2015 S8 Manifold stuck
Morski
Cheshire UK
C?ID=90186
Got this S8 in and fault is showing the manifold flaps stuck closed on bank 2. Ran some tests and shows no movement on bank 2 flaps so assuming that the vacuum unit needs attending to or replacing. Problem is that they are buried deep down below the manifold by the chassis legs and can see anyway of getting to these except for dropping the engine. unless someone knows of a better way and can advise..
The AWD fault is a duff module.
Thanks
VIN: WAUZZZ4H3FN011519   License Plate: X2OHR
Mileage: 224729km-139640mi   Repair Order: S8 scan after 1st clear
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 15 16 17 19 1B 22 30 34 36 3B 42 44
          46 47 52 53 55 56 5F 62 6C 6D 6F 72 81 82 85 88 89 8F 90 A9
          BA
VIN: WAUZZZ4H3FN011519   Mileage: 224729km-139640miles
82-Head Up Display -- Status: OK 0000
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CTFA)       Labels:. 079-907-560-CFS2.clb
   Part No SW: 4H0 907 557 C    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0001
   Revision: NCH62---    CVN: 7AD6D617
   Coding: 022A00326526010B3800
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM40TFS0114H0907557C 001002
   ROD: EV_ECM40TFS0114H0907557C.rod
   VCID: 30391284EAA3768B7FF-8064
   VINID: 9D196AAAA1180D678004114124E26C8791
8993 - Intake Manifold Flap; Bank 2
          P2007 00 [229] - Stuck Closed
                    Mileage: 224729 km
                    Date: 2022.07.14
                    Time: 18:03:43
                    Engine RPM: 661.50 /min
                    Normed load value: 6.7 %
                    Coolant temperature: 38 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 13.900 V
                    Engine status: COENG_RUNNING
Readiness: 1110 1101
   Part No SW: 4H1 927 158 CE    HW: 0BK 927 156 AD
   Component: 0BK 40TFSIRdW H18 1001
   Revision: --H18---    CVN: 7B3B2DDE
   ASAM Dataset: EV_TCMALX51011 002022
   ROD: EV_TCMALX51011_002_AU64.rod
   VCID: 75B7E390554113A3EC9-8020
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 T    HW: 4H0 907 379 T
   Component: ESP PREMIUM   H10 0665
   Coding: D2FDAB004BBFD500E300
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 43D34D484B15FD1392D-8016
0679 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Net_QSP_02_QSP_Ist_Moment]
                    Reset counter: 200
                    Mileage: 224729 km
                    Date: 2022.07.14
                    Time: 18:00:05
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: A2
                    Bit Info 4: 00
                    F-Path: 2C
                    F-Type: 2E
                    Uz: 94
   Part No SW: 4H0 907 064 FB    HW: 4H0 907 064 EB
   Component: BCM2 2.0      H36 0551
   Coding: 05B76F4E000000000000
   VCID: 6E85CCFC3097207B2D3-803A
   Serial number: 0214000066378006
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000107222197
   Coding: 0038320000047201000001010101112131313333283333
   VCID: 34311E941E3B4AAB1B7-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 N    HW: 4H0 820 043 N
   Component: Klima 2 Zonen H20 0210
   Coding: 68210028340000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2B0305E8C38515534AD-807E
0129 - Motor for  Left Side Window Defrost Flap
          B10D7 22 [009] - Signal Amplitude Too High
                    Reset counter: 200
                    Mileage: 224729 km
                    Date: 2022.07.14
                    Time: 17:57:46
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 AB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0242
   Revision: 19020001    Serial number: 00000837999602
   Coding: 0105001440349FF0F90140C7A0001800009DC30A2F0802018000089461001700004000240B0000
   VCID: 6889BAE41273FE4B67F-803C
   Subsystem 1 - Part No SW: 4H2 955 119 C    HW: 4H2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 140322  H36 0090
   Serial number:         140324222945
   Coding: 0045F7
   Serial number: 22806032
   Coding: 02004E
   Subsystem 3 - Part No SW: 4H0 941 531 F    HW: 4H0 941 531 F
   Component: E1 - LDS  H01 0044
   Serial number: 30 06 2014  00000446
   Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA107823000006937699
   Coding: 020300
   Serial number: 01584637000000000001
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 F    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0200
   Revision: AA001001
   VCID: 2313EDC8ABD5DD13F2D-8076
   Revision: --------    Serial number: 003P1001HMB.
