Retrofit ACC ibiza 2019
wamba
Algeria
C?ID=490768
hi all
I'm trying to retrofit ACC on seat ibiza 2019
I have to change the steering column and I need the complete adaptation of the BCM 2Q0 ibiza with ACC and if possible also the photo or the diagram of the connection of the steering column
Thank you for your help
downtime
C?ID=280813
And why do you need to change the steering column? Never heard of that in ACC retrofit.
wamba
Algeria
C?ID=490768
so I come back with something new, I changed the steering column and coded everything correctly, now I have only this error (fault timout tsk 08)
2kaa52
Ceska Republica, Praha
C?ID=319193
Again.......pls post a complete Autoscan for help.
And it can also be helpful to answer question from @downtime
wamba
Algeria
C?ID=490768
Saturday,09,July,2022,12:10:48:51159
VCDS Version: 22.3.1.4 (x64)  HEX-NET2 CB: 0.4615.4
Data version: 20220407 DS337.0
VIN: VSSZZZKJZK5003755   License Plate:
Mileage: 23780km-14776mi   Repair Order:
Chassis Type: KJ-SE27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 44 55 5F 6C A5 D6 D7
VIN: VSSZZZKJZK5003755   Mileage: 23780km-14776miles
Address 01: Engine (J623-CWVA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 057 DQ    HW: 04E 907 309 CP
   Component: R4 1.6l MPI   H24 5380
   Revision: 31H24000    CVN: A321479F
   Coding: 011A0012034414000000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM16MPI01104E906057DQ 001003
   ROD: EV_ECM16MPI01104E906057DQ.rod
   VCID: 79A4840649552FB3881-802C
   VINID: 9A38EAAAA6DAA9B1400031C5143ACDBB10
Readiness: 1100 0000
   Part No SW: 09G 927 158 BS    HW: 09G 927 158
   Component: AISIN AG6 G3  204 3514
   CVN: F6AEA27E
   Coding: 0000000000000000010000000000000000000000
   Shop #: WSC 00049 770 00100
   ROD: EV_TCMAQ250031_002_VW27.rod
   VCID: 055CF8F635AD5B53FC9-8050
   Part No SW: 2Q0 614 517 AE    HW: 2Q0 614 517 L
   Component: ESC_base      H13 0242
   Serial number: 08501372181213
   Coding: 530D4C573541CAB03203AC1B34DF22A649124926226A245844542254452C4465924892644456241A222A442AA2299643759469C2AE
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004036
   ROD: EV_Brake1BOSCHESPMQBA0_004.rod
   VCID: 71B4BC26112567F3301-8024
   Part No SW: 6F1 820 045 F    HW: 6F1 820 045 F
   Component: SG_AC_Manuell H01 0301
   Coding: 010000000800000010000800020000000000000000000000000000000000
   ASAM Dataset: EV_ACManuePrehMQBA0 001011
   ROD: EV_ACManuePrehMQBA0_SE27.rod
   VCID: 261E9F7AE86B704B953-8072
   Part No SW: 2Q0 937 090 A    HW: 2Q0 937 090
   Component: BCM A0 Std+   H98 0926
   Serial number: 00001834601125
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204_SK27.rod
   VCID: 30327922DAAF2EFB7FF-8064
   Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S8Y17M08D04H00M15S38
   Coding: 00194D
   Driver door control module:
   Subsystem 2 - Part No SW: 2Q1 959 881 B    HW: 2Q1 959 881 B
   Component: FHSG_DRV  001 0001
   Serial number: 00000000000016089541
   Coding: 13000F
   Front passenger door control module:
   Subsystem 3 - Part No SW: 2Q1 959 882 B    HW: 2Q1 959 882 B
   Component: FHSG_PSG  001 0001
   Serial number: 00000000000015872756
   Coding: 09000F
   Subsystem 4 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000026425319
   Subsystem 5 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000026622720
   Coding: 190000
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417618093
   Coding: 0271163811
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51F41CA6B16547F3101-8004
   Part No SW: 2Q0 907 572 T    HW: 2Q0 907 572 C
   Component: ACCCONTIMQB   H06 0383
   Coding: 3000600348FF8728749C810560508700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: 45DC38F6752D9B53BC9-8010
1085 - Databus
          [FAULT_TIMEOUT_TSK_08]
                    Reset counter: 113
                    Mileage: 23780 km
                    Date: 2022.07.09
                    Time: 12:05:53
                    Voltage terminal 15: 13.8 V
                    Control Module temperature: 56 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.09 m/s²
                    Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
   Part No SW: 5QF 959 655 L    HW: 5QF 959 655 L
   Component: Airbag VW22   006 0520
   Revision: --------    Serial number: 003XNPQWSJK.
