressor cut-off conditions).
awdemers2
C?ID=497269
001-4 is 1.0 bar - refrigerant pressure
002-1 is 5.0 current shut-off criteria
i'll look and see if there's anything obvious leaking or broken.
1.0 bar is too low. However, I'm not sure if that reading is "absolute" or "gauge".
5.0 for the shut-off criteria is "Engine not running or less than 300 RPM".
You might want to check both again with the engine at idle and the controls calling for A/C.
  • Agree
Reactions: JMR
EuroX
Northern NJ USA
C?ID=208579
I would assume possibly the ac compressor seized/grenaded and broke the the oil that was see could of been dye mixed with very fine grayish fine metal mixed with dye as this vehicle has a clutch type ac compressor and no N280 IIRC, also 1.0 bar is way to low could be empty. However intermittent fault for the high pressure switch. Fault could be intermittent since the ac compressor does not work therefore the fault will not be static. I think we need more information. With engine running turn ac on also make sure econ is off on hvac head. If you hit econ button it turns off and turns on it usually mean there is less than 200grams in the system meaning you have a leak,or a ac component possibly failed and leaks freon like the compressor,however let's not jump to conclusions just yet, one step at a time. Can you post complete MVB value for MVB 001,002 and 003. All 4 fields from each mvb??
JMR
Romania
C?ID=432218
yes it is if it had dye inserted in it . Mostly green like color...
JMR
Romania
C?ID=432218
Today i went to a garage where they had an A6 2007-8 ish , on which they put a brand new QWP ac compressor and the solenoid valve was defective stating that it's shorted to ground..( imagine that ). They switched it to a brand new Nissens compressor and troubles gone..hmm...brand new compressor defective , how the hell did it pass QC ?