   Coding: 30333045313430303038554A305234483053
   VCID: 3B2335A833E585D3DAD-806E
   Serial number: 3575HRB405R2LI9IDP46
   Serial number: 3585HRB405J2LI9IEGUH
   Serial number: 3515JRB401452LJU5H07
   Serial number: 3525JRB401452LJU91TP
   Serial number: 3554VRB405V2QH188PGE
   Serial number: 3564VRB405V2QH18BPVX
   Revision: --------    Serial number: 01335NFQ000BE
   Coding: 000034
   VCID: 372B29980F4DA1B33E5-8062
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Serial number: 23 05 2014  E0014225
   Part No SW: 4H0 920 811 C    HW: 4H0 920 811 C
   Component: TBenGB----NV- H53 0707
   Revision: 37081202    Serial number: 658190514592028
   Coding: 33A70802BB412600010100
   ASAM Dataset: EV_RBD4K 004050
   ROD: EV_RBD4K_AU64.rod
   VCID: 2411EED4AE5BDA2B8B7-8070
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 P    HW: 4H0 919 204 P
   Component: Analoguhr D4  H05 0225
   Serial number: 2140526009561
Address 19: CAN Gateway (J533)       Labels:| 4H0-907-468.clb
   Part No SW: 4H0 907 468 AF    HW: 4H0 907 468 AC
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001451363
   Coding: C0ED07480C
   GVL: FFC3EC98FEE3E8CD91000000
   ASAM Dataset: EV_GatewPkoUDS 001024
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 51161E27311911328515
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 14175001374011200410
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Coding: 090100
   VCID: 392F2FA03959B7C3C81-806C
Address 22: AWD (J492)       Labels: 4H0-907-163.clb
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 002406140001002
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
   VCID: 2809FAE4D2733E4BA7F-807C
0325 - Internal Control Module Memory Check Sum Error
          B2000 00 [137] - -
          [SG Defekt DTC_QCU_DEFEKT]
                    Mileage: 213339 km
                    Date: 2021.11.18
                    Time: 00:23:04
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000060773
   VCID: 6491AED4EE5B9A2B4B7-8030
   Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
   Coding: 008004
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3B11F8F79D6973665-807A
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000107222199
   Coding: 00383B0000057201000001010101112131313333203333
   Part No SW: 4H0 907 637 L    HW: 4H0 907 637 G
   Component: SARA 6D red   H03 0056
   Revision: --------    Serial number: EJ1BPA7100GP44
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 38292AA402D3AECB37F-806C
   Part No SW: 4H0 959 793 S    HW: 4H0 959 793 H
   Component: TSG FA        H07 0280
   Revision: --------    Serial number: 0000099537266
   Coding: 011F12005E01628202083002
   VCID: 49CF5F6069B92743581-801C
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H40 0011
   Revision: 00001000    Serial number: 0012678208
   Coding: 011000010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 33331D881BB54D9302D-8066
   Revision: 00002001    Serial number: 0338052555
   Coding: 011B0E2280B93881F330C784080316470000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Subsystem 3 - Part No SW: 4H0 947 135 A    HW: 4H0 947 135 A
   Component: Dachelektroni  H13 0080
   Serial number: A2014000000000801088
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93253422
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000010283
   Coding: 030000
   VCID: 1C61D63496ABE2EB337-8048
   Part No SW: 4H0 959 792 H    HW: 4H0 959 792 H
   Component: TSG BF        H06 0280
   Revision: --------    Serial number: 0000105532616
   VCID: 3D273BB02D718BE3E49-8068
   Revision: --------    Serial number: 00000001114079
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070BF0FD911B63549-8078
   Part No SW: 4H4 907 357 B    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0049
   Coding: 02F60A2022130200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
   ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
   VCID: 313F1780E1A97F83701-8064
   Left LED Headlamp Power Output Stage 1:
   Subsystem 1 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7540
   Coding: E00300
   Right LED Headlamp Power Output Stage 1:
   Subsystem 2 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7540
   Coding: E00300
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0021
   Coding: E00300
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0021
   Coding: E00300
Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109F.0E7941172
