2010 VW EOS No Power Steering
gmw
Galax, VA, USA
HUC-2H
I have a 2010 VW EOS (VIN: WVWBA7AH3AV018239) and the power steering has failed. Code reader says code 778 Steering Angle Sensor (G85) and code 1309 Power Steering Control Module (J500) Implausible Signal. After reading around in several forums I learned that the 2010 EOS did not have the steering angle sensor in the steering column. So I assume the steering angle sensor is internal to the steering rack. It's my understanding that the steering angle sensor that is internal to the rack can not be replaced. I found an electric power steering rack out of a 2014 Passat. The Passat steering rack part number is 561.423.051.M. I installed it, but still no power steering. I recently read Dana's thread on the location and other info regarding VW steering racks (https://forums.ross-tech.com/index.php?threads/11654/). One section on the 2014 Passat steering rack says 5N1 part number steering racks with Component J500 do NOT support an internal Steering Angle Sensor. So does this mean the steering rack I have does not have an internal steering angle sensor or that the 2014 Passat does not support an internal steering angle sensor? If it does have an internal steering angle sensor, do I just need to get someone with a Vagcom to edit the settings? Thanks for any help!
2kaa52
C?ID=319193
For help,pls post a Autoscan of this car
Yes the G85 is in the steering gear.
Are you sure? It depends on the type of ABS in the car. An Auto-Scan would really help here.
Reactions: JMR
It is what I gleaned from the VIN then elSa using the sales type and wiring diagram
  • Informative
etz2k
C?ID=69430
Not realy, it's only a virtual sensor in the J500 modul of the ZF Gen3 steering rack ;).
Rdw lhd Passat use the APA steering rack (5N1) w/o intern G85. Rhd and nar Passat has a gen3 steering rack.
Reactions: JMR
gmw
Galax, VA, USA
HUC-2H
2010 VW EOS (VIN: WVWBA7AH3AV018239). Code reader says code 778 Steering Angle Sensor (G85) and code 1309 Power Steering Control Module (J500) Implausible Signal. So what I've read I need to make a setting change to enable the steering angle sensor in the steering rack. I thought I could do this with Ross-Tech VCDS. I've connected it to the car and the VCDS is connected and functional. When I try to go to 44-Steering Assist it says no response from controller module. Can't get a scan since there is no response from control module. Does anyone know what I need to do to enable the steering angle sensor in the steering rack? Thanks for any help.
gmw
Galax, VA, USA
HUC-2H
Friday,08,July,2022,20:52:38:13524
VCDS Version: 22.3.1.4 (x64)
VIN: WVWBA7AH3AV018239   License Plate:
Chassis Type: AH-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 26 2E 42 44 46 52 56 62 63
          65 72 77
VIN: WVWBA7AH3AV018239   Mileage: 270910km-168335miles
04-Steering Angle -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
63-Entry Assist,D -- Status: OK 0000
Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
   Part No SW: 06J 906 021 B    HW: 06J 906 021
   Component: MED17.1             5868
   Revision: E3H15---    Serial number:
   Coding: 041C01081C070160
   Shop #: WSC 00020 790 00000
   VCID: 244DF857E7EF2BAF8B-8070
   VINID: 9E69D24474580D198004808324EAD81E01
008801 - Boost Pressure Control Valve (N249)
               P2261 - 000 - Mechanical Malfunction - Intermittent
                    Mileage: 270907 km
                    Date: 2016.11.28
                    Time: 05:26:21
                    RPM: 2030 /min
                    Load: 11.0 %
                    Speed: 99.0 km/h
                    Temperature: 99.0°C
                    Temperature: 35.0°C
                    Absolute Pres.: 930.0 mbar
   Part No SW: 02E 300 053 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2106
   Revision:    51112    Serial number: 00001002240674
   Shop #: WSC 00020 000 90108
   VCID: 132FAB8B32415C1762-8046
18036 - Powertrain Data Bus
            P1628 - 000 - Missing Message from Steering Angle Sensor