   Coding: 88CCC0C000000000580000CF000C00000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
   ROD: EV_AirbaVW22TS6VW48X.rod
   VCID: 5F90CA9EF7B1E183965-800A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 512 18
   Serial number: 3570000000025045073+
   Subsystem 2 - Part No SW: -----------    HW: 454 002 711 18
   Serial number: 358000000004F160453B
   Subsystem 3 - Part No SW: -----------    HW: 454 800 812 18
   Serial number: 35100C22B2717000000A
   Subsystem 4 - Part No SW: -----------    HW: 454 800 501 19
   Serial number: 352002A0A2C17000000B
   Subsystem 5 - Part No SW: -----------    HW: 454 800 512 18
   Component: FrontSensor_D  307 0189
   Serial number: 355005EB8A116000000Q
   Part No SW: 5Q0 953 521 GE    HW: 5Q0 953 569 A
   Revision: FF035035    Serial number: 20180219400046
   Coding: 6414
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7BA89E0E43691DA39AD-802E
Address 17: Instruments (J285)       Labels:* None-SRI3
   Part No SW: 6F0 920 790     HW: 6F0 920 790
   Component: KOMBI         616 1703
   Coding: 04AD190C6D800008038872031001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001031
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 6780D27E2FE1A9436E5-8032
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5366
   Serial number: 18121810803579
   Coding: 0101000820086400E8000010140F00000001070000000000000000000000
   Shop #: WSC 12345 123 61029
   GVL: 01543C0000000000408090000002C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 6E8EA75A001B780B2D3-803A
   Generator:
   Component: 0-00-02-00-04
   Subsystem 2 - Part No SW: 5F0 959 537 D    HW: 5F0 959 537 D
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000I0315240818
   Coding: 012000
Address 44: Steering Assist (J792)       Labels:* 2Qx-909-144-V1.clb
   Part No SW: 2Q1 909 144 M    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 611 6041
   Serial number: 0900981CB4J3433
   Coding: 010001000100000001000201010001010000010001
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: 3C2A5D1206E7DA9BD37-8068
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0080
   Coding: 0708000009200003
   ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
   ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
   VCID: 41D42CE66105B773801-8014
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5F0 035 874 A    HW: 5F0 035 874 A
   Component: MU-S-ND-ER    H50 0516
   Serial number: SEZAZ2W0372078
   Coding: 04720001BE0A000011110001010808001F0101E401200400C6
   ASAM Dataset: EV_MUStd6C3TSAT 001015
   ROD: EV_MUStd6C3TSAT_SE27.rod
   VCID: 2700927EEF616943AE5-8072
   Subsystem 1 - Part No SW: 6F0 919 605 A    HW: 6F0 919 605 A
   Component: ABT_Std-2_Nav  H53 8130
   Serial number: SEZ6ZHW0321483
   Data carrier:
   Subsystem 2 - Part No SW: 6P0 919 866 BN    HW: -----------
   Component: MRM3 2021  --- 1520
   Component: RVC Compact   H18 0231
   Coding: 0473000122002017000040
   VCID: 3924440609D5EFB3C81-806C
Address A5: Frt Sens. Drv. Assist (R242)       Labels:. 3Q0-980-65X-A5.clb
   Component: MQB_B_MFK     H08 0272
   Serial number: 16031812P23039
   Coding: 000307000000040100221344C156A80090000E200020
   ROD: EV_MFKBoschMQBB.rod
0663 - Control Module For Camera
          C110A 76 [009] - Incorrect Mounting Position
          [Initial_calibration_out_of_range]
                    Reset counter: 113
                    Mileage: 23780 km
                    Date: 2022.07.09
                    Time: 12:03:54
                    Control Module temperature: 70 °C
                    Outside temperature: 26.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 37.1 s
                    Voltage terminal 15: 13.5 V
                    mid: 00 1C
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
   Component: LED1L         H06 0005
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 7EAE971A507B088BBD3-802A
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H06 0005
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW27.rod
End----------(Elapsed Time: 01:24, VBatt start/end: 13.8V/13.7V)-----------
wamba
Algeria
C?ID=490768
downtime
C?ID=280813
Retrofit the right camera. You need 2Q0 camera and of course someone to generate the swap code for traffic sign recognition.
You will never get the 3Q0 camera to work good enough :(
The TSK error on ACC is most likely coding error on it. Can’t check it now as not home :(
wamba
Algeria
C?ID=490768
thank you for your answer, but the problem is not the camera, I installed it just for testing even when the camera is disconnected I have this error and I cannot find the problem
downtime
C?ID=280813
TSK error in ACC is probably due to incorrect coding IN ACC.
