- Jul 21, 2022
- 22
- 2
- Taunton, UK
- C?ID=513798
I have just received my newly purchased copy of VCDS and thought I would start by carrying out a full scan of the car. The scan seems to have worked OK, and generally all was found to be OK, although there were a couple of intermittent faults detected, for example when I found that for some reason a few weeks back the rear passenger window on the nearside would not open one day.
I then proceeded to explore some of the other specific controllers and I am concerned that I keep getting the message "No response from controller". I consulted Google, which suggested that this message is generated if specific options are not fitted to the car in question, which is quite understandable - the only problem is that I am getting the message from A LOT of the different controllers - for features that I KNOW ARE fitted to my car, such as navigation and Parking Brake.
I have registered my software and the test was conducted with the ignition switched on - but the engine not running - so I think that I have been doing things correctly.
My reason for buying VCDS was that I wanted to explore adding a reversing camera to my car, which VW says cannot be retrofitted, but several VW Tiguan Mk2 forum members say that they have done. I also need to replace the read brake disks, as I do not think that they will pass an MOT next month due to corrosion, so I need to get to the bottom of the apparent problems I am experiencing.
The car is actually working absolutely fine - and I am pretty sure that if any of the controllers had faults I would have been aware of the fact by now.
Can anyone suggest how to address the problem? I note that my copy of VCDS does not have options in quite the sae places as shown on some Youtube vbideos, but I am assuming that is just due to me using the latest version. Specifically, I noticed that the Navigation option on a video appeared on the Installed Tab, whereas on my car it appeared under on of the Electronics tabs. What is the suignificance of the "Installed" tab?
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 22.3.1(x64) Data version: 20220407 DS337.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Thursday,21,July,2022,09:59:00:06421
VIN: WVGZZZ5NZHW321351 License Plate: DT16 HLU
Mileage: 65129km-40469mi Repair Order:
Chassis Type: 5N-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 29 39 42 44 52 55 5F A5 BB BC
CA D6 D7
VIN: WVGZZZ5NZHW321351 Mileage: 65129km-40469miles
BB-Door Rear Drv -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Self-Diagnosis Log
Page 2
Address 01: Engine (J623-DFGA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 HQ HW: 04L 907 309 P
Component: R4 2.0l TDI H24 3022
Revision: B4H24--- CVN: 2526BD574C6C0C4B
Coding: 0119001203441D082000
ASAM Dataset: EV_ECM20TDI01104L906026HQ 004002
ROD: EV_ECM20TDI01104L906026GQ_004.rod
VCID: 00598E766A82925BCFF-8054
VINID: 9E65EAAAA15EA989C30810C504C16E8440
28252 - Coolant Pump 3
P26FA 00 [032] - Air in System
Mileage: 64731 km
Date: 2022.06.22
Time: 11:26:33
Engine RPM: 845.50 /min
Normed load value: 20.0 %
Coolant temperature: 87 °C
Intake air temperature: 62 °C
Voltage terminal 30: 13.240 V
Unlearning counter according OBD: 14
Engine status: COENG_RUNNING
28991 - No Communications with NOX Sensor 1
U029D 00 [032] - -
Self-Diagnosis Log
Page 3
Part No SW: 5Q0 614 517 CE HW: 5Q0 614 517 AC
Component: ESC H25 0413
Revision: 00000000 Serial number: 61886000001548
Coding: 0AEE929A34220B6D477A060562C44950492CD0E2604692713460F078C0224200002E64121A03102F3535
VCID: 76B5E8AE3846ACEBE53-8022
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NA 907 044 K HW: 5NA 907 044 K
Component: AC Automat H35 4003
Revision: 20K08000 Serial number: 00000B00171677
Coding: 00120124202110011105100000101022
ASAM Dataset: EV_ACClimaPrehVW37X 002014
VCID: 47CB556A0F2C65634E5-8012
Rear A/C control head:
Subsystem 1 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Self-Diagnosis Log
Page 4
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001619400702
ROD: EV_BCMBOSCH_017.rod
VCID: 7F5B0D8A177CEDA3B65-802A
Subsystem 1 - Part No SW: 5NC 955 119 HW: 5NC 955 119 Labels: 1KX-955-119.CLB
Component: 326 RL 160603 033 0372
Serial number: 00000001605310303651
Component: RLHS 037 0059
Serial number: S3Y16M06D30H18M50S37
Coding: 00A8DD
Serial number: 000000000ZY1615210CG
Serial number: 00000000000035818364
Self-Diagnosis Log
Page 5
Part No SW: 3Q0 919 294 A HW: 3Q0 919 294
Component: PDC 8 Kanal H07 0020
Serial number: 002005167478000
Coding: 0071051801
ASAM Dataset: EV_EPHBO18VW3260000 007015
ROD: EV_EPHBO18VW3260000_SK37.rod
VCID: 372B25AA7FCC15E33E5-8062
1113328 - Parking Sensor(s); Front
B10FC F0 [008] - Function Limitation due to External Factors
[Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
