VW cc air conditioner
ajea7474
C?ID=170603
vw cc 2011 only blow hot air, compressor replaced, condenser was also replaced, high pressure switch was also replace but still no ac. lines were vacuum and refilled
Address 08: Auto HVAC       Labels: 3C8-907-336.clb
Control Module Part Number: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
  Component and/or Version: Climatic      H14 0305
           Software Coding: 0000001002
            Work Shop Code: WSC 05311 115 00000
              ASAM Dataset: EV_Climatic A01005 (VW46)
                       ROD: EV_ClimaBasis_VW46.rod
                      VCID: 75E1EE15D45E6E27EC-8020
9481748 - High Pressure Sensor
          B10AE 14 [008] - Open or Short to Ground
                    Reset counter: 121
                    Mileage: 211259 km
                    Date: 2120.14.29
                    Time: 07:17:20
9481769 - High Pressure Sensor
          B10AE 29 [008] - Signal Implausible
                    Reset counter: 121
                    Mileage: 216894 km
                    Date: 2127.14.31
                    Time: 02:14:14
          B10AB F0 [008] - Too Low
                    Reset counter: 85
                    Mileage: 216543 km
                    Date: 2127.14.31
                    Time: 08:04:31
chillout1983
C?ID=162783
Hi
What happens if you clear them ?
Does system still contain the Refrigerant charge ?
I am thinking of the possibility the codes occurred when the system was being worked on
What do you see in these measuring values?
IDE00198-ENG100282 -- Refrigerant pressure
IDE00965 -- Compressor shut-off condition
EuroX
Northern NJ USA
C?ID=208579
Clear faults and post updated auto scan.
JMR
Romania
C?ID=432218
bad wires from sensor or bad crappy sensor. In the IDE s suggested by Uwe you should see at least 5-6 bars while Ac shut off
