EMS
Hello all.
I've not been able to set my ACC above 95 MPH for some time, perhaps after a dieselgate-related software "upgrade". Wondering how to remove that limit? Not seeing anything obvious in ACC settings (address 8B). Any suggestions? Here's the auto scan, if needed. Thanks in advance!
Mark
Mark
Thursday,21,July,2022
VCDS --
VCDS Version 22.3.1.4 (arm64) HEX-NET CB: 0.4615.4
VIN: WV License Plate:
Mileage: 161923km-100614mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 47 52 53 55
56 5F 62 65 69 6C 6D 72 85 8B 8E
VIN: WV Mileage: 161923km-100614miles
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P1 907 401 C HW: 7P0 907 401 K
Component: 3.0TDI FSA H21 0010
Revision: 56H21--- CVN: AF4B74E538D3FF82755A21130E1FC39E
Coding: 292A4012237600050000
Shop #: WSC 26061 444 00000
ASAM Dataset: EV_ECM30TDI0117P1907401C 001011
ROD: EV_ECM30TDI0117P1907401C.rod
VCID: 302C03156BD0E90F7F-8065
VINID: 9E65D58094A0056500006205140A111907
Address 02: Auto Trans (J217) Labels: 0C8-927-755.clb
Part No SW: 0C8 927 755 R HW: 0C8 927 755
Component: AL1000 AISIN 130 3374
CVN: E0C27B10
Coding: 010200000C008400000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 40CC53D5DB70798F8F-8015
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 43524438603942
Coding: 5B7613C349246F59DAFCC89892D7F6607301
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4CD477E5E738ADEF63-8019
Part No SW: 4H0 907 064 FK HW: 4H0 907 064 EK
Component: BCM2 2.0 H36 0560
Coding: 0D860016000000000000
VCID: 77BEF809C63EFE37FE-8023
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 3215000045317007
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 CD HW: 7P6 907 040 CD
Component: Klima 2 Zonen H23 1406
Coding: B686200A80
VCID: 78BCFB35C320F14FF7-802D
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 22020001 Serial number: 00001034501601
Coding: 26000096963C5D010020480300005D4C431C6608A2014261000000008040110000000000000000
VCID: 6A98D17D858C53DF71-803F
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150317 033 0021
Serial number: 90243400150323151932
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20524806
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AC HW: 7P6 941 431 AC
Component: E1 - LDS H02 0040
Serial number: 00000000002403150075
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01E6A9C7
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28291506500159
Coding: 510D04
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 44C45FC5CF6865AFAB-8011
Part No SW: 7P6 907 561 C HW: 7P6 907 561
Component: ACC3 H21 0400
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContrVW526 002012
ROD: EV_AdaptCruisContrVW526_002.rod
VCID: 3C342725B7981D6FD3-8069
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 E HW: 7P0 959 655 E
Component: VW10Airbag04Z H10 0043
Revision: -------- Serial number: 003NK00326DR
Coding: 00000000000000000000000000000000345A
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
VCID: 43C65CD9CA66629792-8017
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R151270KB3F
Serial number: 3575LRB405D36RT6F9D.