Reset counter: 80
Mileage: 64803 km
Date: 2022.06.29
Time: 10:48:02
1080304 - Parking Sensor(s); Rear
B107B F0 [008] - Function Limitation due to External Factors
Reset counter: 80
Mileage: 64803 km
Date: 2022.06.29
Time: 10:48:38
Part No SW: 2Q0 907 572 H HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0155
Coding: 2A01404158FF8728749C8065104085
ASAM Dataset: EV_ACCMRRCONTIVW376 001010
ROD: EV_ACCMRRCONTIVW376_001.rod
VCID: 392F239249D80393C81-806C
Self-Diagnosis Log
Page 6
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0315
Serial number: 003TDR1XTSZQ
Coding: 98CCC0C00C0000005C5400CF008800000065
VCID: 1079BE363AE2E2DB5FF-8044
Left seat belt tensioner:
Serial number: 5NC857705C0181Q01628
Coding: 80000D
Right seat belt tensioner:
Serial number: 5NC857706C0182Q01286
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 000 107 16
Serial number: 357000000002493C6C1L
Subsystem 4 - Part No SW: ----------- HW: 480 000 107 16
Serial number: 358000000004F6D86C1
Subsystem 5 - Part No SW: ----------- HW: 480 400 607 16
Serial number: 35100019F213E8D1E55E
Subsystem 6 - Part No SW: ----------- HW: 480 400 607 16
Serial number: 3520001AD21816E4C163
Subsystem 7 - Part No SW: ----------- HW: 480 401 407 16
Serial number: 3550001C9213E8D43603
Self-Diagnosis Log
Page 7
Subsystem 8 - Part No SW: ----------- HW: 480 400 407 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001BD2134BB592FE
Subsystem 9 - Part No SW: ----------- HW: 480 400 407 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001BD2134BB592AA
Subsystem 10 - Part No SW: ----------- HW: 480 400 407 16
Component: PedP_Sensor_C 000 6149
Serial number: 2300001BD2134BB5C1A4
Subsystem 11 - Part No SW: ----------- HW: 480 000 807 16
Serial number: I0M00000000132608C1U
Subsystem 12 - Part No SW: ----------- HW: 480 000 807 16
Serial number: I0N000000004FCBC7C1T
Part No SW: 5Q0 953 521 R HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20160708401181
Coding: 0C00
ROD: EV_SMLSVALEOMQB.rod
VCID: 41DF4B7221085B53801-8014
Self-Diagnosis Log
Page 8
Part No SW: 5NA 920 791 A HW: 5NA 920 791 A
Component: KOMBI 405 2153
Coding: 27A401006F84260001886A031401000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009052
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 30061610800273
Coding: 030100041F087300FB00025E080F00010001050000000000000000000000
GVL: 01543C0000000000408C90000000480010000000000000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 7CA1FA86066AF6BB937-8028
Generator:
Subsystem 2 - Part No SW: 5TA 959 442 B HW: 5TA 959 442 B Labels: 3C8-959-537.CLB
Serial number: 1821608503301031AT1B
Coding: 2C0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 0195660704
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH07 0014
VCID: 45D75F6235207773BC9-8010
Self-Diagnosis Log
Page 9
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Component: TSG FS 020 0041
Serial number: 210616EFK14551
Coding: 003F0220D001048000001000
VCID: 43D3417A3B14494392D-8016
65593 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Fault Frequency: 12
Reset counter: 100
Mileage: 63670 km
Date: 2022.04.29
Time: 17:00:49
Component: EPS_MQB_ZFLS 128 1072
Coding: 1107
ROD: EV_SteerAssisMQB_013.rod
Self-Diagnosis Log
Page 10
Component: TSG BFS 020 0041
Serial number: 190616EFI29887
Coding: 003F0020DE01048000001000
VCID: 42DD447E240E404B99B-8016
B122D 29 [009] - Signal Implausible
Fault Frequency: 62
Reset counter: 61
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0051
Coding: 089E00104B200201
ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
Self-Diagnosis Log
Page 11
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0764
Coding: 02730601FF00000051110101008808001F0100E6012000008F
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 313F1BB291A8CBD3701-8064
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL021GN
Subsystem 2 - Part No SW: 5NA 919 866 CH HW: -----------
Component: ECE1 2023 --- 1910
Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H06 0220
Serial number: 05071611P11683
Coding: 0003070600000401000213448040A10094000E200040
VCID: 3A2D3C9E4CDE088BC1B-806E
Self-Diagnosis Log
Page 12
Component: TSG HFS 020 0041
Serial number: 280616BFP04401
Coding: 002A00200100048000001000
Fault Frequency: 41
Reset counter: 100
Date: 2022.04.01
Time: 11:26:08
Component: TSG HBFS 020 0041
Serial number: 280616BFR0266B
65590 - Motor for Window Regulator
B1487 01 [008] - Electrical Failure
Reset counter: 68
Mileage: 61585 km
Date: 2021.12.03
Time: 10:33:00
Self-Diagnosis Log
Page 13
Part No SW: 4M0 907 594 D HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Coding: 308040732602
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 1675C82E18060CEB053-8042
Component: LED1R H09 0003
End----------(Elapsed Time: 01:52, VBatt start/end: 12.2V/12.2V)-----------
