Wiring help (2007 VW Rabbit)
AlexV86
Bakersfield, CA, USA
C?ID=520736
I have a 2007 VW Rabbit
These are the codes I have
-000152 - Intake Air Temperature Sensor 2 (G299)
-008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
I don’t have a wiring diagram for intake temp sensor. It’s the one towards front of car on the intake elbow.
Wiring from the ECT looks to go directly to ecu. While using VCDS I get -48C.
I measured about 5 volts at the connectors. Is that normal?
AlexV86
C?ID=520736
P0098 - 002 - Signal too Low - MIL ON
Fault Status: 11100010
Reset Counter: 255
Mileage: 286917 km
Time: 01:24:51
RPM: 689 /min
Load: 22.3 %
Temperature: 76.0 °C
Temperature: 66.0 °C
Absolute Pres.: 990.0 mbar
Voltage: 13.335 V
P2185 - 002 - Signal too High - MIL ON
Reset Counter: 255
Mileage: 286917 km
Time: 01:24:51
RPM: 691 /min
Load: 22.3 %
Voltage: 13.462 V
AlexV86
C?ID=520736
Looks to me like it’s a ground issue. Since that is what links these two codes together.
what would be the best way to go about it? Should I take apart the wiring loom. Or is there an easier way?
Bruce
Near Philadelphia, PA, USA
When it comes to wiring issues, there are no easy ways. One has to trace the wires and inspect.
Go to the ground point. Inspect,clean, tighten. See if the problem is resolved.
If not, continue the inspection further along the harness.
  • Agree
dieseldub
Gresham, OR
C?ID=28764
Not to mention, those of us who have wiring diagrams and are willing to spend a few minutes pouring over them to help could use the information of production date and engine code supplied by the auto scan...
AlexV86
C?ID=520736
After checking again I did notice Fuse SB24 was blown. Still have a few codes.
Is it normal for relay R1 to be hot?
Here is the new scan.
Wednesday,22,June,2022,20:24:00:21007
VCDS Version: 22.3.1.4 (x64)  HEX-NET2 CB: 0.4615.4
VIN: WVWDS71K27W203855   License Plate:
Chassis Type: 1K (1K0)
VIN: WVWDS71K27W203855   Mileage: 286910km-178277miles
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 Q    HW: 07K 906 032 Q
   Component: 2.5l R5/4V      G   9650
   Revision: --H01---    Serial number: VWZ7Z0G8062260
   Coding: 0000003
   Shop #: WSC 01392 785 00200
   VCID: 372042649348A4433E5-8062
   VINID: 9E69D48C705B0879C200320514FD7EC204
001682 - Fan 1 Control Circuit
               P0692 - 001 - Short to Plus
                    Fault Status: 01100001
                    Mileage: 286917 km
                    Time: 23:44:44
                    RPM: 695 /min
                    Load: 23.5 %
                    Temperature: 74.0°C
                    Temperature: 50.0°C
                    Voltage: 13.589 V
                    Fault Status: 01100010
                    Mileage: 286917 km
                    Time: 23:44:44
                    RPM: 706 /min
                    Load: 25.9 %
                    Temperature: 73.0°C
                    Temperature: 50.0°C
                    Voltage: 13.716 V
                    Mileage: 286917 km
                    Time: 23:44:44
                    RPM: 707 /min
                    Load: 25.9 %
                    Temperature: 73.0°C
                    Temperature: 50.0°C
                    Voltage: 13.716 V
Readiness: 0110 1101
   Part No SW: 09G 927 750 FL    HW: 09G 927 750 FL
   Component: AQ 250 6F           0920
   Revision: 00H69000    Serial number:
   Coding: 0000072
   Shop #: WSC 01279 785 00200
   VCID: 0052E9B8860623FBCFF-8054
   Part No: 1K0 907 379 P
   Coding: 0017025
   VCID: 3FD02A44BB789C03F65-806A
   Part No: 1K0 820 047 GS
   Component: Climatic PQ35   120 0606
   VCID: 7BA89E54EFE040239AD-802E
            009 - Open or Short to Ground
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006698564
   Coding: 108D8F214004150047140000001400000008730B5C0001
   Shop #: WSC 22593 444 85670
   VCID: 6B88AE149F80D0A30AD-803E
   Component: Wischer 100207 020  0501
   Coding: 00038805
   Shop #: WSC 22593
   Component: 5L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D081XRG
   Coding: 0013644
   VCID: 6C8AAD089A8ED79B037-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME167501270
   Subsystem 3 - Serial number: 6342MSME170C0966D
   Subsystem 4 - Serial number: 6352QSME22417A339
   Subsystem 5 - Serial number: 6362QSME21134679B
   Subsystem 6 - Serial number: 63727SME0C290B194
   Subsystem 7 - Serial number: 63827SME0C382530.
