Scale of ABS wheel speed sensors when graphing
welcome to my life :banghead:
My suggestion: Make a log of some data like that. Then use VC-Scope to re-play that data off-line. You can do this as many times as you wish while adjusting the scaling to see what happens. If you still can't get it, send us the log file so we can take a look at what's going on.
Note: It is important that you do not edit the log file. Leave it un-touched by anything other than VC-Scope (which opens it for Read only) after VCDS produces it.
D-Rok
Fort Pierce, FL, USA
C?ID=524098
that is exactly what i've been doing....play, adjust, play again, re-adjust....exit from the program , restart,.....frustrating
   #23
D-Rok
C?ID=524098
just tried it again....now, only the dark blue line is showing FML!!!!!!
   #24
So you're doing this repeatedly with the same log file? If so, send the file (and a link to this thread) to Support@Ross-Tech.com
Andy
Sector 7G
HC424490
I was able to use VC-Scope to replay your datalog:
Notice the faint rectangle around the field with 1296 in it. When you select a field, the vertical scale on the right shows you the settings for that field. You need to click on each field to change them as needed.
   #27
D-Rok
C?ID=524098
yes i see it, and i understand it...but dont the numbers at the top left and bottom left represent the scale values? yours are showing at 100 yet you have 3000 showing in the field. If you look at my posts #18 the red line disappears with the same values as post #15 min at 500 and max at 6000.....where did the red line go??
   #28
D-Rok
C?ID=524098
Here i took another screen shot of the same log (stopped in almost the same position as your screen shot), 3 of the 4 lines are missing. I have the same field highlighted to 3000 (as it shows in the upper left corner as well)...not sure what is going on...
