Clock spring query
chillout1983
C?ID=162783
Hi all
I have a noisey clock spring on my 2014 Passat B7 I need part no. 5K0953569AS however it is on back order ! With no estimate on availability, I may have to source one outwith the vw network (Ebay) I wondered if the software version would always be the same with the identical part number ?
Currently it is only noisey although I worry it may fail soon and as my car is due its MOT(inspection in the USA) in September if it was to fail and cause an Airbag light my car would have to be taken off the road.
I have seen parts available in Europe and the USA and once I factor in Tax and duty they are quite expensive so I don't want to make an error.
I don't have access to a recent scan just now
Chillout
chillout1983
C?ID=162783
Just noticed I posted in the wrong section
Please post a complete and unedited Auto-Scan so the forum can comment on your application. Including the VIN so that your PN can be verified.
Here is another ; a bit closer to home!
chillout1983
C?ID=162783
Scan attached my question is will the software version be different on a replacement with the same part number and if so will it cause any issues ?
Chillout
Sunday,12,February,2017,10:58:05:04925
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
VIN: WVWZZZ3CZFE037171   License Plate: CHILLOUT
Mileage: 23850km-14819mi   Repair Order:
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 47 4C 4F 52
          53 55 56 61 62 6D 72
VIN: WVWZZZ3CZFE037171   Mileage: 23850km-14819miles
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 PA    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H28 9978
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 001D0012042501080000
Shop #: WSC 34742 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906018PA 003009
ROD: EV_ECM20TDI01103L906018PA.rod
   VCID: 78F5D876C3C07681D1-802C
Component: GSG DSG AG6 521 4017
   Revision: 05652104    Serial number: 00001406120657
Shop #: WSC 05311 000 00001
   VCID: 142D8CC63768B2E15D-8040
Address 03: ABS Brakes Labels: 3AA-614-109.clb
   Part No SW: 3AA 614 109 BM    HW: 3AA 614 109 BM
   Component: J104   C2 450M VD50 0040
   Revision: --H07---    Serial number: 00000008306711
   Coding: 0008115
   VCID: 79F3DD7230CA6F89AE-802C
   Part No SW: 3AA 907 044 BT    HW: 3AA 907 044 BT
   Component: Climatronic   H05 0607
   Revision: 00001K02
   Coding: 061400C803
Shop #: WSC 00015 115 00001
   VCID: 030FBF9A8A062559F4-8056
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 Q    HW: 3AA 937 087 Q
Component: BCM PQ47 H+ 422 0475
   Revision: BC422001
   Coding: 0208000000000000009C0080740029F423F54B88676D8760E488C7240041
Shop #: WSC 05311 123 00001
   VCID: 489568B6FBA0C60161-801C
   Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 20061  26  0612
   Coding: 00B795
Component: RLS 110714 05 54 0403
   Coding: 0630ED
Address 10: Park/Steer Assist (J446)       Labels: 3AE-919-475.clb
   Part No SW: 3AE 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0018
   Revision: --------    Serial number: 28201418200198
   Coding: 108102
ASAM Dataset: EV_EPHVA18VW47X0000 001006
ROD: EV_EPHVA18VW4280000.rod
   VCID: 3F87736AA66E81B9D0-806A
   Part No SW: 5N0 959 655 AE    HW: 5N0 959 655 AE
   Component: J234__10J VW10 HI   2418
   Revision: 29020000    Serial number: 003N5PC03SMZ
   Coding: 0012362
   VCID: 0005B09653103E41E9-8054
   Subsystem 1 - Serial number: 6332MTS672781794
   Subsystem 2 - Serial number: 6342MTS685451754
   Subsystem 3 - Serial number: 6351HTS6JO2O1DKR
   Subsystem 4 - Serial number: 6361HTS627S62DKJ
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C9 953 501 CN    HW: 5K0 953 569 AS
   Revision: FF010042    Serial number: 20140624101118
   Coding: 1992250001
   VCID: 77F7DB4ACEDE79F9D8-8022
   Component: E221__MFL-TK6  H07 0022
   Coding: E30000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 981 A    HW: 3AA 920 981 A
   Component: KOMBI         H03 0705
   Coding: 461F01
Shop #: WSC 05314 115 00001
   VCID: 336F2F5A9A2655D924-8066
   Part No SW: 7N0 907 530 AS    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1653
   Revision:   H56       Serial number: 250614F2001170
   Coding: 462007
Shop #: WSC 05314 000 00001
   VCID: 0103B592981A3749E6-8054
   Part No SW: 3AA 959 799 E    HW: 3AA 959 799 E
   Component:    IMMO         090 0409
   Revision: 00090000    Serial number: VWZCZ000000000
   VCID: 4A9152BE25AC341177-801E
   Revision: A1001003    Serial number: 7666435973
   Coding: 020100
   VCID: 2B5F373A4A160D196C-807E