   Coding: 010103010000000001
   VCID: 2809FAE4D2F33E4BA7F-807C
   Part No SW: 4H0 035 670 S    HW: 4H0 035 670 P
   Component: H-BNT-EU      H47 0814
   Revision: --------    Serial number: 179F/0EB002473
   Coding: 03010100020BF5EF45908B1E00000003000001000000000000
   Subsystem 1 - Part No: 8R0 060 884 BT
   Component: EUR 2014  1903
   Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
   Component: DU8 D4 SV NB  H48 0021
   Serial number: AUZ8ZDEC901K2Q0
   Subsystem 3 - Part No SW: 4H2 919 600 H    HW: 4H2 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000162126
   Component: CD-Database  5950
   Part No SW: 4H0 959 795 E    HW: 4H0 959 795 E
   Component: TSG HL        H06 0280
   Revision: --------    Serial number: 0000105538665
   Coding: 010F12004000628202083002
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0161472
   Coding: 020F000101000000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI_007.rod
   VCID: 2C0106F4C68B126B437-8078
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 167400065
   Coding: 021004C020
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FBBD1F8371D2973265-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000154780
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6393ADC8EBD59D13B2D-8036
   Component: TSG HR        H06 0280
   Revision: --------    Serial number: 0000105538985
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H09 0083
   Revision: 0R0D5015    Serial number: SN140509  0036
   ROD: EV_GSM2x3Mono_AU64.rod
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 4H0 919 617 A    HW: 4H0 919 617 A
   Component: HeadUpDisplay H08 0021
   Coding: A20000
   ASAM Dataset: EV_HUDContiC7 001025
   ROD: EV_HUDContiC7.rod
   VCID: 2E050CFCF097607B6D3-807A
   Component: DPC-SG        H27 0081
   Coding: E0140000
   ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00016971003102
   Coding: 672FF2
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00016971005001
   Coding: 272FF2
   Coding: 00060000031F030000030800424CD8010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323D188CE4AF449B09B-8066
   Part No SW: 4H0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0003
   Serial number: 140519200074
Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H07 0008
   Revision: 00001001    Serial number: 97812003932901
   ROD: EV_AEMLearAU64X.rod
1294 - Actuator 1 for Drivetrain Mounts
          C1131 07 [009] - Mechanical Failure
                    Reset counter: 200
                    Mileage: 224729 km
                    Date: 2022.07.14
                    Time: 18:05:56
End----(Elapsed Time: 02:47, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
Mileage is about right for this to occur also, 139640 miles. My experience was at about 115-120K.
Mileage: 224729 km
Date: 2022.07.14
Time: 18:03:43
Are you referring to the intake (top of engine) manifold ? Or, the exhaust manifold...... " buried deep down below the manifold by the chassis legs" ?
I've had some experience with my 2009 S5 B8 intake manifold ; electric motors operate the flaps inside the intake manifold ; yours I realize are vacuum. Typically, the plastic flaps within each air runner fracture somewhere on the common axle rod and the flap, or pieces of it, fall down further into the intake manifold. There is another set of "air tumbler valves" (near the intake ports of the head) and the pieces of plastic block these air tumbler valves and prevent them from operating properly, thus registering the fault code. Some pieces may get past this air tumbler system and you will find those pieces in/near the intake ports / valves of the head!
This may give you some additional insights (start around post #17) :
Morski
Cheshire UK
C?ID=90186
B8 engine is different to this version on the S8/R8 S6/RS6/7 models. The intake manifolds are the ones buried deep down by the legs and exhaust is in the 'V'. Then they managed to put the vacuum units below the manifold just to make sure you cant get to them never mind see them.
EuroX
Northern NJ USA
C?ID=208579
Either a vacuum line, vacuum solenoid or intake itself is no good. Check vacuum supply first.
Morski
Cheshire UK
C?ID=90186
Tried a used 4wd module but no joy coding it back to the car. ODIS online could not re parameterise it. I thought a used module should have worked ok?
Vac lines ans supply all test out ok.
