- Jan 28, 2018
- 214
- 141
- Cheshire UK
- C?ID=90186
Got this S8 in and fault is showing the manifold flaps stuck closed on bank 2. Ran some tests and shows no movement on bank 2 flaps so assuming that the vacuum unit needs attending to or replacing. Problem is that they are buried deep down below the manifold by the chassis legs and can see anyway of getting to these except for dropping the engine. unless someone knows of a better way and can advise..
The AWD fault is a duff module.
VIN: WAUZZZ4H3FN011519 License Plate: X2OHR
Mileage: 224729km-139640mi Repair Order: S8 scan after 1st clear
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 15 16 17 19 1B 22 30 34 36 3B 42 44
46 47 52 53 55 56 5F 62 6C 6D 6F 72 81 82 85 88 89 8F 90 A9
BA
VIN: WAUZZZ4H3FN011519 Mileage: 224729km-139640miles
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CTFA) Labels:. 079-907-560-CFS2.clb
Part No SW: 4H0 907 557 C HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0001
Revision: NCH62--- CVN: 7AD6D617
Coding: 022A00326526010B3800
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114H0907557C 001002
ROD: EV_ECM40TFS0114H0907557C.rod
VCID: 30391284EAA3768B7FF-8064
VINID: 9D196AAAA1180D678004114124E26C8791
8993 - Intake Manifold Flap; Bank 2
P2007 00 [229] - Stuck Closed
Mileage: 224729 km
Date: 2022.07.14
Time: 18:03:43
Engine RPM: 661.50 /min
Normed load value: 6.7 %
Coolant temperature: 38 °C
Intake air temperature: 26 °C
Voltage terminal 30: 13.900 V
Engine status: COENG_RUNNING
Readiness: 1110 1101
Part No SW: 4H1 927 158 CE HW: 0BK 927 156 AD
Component: 0BK 40TFSIRdW H18 1001
Revision: --H18--- CVN: 7B3B2DDE
VCID: 75B7E390554113A3EC9-8020
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 T HW: 4H0 907 379 T
Component: ESP PREMIUM H10 0665
Coding: D2FDAB004BBFD500E300
ASAM Dataset: EV_ESPPremi 005024
ROD: EV_ESPPremi_005_AU64.rod
VCID: 43D34D484B15FD1392D-8016
0679 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Net_QSP_02_QSP_Ist_Moment]
Reset counter: 200
Mileage: 224729 km
Date: 2022.07.14
Time: 18:00:05
VzRef: 00
Bit Info 1: 00
Bit Info 2: 07
Bit Info 3: A2
Bit Info 4: 00
F-Path: 2C
F-Type: 2E
Uz: 94
Part No SW: 4H0 907 064 FB HW: 4H0 907 064 EB
Component: BCM2 2.0 H36 0551
Coding: 05B76F4E000000000000
VCID: 6E85CCFC3097207B2D3-803A
Serial number: 0214000066378006
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0156
Revision: AA000000 Serial number: 00000107222197
Coding: 0038320000047201000001010101112131313333283333
VCID: 34311E941E3B4AAB1B7-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 N HW: 4H0 820 043 N
Component: Klima 2 Zonen H20 0210
Coding: 68210028340000
ASAM Dataset: EV_AirCondiFront 003001
ROD: EV_AirCondiFront_002.rod
VCID: 2B0305E8C38515534AD-807E
0129 - Motor for Left Side Window Defrost Flap
B10D7 22 [009] - Signal Amplitude Too High
Reset counter: 200
Mileage: 224729 km
Date: 2022.07.14
Time: 17:57:46
Part No SW: 4H0 907 063 AB HW: 4H0 907 063 AB
Component: BCM1 2.0 H20 0242
Revision: 19020001 Serial number: 00000837999602
Coding: 0105001440349FF0F90140C7A0001800009DC30A2F0802018000089461001700004000240B0000
VCID: 6889BAE41273FE4B67F-803C
Subsystem 1 - Part No SW: 4H2 955 119 C HW: 4H2 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 140322 H36 0090
Serial number: 140324222945
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 22806032
Coding: 02004E
Subsystem 3 - Part No SW: 4H0 941 531 F HW: 4H0 941 531 F
Component: E1 - LDS H01 0044
Serial number: 30 06 2014 00000446
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA107823000006937699
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 01584637000000000001
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
VCID: 2313EDC8ABD5DD13F2D-8076
Revision: -------- Serial number: 003P1001HMB.
