09' Seat Leon FR, ABS Coding lost
ojaibat
Saudi Arabia
C?ID=255829
So a friend of mine just bought this car recently with loads of issues and i'm trying to help him to figure it out. I ran a full auto scan and one of the most obvious things was that the ABS module lost it's coding. We don't know much of history about the car but as per my inspection i DON'T think the ABS was replaced that is why coding is required. Can someone help me to get the ABS code for this car? Full auto scan is bellow:
Thursday,30,June,2022,01:05:18:43247
VCDS Version: 22.3.1.4 (x64)
VIN: VSSCE61P09R019457   License Plate:
Mileage: 355710km-221027mi   Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSCE61P09R019457   Mileage: 355710km-221027miles
   Part No SW: 1P0 907 115 J    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: SEZ7Z0H3986839
   Coding: 0303001018070160
   Shop #: WSC 06402 785 00200
   VCID: 326B1C4BAD878E1F09-8066
   VINID: 9A38D35460600098800491051C222694EA
Readiness: 0110 0101
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 42802 428 98691
   VCID: 7EF3F87BE95F9A7FBD-802A
01486 - System Function Test Activated
                    Reset counter: 182
                    Mileage: 355719 km
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 320
                    Count: 44544
                    Fault Status: 01100101
                    Reset counter: 182
                    Mileage: 355719 km
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 279
                    Count: 44544
                    Reset counter: 182
                    Mileage: 355719 km
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 295
                    Count: 44544
                    Reset counter: 182
                    Mileage: 355719 km
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 270
                    Count: 44544
                    Reset counter: 182
                    Mileage: 355719 km
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 195
                    Count: 44544
                    Fault Status: 01101100
                    Reset counter: 182
                    Mileage: 355719 km
                    Count: 2
                    Count: 2
                    Count: 12800
                    Count: 105
                    Count: 43776
   Part No: 1P0 907 044 D
   Component: ClimatronicPQ35 011 0702
   VCID: 2D510F37B4B9D1E754-8078
   Revision: 00H54000    Serial number: 00000005839988
   Coding: 818C0F2F00041000431D00000000000000017F075C400000000000000000
   VCID: 3365194F529D871702-8066
   Subsystem 1 - Part No: 1P0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 100708 022  0601
   Coding: 00056208
   Shop #: WSC 06402
9 Faults Found:
01117 - Generator Terminal DF Load Signal
                    Reset counter: 222
                    Mileage: 355719 km
                    Voltage: 12.30 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 182
                    Mileage: 355719 km
                    Voltage: 12.35 V
                    Reset counter: 182
                    Mileage: 355719 km
                    Voltage: 12.35 V
01495 - Bulb for High-Beams; Left (M30)
                    Reset counter: 182
                    Mileage: 355719 km
                    Voltage: 12.35 V
                    Reset counter: 182
                    Mileage: 355719 km
                    Voltage: 12.35 V
02403 - Terminal 15 for Interior
                    Fault Status: 00101100
                    Reset counter: 222
                    Mileage: 355719 km
                    Voltage: 12.35 V
                    Reset counter: 222
                    Mileage: 355719 km
                    Voltage: 12.35 V
                    Reset counter: 222
                    Mileage: 355719 km
                    Voltage: 12.35 V
                    Reset counter: 222
                    Mileage: 355719 km
                    Voltage: 12.35 V
   Component: J234__A01 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPDRPGNP
   Coding: 0012337
   VCID: 3B75316F7ACD4F57DA-806E
   Subsystem 1 - Serial number: 6333FTS613741508
   Subsystem 2 - Serial number: 6343FTS633231488
   Subsystem 3 - Serial number: 6353ETS6BH7VTVNH
   Subsystem 4 - Serial number: 6363ETS6A4TLTVNP
                    Fault Status: 11100001
                    Reset counter: 182
                    Mileage: 355718 km
                    Time: 11:04:32
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           752 0101
   Coding: 0002042
   VCID: 78FFEE630B7BA44FF7-802C
   Component: E0221           005 0060
   Part No: 1P0 920 825 B
   Component: KOMBIINSTRUMENT VO3 0424
   Coding: 0002601
   Shop #: WSC 54321 123 999999
