- Apr 9, 2014
- 2,304
- 2,252
- Tartu, Estonia
- C?ID=195131
Wednesday,20,July,2022,18:09:48:63851
VCDS Version: 22.3.1.4 (x64) HEX-NET2 CB: 0.4616.4
VIN: WVWZZZ1KZCM638186 License Plate: G6 BT CLUSTER
Mileage: 189690km-117867mi Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZCM638186 Mileage: 189690km-117867miles
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GB HW: 03F 907 309
Component: SIMOS10.12H03 5554
Revision: --H03--- Serial number: 00000000000000 CVN: 7705ADFC
Coding: 002500D6232400080000
Shop #: WSC 00066 000 00089
ASAM Dataset: EV_ECM12TFS02103F906070GB 004007
ROD: GV_ECM12TFS021VW36X.rod
VCID: 6882D3E802FC4DFB67F-803C
VINID: 9E69EAAAA05BA937460C804818676DA5FB
11730 - Fuel Trim; Bank 1
P0171 00 [096] - System Too Lean
Mileage: 188780 km
Date: 2022.07.14
Time: 16:40:05
Engine RPM: 647.00 /min
Normed load value: 13.7 %
Coolant temperature: 91 °C
Intake air temperature: 62 °C
Voltage terminal 30: 13.691 V
Unlearning counter according OBD: 28
Mixture variation in adapted part load range 1-FAC_MPL_LAM_AD[1][0]: -7.443 %
Mixture variation in adapted part load range 2-FAC_MPL_LAM_AD[1][1]: -1.901 %
Mixture variation in adapted part load range 3-FAC_MPL_LAM_AD[1][2]: -9.386 %
Mixture variation in adapted part load range 4-FAC_MPL_LAM_AD[1][3]: -1.245 %
Readiness: 0010 0001
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 058 P HW: 0AM 927 769 D
Component: GSG DSG AG7 431 3651
Revision: 00043014 Serial number: CU501403206804
Shop #: WSC 04940 001 00001
VCID: 3E2E55B03C78234BFD3-806A
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 113B200D21250002880C04EC841F0040350000
Shop #: WSC 00066 000 00000
VCID: 7BA89CA463EAF6639AD-802E
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0304
Revision: 00001016
Coding: 0000004002
Shop #: WSC 00066 000 00119
VCID: 0052EB480A8C95BBCFF-8054
9477141 - Position Sensor for Air Distribution Flap Motor
B109C 15 [008] - Open or Short to Plus
Reset counter: 190
Mileage: 189019 km
Date: 2022.07.15
Time: 19:38:38
Part No SW: 5K0 937 084 F HW: 5K0 937 084 F
Component: BCM PQ35 B 011 0048
Revision: BA011001
Coding: 08180E3A882DE3C040000080500000E443000088725D0D60648000200040
VCID: 353C4A9C054EE0132C9-8060
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 08101 26 0512
Coding: 009795
Component: Innenraumuebe 004 0611
Subsystem 3 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
01502 - Bulb for Rear Fog; Left (L46)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 141
Mileage: 188290 km
Date: 2016.12.01
Time: 00:10:30
Voltage: 13.70 V
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 1K9 919 475 A HW: 5K0 919 475 E
Component: PARKHILFE 8K H01 0004
Revision: -------- Serial number: 12501120402083
Coding: 108103
VCID: 392446AC29560473C81-806C
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6M00ZJHW
Coding: 00003536
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 32367180F4A0F72B09B-8066
Subsystem 1 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME41107361ZZZG
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME24547261ZZZP
Serial number: 3511HSME29324428ZZZF
Serial number: 3521HSME094A4528ZZZO
Part No SW: 5K0 953 507 AE HW: 5K0 953 549
Revision: -------- Serial number: 90440KGM000K7
Coding: 5880140000
Shop #: WSC 00066 000 00184
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 73B8B4844B3ABE23C2D-8026
Part No SW: 5K0 920 862 HW: 5K0 920 862
Component: KOMBI H32 0305
Revision: X0032006 Serial number:
Coding: 170E01
Shop #: WSC 00066 123 00119
ASAM Dataset: EV_KombiUDSMM9RM10 A04305
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 6B88ACE4130A66E30AD-803E
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 06101101270001
Coding: 352002
Shop #: WSC 00066 123 12345
Part No SW: 5K0 953 234 HW: 5K0 920 862
Component: IMMO H32 0305
ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
VCID: 6A86A9E01CF07FEB71B-803E
Part No SW: 3C8 035 279 HW: 3C8 035 279
Component: RNS315-EU H70 0407
Serial number: VWZAZ2N0391950
Coding: 0400043104000D0000008000
Shop #: WSC 00020 999 00000
ROD: EV_RNS315EUV2UDS.rod
Component: EUR_W_V4 0050
7 Faults Found:
1048595 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
[woofer rear left open load]
Reset counter: 141
Mileage: 188290 km
Date: 2022.07.11
Time: 00:05:18
1048596 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
[woofer rear right open load]
Reset counter: 141
Mileage: 188290 km
Date: 2022.07.11
Time: 00:05:18
1048599 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
[tweeter rear left open load]
Reset counter: 141
Mileage: 188290 km
Date: 2022.07.11
Time: 00:05:17
1048600 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
[tweeter rear right open load]
Reset counter: 141
Mileage: 188290 km
Date: 2022.07.11
Time: 00:05:17
1048629 - Aux IN Socket
B1104 13 [009] - Open Circuit
Reset counter: 141
Mileage: 188290 km
Date: 2022.07.11
Time: 00:05:20
1048634 - Antenna 2 for radio
B111A 13 [009] - Open Circuit
Reset counter: 141
Mileage: 188290 km
Date: 2022.07.11
Time: 00:05:15
1048582 - GPS Antenna
B1054 13 [009] - Open Circuit
[GPS antenna open load]
Reset counter: 141
Mileage: 188290 km
Date: 2022.07.11
Time: 00:05:15
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0501
Revision: 12110009 Serial number: 0003412708
Coding: 0000B4
Shop #: WSC 01383 790 50316
VCID: 1C6ABF388624515B337-8048
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 B HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1509
Serial number: 00000006050772
Coding: 000090
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 343A77980234F91B1B7-8060
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0501
Revision: 14110009 Serial number: 0003432057
Coding: 0001B4
VCID: 1D6CB23C9D3E5853C49-8048
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1509
Serial number: 00000006073024
Coding: 000090
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0946
Revision: -------- Serial number: 35502105027432
Coding: 020000010100010000000101
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_UHVPremi 002708
ROD: EV_UHVPremi.rod
VCID: 241A87D8BE54699B8B7-8070
End----------(Elapsed Time: 01:26, VBatt start/end: 12.3V/12.4V)-----------
Cluster is changed to 5K0 920 872 (B/W Maxidot) which doesn't reflect in this scan.
When I'm in BT menu of cluster and navigating down or up it "jumps" by 2 submenus.
I've already tried flashing GW do higher known version that doesn't have this issue. I've also tried cluster with 08xx(BW), which had same issue.
I kinda remember someone having same issue, but I really can't remember the resolution.
As this being MFA stalk, by "guess" is maybe SWCM isn't supporting?
Thanks!
