2008 Audi TT 3.2 Roadster Fun
EuroX
Northern NJ USA
C?ID=208579
So this post is mostly just for some pure enjoyment of how some people repair vehicle's half ass. To make a long story short this vehicle was in a accident was repaired, then driven for a period of 4 months then suddenly started having issues starting. Long story short If your gonna bypass the pyro fuse please make sure the bypass you have is bolted and secured at both ends otherwise you'll end up spending money on 3 starters before towing it to a pro to get your sorted out.
Only thing I still need to check is the parking aid sensors. Both fuses are good. Vehicle was in a front end hit only has rear parking aid. It looks like i'll be doing some wiring checks to see what's going on. The one thing that weird is if you put the vehicle in reverse you heard audible beep till it times out so it is coming on but, I suspect a bad wire or sensor perhaps.
Tuesday,28,June,2022,20:24:46:47988
VCDS Version: 22.3.1.4 (x64)  HEX-NET CB: 0.4615.4
VIN: TURD38J281  License Plate: AUDI TT TURD
Mileage: 122530km-76136mi   Repair Order:
Chassis Type: 8J (1K0)
Scan: 01 02 03 08 09 0F 14 15 16 17 19 22 25 26 37 42 44 46 47 52
          55 56 65 76 77
VIN: TRURD38J281  Mileage: 122530km-76136miles
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 HG    HW: 022 906 032 GP
   Component: TT-3.2-DQ-LEV2  G   1166
   Revision: 1QH02---    Serial number: AUX7Z0G9FN810N
   Coding: 0000178
   Shop #: WSC 01236 785 00200
   VCID: 57FE4A27E6B61037DE-8002
   VINID: 92296250321A088040087007149BD5E4E5
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 002 - Signal too High
                    Fault Status: 01100010
                    Mileage: 122534 km
                    Date: 2022.04.10
                    Time: 00:25:35
                    Temperature: 32.0°C
                    Temperature: -40.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.335 V
000258 - Mass Air Flow Sensor (G70)
               P0102 - 002 - Signal too Low
                    Mileage: 122534 km
                    Date: 2022.04.10
                    Time: 00:27:50
                    RPM: 959 /min
                    Load: 31.8 %
                    Temperature: 31.0°C
                    Voltage: 12.319 V
Readiness: 0110 1101
   Part No SW: 02E 300 011 CC    HW: 02E 927 770 AD
   Component: GSG DSG         082 1404
   Revision: 05108020    Serial number: 00001006010302
   Shop #: WSC 04940 001 00001
   VCID: 52E8BB33CD54351F29-8006
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 614 517     HW: 8J0 614 517
   Component: ESP MK60E1          0130
   Revision: 00H52001
   Coding: 0026177
   VCID: 6A9803D345C49DDF71-803E
                    Fault Status: 01100101
                    Reset counter: 200
                    Mileage: 122534 km
                    Date: 2022.04.10
                    Time: 00:14:54
                    Count: 128
                    Count: 12545
                    Count: 212
                    Count: 47872
                    Reset counter: 200
                    Mileage: 122534 km
                    Date: 2022.04.10
                    Time: 00:14:55
                    Count: 128
                    Count: 12545
                    Count: 297
                    Count: 47872
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 200
                    Mileage: 122534 km
                    Date: 2022.04.10
                    Time: 00:27:51
                    Count: 64
                    Count: 12545
                    Count: 8196
                    Count: 44288
Address 08: Auto HVAC        Labels: 8J0-820-043.clb
   Part No SW: 8J0 820 043 AJ    HW: 8J0 820 043 AJ
   Component: J255  Klima 1 Zone  0080
   Revision: 00H07003    Serial number: 00000001062497
   Coding: 1048870
   VCID: 6E900FC3792C71FF2D-803A
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 K    HW: 8P0 907 279 K
   Component: Bordnetz-SG     H54 2501
   Revision: 00H54000    Serial number: 00000007774470
   Coding: F1061E83C0141C00471800001800000000284E075A250802000000000000
   VCID: 45C2906F0C1A92A7BC-8010
   Subsystem 1 - Part No: 8J1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer AU354   H07 0070
   Coding: 00064784
   Shop #: WSC 01236
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00149804
   Shop #: WSC 01236
Address 0F: Digital Radio        Labels: None
   Part No SW: 8E0 035 593 Q    HW: 8E0 035 593 Q
   Component: SDAR SIRIUS     H08 0160
   Revision: 00000000    Serial number: AUZ4Z7M0616355
   Coding: 0000000
   VCID: 373EEAA746F6F0373E-8062
                    Reset counter: 200
                    Mileage: 122534 km
                    Date: 2022.04.10
                    Time: 00:31:56
Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
   Part No SW: 8J0 910 376     HW: 8J0 907 376 A
   Component: J250 Raddaempfung   0050
   Revision: --H16---    Serial number: 190DPH 7095303
   Coding: 0000014
   VCID: 6C9405CB4F3083EF03-8038