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K086260C36
   Coding: E9807F060002020200
   VCID: 356127575CE999272C-8060
                    Fault Frequency: 16
                    Reset counter: 182
                    Mileage: 355718 km
                    Time: 11:04:31
01304 - Radio
                    Reset counter: 182
                    Mileage: 355718 km
                    Time: 11:04:36
   Component: IMMO            VO3 0424
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1517
   Revision: 71009005    Serial number: 00000771988508
   Coding: 0004272
   VCID: 408F4683132B2C8F8F-8014
                    Reset counter: 182
                    Reset counter: 222
                    Mileage: 355719 km
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 000    3201
   Revision: 00H15000
   Shop #: WSC 79408 027 739526
   VCID: 34671A535793802F1B-8060
                    Fault Status: 11100101
                    Mileage: 355718 km
                    Time: 11:04:30
                    Battery Volts: 12.5 V
                        DU
                    Temperature: 56.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Coding: 988000005283CC7F7F06850560084F01207C80
   VCID: 0305898F42BDF797D2-8056
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1517
   Revision: 71009005    Serial number: 00000310188524
   Coding: 0004272
   VCID: 418943871821258780-8014
                    Reset counter: 182
                    Reset counter: 222
                    Mileage: 355719 km
Address 56: Radio
   Part No SW: 1K0 959 703 AF    HW: 1K0 959 795 S
   Component: J388   TUER-SG HL   1401
   Revision: 11006001    Serial number: 00000003240198
   Coding: 0000144
   VCID: 74E7DA531713C02FDB-8020
   Part No SW: 1K0 959 704 AF    HW: 1K0 959 794 S
   Component: J389   TUER-SG HR   1401
   Revision: 11006001    Serial number: 00000003221581
   Coding: 0000144
   VCID: 75E1E7571C69D927EC-8020
End-------------------------(Elapsed Time: 01:45)--------------------------
And any insight on the fault codes overall is more than welcome.
JMR
Romania
C?ID=432218
The following code was computed by a 3rd party provider (vis4vag.com) based on VIN and ABS part number. It is provided without any guarantee that it is correct for your particular application and we expressly disclaim any liability if it is not correct. Incorrect coding may negatively affect safety or vehicle systems functions ! If you are willing to try it, do so at your own risk. If you are not comfortable with that, please seek advice/repair/coding from the manufacturer of the vehicle.
Don't forget to do the basic settings in the same session, otherwise the coding won't stick ! Please copy/paste the coding.
NO vacuum sensor 113B401209230003880F02E9902000403400
ojaibat
Saudi Arabia
C?ID=255829
Thanks a lot for the quick response! I will try it tomorrow and report back the outcomes.
Reactions: JMR
etz2k
C?ID=69430
Because the coding from JMR is wrong (tmc size, brake size & edl engine torque), i will try to give you a correct one.
with iTPMS button: 143B601209230003280F06E9902000413400
w/o iTPMS button: 143B601209230003280F06E9902000413000
@JMR can you try to select the correct brake parts size and engine for your coding?
JMR
Romania
C?ID=432218
No , vis4vag won t let you select tire sizes ,it s based only on VIN perhaps. Sometimes the only option is it s with a vacuum sensor or no vacuum sensor.
JMR
Romania
C?ID=432218
@etz2k As you can see..there are not many options to input regarding the coding , sometimes it gives 4 codings for same module ( vac sensor yes no , type a or type 2. I believe it s calculated somewhat on a VIN and abs part number. Sometimes good..sometimes bad. Mostly good. But it s free to try . Disregardbthe part that says i m not logged in , i m on my phone and wanted to show you what i meant about the limited options for abs coding. But , at least you re around and can provide good coding in case it needs be.. :thumbs:
https://flic.kr/p/2nvJxr6
ojaibat
Saudi Arabia
C?ID=255829
@etz2k Thank you for the new codes. I haven't really had the chance to work on that car since i'm now in business trip for three weeks. I will try the codes when i'm back and report to you guys which one worked for me.
etz2k
C?ID=69430
The question is not which coding work, it's which coding fits your car. You can have many codings that work w/o an error, but are still not correct for the car.
ojaibat
Saudi Arabia
C?ID=255829
Fair enough. I unfortunately have limited knowledge about coding this module and the long coding helper didn't provide much information that is why i unable to verify the correct coding for the car. But at least it is great to have such nice people as you guys to give a hand. :thumbs:
Reactions: JMR
