Polo 6R ABS Coding
nik1020
C?ID=81989
The Customer replaced ECU kit and lost the ABS coding - please calculate proper codding for this car
Original VIN from the car - WVWZZZ6RZBU081076
ECU donor VIN - WVWZZZ6RZBU058691
Sunday,03,July,2022,17:21:51:57449
VCDS Version: 21.3.0.0 (x64)
VIN: WVWZZZ6RZBU058691   License Plate:
Mileage: 119450km-74222mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZBU058691   Mileage: 119450km-74222miles
Address 01: Engine (J623-CGPA)       Labels:. 03E-906-019-CGP.clb
   Part No SW: 03E 906 019 B    HW: 03E 906 019 B
   Component: SIMOS11.1     H03 8691
   Revision: --------    Serial number:
   Coding: 00110016000400080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12MPI02103E906019B 001006
   ROD: EV_ECM12MPI021.rod
   VCID: 234E072B2A359193FE-8076
Readiness: 0110 0101
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 31414 790 31414
   VCID: 071673BBB2CD5DB382-8052
                    Fault Frequency: 15
                    Reset counter: 160
                    Mileage: 119437 km
                    Date: 2016.11.22
                    Time: 00:29:51
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1213
                    Hex Value: 0x149E
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Status: 01100101
                    Fault Frequency: 15
                    Reset counter: 160
                    Mileage: 119437 km
                    Date: 2016.11.22
                    Time: 00:29:51
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1251
                    Hex Value: 0x1B9E
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
                    Fault Frequency: 15
                    Reset counter: 160
                    Mileage: 119437 km
                    Date: 2016.11.22
                    Time: 00:29:51
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x12E1
                    Hex Value: 0x209E
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
03306 - Coding Not Valid
                    Reset counter: 199
                    Mileage: 119437 km
                    Date: 2016.11.22
                    Time: 00:41:37
                    Hex Value: 0x0002
                    Hex Value: 0x0002
                    Hex Value: 0x12E7
                    Hex Value: 0x259B
                    Hex Value: 0x00FF
                    Hex Value: 0x7F81
                    Hex Value: 0x7C00
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 3260F26F6DCF081B05-8066
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 160
                    Mileage: 119455 km
                    Date: 2012.09.09
                    Time: 02:49:20
                    Temperature: 23.0°C
                    Time: 372.60 s
                    Time: 0.00 s
                    Voltage: 11.90 V
                    Absolute Pres.: 0.0 bar
                    Time: 0.00 s
   Part No SW: 6R0 937 086 K    HW: 6R0 937 086
   Component: BCM PQ25 M++4 H46 0256
   Revision: BD046001    Serial number: 0392 013111030
   Coding: 24B02BBF08A10000003008003D2B0CD00040410F60060000200000000000
   Shop #: WSC 00113 210 92232
   VCID: 448CA4B7C77BB6ABA7-8010
   Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  007 1611
   Serial number: KU0KU017031100010080
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  007 1611
   Serial number: KU0KU016031100014686
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Serial number: KU0KU022031100010375
   Coding: 08BC32
   Subsystem 4 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  007 1611
   Serial number: KU0KU023031100014650
   Coding: 08BC32
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag027 H09 0020
   Revision: --------    Serial number: 003GX00JYZ7I
   Coding: 003237
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A908A8FED5F60DB5D-801E
   Serial number: 3575HRB40670H0LUC9KT
   Serial number: 3585HRB40610H0LU8O7M
   Serial number: 3515RRB405L0H1GGL90H
   Serial number: 3525RRB405N0H1GGJ1IS
   Part No SW: 6R0 920 960 F    HW: 6R0 920 960 F
   Component: KOMBI         H04 0304
   Coding: 440200
   VCID: 3874C04783B3E24B3B-806C
   Part No SW: 6N0 909 901     HW: 6R0 937 086
   Component: GW-K-CAN TP20 H46 0256
   Revision: BD046001
   Coding: 002300
   VCID: 70E43867A3437A0B33-8024
   Component: IMMO          H04 0304
   VCID: 6AD02A0F8D9F80DB7D-803E
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 31414
   VCID: 2F66FB1BEAFD25F36A-807A
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2L0383456
   Coding: 0500040002
   VCID: 6BDE2F0B8A6599D306-803E
End-------------------------(Elapsed Time: 02:14)--------------------------
Tazawii
Hi, We have the same problem. Can you please help us out?
WVWZZZ6RZAY013047
Westbury, UK
WVWZZZ6RZAY013047
Will need you to post an Auto-Scan, full and unedited using the English version of VCDS, as the ABS coding is dependent on the configuration of the vehicle so just a VIN isn't enough.
iichel
Eindhoven, NB, NL
C?ID=284912
Technically, you could with a good Partslink24 subscription. Find engine code, gearbox code, abs type etc. and assume they are all still as it left the factory. But it's more fun with a full autoscan, of course.
Westbury, UK
Not sure that this request is going to end well....
  • Haha
Reactions: JMR
etz2k
C?ID=69430
It's also unclear to me, why some guys don't read/understand some simple things like, "please post a autoscan, if you need car specific help". This happens so many times. :banghead:
JMR
Romania
C?ID=432218
Well..some people think that just registering on a forum will bring them a higher rate of success in finding the answer to their problem. And they do on some forums. However , this here forum is to support /help the VCDS and its users ( legit users ). So there is the difference..on other forums they don t care what diagnostic interface they use ..here is a must to use a legit one.
Westbury, UK
I think the issue is that even some verified users seem resistant to posting an Auto-Scan when requested, even when it's explained that an Auto-Scan is not just about fault codes but also tells us important information about the configuration of the vehicle.
Sometimes it seems that it's believed that all builds of a given vehicle type are identical, and even that what applies to one vehicle will apply to all others.
I think the complexity of modern vehicles is something that many owners simply do not comprehend, and hence they do not understand our need for real detail of their vehicle in order to help them.
iichel
Eindhoven, NB, NL
C?ID=284912
I think people are just being lazy
etz2k
C?ID=69430
But, if all other users are also lazy they get nothing.
If i have a problem i search in the forum if i find a solution and if i find nothing i start a thread. And if i read min. 1 or 2 other threads i will recognize that other users mostly need a autoscan to see details of my car and can help me.
That tells me that this guys seems to think this forum is something like a RT-Hotline.
But maybe i'm a little oldschool and stupid.
Westbury, UK
I think since @Tazawii still only has a post count of 1 he's not relying on us to help him...
