"Gearbox Malfunction" - just got ross tech to help dignose
A-Aron
80134, USA
C?ID=522024
All,
I just purchase my Ross Tech scanner to use on my 2013 Audi Q7. I purchased the vehicle from my sister because she got in a fender bender and so I bought it off her for a good price. The car just had some front end damage that didnt affect anything mechanically. There are 2 main things that I am noticing the car doing which I will descibe below. Also please let me know if there is a better location to post this on this website.
1) The main issue that I have a caution light that comes on the screen behind the steering wheel and says "gearbox malfunction, you can continue to drive". The wierd part is, my sister was still driving it around after the accident and didnt have this pop up. I was flipping through from drive to reverse when it was on the jacks with the key on but not running because I was trying to figure out the cameras (the front one is broken). Now I also have a warning light that the distance sensor is not working. I remouted that because it got damaged during the collision but its still not working. I am wondering if maybe the cruise control is the reason for that gearbox malfunction warning? The only reason I am thinking that is beccause there was nothing in the scan that showed any relation to this warning. Any help here will be apprecaiated.
2) The second issue that is not as straight forward is a sounds its making. I say not as straight forward because sounds are nearly impossible to describe by typing. But when the engine is cold and you first start it up, sometimes it makes a grinding noise for a few seconds. almost sounds like the starter getting caught, but not sure. Would thinkin that it would be more likely something on the front of the motor from the accident. It only last a couple seconds which is not long enough for me to figure out where it is coming from. It also doesnt do it every time you start the car. Thoughts?
Here is the auto scan I took from the car. It appears a lot of them are old codes that never got deleted. Please let me know if anyone has any tips. The gearbox malfunction thing has me a little worried, but if thats just the cruise control, then I am not concerned. I plan on switching the cruise control from adaptive to regular using the ross tech software. If anyone has any tips on this let me know. I saw a youtube video of a guy doing this.
Saturday,02,July,2022,10:38:25:54960
VIN: WA1DGAFE8DD014789   License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3C 42 46 47 4C 4F
          52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFE8DD014789   Mileage: 145250km-90254miles
13-Auto Dist. Reg -- Status: Cannot be reached 1100
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (CTW)       Labels:. 06E-907-551-CAJ.clb
   Part No SW: 4L0 910 551 Q    HW: 4L0 907 551 A
   Component: 3.0l V6 TFSI        0030
   Revision: --H08---    Serial number:
   Coding: 0121000A290F0A28
   Shop #: WSC 31414 790 00001
   VCID: 36352B92144A16BB253-8062
   VINID: 9D10545D15952145000441C824175E8832
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - Intermittent
                    Mileage: 143743 km
                    Date: 2022.01.12
                    Time: 12:06:50
                    RPM: 1248 /min
                    Mass Air / Rev.: 376.1 mg/str
                    Temperature: 6.0°C
                    Bin. Bits: 00000010
                    Time: 0.0 s
000774 - Cylinder 6
               P0306 - 000 - Misfire Detected - Intermittent
                    Mileage: 143743 km
                    Date: 2022.01.12
                    Time: 12:06:50
                    RPM: 1248 /min
                    Temperature: 6.0°C
                    Bin. Bits: 00000010
                    Time: 0.0 s
000773 - Cylinder 5
               P0305 - 000 - Misfire Detected - Intermittent
                    Mileage: 143743 km
                    Date: 2022.01.12
                    Time: 12:06:50
                    RPM: 1248 /min
                    Temperature: 6.0°C
                    Bin. Bits: 00000010
                    Time: 0.0 s
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected - Intermittent
                    Mileage: 143743 km
                    Date: 2022.02.23
                    Time: 17:43:00
                    RPM: 1280 /min
                    Mass Air / Rev.: 332.5 mg/str
                    Temperature: 18.0°C
                    Bin. Bits: 00000010
                    Time: 0.0 s
049717 - No Communications with Cruise Control (Front) Distance Sensor
