2015 e-Golf Security Code help needed
VWVic
C?ID=9932
Hello to all-
I'm a long time VAG-COM user but newbie to the forum. I just bought a new 2015 e-Golf (all electric). I'm trying to update "Address BD: Hi-voltage battery charger" using the latest Beta VAG-COM software version to allow me to charge the battery at night off-peak, but I need a security code to do so... VW has a cool app called Car-Net using a PC or smart phone but it still has bugs and can't update the charging profile. VW is working on a fix but I'd like to update it myself... How can I get the security access code???
Any help appreciated. You folks are great.
Thanks-
Vic Welker (VW)
Los Olivos, CA
2000 Jetta GLS (high school daughter)
2002 Jetta TDI (son in college)
2002 Jetta TDI (old commuter car, give to high-school son)
2006 Passat (wife)
2015 e-Golf (ultimate commuter car for me)
In order to see if we have any data that might be helpful, we'd need to see the ID info from that module. Ideally, you would give us that by posting an Auto-Scan. ;)
VWVic
C?ID=9932
VCDS Version: Beta 15.6.1
Data version: 20150612
VW Welkers
Thursday,18,June,2015,17:40:26:26359
Chassis Type: AU (5QE)
Scan: 01 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 55 5F 75 8C
          BD C0 C5 C6
VIN: WVWPP7AU6FW901772
BD-Hi Volt. Batt. Charger -- Status: OK 0000
C5-Therm. mgt. -- Status: Malfunction 0010
Address 01: Engine (J623-EAGA)       Labels: 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 C    HW: 0EA 907 309 A
   Component: E-Vehicle     H22 8073
   Revision: WMH22---
   Coding: 000D0016002400007000
   ASAM Dataset: EV_VCU00XXX0110EA906016C 002005
   ROD: EV_VCU00XXX0110EA906016C.rod
   VCID: AF670CFDF67B3B47D0-80FA
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 N    HW: 5Q0 907 379 H
   Component: ESC           H31 0807
   Revision: 00000000    Serial number: 61954000000076
   Coding: 01FA40A12C20316D017E020781C5298002348C80408194B202810058C242
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
   ROD: EV_Brake1UDSContiMK100OMG_AU37.rod
   VCID: C797445D7ECB8307F8-8092
   Revision: 00021000    Serial number: 0343295664
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: BA712DA93D39EEEF77-80EE
   Part No SW: 5GE 907 044 S    HW: 5GE 907 044 S
   Component: Climatronic   H02 1105
   Revision: 00001K07
   Coding: 00022200200100000005000200111801
   ASAM Dataset: EV_ACClimaBHBVW37X 005132
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: CC9D7B7167AD605FD5-8098
   Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
   Component: BCM MQBAB MNA H18 0134
   Serial number: 01011421000012
   Coding: 00051A66434182E169E44000001407201C00000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: F9F3F2A578BF25F73E-80AC
   Slave 1:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A
   Component: WWS    140726  043 0551
   Serial number:         140801013404
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S5Y14M08D22H16M48S08
   Coding: 00A8DD
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39311421302370
   Coding: 2031151011
   ROD: EV_EPHVA18AU3700000_SK48.rod
   VCID: BD7B26B52C17D9D752-80E8
13637426 - Databus
                    Reset counter: 73
                    Mileage: 2614 km
                    Date: 2015.06.13
                    Time: 00:49:10
   Serial number: 003GCR00JT9T
   Coding: 8CCCFC00002000005000001AC24800000065
   Seat occupant detection; front passenger side:
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  005 0016
   Serial number: IBH0000J140000ND300N
   Coding: 303356
   Subsystem 2 - Part No SW: -----------    HW: 480 001 408 14
   Serial number: 35700000000B9B35B01N
   Subsystem 3 - Part No SW: -----------    HW: 480 001 408 14
   Serial number: 3580000000071A35B01B
   Subsystem 4 - Part No SW: -----------    HW: 480 401 408 14
   Serial number: 3510002AB16DB804102Z
   Subsystem 5 - Part No SW: -----------    HW: 480 401 108 14
   Serial number: 3520002C116DB814F053
   Subsystem 6 - Part No SW: -----------    HW: 480 401 408 14
   Serial number: 3550002AB16DB80370BA
   Subsystem 7 - Part No SW: -----------    HW: 480 401 408 14
   Serial number: 3560002AB16DB8046123
   Part No SW: 5Q0 953 507 EA    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 15081404221116
   Coding: 0410
   ROD: EV_SMLSKLOMQB_SE37.rod
Address 17: Instruments (J285)       Labels: None
   Part No SW: 5GE 920 855     HW: 5GE 920 855
   Component: KOMBI         301 4311
   Coding: 0B35181A2B80CF05020868001700030000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   VCID: FEF9E1B9619102CF0B-80AA
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5QE 907 530 B    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3186
   Revision: --------    Serial number: 21071410800902
   Coding: 0201001746F81000EF001200081E00000001050100030000000000000000
   ASAM Dataset: EV_GatewEVConti 011017
   ROD: EV_GatewEVConti.rod
   VCID: C58B4E5544C791170A-8090
   Subsystem 1 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29140001375290104275
   Coding: 30FFFF
   Subsystem 2 - Part No SW: 5GE 915 181     HW: 5GE 915 181
   Component: J367-BDMHella  H03 8050
   Serial number: 9199653003
   Part No SW: 5QE 909 059 A    HW: 5QE 909 059 A
   Component: EBKV          H12 0160
   Serial number:   085430010332
   Coding: 01720100321A02030002000500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 002014
   ROD: EV_BrakeBoostBoschMQBOMG_VW37.rod
   Subsystem 2 - Part No SW: 5QE 909 057 A    HW: 5QE 909 057 A
   Component: VX7  H04 0140
   Serial number: 05802861170714183823