EuroX
Northern NJ USA
C?ID=208579
Can the vacuum solenoid be actuated?? Does the MVB says the flaps move when revving it above 3k rpms???
Morski
Cheshire UK
C?ID=90186
Bank 1 moves ok bank 2 shows no movement at all; stays at 0%
EuroX
Northern NJ USA
C?ID=208579
If one bank move but the other does not I would assume a vacuum leak perhaps or a broken flap/sensor.
Morski
Cheshire UK
C?ID=90186
Plan is to inspect the manifold and replace the sensor and vac unit using the repair kit audi sell, problem is getting access to the manifold without dropping or lowering the engine.
Morski
Cheshire UK
C?ID=90186
Am i correct in assuming that if it had a leak it also throw a code of some sort for the intake?
Morski
Cheshire UK
C?ID=90186
Well awd module was replaced, tried a used one and ODIS could not reparamatise it. Fitted a brand new one and was a pain readapting it to the car. Had to re input the HEX values directly stamped on the diff for it to work.
  • Informative
EuroX
Northern NJ USA
C?ID=208579
Doubtful as most vacuum systems have a check valve built in. So no I don't think you'd have any additional codes not unless a massive vacuum leak from intake tract or other area was found separate from the vacuum hoses and solenoids. However if that was the case you would have lean codes and air intake system leak codes stored. You could rev it up above 3 grand and see if that flap sensor is seeing the percentage change or not.
Morski
Cheshire UK
C?ID=90186
Thanks. Tried the 3k rev and bank 2 shows nothing on movement so im thinking its either vac unit, solenoid or potentiometer; all of which are fitted to the manifold :-(
EuroX
Northern NJ USA
C?ID=208579
I know space is tight in that sucker. But best bet would be to disconnect vacuum line at runner and hook up a vacuum gauge to see if you have vacuum at the line. IIRC both runners are on the same vacuum solenoid. So to be it sound like either a faulty intake runner, wiring issue for runner postion sensor, or maybe broken line at runner.
:banghead:Ahh, ok. Thank you for that clarification @Morski; other Audi's with turbo's are known as the "hot V" : turbo's where the intake would normally be and the intakes where the exhaust manifolds would typically be. Thanks.
Time 7:25 to about 7:40
Audi RS5 B9 2.9TFSI V6 (part 2 of 3)​
EuroX
Northern NJ USA
C?ID=208579
S8 is a Hot V V8 not V6. There is no room under hood of that car.
boostboy
What w
Thanks
          BA
                    Mileage: 224729 km
                    Date: 2022.07.14
                    Time: 18:03:43
          U1113 00 [009] - -
                    Reset counter: 200
                    Mileage: 224729 km
                    Date: 2022.07.14
                    Time: 18:00:05
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: A2
                    Bit Info 4: 00
                    F-Path: 2C
                    F-Type: 2E
                    Uz: 94
                    Reset counter: 200
                    Mileage: 224729 km
                    Date: 2022.07.14
                    Time: 17:57:46
   Coding: 0045F7
   Coding: 02004E
   Coding: 020300
   Revision: AA001001
   Coding: 000034
   Analog_clock:
   Coding: C0ED07480C
   Voltage stabilizer:
   Coding: 090100
          B2000 00 [137] - -
                    Mileage: 213339 km
                    Date: 2021.11.18
                    Time: 00:23:04
   Coding: 008004
   ROD: EV_SARA2.rod
   Coding: 030000
   Coding: E00300
   Coding: E00300
   Coding: E00300
   Coding: E00300
   Coding: 021004C020
   Coding: 220000
   ROD: EV_Ambie.rod
   Coding: A20000
   Coding: E0140000
   Coding: 672FF2
   Coding: 272FF2
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
                    Reset counter: 200
                    Mileage: 224729 km
                    Date: 2022.07.14
                    Time: 18:05:56
What was the end result? I'm dealing with the exact same issue 2013 S6
actuator moves freely and holds vacuum fine. Cant find any leaks in the lines last thing i can think of is G336 the potentiometer
Morski
Cheshire UK
C?ID=90186
Nothing to report.. customer wasnt looking to spend money on it and no idea what he did with it in the end