               U0235 - 000 -
                    Fault Frequency: 119
                    Mileage: 143751 km
                    Date: 2022.03.17
                    Time: 21:40:01
                    Time: 0.0 s
                    Bin. Bits: 00000000
                    Voltage: 11.83 V
   Part No SW: 0C8 927 750 Q    HW: 0C8 927 750 Q
   Component: AL1000 AISIN  002 2090
   Serial number:                CVN: CD2EA01E
   Coding: 001378
   Shop #: WSC 29140 001 1048576
   ROD: EV_TCMAL991031_002_AU56.rod
   VCID: 3A2D3FA22CD2F2DBC1B-806E
12816 - No Communication with Cruise Control Module
          U0104 00 [009] - -
          [Lost Communication With Cruise Control Module]
                    Reset counter: 201
                    Engine RPM: 0.0 /min
                    Transmission input speed: 0 /min
                    Engine torque: -52 Nm
                    ATF temperature: 10 °C
                    Accelerator pedal position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    EOP target revolution: 65534 /min
                    EOP actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    EOP failure status with EOP without HV 1: Motor normal stop
                    EOP target current: 65278 mA
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0623697
   VCID: 3431119A023604AB1B7-8060
01319 - Control Module for Distance Control (J428)
                    Reset counter: 95
                    Mileage: 143751 km
                    Date: 2022.03.17
                    Time: 21:40:02
                    Count: 8257
                    Count: 8206
                    Count: 41984
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0200
   Revision: 00H08000    Serial number: 10603702056150
   Coding: 0000135
   VCID: 2517FCDEB9EC6D239C9-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H04 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Component: FBSAUDIC6 IDG   H01 0053
9 Faults Found:
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Fault Status: 01110111
                    Fault Frequency: 21
                    Reset counter: 92
                    Mileage: 114170 km
                    Date: 2020.01.10
                    Time: 17:02:52
                    Fault Status: 00111000
                    Fault Frequency: 50
                    Mileage: 113232 km
                    Date: 2019.12.14
                    Time: 17:46:18
            007 - Short to Ground
                    Fault Status: 01111011
                    Fault Frequency: 13
                    Reset counter: 83
                    Mileage: 113422 km
                    Date: 2019.12.19
                    Time: 07:25:34
00191 - Passenger's Door Handle Touch Sensor (G416)
                    Fault Frequency: 60
                    Reset counter: 190
                    Mileage: 116862 km
                    Date: 2020.03.04
                    Time: 07:50:29
                    Reset counter: 59
                    Fault Status: 00111011
                    Fault Frequency: 27
                    Reset counter: 189
                    Mileage: 129739 km
                    Date: 2021.04.29
                    Time: 17:02:56
00956 - Key 2
                    Fault Status: 00110010
                    Fault Frequency: 13
                    Reset counter: 242
                    Mileage: 136064 km
                    Date: 2021.08.08
                    Time: 08:56:44
00183 - Interior Access/Start Authorization Antenna 1 (R138)
            006 - Short to Plus - Intermittent
                    Fault Status: 00110110
                    Mileage: 143429 km
                    Date: 2021.12.04
                    Time: 16:13:25
00955 - Key 1
                    Fault Status: 01100010
                    Reset counter: 118
                    Mileage: 145259 km
                    Date: 2022.07.02
                    Time: 11:28:52
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AQ
   Revision: 00---031    Serial number: 00000030279252
   Coding: 000CC026
   VCID: 2517FCDEB5EC6D239C9-8070
   Subsystem 1 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0057178048
   Coding: 070000
   Subsystem 2 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
   Serial number:           0057179898
   Coding: 070000
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0133123
   VCID: 6E85C3F22C9A6E7B2D3-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 129
                    Mileage: 143748 km
                    Date: 2022.03.17
                    Time: 21:40:00
                    Reset counter: 129
