Software Release 22.3.1 VS older versions (Group numbers, measuring blocks, basic settings)
gazayerly82
UAE
C?ID=523123
Dear Members,
I would like to get your advise/explanation regarding the differences i can see between the latest VCDS software release i am currently using (downloaded from ross tech website) and the older versions i see on youtube and on ross tech you tube channel and on the basic setting directions issued on Wiki Ross Tech site.
The latest version is not showing measuring blocks 08 for all control units on my car, not showing groups for any basic setting for any module. it is giving me only limited options from drop down menu.
An example for abs module basic setting is illustrated in the RossTech video link "
". i can not use groups as shown in this video, i have only drop down menu of options, that i can not determine 100% sure which one is matching to ross tech wiki instructions of doing basic settings.
i have a screen shot of an example of this drop down menu in my software but i am unable to attach here.
I hope my problem explanation is clear and i can have your advises on that.
VCDS has not changed. What you see there is still applicable to the control modules in that video and others. What has changed is the protocol used by control modules in newer cars. See:
gazayerly82
UAE
C?ID=523123
So, to perform any type of maintenance that may require a basic setting, i need to select a suitable function from the related module's dropdown menu. And to di that, i might need to make a post here and ask for guidance? Since the wiki is showing only the guidance for non uds protocol modules.
Or there is some guide to help in the uds protocol basic settings?
No, the wiki also has guidance for a some UDS modules. But UDS does have an unfair advantage. Instead or arbitrary group or channel numbers, the channels all have descriptive names.
Some additional context would be good here. What exactly are you trying to do, and on what control module?
gazayerly82
UAE
C?ID=523123
Thanks Uwe for the response.
I recently had a reset for the ABS module in my skoda 2017 model car (which i restored successfully and cleared all faults). Before doing that and while resenting, i tried to find guidance / directions on this issue and its related basic settings (based on a UDS protocol) but unfortunately i didn't find a 100% related topics on Ross tech wiki.
The link i am attaching --> "http://wiki.ross-tech.com/wiki/index.php/Diagnostic_Procedures#Skoda" is showing diagnostic procedures. For the skoda, it is showing octavia II (2005+). while there is for example my car is Octavia III which is not there.
Somehow i managed to get things done for this module issue. As another context, i changed a damaged A/C blower fan and resistor and i am not 100% sure if i need to perform a basic setting on the HVAC module or not. This is also not there in Wiki , i believe, or at least not for a UDS protocol.
I hope my explanation is clear.
JMR
Romania
C?ID=432218
would you provide an auto-scan ?
gazayerly82
UAE
C?ID=523123
Hi JMR, i am not discussing about this. my query is about the UDS protocol drop down menus for basic settings (for the sake of examples i mentioned the HVAC blower fan issue and if i need to perform basic setting or no).
Also as i mentioned; for Octavia III and later versions, there are no "diagnostic procedures" on wiki.
JMR
Romania
C?ID=432218
i was just curious to see what errors your car will show , but then it's optional if you want to post it or not. However , seeing how your car is configured might jar the memories of members on procedures. I for one cannot remember procedures out of top of my head to save my life and i do see at least 5-10-15 cars a day for diverse adaptations, settings, errors,repairs and what not.
gazayerly82
UAE
C?ID=523123
I understand.
Ok, Let me post the following scan which was done earlier. The errors shown are no more active.