Serial number: 3585LRB405F36RT66O7/
Serial number: 3517ARB404R38ACS9GKX
Serial number: 3527ARB404R38ACS8OH
Serial number: 3557BRB405535NVI99AJ
Serial number: 3567BRB405735NVICOTG
Part No SW: 4H0 953 568 M HW: 7P6 953 507 AJ
Component: Lenks.Modul H06 0005
Revision: -------- Serial number: 01374OCS0003F
Coding: 000CDD
VCID: 3D322A21A4821467E4-8069
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0083306 TRW 20150301
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 983 D HW: 7P6 920 983 D
Component: Kombi H13 0515
Revision: 13240300 Serial number: 658250315592055
Coding: 8B5733026F08CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001022
ROD: EV_KombiUDSRBVW526.rod
Part No SW: 7P6 907 530 N HW: 7P6 907 530 G
Component: GW-CAN-L-FR-M H13 6042
Revision: -------- Serial number: 00000001791276
Coding: 000103AD00
GVL: FB5F40655D7F680000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 32077I59375701733179
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000140720348
Coding: 00581B0000004001000001010101202020202121202020
VCID: 34240F0597C8D52F1B-8061
Part No SW: 7P6 907 566 A HW: 4H0 907 566 F
Component: SWA Master H06 0021
Serial number: 0363710938
Coding: 030221
ROD: EV_LaneChangAssis_VW51.rod
VCID: 3FCE5029A68E0677F6-806B
Subsystem 1 - Part No SW: 7P6 907 568 A HW: 4H0 907 568 F
Component: SWA Slave H06 0021
Serial number: 0363258519
Coding: 030221
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000143324923
Coding: 011D17205E00453005080001
VCID: 7AB8E13DF52CE35F81-802F
Revision: 00002001 Serial number: 0362283231
Coding: 0187123A68B9509580A00620210A18000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 A HW: 7P6 959 719 A
Component: GTO BT H20 0059
Serial number: 026152470
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.062 H01 0008
Serial number: WOO3470721+
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.062 H01 0008
Serial number: WOO3482388A
Coding: 191100
Subsystem 5 - Part No SW: 3AA 962 243 E HW: 3AA 962 243 E
Component: GEB.F.Heckoef H16 0813
Serial number: 65016377
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10811002429508
VCID: 75A2F201DC328C27EC-8021
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000142639021
Coding: 011D17205E00453005080000
VCID: 48DC4BF5FB4041CF47-801D
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1532000194
Coding: 01040200
Shop #: WSC 63318 003 1048576
ROD: EV_ParkbA7.rod
VCID: 3620350D89B4C73F25-8063
Slave 3:
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Coding: 012A02010B000400
ROD: EV_HeadlRegulAFSMQBMLB.rod
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0005
Coding: B00000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0005
Coding: B00000
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156CZ0F8244740
Coding: 020007010000000001
VCID: 2404FF45272845AF8B-8071
Part No SW: 7P6 035 664 G HW: 7P6 035 664 A
Component: H-BN-NA H40 0881
Revision: -------- Serial number: 273CY0FB006308
Coding: 020200050040E9EF79022B0E00000003F00001030000000000
VCID: 3C342725BF981D6FD3-8069
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Subsystem 2 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Component: DU8 SV Touch H53 0046
Serial number: VWZ8Z9RX8003TV
Subsystem 3 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Component: CD-Database 5950
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000142784950
Coding: 011817200000253005080000
Reset counter: 146
Mileage: 158679 km
Date: 2022.06.22
Time: 19:56:39
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 L HW: 5Q0 907 273
Component: RDKBERU30 H04 0003
Serial number: 40000000012476
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
VCID: 45C242C1C4525CA7BC-8011
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4H0 907 383 M HW: 4H0 907 383 K
Component: Anhaenger H14 0137
Revision: 7C001001 Serial number: 0362148820
Coding: 0200000200000000
ROD: EV_TrailFunctGener2Hella_VW52.rod
VCID: 373E38098EBE3E373E-8063
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 G HW: 7P6 907 441 G
Component: TopView H08 0115
Revision: 11001001 Serial number: 82330JF0217212
Coding: 0100000000010000010102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
VCID: 3D322A21AC821467E4-8069
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 069501180
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000142786726
Reset counter: 146
Mileage: 158667 km
Date: 2022.06.22
Time: 18:31:13
Part No SW: 7P6 907 217 B HW: 7P6 907 217
Component: DPC-SG H26 0035
Coding: 69020000
ASAM Dataset: EV_OnBoardCamerDTR 001001
ROD: EV_OnBoardCamerDTR.rod
VCID: 393A3E31B8AA2847C8-806D
Slave 1:
Subsystem 1 - Part No: 7P6 907 658
Component: NICKRATENSENS H02 0001
Serial number: 000000007064700_3352
Part No SW: 7P6 907 541 C HW: 7P6 907 541
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContr2VW526 002011
ROD: EV_AdaptCruisContr2VW526_002.rod
VCID: 3A38213DBDAC235FC1-806F
Address 8E: Image Processing (J851) Labels:| 7P6-907-107.clb
Part No SW: 7P6 907 107 B HW: 7P6 907 107
Component: BV-SG H33 0035
Serial number: 005000011103157
Coding: 0AA118040000
ASAM Dataset: EV_BTR 002001
ROD: EV_BTR_002.rod
End----------(Elapsed Time: 02:23, VBatt start/end: 12.4V/12.3V)-----------