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 3C8 035 279 S    HW: 3C8 035 279 S
   Component: RNS315-EU   H80 0500
   Serial number: VWZAZ2P0380543
   Coding: 040700010100110000019002
ROD: EV_RNS315EUV2UDS.rod
   VCID: 3B7F077AB2769D99FC-806E
   Component: EUR_W_V6  0062
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0534
   Revision: 12110009    Serial number: 0008808303
   Coding: 0212F7
Shop #: WSC 05311 115 00001
ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 356B114294524BE90A-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  005 0503
   Serial number: 00000004061119
   Coding: 0102D0
133120 - Warning Light for Rear Door
          B11F7 01 [008] - Electrical Failure
                    Reset counter: 119
                    Mileage: 23694 km
                    Date: 2017.02.05
                    Time: 17:53:10
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 196    3501
   Revision: 00H22000
Shop #: WSC 02069 000 90108
   VCID: 39731D72704AAF89EE-806C
Address 46: Central Conv.        Labels: 3C0-959-799-46.clb
   Component: 02 KESSY PQ47   090 0375
   Coding: 01900A00D2C34E7634029C3F7E005FCE105800130427BC
   Component: Neigungssensor  004 0611
   Subsystem 4 - Part No: 3AA 962 243 D
   Component: GEB.F.Heckoef       0811
Address 47: Sound System (R184)       Labels: 5K0-035-456.clb
   Part No SW: 3AA 035 466     HW: 3AA 035 466
   Component: KonzernAmp12K H03 6904
   Revision: --------    Serial number: A1108A00001899
ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
ROD: EV_AudioVerst12KanalSTT1.rod
   VCID: 6DDBF922BC82C32932-8038
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1653
   Coding: 00000008
   VCID: 6FE7E32ABE8E313900-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0004
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0534
   Revision: 14110009    Serial number: 0008782149
   Coding: 0212F6
ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3669164E895440F103-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  005 0503
   Serial number: 00000004054739
   Coding: 0102D0
67584 - Warning Light for Front Door
          B11F5 01 [008] - Electrical Failure
                    Reset counter: 119
                    Mileage: 23707 km
                    Date: 2017.02.07
                    Time: 09:34:45
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000168523
   Coding: 0022167
   VCID: 387518764B40B68111-806C
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
Component: AFS-ECU H04 0111
   Coding: 029600000B000200
ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   VCID: 37771B4A8E5EB9F918-8062
   Subsystem 1 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 230000
   Component: Batt.regelung H56 1653
   Coding: 030F1859
   VCID: 71E3E552A8BA27C916-8024
   Component: J367-BDM  H07 0180
   Serial number: 41183H11301491466170
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 3AF 827 383 A    HW: 3AF 827 383 A
   Component: J605  HECKDECKEL    0860
   Revision: 00H52001
   VCID: 3A71027E754CA491E7-806E
   Subsystem 1 - Part No: 3AF 827 384 A
   Component: J756  HECKDECKEL    0860
   Subsystem 2 - Serial number: 1400H52001001C0311ÿ
End-------------------------(Elapsed Time: 03:41)--------------------------
How much leeway do you have on the inspection timing? Can you get it done early? In Pennsylvania if an inspection is due in September, it can be done as early as July. If I was worried about that part failing and being unavailable, I'd get the inspection done ASAP, and get the correct part on order.
That said, I've seen cars with noisy clocksprings go for years without any outright failure.
chillout1983
C?ID=162783
Hi i can get it Tested 1 month early so thats next month, however vw have said the part is currently not in production I will likely have to source from abroad .
My fear is the new one has different software that causes issues ?
Chillout
siLc
Tallinn, Estonia
C?ID=330192
You probably can use 569T which comes in older B7's but chances are you won't find one new and there is no point in installing older used parts just because of noise.
Since you already have 569AS, which has been the go-to replacement for all those failed 569T's, then personally I wouldn't sweat it. If you really want to have a replacement handy for MOT, buy used and use it when the current one fails.
chillout1983
C?ID=162783
Hi thank you for your reply I have also seen replacement ribbons on ebay i have considered this as a last resort , I think it is made by valeo I have seen one branded valeo with the same part no.