                    Fault Status: 11101101
                    Reset counter: 200
                    Mileage: 122534 km
                    Date: 2022.04.10
                    Time: 00:27:05
                    Voltage: 13.32 V
                    Voltage: 4.95 V
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: -F Airbag 9.43  H02 0020
   Revision: 93H02002    Serial number: 0036K0021GTY
   Coding: 0011590
   VCID: 79BA2C9F3062264788-802C
   Subsystem 1 - Part No: 8J0 910 339 A
   Component: BF-Gewichtsens. H02 0030
   Subsystem 2 - Serial number: 00GYF
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB4060ACA9B+ÿ†63
   Subsystem 5 - Serial number: ACA9B+ÿ†6342DRB405FB8D0B4ÿ†63
   Subsystem 6 - Serial number: B8D0B4ÿ†63747RB402E3661BQÿ†63
   Subsystem 7 - Serial number: 3661BQÿ†63847RB402E365A7Vÿ
   Subsystem 8 - Serial number: 365A7Vÿ
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
            007 - Short to Ground - MIL ON
                    Fault Status: 11100111
                    Reset counter: 200
03083 - Ignitor for Driver's Belt Force Limiter (G551)
                    Fault Status: 11100001
                    Reset counter: 200
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0013141
   VCID: 41CA847F1832BE8780-8014
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 990 E    HW: 8J0 920 990 E
   Component: KOMBIINSTR. VDO H22 0130
   Revision: D0H22001    Serial number: 224NG001101036
   Coding: 0113266
   VCID: 3424DDAB57801B2F1B-8060
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K07A100464
   Coding: ED8B1F2F5007025100
   VCID: 302CD1BBA398270F7F-8064
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   Coding: 0000001
   VCID: 3620E7A341FC093F25-8062
   Revision: D0H22001    Serial number: AUX7Z0G9FN810N
   Shop #: WSC 04125 004 1048576
Address 26: Auto Roof        Labels: 8J7-959-255.lbl
   Part No: 8J7 959 255 B
   Component: 256 VSG TT      H13 0110
   VCID: 3E30FF8369CCC17FFD-806A
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8J0 035 192 B    HW: 8J0 035 192 B
   Component: RNS-E US        H11 0260
   Revision:      03S    Serial number: AUZBZ7G3802072
   Coding: 0619637
   Shop #: WSC 22129 444 54391
   VCID: 281C39DB9B486FCFA7-807C
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX1.lbl
   Part No: 8J7 959 801 C
   Component: Tuer-SG         H02 0060
   Coding: 0001077
   VCID: 3C34F58B7FD0D36FD3-8068
   Part No: 8J1 909 143 C
   Component: EPS_ZFLS Kl.155 H08 1903
   Shop #: WSC 22129 444 52429
                    Mileage: 122520 km
                    Temperature: 22.0°C
                    Voltage: 18.90 V
                    Voltage: 18.70 V
Address 46: Central Conv.        Labels:. 8J0-959-433.lbl
   Part No: 8J0 959 433 C
   Component:    KSG          H11 0080
   Coding: 1B90328241382D090F0FC88A0473
Address 47: Sound System        Labels: 8J0-035-223.lbl
   Part No SW: 8J0 035 223 D    HW: 8J0 035 223 D
   Component: J525 Amp High   H04 0150
   Revision: PROD_01     Serial number: 00000000010523
   Coding: 0246136
   VCID: 250230EFEC5A72A79C-8070
16349 - Control Module - Error in Output Stage
                    Fault Status: 00101110
                    Reset counter: 141
                    Mileage: 40854 km
                    Date: 2016.11.05
                    Time: 00:34:42
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MAX1.lbl
   Part No: 8J7 959 802 C
   Coding: 0001077
   VCID: 3D32F88F64CADA67E4-8068
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000025
   VCID: 291A3CDF804256C7B8-807C
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H05 0030
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH05 0030
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0619637
Address 65: Tire Pressure        Labels: 8J0-907-273.lbl
   Part No SW: 8J0 907 273 A    HW: 8J0 907 273 A
   Component: J502-RDK        H02 0300
   Revision: --H02-D0    Serial number: 12679771792033
   Coding: 0860021
   VCID: 2F2ED2C7BEA638F766-807A
Address 76: Park Assist        Labels: 8P0-919-283.lbl
   Part No SW: 8P0 919 283 D    HW: 8P0 919 283 D
   Component: Parkhilfe 4-Kan H09 0070
   Revision: 00H09000    Serial number: 00067824840728
   Coding: 0001221
01549 - Supply Voltage for Parking-Aid Sensor
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 200
                    Mileage: 122534 km
                    Date: 2022.04.10
                    Time: 00:24:13
            002 - Lower Limit Exceeded
                    Reset counter: 200
                    Mileage: 122534 km
                    Date: 2022.04.10
                    Time: 00:24:13
   Part No SW: 8P0 862 335 R    HW: 8P0 862 335 R
   Component: FSE_255x BT     H26 0350
   Revision: 00000000    Serial number: 00000005056221
   Coding: 0011407
End----------(Elapsed Time: 01:38, VBatt start/end: 13.5V/13.5V)-----------
SwissJetPilot
Switzerland
C?ID=317276
If you need Audi TT specific assistance that can't be resolved here, stop by the Forum and say hello.
