Caddy 2k, 2012, trying fit CruiseControl
boathansm
Norway
C?ID=448382
Hi, I am trying to get cruisecontrol to work, get VCDS to accept enige Lcode, but not the steering wheel.
I get, error 31, when I am trying code with code: 1882160000, my original code is 1882060000
Is the steering module wrong or I am trying wrong code?
Can someone help a newbie?
Monday,04,July,2022,18:09:42:55611
Dealer/Shop Name: HML Garage
VIN: WV1ZZZ2KZCX   License Plate:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 22 25 42 44 46 52 56 69 77
VIN: WV1ZZZ2KZCX134168   Mileage: 255470km-158741miles
Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 NL    HW: 03L 907 309 AD
   Component: R4 2.0l TDI   H25 9978
   Revision: 42H25---    Serial number: 00000000000000 CVN: B7482B95
   Coding: 001D001A042600080000
   Shop #: WSC 00087 218 12345
   ASAM Dataset: EV_ECM20TDI01103L906018NL 003006
   ROD: EV_ECM20TDI01103L906018NL.rod
   VCID: 015F8CA0D18499B3C01-8054
   VINID: 9E606AAAA09BA93A010C4046208607A10C
4714 - Steering Column Control Module
          U0212 00 [047] - No Communications
                    Mileage: 255477 km
                    Date: 2022.07.04
                    Time: 16:58:24
                    Engine RPM: 782.00 /min
                    Normed load value: 35.3 %
                    Coolant temperature: 62 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 13.880 V
                    Cruise Control System (CCS): status-Bits 0-7: 204
                    selected gear-Bits 0-7: 0
   Part No SW: 02E 300 014 G    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3112
   Revision: 05551213    Serial number: 00001203022062
   Shop #: WSC 35110 377 08192
   VCID: 1675CFFCA48A0E0B053-8042
   Revision: 00H31001
   Coding: 623C600D092503FE460C06EA9021C042310000
   VCID: 7BA3FE48B3E8F3639AD-802E
   Part No SW: 7N0 907 426 AQ    HW: 7N0 907 426 AQ
   Component: AC Manuell    H19 0404
   Revision: 00001018
   Coding: 0000004002
   Shop #: WSC 35110 790 50316
   VCID: 035386A8CB988BA3D2D-8056
   Part No SW: 5K0 937 086 P    HW: 5K0 937 086 P
   Component: BCM PQ35 M+   021 0064
   Revision: BD021001
   Coding: 411A583A80251A6B088800829000016403017288524FAD60648000000040
   VCID: 41DF4CA0918459B3801-8014
   Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 07031  26  0512
   Coding: 009795
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 L    HW: 1K0 919 475 L
   Component: PARKHILFE     006 1806
   Revision: 00006000    Serial number: 0 263 004 450
   Coding: 118101
   VCID: 3B233E48F3683363DAD-806E
   Component: VW10Airbag029 H07 0013
   Revision: --------    Serial number: 003HL00AW3JJ
   Coding: 000000000000000000000000000000003239
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 35372870D5CCE5132C9-8060
   Part No SW: 5K0 953 507 AF    HW: 5K0 953 549 A
   Revision: --------    Serial number:  90422LCC001MA
   Coding: 1882060000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 74B1D5749E36BC1BDB7-8020
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0080802
   Coding: 820000
   Part No SW: 2K0 920 875 E    HW: 2K0 920 875 E
   Coding: 181A01
   VCID: 313F1C6021A4C933701-8064
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 A
   Component: Standheizer     043 4730
   Revision: 00043000    Serial number: 09022127000000
   Coding: 0031012
   Shop #: WSC 41559 001 1048576
   VCID: 33331668D738FB2302D-8066
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 110312F2002914
   Coding: 357400
   VCID: 3A2D3B4CFC520A6BC1B-806E
   Part No SW: 2K0 907 554 B    HW: 2K0 907 554 B
   Component: Haldex 4Motion      5007
   Coding: 0000005
   VCID: 2D070010311CADD3549-8078
   VCID: 6A8DCB0CCCF27AEB71B-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2109
   Coding: 0000048
   VCID: 48C95184BEBE68FB47F-801C
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 140    3305
   Revision: 00H22000
   VCID: 372B2278C34017033E5-8062
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000048
   VCID: 47CB52B8B3A067834E5-8012
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: Radio RCD310  042 0082
   Revision: 00000001    Serial number: VWZ1Z2M4280780
   Coding: 05000200010013
   VCID: 72BDD36CE4A2B22BC9B-8026
00856 - Radio Antenna
                    Reset counter: 36
                    Mileage: 255477 km
                    Date: 2016.11.24
                    Time: 16:58:39
   Revision: 3A001001    Serial number: 00008030087107
   Coding: 410D000100000000
   VCID: 303919642A2EC03B7FF-8064
   Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007662106207
   Coding: 0A01010000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 2615FF3C186A9E8B953-8072
End----------(Elapsed Time: 01:13, VBatt start/end: 13.4V/13.5V)-----------
boathansm
Norway
C?ID=448382
Now I have cruise controll, but I have another problem. Since I took steering wheel module from a car with manuel car and I have automatic gear, I have lost function to not get the key out of ingnition without gear is in Park.
Steering module I have in car now is 5K0-953-549-E
Then I need 5K0-953-549-B to get all to work like I want.
If I know right now?