                    Mileage: 143580 km
                    Date: 2021.12.07
                    Time: 17:05:00
                    Fault Status: 00111010
                    Reset counter: 129
                    Mileage: 143748 km
                    Date: 2022.03.17
                    Time: 21:40:00
                    Reset counter: 129
                    Mileage: 143748 km
                    Date: 2022.03.16
                    Time: 23:55:00
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55961309400210
   Coding: 29011F
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 3431119A0EB604AB1B7-8060
Address 13: Auto Dist. Reg
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH44 0230
   Revision: 08H44000    Serial number: 0038QD0C4B0Y
   Coding: 0014131
   VCID: 2B030AE6DF085B534AD-807E
   Subsystem 1 - Part No: 4L0 959 339 C
   Component: BF-Gewichtsens. H05 0040
   Subsystem 2 - Serial number: 6332QSME1531055C7
   Subsystem 3 - Serial number: 6342QSME133158401
   Subsystem 4 - Serial number: 6352QSME0F3120648
   Subsystem 5 - Serial number: 6362QSME1531296EJ
   Subsystem 6 - Serial number: 63734SME68290860/
   Subsystem 7 - Serial number: 63834SME642C564CA
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H08000    Serial number: 90026130670295
   Coding: 0012152
   VCID: 2809F5EACEFE704BA7F-807C
   Component: E0221           H03 0040
                    Fault Frequency: 8
                    Mileage: 124983 km
                    Date: 2020.11.20
                    Time: 17:36:03
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 985 F    HW: 4L0 920 985 F
   Component: KOMBIINSTR.   H35 0317
   Revision: 00000000    Serial number: VIP22U94E
   Coding: 8BD663040D00CF05020205
   VCID: 372B26961F40EFB33E5-8062
                    Reset counter: 95
                    Mileage: 143751 km
                    Date: 2022.03.17
                    Time: 21:40:02
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0058
   Revision: MB700037    Serial number: 3700M13406008F
   Coding: 00C303
   VCID: 3FDB4EB63770D7F3F65-806A
   Component: J367-BDM  H07 0125
   Serial number: 00000000004121030196
                    Fault Status: 00101011
                    Fault Frequency: 48
                    Reset counter: 131
                    Mileage: 137463 km
                    Date: 2021.09.08
                    Time: 06:24:50
                    Bin. Bits:    11111
                    Voltage: 13.90 V
                    Count: 7
                    Bin. Bits:    10011
                    Fault Frequency: 13
                    Reset counter: 129
                    Mileage: 143743 km
                    Date: 2022.02.20
                    Time: 11:42:10
                    Bin. Bits:    10000
                    Voltage: 11.50 V
                    Count: 12
                    Reset counter: 95
                    Mileage: 143751 km
                    Date: 2022.03.17
                    Time: 21:40:01
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AE
   Revision: 00---011    Serial number: 00000000370705
   Coding: 0000006
   VCID: 6889B5EA0E7EB04B67F-803C
00003 - Control Module
                    Fault Status: 00100011
                    Fault Frequency: 22
                    Mileage: 113710 km
                    Date: 2019.12.31
                    Time: 14:47:14
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00000056116268
   Coding: 00581B00000011110000
   VCID: 323D1782F4220A9B09B-8066
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH02 0050
   Revision: 00H02000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   Shop #: WSC 41104 000 1048576
   VCID: 2E0503F2EC1A2E7B6D3-807A
   Component: J0770_SWA_Slave_H02 0050
   Subsystem 3 - Serial number: 5F27.03.1300H02000AMS15381ÿ
   Subsystem 4 - Serial number: S15381ÿ
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000057087383
   Coding: 011F57205E40440004
   VCID: 48C9556A62BE904B47F-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 01927981010000
   Coding: 3569949
   VCID: 382925AA1E5EE0CB37F-806C
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H04 0160
   Revision: CH004000    Serial number: 00000000021970
   Coding: 030000
   VCID: 290FF0EED9F44943B81-807C
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 150
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005191005687
   Coding: 0693965
   VCID: 2313E2C6B7D89313F2D-8076
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000137521
   Coding: 0012001
   VCID: 5EE59332DC3AFEFB9D3-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000056338468
