Vcds won’t connect to b7 cc
Roysnail
Hi..can’t get vcds to connect to 2016 vw cc
Even on auto scan it comes up with message-l function not supported by the gateway”
Connector flashing blue, updated software & hardware & works perfectly on my 2011 Passat.
any ideas?
Version of VCDS?
Type of interface cable/lead?
What are the exact results when you do [Options] -> [Test] with everything plugged in?
Roysnail
Sorry..it’s a HexV2
V 22.3.1
Port status ok
Interface found
Hex-v2
Version cb 0.4615.4
Fw 0.256
Status:questionable
Can:testing, k1:no power,k2:no power
Vbat:0.11v vlgn:0.01v
Vin used 1/10
Tried with old version & no joy either
Roysnail
Actually
Vbat 1.59 vign 12.58v
Sounds like the fuse supplying power to the OBD-II port is blown.
PS: Please Get Verified.
Roysnail
Thanks mate, I will check it out..if I can find it.
siLc
Tallinn, Estonia
C?ID=330192
Fuses SC4 and SC13 are for the OBD port, located in the driver side dashboard fusebox.
Roysnail
Thanks mate..I will check it out if I can find it.
Roysnail
Ahh..seemed to post that twice
Roysnail
I’m intrigued about this, is it the voltage of the key battery?
Westbury, UK
Dumb question time - does the B7 CC actually have a CAN Gateway?
None of the B7 A4's I've owned had a CAN Gateway, you had to manually select the platform type to do an Auto-Scan.
siLc
Tallinn, Estonia
C?ID=330192
You're mistaking the Passat CC, and more particularly the facelift (just) CC for an Audi A4 :)
  • Agree
Westbury, UK
I did say it was a dumb question :cool:
Just seems strange that both are described as a B7 but are fundamentally different, but then VAG have always done strange things :D
Things got a bit out-of-synch. The "B7" A4 really should have been referred to as a B6.5. I mean it shared the same platform and even chassis code (8E) as the B6.
And of course the B6 and on Passats have a transverse drivetrain, whereas the A4s have always been longitudinal. So yes, fundamentally different.