Coding: 30333045313430303038554A305234483053
VCID: 3B2335A833E585D3DAD-806E
Serial number: 3575HRB405R2LI9IDP46
Serial number: 3585HRB405J2LI9IEGUH
Serial number: 3515JRB401452LJU5H07
Serial number: 3525JRB401452LJU91TP
Serial number: 3554VRB405V2QH188PGE
Serial number: 3564VRB405V2QH18BPVX
Revision: -------- Serial number: 01335NFQ000BE
Coding: 000034
VCID: 372B29980F4DA1B33E5-8062
Subsystem 1 - Part No SW: 4H0 951 528 A HW: 4H0 951 528 A
Serial number: 23 05 2014 E0014225
Part No SW: 4H0 920 811 C HW: 4H0 920 811 C
Component: TBenGB----NV- H53 0707
Revision: 37081202 Serial number: 658190514592028
Coding: 33A70802BB412600010100
ASAM Dataset: EV_RBD4K 004050
ROD: EV_RBD4K_AU64.rod
VCID: 2411EED4AE5BDA2B8B7-8070
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 P HW: 4H0 919 204 P
Component: Analoguhr D4 H05 0225
Serial number: 2140526009561
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4H0 907 468 AF HW: 4H0 907 468 AC
Revision: -------- Serial number: 00000001451363
Coding: C0ED07480C
GVL: FFC3EC98FEE3E8CD91000000
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 51161E27311911328515
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Serial number: 14175001374011200410
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 M HW: 8K0 907 144 M
Component: DYNAMIKLENK. H06 0730
Revision: 52001005 Serial number: --------------
Coding: 090100
VCID: 392F2FA03959B7C3C81-806C
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H17 0200
Serial number: 002406140001002
VCID: 2809FAE4D2733E4BA7F-807C
0325 - Internal Control Module Memory Check Sum Error
B2000 00 [137] - -
[SG Defekt DTC_QCU_DEFEKT]
Mileage: 213339 km
Date: 2021.11.18
Time: 00:23:04
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000060773
Coding: 01010101000000000001000102
VCID: 6491AED4EE5B9A2B4B7-8030
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Coding: 008004
ROD: EV_AirSuspe_VW51.rod
VCID: 2F3B11F8F79D6973665-807A
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000107222199
Coding: 00383B0000057201000001010101112131313333203333
Part No SW: 4H0 907 637 L HW: 4H0 907 637 G
Component: SARA 6D red H03 0056
Revision: -------- Serial number: EJ1BPA7100GP44
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 38292AA402D3AECB37F-806C
Part No SW: 4H0 959 793 S HW: 4H0 959 793 H
Component: TSG FA H07 0280
Revision: -------- Serial number: 0000099537266
Coding: 011F12005E01628202083002
VCID: 49CF5F6069B92743581-801C
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H40 0011
Revision: 00001000 Serial number: 0012678208
Coding: 011000010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
VCID: 33331D881BB54D9302D-8066
Revision: 00002001 Serial number: 0338052555
Coding: 011B0E2280B93881F330C784080316470000000000000000000000000000
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4H0 947 135 A HW: 4H0 947 135 A
Component: Dachelektroni H13 0080
Serial number: A2014000000000801088
Subsystem 4 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93253422
Part No SW: 4G1 035 223 A HW: 4G1 035 223 A
Component: BOSE-G3C7-ANC H02 0540
Revision: CJ002700 Serial number: 00000000010283
Coding: 030000
VCID: 1C61D63496ABE2EB337-8048
Part No SW: 4H0 959 792 H HW: 4H0 959 792 H
Component: TSG BF H06 0280
Revision: -------- Serial number: 0000105532616
VCID: 3D273BB02D718BE3E49-8068
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001114079
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D070BF0FD911B63549-8078