   VCID: 47CB56566FA09F334E5-8012
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000031
                    Reset counter: 143
                    Mileage: 124989 km
                    Date: 2020.11.28
                    Time: 09:21:45
                    Reset counter: 143
                    Mileage: 124989 km
                    Date: 2020.11.28
                    Time: 09:39:18
02234 - Right Headlight Power Output Stage (J668)
                    Reset counter: 12
                    Mileage: 127076 km
                    Date: 2021.02.13
                    Time: 17:02:31
03798 - Output Module 2 for Right Headlamp
                    Reset counter: 12
                    Mileage: 127076 km
                    Date: 2021.02.13
                    Time: 17:02:31
   Part No SW: 4G0 035 082 E    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0121
   Revision: AB001007    Serial number: 156D-0D7712365
   Coding: 020007010000000000
   VCID: 221DE7C2A4C29A1BF9B-8076
   Part No SW: 4L2 035 746 C    HW: 4L2 035 746 A
   Component: H-BNT-NA      H44 0624
   Revision: --------    Serial number: 224D$0D7519934
   Coding: 180200060004E9EF710023456F632003140000000100000000
   VCID: 2E0503F2E01A2E7B6D3-807A
   Subsystem 1 - Part No: 8R0 060 884 BA
   Component: NAR 2013  0703
   Component: DU7 High  H42 0104
   Serial number: A130D/0D2697964
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002103595
   Component: CD-Database  4949
                    Fault Frequency: 74
                    Reset counter: 118
                    Mileage: 145259 km
                    Date: 2022.07.02
                    Time: 11:30:35
                    Bin. Bits: 00000000 00100000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000056369301
   Coding: 010E57204040230004
   VCID: 46D55B5268AA863BB53-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000193208910
   Coding: 0200000000000000
   VCID: 313F188EF1243183701-8064
   Part No SW: 4L0 907 428     HW: 7P6 907 441 D
   Component: TopView       H05 0293
   Revision: 11001001    Serial number: 82330JF0076629
   Coding: 020C010001000100010102000000
   ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
   ROD: EV_CamSysteCorneViewAUDI.rod
   VCID: 6E85C3F2201A6E7B2D3-803A
9616921 - Supply Voltage for Front Surroundings Camera
          B1284 12 [008] - Short to Plus
                    Reset counter: 129
                    Mileage: 143751 km
                    Date: 2022.05.09
                    Time: 16:23:40
                    Voltage terminal 30: 10.9 V
                    Terminal 15 status: Terminal 15 on
9616922 - Supply Voltage for Front Surroundings Camera
          B1284 14 [009] - Open or Short to Ground
                    Reset counter: 83
                    Mileage: 143581 km
                    Date: 2021.12.07
                    Time: 17:01:10
                    Voltage terminal 30: 14.6 V
9471744 - Local Databus
          U1030 00 [008] - Electrical Malfunction
          [LIN bus error]
                    Reset counter: 130
                    Mileage: 143581 km
                    Date: 2021.12.07
                    Time: 17:24:24
                    Voltage terminal 30: 11.5 V
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81C9FA1A869C6B037-8038
   Subsystem 2 - Serial number: %0
ó
   Subsystem 3 - Serial number: RD05.04.13--H57001002E0104ÿ
   Subsystem 4 - Serial number: 2E0104ÿ
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 0057518167----
   Coding: 0003595
   VCID: 2615FBD2C4EA663B953-8072
   Component: J_245_EE16_SKB10H14 0220
   Component: J_394_EE16_SKB10H14 0220
   Component: J_392_EE16_SKB10H14 0220
01514 - Regulator for Roof
                    Fault Status: 00101100
                    Fault Frequency: 20
                    Reset counter: 128
                    Mileage: 143734 km
                    Date: 2021.12.16
                    Time: 07:44:14
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000056369302
End----------(Elapsed Time: 02:23, VBatt start/end: 12.1V/12.1V)-----------
First thing I would do is clear them all, drive the vehicle a bit, then do another scan to see what has come back.
  • Agree
Reactions: JMR
JMR
Romania
C?ID=432218
for all your described troubles perhaps the car Gods think you underpaid your sister and it's giving you headaches huh ? :)
A-Aron
80134, USA
C?ID=522024
@JMR haha maybe! but insurance totalled it because of the cost to repair audis, so insurance gave them the price not me! I just paid them the buyback price.