Please note that when i go to advanced measuring values in HVAC, i can see that the control unit is reading the voltage at the fan terminal, but it is not reading the current and speed and some other parameters. In Wiki i have seen some non UDS protocol procedures talking about making basic setting for the car's HVAC module when changing the fan, Please refer to this link for example " "
Monday,18,July,2022,20:58:54:57643
VIN: TMBAN6NE1H0140339   License Plate: 75810
Mileage: 117157km-72797mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 36 42 44 52 55 5F
VIN: TMBAN6NE1H0140339   Mileage: 117157km-72797miles
Address 01: Engine (J623-CWVA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 057 AF    HW: 04E 907 309 AH
   Component: R4 1.6l MPI   H24 9127
   Revision: 31H24000    CVN: E1593F0B
   Coding: 011A0052032400001000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM16MPI01104E906057AF 001015
   ROD: EV_ECM16MPI01104E906057AF_VW37.rod
   VCID: 6B83CADEE30BE2E30AD-803E
   VINID: 91D4917867950580011000C324A733B659
5649 - Throttle Control
          P3078 00 [109] - Airflow at Idle too Low
                    Mileage: 116915 km
                    Date: 2022.07.15
                    Time: 18:59:36
                    Engine RPM: 758.50 /min
                    Normed load value: 33.7 %
                    Coolant temperature: 87 °C
                    Intake air temperature: 64 °C
                    Voltage terminal 30: 13.499 V
                    Mass flow through throttle valve: 10.3 kg/h
                    Engine operating condition: Idle
9025 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0106 00 [038] - Implausible Signal
                    Mileage: 116890 km
                    Date: 2022.07.15
                    Time: 18:35:50
                    Engine RPM: 723.00 /min
                    Normed load value: 37.6 %
                    Coolant temperature: 81 °C
                    Intake air temperature: 69 °C
                    Voltage terminal 30: 13.923 V
   Part No SW: 09G 927 158 AH    HW: 09G 927 158
   Component: AISIN AG6 G3  204 3178
   CVN: AA13569E
   Coding: 010100000C000000000000000000000000000000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW23.rod
   VCID: 79AFE09699574073881-802C
25548 - Implausible Data Received from Engine Control Module
          U0401 00 [042] - -
                    Reset counter: 126
                    Mileage: 116890 km
                    Date: 2022.07.15
                    Time: 18:35:51
                    Engine RPM: 730.5 /min
                    Transmission input speed: 710 /min
                    Engine torque: 8 Nm
                    ATF temperature: 81 °C
                    Accelerator pedal position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    Electrical Oil Pump target revolution: 65534 /min
                    Electrical Oil Pump actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
                    Electrical Oil Pump target current: 65278 mA
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 63316000000800
   Coding: 1A076A911424216C407A060340CC245856288402600224320043F070C002430000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036_SK37.rod
   VCID: 00598D72FA8D11BBCFF-8054
8291 - Databus
          [FCAN: MO_QBit_Motormomente signal is invalid]
                    Reset counter: 170
                    Mileage: 116890 km
                    Date: 2022.07.15
                    Time: 18:35:51
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 170
                    Mileage: 116901 km
                    Date: 2022.07.15
                    Time: 18:46:49
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0423762389
   Coding: 032C0C
   Shop #: WSC 73430 790 00000
   VCID: 3B233A9ED3EBB263DAD-806E
   Part No SW: 5E0 907 044 AB    HW: 5E0 907 044 AB
   Component: Climatronic   H04 1601
   Revision: 00001K07
   Coding: 01010004000100010005004012101002
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 6597BCE605EFD4935C9-8030
   Air quality sensor:
329988 - Motor for Defroster Flap
          B1090 71 [008] - Actuator Stuck
                    Reset counter: 170
                    Mileage: 116982 km
                    Date: 2022.07.18
                    Time: 09:22:16
                    Voltage terminal 30: 12.5 V
                    Outside temperature: 40.0 °C
                    Inside temperature: 48.6 °C
                    Defroster flap: actual value: 231
                    Defroster flap: actual value: 88.0 %
                    Defrost door - Specified value: 250
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Serial number: 01061632901754
   Coding: 0C111A42404722FB47E04000000C07000800000000000000000000000000
   Shop #: WSC 73430 790 12345
   ROD: EV_BCMBOSCH_015.rod
   VCID: 04518162EE950D9BEB7-8050
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 161027  041 0570
   Serial number:         161111082639
   Coding: 065DDD
   Component: RLHS  042 0105
   Serial number: S7Y16M11D28H14M36S18
   Coding: 00885D
   Sunroof control module:
   Subsystem 3 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS72.403  H03 0004
   Serial number: 0000FST001A360K00000
   Coding: 981803
5898 - Bulb for Rear Left Side Turn Signal
          B12D0 15 [009] - Open or Short to Plus