Part No SW: 4H4 907 357 B HW: 7P6 907 357 B
Component: MxB-ECU 001 0049
Coding: 02F60A2022130200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
VCID: 313F1780E1A97F83701-8064
Subsystem 1 - Part No SW: 7PP 941 472 G HW: 7PP 941 472 G Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7540
Coding: E00300
Subsystem 2 - Part No SW: 7PP 941 472 G HW: 7PP 941 472 G Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7540
Coding: E00300
Power module 1 for left matrix headlamp:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0021
Coding: E00300
Power module 1 for right matrix headlamp:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0021
Coding: E00300
Part No SW: 4G0 035 061 N HW: 4G0 035 061
Component: Radio U DAB H60 0139
Revision: AB001007 Serial number: 109F.0E7941172
Coding: 010103010000000001
VCID: 2809FAE4D2F33E4BA7F-807C
Part No SW: 4H0 035 670 S HW: 4H0 035 670 P
Component: H-BNT-EU H47 0814
Revision: -------- Serial number: 179F/0EB002473
Coding: 03010100020BF5EF45908B1E00000003000001000000000000
Subsystem 1 - Part No: 8R0 060 884 BT
Component: EUR 2014 1903
Subsystem 2 - Part No SW: 4H0 919 604 G HW: 4H0 919 604 G
Component: DU8 D4 SV NB H48 0021
Serial number: AUZ8ZDEC901K2Q0
Subsystem 3 - Part No SW: 4H2 919 600 H HW: 4H2 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000162126
Component: CD-Database 5950
Part No SW: 4H0 959 795 E HW: 4H0 959 795 E
Component: TSG HL H06 0280
Revision: -------- Serial number: 0000105538665
Coding: 010F12004000628202083002
Part No SW: 4H0 907 428 B HW: 7P6 907 441 D
Component: TopView H05 0220
Revision: 11001001 Serial number: 82330JF0161472
Coding: 020F000101000000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
ROD: EV_CamerSysteTopViewAUDI_007.rod
VCID: 2C0106F4C68B126B437-8078
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 AC HW: 4H0 959 107 AC
Component: HDSG-Modul H12 0049
Revision: 10012001 Serial number: 167400065
Coding: 021004C020
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6FBBD1F8371D2973265-803A
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000154780
Coding: 220000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6393ADC8EBD59D13B2D-8036
Component: TSG HR H06 0280
Revision: -------- Serial number: 0000105538985
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H2 927 731 A HW: 4H2 927 731 A
Component: GSM-RL H09 0083
Revision: 0R0D5015 Serial number: SN140509 0036
ROD: EV_GSM2x3Mono_AU64.rod
Address 82: Head Up Display (J898) Labels:* None
Part No SW: 4H0 919 617 A HW: 4H0 919 617 A
Component: HeadUpDisplay H08 0021
Coding: A20000
ASAM Dataset: EV_HUDContiC7 001025
ROD: EV_HUDContiC7.rod
VCID: 2E050CFCF097607B6D3-807A
Component: DPC-SG H27 0081
Coding: E0140000
ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00016971003102
Coding: 672FF2
ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00016971005001
Coding: 272FF2
Component: RGS-VL H13 0080
Coding: 00060000031F030000030800424CD8010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323D188CE4AF449B09B-8066
Part No SW: 4H0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0003
Serial number: 140519200074
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H07 0008
Revision: 00001001 Serial number: 97812003932901
ROD: EV_AEMLearAU64X.rod
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [009] - Mechanical Failure
Reset counter: 200
Mileage: 224729 km
Date: 2022.07.14
Time: 18:05:56
End----(Elapsed Time: 02:47, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