@Uwe Here is the new scan. Thought I uploaded it yesturday but looks like it didnt actual upload.
Friday,15,July,2022,19:16:53:54960
VIN: WA1DGAFE8DD014789   Mileage: 145380km-90334miles
               U0235 - 000 -
                    Fault Frequency: 21
                    Mileage: 145259 km
                    Date: 2022.07.02
                    Time: 11:59:45
                    Time: 0.0 s
                    Bin. Bits: 00000000
                    Voltage: 12.04 V
   Coding: 001378
          U0104 00 [009] - -
                    Reset counter: 201
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
   Revision: 00H02001
   Coding: 0623697
                    Reset counter: 95
                    Mileage: 143751 km
                    Date: 2022.03.17
                    Time: 21:40:02
                    Count: 8257
                    Count: 8206
                    Count: 41984
   Coding: 0000135
                    Reset counter: 118
                    Mileage: 145259 km
                    Date: 2022.07.02
                    Time: 12:23:20
00955 - Key 1
                    Reset counter: 158
                    Mileage: 145259 km
                    Date: 2022.07.02
                    Time: 12:22:25
                    Reset counter: 118
                    Mileage: 145259 km
                    Date: 2022.07.02
                    Time: 12:23:20
   Coding: 000CC026
   Coding: 070000
   Coding: 070000
   Coding: 0133123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 29011F
   Coding: 0014131
   Coding: 0012152
                    Reset counter: 118
                    Mileage: 145259 km
                    Date: 2022.07.02
                    Time: 11:56:51
   Coding: 00C303
                    Reset counter: 118
                    Mileage: 145259 km
                    Date: 2022.07.02
                    Time: 12:01:06
                    Bin. Bits:    10111
                    Voltage: 11.80 V
                    Count: 7
                    Bin. Bits:    10011
                    Time: 25.40 s
   Coding: 0000006
   Coding: 0010001
   Coding: 3569949
   Coding: 030000
   Coding: 0693965
   Coding: 0012001
   Coding: 0000031
                    Fault Frequency: 8
                    Reset counter: 121
                    Mileage: 145384 km
                    Date: 2022.07.15
                    Time: 16:38:01
                    Reset counter: 118
                    Mileage: 145259 km
                    Date: 2022.07.02
                    Time: 11:48:56
                    Voltage terminal 30: 12.0 V
ó
   Coding: 0003595
End----------(Elapsed Time: 02:20, VBatt start/end: 12.1V/12.1V)-----------
JMR
Romania
C?ID=432218
Car seems pretty clean , you need to remove door handles and clean touch sensors and do something about distance regulation module. Start by checking fuses , wires and plugs , i m sure you have damaged wires/module.
A-Aron
80134, USA
C?ID=522024
Yeah the module up front got hit pretty good and knocked it off the bracket and broke the mounts. Right now I have double sided tape holding it on. It might be completly toast and they are very expensive for a new one. I want to remove the ACC so I can just use normal cruise control so I dont have to run through this module. I found this video (Link below) on how to change the cruise control from auto to manual, but I was going to ask if anyone has tried to do this on their car. Seems straight forward but I dont want to mess anything. Anyway, that should probably be its own thread after I figure this out.
Back to the original problem of it saying gearbox malfunction. Is it safe to say that it is not an actual problem with the transmission but just a problem with it not being able to communicate with the cruise control module??? Obvisouly if it was an actual tranmission problem this would be a much bigger issue which is why I am trying to make sure that this is not the case.
Thanks in advanced.
JMR
Romania
C?ID=432218
Yes , trans works with that damned module but it doesnt affect the workings of it i believe .
I don't think it's possible to say that in a definitive way. But since we haven't seen fault codes for anything else from the TCM, I would use that as the working assumption at this time, and those Aisin transmissions are usually pretty decent.
Let's start by removing it from the Gateway's Installation List and work incrementally from there.
