MK7 R Steering Wheel Retrofit
Righteouness
Australia
C?ID=434582
Hi all,
I own a Highline TDI wagon MK7 and I’m interested in exchanging the steering wheel with a golf r steering that comes with factory paddle shifters. Is this possible? Will it require coding to work? Thanks in advance.
Righteouness
Australia
C?ID=434582
Yes and yes.
I need affirmation here. I have a steering wheel without the cables. It contains the paddle shifters and multi-function buttons. No airbag but I will purchase an airbag cover and swap my old airbag into it. Do I need the cables from the new steering wheel to make it work or can mine plug and play directly into it?
Righteouness
Australia
C?ID=434582
It would help us to help you if you post an Auto-Scan of your Mk7 TDI in its current state.
Sorry, I didn’t think I needed an auto-scan for this retrofit enquiry.
Behold, my auto scan.
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WVWZZZAUZFP567409   Mileage: 45772km-28441miles
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 8127
   Revision: 83H22---    CVN: 0DE255AC
   Coding: 111D0012042505082000
   Shop #: WSC 00028 028 00073
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002008
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: FAA61892FC53652B01B-80AE
   VINID: 9E69EAAAA465A968051871002487131FDD
   Part No SW: 0D9 300 041 P    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4507
   Revision: 05853104    Serial number: TFK01409250651 CVN: 000092A8
   Shop #: WSC 00028 028 00067
   ROD: EV_TCMDQ250021.rod
   VCID: A51C1BEE256D3AD31C9-80F0
   Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
   Component: ESC           H42 0609
   Revision: 00000000    Serial number: 63004000000599
   Coding: 04FA8AA124260973077B060041CC2920512490E0608294F300620038C202
   Shop #: WSC 00028 028 00244
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: BD2CD38EADFD9213649-80E8
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 02120124200100001005000012101400
   VCID: EA8628D28CF3D5ABF1B-80BE
   Air quality sensor:
   Part No SW: 5Q0 937 086 AE    HW: 5Q0 937 086 AE
   Revision: --------    Serial number: 86582810140755
   Coding: 03501A46C24122FB4BE44000000C07081000000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: FDAC138EED7D5213249-80A8
   Component: WWS    141015  042 0551
   Serial number:         141017171040
   Coding: 0E4DFD
   Component: RLHS  037 0059
   Serial number: S4Y14M10D30H06M29S17
   Coding: 06A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 5G0 959 591     HW: 7P0 959 591 C
   Component: J245 PS22.018  H01 0008
   Serial number:     WOO3332235
   Coding: 191800
   Roof shade control module:
   Subsystem 4 - Part No SW: 5G0 959 591     HW: 7P0 959 591 C
   Component: J394 PS22.018  H01 0008
   Serial number:     WOO3332183/
   Coding: 191800
   Humidity sensor: interior:
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331429805178
   Coding: 0031111011
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R0CHZM8
   Coding: 98CCC000000000005C00000000C800000065
   Shop #: WSC 00028 028 00059
   VCID: C1D4AF7ED105F6F3001-8094
   Subsystem 1 - Part No SW: -----------    HW: 480 002 510 14
   Serial number: 35767000000F8214711O
   Subsystem 2 - Part No SW: -----------    HW: 480 002 510 14
   Serial number: 3586700000071524711E
   Subsystem 3 - Part No SW: -----------    HW: 480 402 210 14
   Serial number: 3516502C51811BA2220Y
   Subsystem 4 - Part No SW: -----------    HW: 480 402 310 14
   Serial number: 3526502B71860BA4E2AL
   Subsystem 5 - Part No SW: -----------    HW: 480 402 210 14
   Serial number: 3556502A5169752271A5
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141029400068
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: BFD0A986A7F18003765-80EA
617752 - Selector Lever Park Position Lock Switch
          B1162 29 [008] - Signal Implausible
                    Reset counter: 150
                    Mileage: 44623 km
                    Date: 2022.05.03
                    Time: 17:41:08
                    Ubat 30 Voltage: 14.50 V
                    Ignition State: On
                    Terminal 15: 13.70 V
                    A/D #1: 0.00 %
                    A/D #2: 0.00 %
                    A/D #3: 0.00 %
   Part No SW: 5G1 920 741     HW: 5G1 920 741
   Component: KOMBI         204 4270
   Coding: 27A511082B80000800087A001400000000000000
   VCID: E49A46EA6ED783DBCB7-80B0
   Revision: --------    Serial number: 17101410801090
   Coding: 030100340F087300EF00024A1C0F00010001050000000000000000000000
   GVL: 01543C0000000000400C10000000C80000000000000000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: F2B630B2A4231D6B49B-80A6
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0038
   Serial number: 29140002377360094441
   Coding: 28FFFF
   Serial number: 9676244703
   Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
   Component: TSG FS        009 0015
   Serial number: 0000122900733
   Coding: 003A03208001020000000000
   VCID: C5DCBB6EC52DDAD33C9-8090
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000006960022
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 0102
   VCID: C3D8A576CB19E4E312D-8096
   Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0015
   Serial number: 0000122828332
   Coding: 003A03208E01020000800000
   VCID: C4DAA66ACE17E3DB2B7-8090
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000006893668
   Coding: 050000
   Coding: 069E00000B000200
   VCID: C0D2AA7ADA0FFFFB0FF-8094
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 5G0 035 846 A    HW: 5G0 035 846 A
   Component: MU-S-N-ER     041 0430
   Serial number: V1F02610144153
   Coding: 02730208FF00000011510001000900001F0102960100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: A70011E65F6128C32E5-80F2
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS403VP7
   Subsystem 2 - Part No SW: 5G0 919 866 R    HW: -----------
   Component:  ROW 2015  --- 0031
6922 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 110
                    Mileage: 44801 km
                    Date: 2022.05.05
                    Time: 14:38:58
                    Voltage terminal 30: 11.9 V
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 110
                    Mileage: 44801 km
                    Date: 2022.05.05
                    Time: 14:39:01
                    BAP-BAP_Function_ID: 02
End----(Elapsed Time: 01:35, VBatt start/end: 11.8V/11.9V. VIgn 11.7V)-----
iichel
Eindhoven, NB, NL
C?ID=284912
It appears it will be plug and play since you already have a MFSW in your car.