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 636 0070
   Coding: 0010022
   VCID: 76BE8F60D4C21D4BE53-8022
   Part No SW: 1K0 920 953 P    HW: 1K0 920 953 P
   Revision: V0003000    Serial number: VWZ7Z0G8062260
   Coding: 0007207
   Shop #: WSC 22593 444 58611
   VCID: 382241589E56AB3B37F-806C
                    Fault Status: 00101010
                    Reset counter: 145
                    Mileage: 286917 km
                    Time: 20:10:11
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 180207F2001821
   Coding: 3F3F034007000002
   VCID: 2F307A046B186C83665-807A
                    Fault Status: 00101011
                    Fault Frequency: 216
                    Reset counter: 139
                    Mileage: 284122 km
                    Time: 19:37:54
   Component: IMMO            VDD 1610
   Component: Tuer-SG         005 0979
   Coding: 0001205
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 343A7568823E4F5B1B7-8060
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Component: A_ KSG PQ35 G2  020 0203
   Coding: 939006885103087F0904058FB0080F0488FC80
   VCID: 71B4BC7CBDAC3A73301-8024
00080 - Function Request - Sliding Roof
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 105
                    Mileage: 286917 km
                    Time: 23:42:05
   Coding: 0001204
   VCID: 3924445CA55CB233C81-806C
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 1K0 035 180 H    HW: 1K0 035 180 H
   Component: Radio PM6       017 0023
   Revision: 00017000    Serial number: VWZ5Z7G2132777
   Coding: 0040402
   VCID: 251C982C39E426D39C9-8070
00857 - CD Changer Unit (R41)
                    Reset counter: 105
                    Mileage: 286917 km
                    Time: 22:15:41
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         005 0913
   Coding: 0001168
   Shop #: WSC 01279 785 1012552
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0001168
End----------(Elapsed Time: 01:09, VBatt start/end: 13.0V/13.2V)-----------
AlexV86
C?ID=520736
Wednesday,13,July,2022,13:34:09:21007
VIN: WVWDS71K27W203855   License Plate: 7/13
Mileage: 286910km-178277mi   Repair Order:
   Coding: 0000003
                    Mileage: 286917 km
                    Time: 00:06:24
                    RPM: 741 /min
                    Load: 27.8 %
                    Temperature: 51.0°C
                    Temperature: 37.0°C
                    Voltage: 13.335 V
                    Mileage: 286917 km
                    Time: 00:06:24
                    RPM: 746 /min
                    Load: 27.8 %
                    Temperature: 51.0°C
                    Temperature: 37.0°C
                    Voltage: 13.462 V
   Coding: 0000072
   Coding: 0017025
   Coding: 00038805
   Shop #: WSC 22593
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 146
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.75 V
   Coding: 0013644
   Coding: 0010022
   Coding: 0007207
   Coding: 0001205
   Coding: 0001204
   Coding: 0040402
                    Fault Status: 00110100
                    Reset counter: 146
                    Mileage: 286917 km
                    Time: 00:17:22
   Coding: 0001168
   Coding: 0001168
End----(Elapsed Time: 01:14, VBatt start/end: 11.3V/11.0V. VIgn 11.2V)-----
AlexV86
C?ID=520736
It would be appreciated if you told us how it was resolved.
The cooling fans resolved by replacing the FCU. My problem now is that I still have to codes that are causing a check engine light.
Both sensors G299 Intake Air Temperature sensor and G83 Engine Coolant Temperature at radiator are not giving correct read out.
I have checked for voltage at the connectors (red for IAT/ Yellow for ECT) both reading about 4.6v.
Not sure what normal looks like.
Ground wire has continuity. I tried doing a load test with headlight bulb 12v. on the wires. Didn't notice any issues with that.
What am I missing?
AlexV86
C?ID=520736
Not sure where the ground point is. My guess based of wiring diagram is that the ground is in the ECU. Not sure where the ECU grounds.
Bruce
The grounds are often studs welded to the frame. The ground points are shown in the documents that support the wiring diagram. Modules must have a reference to a good ground to properly function.
AlexV86
C?ID=520736
Thank you for the replies. There are still some questions that have not been answered.
What is normal voltage on wires coming directly from ECU?
What type of test is good to check if ground is bad on wire coming from ECU?
and new question?
When should I rule out the ECU as the problem?
These questions are related to G299 and G83 sensors (wiring diagram).
There are dozens, or possibly a hundred or so wires connected to the ECU. Can we narrow this question down some?
AlexV86
C?ID=520736
Question is in regards to the two sensors that are causing a MIL.
AIT (G299) sensor red wire to pin 49 and ECT (G83) yellow wire to pin 17 at ECU.
AlexV86
C?ID=520736
Update- I was able to get my hands on a used ECU. I plugged it in and went to measure blocks. Engine coolant temp. sensor (G83) was actually giving a proper read out.
Now my new question is about Immobilizer. The car won’t run. Is this something that can be fixed via VCDS?
Or should I look at possibly repairing my current ECU?
Bruce
VCDS cannot help with Immobilizer. Please see this page: Immobilizer
You car Is Immo IV if I am not mistaken and that cannot be matched with VCDS. Dealer tool or some flashing tool will need to be used. @Jetta 97 may be of help to you as he has a business where he works with ECUs and Instrument Clusters. Id reach out to him.