                    Reset counter: 121
                    Mileage: 116505 km
                    Date: 2022.07.13
                    Time: 18:41:12
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.2 V
                    Outside temperature: 37.5 °C
12298 - License Plate Light
          B12CA 15 [009] - Open or Short to Plus
                    Reset counter: 130
                    Mileage: 116505 km
                    Date: 2022.07.13
                    Time: 18:41:12
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.2 V
12307 - License Plate Light
          B12CA 01 [008] - Electrical Failure
                    Reset counter: 170
                    Mileage: 116506 km
                    Date: 2022.07.13
                    Time: 18:47:10
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Voltage: 13.5 V
                    Outside temperature: 36.5 °C
722437 - Control Module for Power Sunroof
          B13C6 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 170
                    Mileage: 117157 km
                    Date: 2022.07.18
                    Time: 20:47:28
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.1 V
                    Outside temperature: 45.0 °C
   Revision: --------    Serial number: 39331632705969
   Coding: 0031151011
   Shop #: WSC 73430 790 00063
   VCID: 43D3427EAB1BCAA392D-8016
   Part No SW: 3Q0 959 655 AJ    HW: 3Q0 959 655 AJ
   Component: Airbag VW21   004 0306
   Revision: --------    Serial number: 003R5PQHHEDI
   Coding: 88CCC000000000005C5400CC000800000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
   VCID: 06559B6AD8A93F8BF53-8052
   Subsystem 1 - Part No SW: -----------    HW: 454 001 011 16
   Serial number: 35700000000A9840502A
   Subsystem 2 - Part No SW: -----------    HW: 454 001 011 16
   Serial number: 358000000002F7405028
   Subsystem 3 - Part No SW: -----------    HW: 454 801 711 16
   Serial number: 3510001C05E0D000000B
   Subsystem 4 - Part No SW: -----------    HW: 454 801 711 16
   Serial number: 35200C9D85E0D000000+
   Subsystem 5 - Part No SW: -----------    HW: 454 800 111 16
   Serial number: 3550079EB7D0D0000001
   Part No SW: 5Q0 953 507 HQ    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 01121604401057
   Coding: 1410
   VCID: 0C41A942C6C545DBA37-8058
   Part No SW: 5E0 920 780 C    HW: 5E0 920 780 C
   Component: KOMBI         202 9630
   Coding: 47A502182980010801082A001000000000000000
   Shop #: WSC 73430 031 12345
   ASAM Dataset: EV_DashBoardJCIMQBAB 009007
   ROD: EV_DashBoardJCIMQBAB_009_SK37.rod
   VCID: 270BF6EE3F630683AE5-8072
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 108963 km
                    Date: 2022.04.29
                    Time: 18:51:51
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 156
                    Mileage: 116327 km
                    Date: 2022.07.12
                    Time: 15:29:52
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0005637356
   Coding: 0101000874086400EB00020A1C0F00000001050000000000000000000000
   GVL: 01543C0000000600401C10000000C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F3B1ECE17935EC3665-807A
   Generator:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Serial number: 000000000B1354091116
   Revision: 00000000    Serial number: 16000201377010
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 343111A2FEB57D1B1B7-8060
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0020
   Serial number: Y0006PK211089
   Coding: 0010000000000400018480808080000000008181000000D400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   VCID: 3C213982D6E5B55BD37-8068
   Component: TSG FS        010 0032
   Serial number: 0000230174653
   Coding: 00110120DE00040000001100
   VCID: 47CB566E9F23E6834E5-8012
   Serial number: 00000000000012420173
   Coding: 010200
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 0106
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D75C66A52FF493BC9-8010
22276 - Databus
          [KFC_MOTOR_11 Botschaft - SNA-Check]
                    Reset counter: 170
                    Mileage: 108967 km
                    Date: 2022.04.29
                    Time: 19:55:15
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 14.00 V
                    Temperature: 53.0 °C
                    KFC: 57
                    KFA: 00 04
                    Freeze frame conditions: 25
                    uioUdNotFilt_xdu16: 14.16 V
                    uAdSensI_SwitchedKl30_xdu16: 14.16 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Component: TSG BFS       010 0032
   Serial number: 0000231002626
   VCID: 46D55B6A9829FF8BB53-8012
   Serial number: 00000000000012500187
   Coding: 190200
   Coding: 034A00003F000000
   VCID: 40D94D72BA0DD1BB8FF-8014
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
   Part No SW: 5Q0 035 840 B    HW: 5Q0 035 840 B
   Component: MU-S--ER      H30 0359
   Serial number: SKZAZ2S5295073
   Coding: 03730100FF00000011110001001100002F0100D40120010002
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 2C0109C2268525DB437-8078
   Subsystem 1 - Part No SW: 5E0 919 605 H    HW: 5E0 919 605 H
   Component: ABT_Std-2  H43 1031
   Serial number: SKZ8Z9SLG01X6L
End----------(Elapsed Time: 01:32, VBatt start/end: 13.6V/13.4V)-----------