                    Fault Frequency: 255
                    Mileage: 270910 km
                    Date: 2016.11.28
                    Time: 08:44:11
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 514B600A492300028A0D06E792220041310000
   VCID: 7AF1E62FF5EB8D5F81-802E
                    Reset counter: 77
                    Mileage: 270589 km
                    Date: 2016.11.28
                    Time: 14:02:02
                    Count: 3
                    Count: 13
                    Count: 28672
                    Count: 167
                    Count: 28928
                    Count: 510
                    Reset counter: 77
                    Mileage: 270589 km
                    Date: 2016.11.28
                    Time: 14:02:10
                    Count: 7
                    Count: 13
                    Count: 28672
                    Count: 128
                    Count: 28416
                    Count: 510
                    Reset counter: 16
                    Mileage: 270280 km
                    Date: 2016.11.28
                    Time: 06:40:24
                    Count: 3
                    Count: 14
                    Count: 28672
                    Count: 166
                    Count: 42496
                    Count: 768
                    Reset counter: 16
                    Mileage: 270280 km
                    Date: 2016.11.28
                    Time: 06:40:24
                    Count: 3
                    Count: 14
                    Count: 28672
                    Count: 8213
                    Count: 42496
                    Count: 768
   Part No SW: 5K0 907 044 CF    HW: 5K0 907 044 CF
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000001002
   Shop #: WSC 00020 999 00000
   VCID: 71E3C103A09DCE0730-8024
   Part No SW: 5K0 937 087 G    HW: 5K0 937 087 G
   Component: BCM PQ35 H+   111 0128
   Revision: BL111001
   Coding: 6D000A1B92232A6480880085700005044101558641008D605C8020000000
   VCID: 39733923B06D4647C8-806C
   Subsystem 1 - Part No: 1Q1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 02031  22  0512
   Coding: 009795
                    Reset counter: 77
                        Term 15 Off
                    Voltage: 5.95 V
                    Reset counter: 77
                    Mileage: 270589 km
                    Date: 2016.11.28
                    Time: 00:01:04
                        Term 15 Off
                    Voltage: 8.65 V
                    Fault Frequency: 18
                    Reset counter: 48
                    Mileage: 270280 km
                    Date: 2016.11.28
                    Time: 06:40:27
                    Voltage: 11.90 V
                    Fault Frequency: 24
                    Reset counter: 48
                    Mileage: 270280 km
                    Date: 2016.11.28
                    Time: 06:40:29
                    Voltage: 11.90 V
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
   Component: AQ Airbag VW8C      0180
   Revision: 92010018    Serial number: 003B3004V1S
   Coding: 0016721
   VCID: 3A71262F756B4D5FC1-806E
   Subsystem 1 - Part No: 1Q0 959 339 A
   Component: BF-Gewichtsens. 007 0003
   Subsystem 2 - Serial number: 52314
   Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332SRB40AE184978ÿ†63
   Subsystem 5 - Serial number: 184978ÿ†6342SRB40AE10D98Bÿ†63
   Subsystem 6 - Serial number: 10D98Bÿ†6372URB40479BB3FLÿ†63
   Subsystem 7 - Serial number: 9BB3FLÿ†6382URB40479B1857ÿ
   Subsystem 8 - Serial number: 9B1857ÿ
   Part No SW: 1K5 953 521 F    HW: 5K0 953 569 B
   Component: LENKS.MODUL   009 0122
   Revision: FF010035    Serial number: 20100223200852
   Coding: 088A140000
   ASAM Dataset: EV_SMLSNGVOLWS A01002
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 306504076B17870F7F-8064
   Coding: E20000
   Part No SW: 1Q0 920 974 N    HW: 1Q0 920 974 N
   Component: KOMBI         H05 0305
   Coding: 271F00
   VCID: 3F87573BA6496877F6-806A
13638912 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 60
