Tuesday,19,July,2022,07:05:14:47380
VCDS Version: 22.3.1.4 (x64)
VIN: WA1DMBFPXFA087134 License Plate:
Mileage: 139460km-86656mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
62 6C 6D 72 AC
VIN: WA1DMBFPXFA087134 Mileage: 139460km-86656miles
Address 01: Engine (J623-CPNB) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 401 AC HW: 4G0 907 401 E
Component: 3.0TDI FSA X14 0010
Revision: 58X14--- CVN: 861DD310000000000000000038D3FF820E1FC39E
Coding: 2A2A4012052603050000
ASAM Dataset: EV_ECM30TDI0118K5907401AC 002010
ROD: EV_ECM30TDI0118K5907401AC_002.rod
VCID: 71E3F8C1A0100E0730-8024
VINID: 9D10547525A0A16440207043104AD5E4C5
5188 - Particle Filter
P2463 00 [175] - Excessive Soot Accumulation
Mileage: 139421 km
Date: 2022.07.18
Time: 17:56:29
Engine RPM: 699.00 /min
Normed load value: 22.0 %
Coolant temperature: 85 °C
Intake air temperature: 25 °C
Voltage terminal 30: 14.260 V
P Flt Ld fac Ash Cor: 0.9580
Particul.filter diff.pressure: 898 hPa
Exh t Adap T Oxi Cat Ds: -0.0 °C
Exh t Adap TP Flt Ds: -0.0 °C
Current operating mode_2-Bits 0-7: 64
Current operating mode_2-Bits 0-7: 0
Current operating mode_2-Bits 0-7: 2
28988 - No Communications with NOX Sensor 1
U029D 00 [175] - -
Mileage: 139421 km
Date: 2022.07.18
Time: 17:56:26
Engine RPM: 698.50 /min
Normed load value: 22.4 %
Cruise Control System (CCS): status-Bits 0-7: 44
selected gear-Bits 0-7: 0
4949 - Exhaust Gas Temp Bank 1 Sensor 2
P2084 00 [101] - Implausible Signal
Mileage: 139421 km
Date: 2022.07.18
Time: 18:00:28
Normed load value: 21.2 %
Coolant temperature: 86 °C
Intake air temperature: 24 °C
Voltage terminal 30: 14.180 V
Exhaust gas model temperature 0: 113.6 °C
Exhaust gas model temperature 1: 133.5 °C
Exhaust gas temperature sensor 1: 152.1 °C
Exhaust gas temperature sensor 2: -0.0 °C
Exhaust gas temperature sensor 3: -0.0 °C
Exhaust gas temperature sensor 4: -0.0 °C
Ambient temperature: 20.0 °C
Readiness: 1 2 0 1 1
Part No SW: 8R0 927 158 Q HW: 0BK 927 156 AM
Component: 0BK 30 TDIUSA H19 1007
Revision: --H19--- CVN: 65368DFB
VCID: 4B9F4A29E27C04D76A-801E
Address 03: ABS Brakes Labels: None
VCID: 55ABAC51BCB84227CC-FFFE
No Faults Found
Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP
Component: BCM2 2.0 H15 0711
Coding: 0DA54040000000000000
Shop #: WSC 06335 000 00000
VCID: 0815B525BB8A2FCF87-805C
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3214000170824001
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01081220141152
Coding: 3621228080
Shop #: WSC 06335 123 12345
VCID: 77F7C6D9C6745037FE-8022
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000962967602
Coding: 260000158034AFE00100488300003D0D0F9CC708A6090221000008004000030100000034000000
VCID: 78F5C5E5CB6A5F4FF7-802C
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 141121 H12 0050
Serial number: 90243014141112214236
Coding: 01DD13
Component: G397_RLFS H06 0004
Serial number: 20018430
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000000212140871
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01D295AC
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 08298067000000000001
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H51 0812
Serial number: 003NED12ZHCY
Coding: 303334313432383132304A55304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4C9D4935E77203EF63-8018
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R140000MWZ5
Serial number: 6334MSME4A4A153EO
Serial number: 6344MSME4A4A185EU
Serial number: 6352QSME09495340B
Serial number: 6362QSME454A3D5E-
Serial number: 63732SME0C4A0D443
Serial number: 63832SME0C4A1644+
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862NLA00084
Coding: 000037
VCID: 48957525FB0AEFCF47-801C
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 982 A HW: 8R0 920 982 A
Component: KOMBIINSTR. H35 0567
Revision: 00100000 Serial number: 03K25X1DF
Coding: 8B3F22000301D705020100
VCID: 397300E1B0E08647C8-806C
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z14C020BF8
Coding: 80CF07FF00
VCID: 4C9D4935EF7203EF63-8018
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 5692175103
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Serial number: 14339001018021200410
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000128000068
Coding: 01581B00000000000000
VCID: 4281670DDD36C59F99-8016
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0353922538
Coding: 010211
Shop #: WSC 06334 000 00000
VCID: 3F876EF9A6C4A877F6-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0353518080
Coding: 010211
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000128024987
Coding: 011D13215E00440004
VCID: 4FA75E391E6438F706-801A
Part No SW: 8R0 909 144 J HW: 8R0 909 144 B
Component: RCEPS H41 0509
Revision: 00001000 Serial number: 0018222619
Coding: 100000010001
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X_008.rod
Revision: 00002001 Serial number: 0353901213
Coding: 0126063A20FA70958420053600040047
Shop #: WSC 06334 123 12345
Component: GTO BF H01 0080
Serial number: 00000000000000924278
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813038110006
VCID: 2D5B24B174A82AE754-8078
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000128137514
VCID: 4E99433D196E31FF0D-801A
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 20000000552021
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A711FEDBDE68D5FC1-806E
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156L+0E8124057
Coding: 020007010000000001
VCID: 244DC1952762EBAF8B-8070
Part No SW: 8R1 035 746 G HW: 8R1 035 746 G
Component: H-BNT-NA H42 0901
Revision: -------- Serial number: 523LZ0E7511117
Coding: 160200060205A1EF5502CF5E00000403140000000000000000
VCID: 3B7F1AE9BADCB457DA-806E
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Component: DU7 High H42 0104
Serial number: A130KU0E3209533
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000002072786
Component: CD-Database 5950
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000128497147
Coding: 010C13204000240004
VCID: 46897B1DF11EF9BFB5-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-J4XA2R2
Coding: 1020010
VCID: 346D31D557827B2F1B-8060
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D7B14F1A4C8BA67E4-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000128496783
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 143100951
ROD: EV_RDCMA00100.rod
VCID: 2D5B24B17CA82AE754-8078
End-------------------------(Elapsed Time: 04:51)--------------------------