239616 - Implausible Data Received from Engine Control Module
          U0401 00 [047] - -
                    Mileage: 3224 km
                    Date: 2015.06.18
                    Time: 17:32:00
   Revision: 00000000    Serial number: 14000216325002
   Coding: 7900000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: B46D03911F5D189FAD-80E0
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 02081401100379
   Coding: 003013208000040000000000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: BE7921B92111C2CF4B-80EA
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000003511303
   Component: EPS_MQB_ZFLS  123 1043
   Coding: C102
   ROD: EV_SteerAssisMQB.rod
   VCID: C1835A4550EFBD3736-8094
   Part No SW: 5QE 907 080 C    HW: 5QE 907 080 C
   Component: VW370E2615010 H05 2461
   Revision: 00H05000
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM09550115QE907080C 001020
   ROD: EV_DMCM09550115QE907080C.rod
   VCID: C689495979C19A0F03-8092
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 26071402090650
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000003524969
   Coding: 190000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 051A000101000000
   ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
   VCID: F5EBFE9554A741975A-80A0
   Part No SW: 5G0 035 876     HW: 5G0 035 876
   Component: MU-S-NS-US    014 R025
   Serial number: V7B00707140732
   Coding: 02737002FF00000021220001001800001F0100140100010546
   ROD: EV_MUStd4CPASE_SK37.rod
   VCID: E9D3A2E5081F9577CE-80BC
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605 K    HW: 5G0 919 605 K
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS60078P
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5G0 919 866 H    HW: -----------
   Component:  NAR 2014/15  --- 0020
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0564
   Coding: 02737002C2829A017FFE06000000
   ROD: EV_OCULowMQB.rod
   VCID: C38F504D4AF3AF2724-8096
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 52
                    Mileage: 709 km
                    Date: 2015.05.29
                    Time: 16:08:48
Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 5QE 915 227 K    HW: 5QE 915 227 H
   Component: K8C           H13 0691
   Serial number: VWADEHD00H
   ASAM Dataset: EV_BECM08820215QE915227K 003015
   ROD: EV_BECM08820215QE915227H.rod
   VCID: D0A56F018B8544BFA9-8084
Address BD: Hi Volt. Batt. Charger (J966)       Labels: 5QE-915-022.clb
   Part No SW: 5QE 915 022 G    HW: 12E 915 022 C
   Component: LMSG          H08 1075
   Serial number: 00920042830344
   Coding: 4A4904
   ASAM Dataset: EV_HVChargManagVWMQB 001001
   ROD: EV_HVChargManagVWMQB.rod
Address C0: Act. for Ext. Noise (----)       Labels: None
   Part No SW: 5QE 035 335 B    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H07 0186
   Serial number: EN142504290000
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 004011
   ROD: EV_ENoiseS1NNVW3707_VW37.rod
   VCID: C0855F415BE5B43F39-8094
Address C5: Therm. mgt. (J1024)       Labels: None
   Part No SW: 5GE 907 458     HW: 5GE 907 458
   Component: TME-Min       H03 0107
   Serial number: 0000633
   ASAM Dataset: EV_ThermContrVISAU49X 001009
   ROD: EV_ThermContrVISAU49X_VW37.rod
   VCID: 820195491569662F6F-80D6
   Slave 2:
   Slave 3:
   Subsystem 11 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G395 pT-Sens1  H61 0006
   Subsystem 12 - Part No SW: 12E 963 231 E    HW: 12E 963 231 E
   Component: J848 HV-PTC  H09 0205
   Serial number:  T141693003805000074
   Subsystem 13 - Part No SW: 5QE 820 803     HW: 5QE 820 803
   Component: J842 eKK  H02 0005
   Subsystem 14 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G826 pT-Sens2  H61 0006
   Subsystem 15 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G827 pT-Sens3  H61 0006
   Subsystem 16 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G828 pT-Sens4  H61 0006
   Subsystem 17 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G829 pT-Sens5  H61 0006
32836 - Coolant Pump Control Circuit
          P2600 00 [036] - Open
                    Mileage: 3224 km
                    Date: 2015.06.17
                    Time: 18:46:10
32837 - Coolant Pump Control Circuit
          P2602 00 [036] - Short to Ground
                    Mileage: 3224 km
                    Date: 2015.06.17
                    Time: 18:46:10
36921 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 3224 km
                    Date: 2015.06.17
                    Time: 18:32:54
37009 - Databus
                    Mileage: 3224 km
                    Date: 2015.06.17
                    Time: 18:32:54
37051 - Databus
                    Mileage: 3224 km
                    Date: 2015.06.17
                    Time: 18:32:54
59059 - Refrigerant Expansion Valve 2
          P1C0E 00 [047] - Implausible Signal
                    Mileage: 3224 km
                    Date: 2015.06.17
                    Time: 19:13:07
Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
   Part No SW: 5QE 915 681 B    HW: 5QE 915 681 B
   Component: OBC Delta-ES  H52 1550
   ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
   ROD: EV_OBCTwoPhaseDT2VW3707.rod
   VCID: CB9F786D62A36767DC-809E
End-------------------------(Elapsed Time: 05:04)--------------------------
VWVic
C?ID=9932
Thanks Uwe for the quick reply!!! Appreciate the tools and help!
Vic
OK, I see that there are Adaptation Channels in J966 for Start and End Charge Time of Day, but if they require a Security Access to change, I've come up empty on that so far. :(