                    Mileage: 270910 km
                    Date: 2022.07.08
                    Time: 08:44:10
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K10226053F
   Coding: ED807F27041612005000
   VCID: 69D3A963404D36C778-803C
                    Reset counter: 60
                    Mileage: 270910 km
                    Reset counter: 60
                    Mileage: 270910 km
   Part No SW: 1Q0 919 965 A    HW: 1Q0 919 965 A
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1350208TLCRN04
   Coding: 0000002
   Component: IMMO          H05 0305
   VCID: 6AD1D66F8D4B3DDF71-803E
Address 26: Auto Roof        Labels: 1Q0-959-255.clb
   Part No SW: 1Q0 959 255 E    HW: 1Q0 959 255 E
   Component: Verdecksteuergeraet 0842
   Revision: 0033100N    Serial number: 100390250
   Coding: 0655364
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667811091
   VCID: 2649E25F51D3D9BF95-8072
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2121
   Coding: 0017591
   VCID: 39733923706D4647C8-806C
Address 44: Steering Assist
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0017590
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0035
   Revision: -----20S    Serial number: VWZ4Z7K1117876
   Coding: 0100040004
   VCID: 61C3B143787D7E87A0-8034
                    Reset counter: 60
                    Mileage: 270910 km
                    Date: 2016.11.28
                    Time: 08:44:11
   Part No SW: 1Q0 959 811 B    HW: 1Q0 959 811 B
   Component: Tuer-SG         004 0602
   Coding: 0000144
   Shop #: WSC 00020 790 1012544
   VCID: 356B35135C75A2272C-8060
Address 63: Entry Assist,D        Labels: 1Q0-959-790.lbl
   Part No SW: 1Q0 959 790 A    HW: 1Q0 959 790 A
   Component: J572  EASYENTRY FS  0603
   Revision: 00H03000    Serial number: 5DS008646-01--
   Coding: 0000002
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           111 0821
   Coding: 018705
02904 - Hard Warning 3
                    Fault Status: 01100010
                    Mileage: 270910 km
                    Date: 2016.11.28
                    Time: 08:44:11
                    Text: 3362983781
                    Pressure: 0.00 bar
                    Pressure: 2.30 bar
                    Temperature: 52.4°C
                    Text: 00
02214 - Tire Pressure Warning
                    Mileage: 270910 km
                    Date: 2016.11.28
                    Time: 08:44:11
                    Text: 3362983781
                    Pressure: 0.00 bar
                    Pressure: 2.30 bar
                    Temperature: 52.4°C
                    Text: 00
                    Mileage: 270910 km
                    Date: 2016.11.28
                    Time: 08:44:11
   Part No SW: 1Q0 959 812 B    HW: 1Q0 959 812 B
   Coding: 0000144
   VCID: 3669321F4173A93F25-8062
Address 77: Telephone        Labels: None
   VCID: 55AB9593BC358227CC-8000
No Faults Found
End-------------------------(Elapsed Time: 07:25)--------------------------
etz2k
C?ID=69430
Address 44: Steering Assist Cannot be reached
If it can't reach the -J500, there is no power steering and there is also no -G85 (because it's a software-modul inside).
Have you checked the wiring and plugs to the -J500 on the steering rack?
gmw
Galax, VA, USA
HUC-2H
Yes, I did a continuity test between the connectors (3 wires signal and 2 wire power) where it plugs onto the steering rack, up to the 3 wire connector just under the left headlight, and to the 2 power wires (one to fuse box and one to ground). All were good. I'm not sure about the 3 wire connector from there as it goes into a large bundle wiring harness from there.
gmw
Galax, VA, USA
HUC-2H
I figured it out. It was a power problem coming out of the fuse box under the hood. No power on the post that the power steering main power lead attaches to. Evidently, there is an 80 amp fuse under the aluminum plate. I've temporarily moved the connection to the main power lead coming in from the battery. I've got to figure out how to replace the fuse or get another fuse box. Thanks etz2k.
