Audi RS3 TPMS malfunction
Bryandanger
C?ID=398421
Hi all, I'm in desperate need of help. My RS3 has the indirect TPMS monitor and it is reading a malfunction (code 16388). I've tried everything I can think of. Of course reset it. Tires are all the correct pressure. ABS sensors work bc I can read the speed off of each wheel speed sensor. I got my tires rebalanced without improvement (even tried a different set of tires). As best I can tell all the long coding is correct based on other forms here. I'll attach my scan. Anybody have any ideas what in the world is the problem?
Sunday,05,June,2022,20:03:41:03320
VIN WUABWGFF2J1907052
Mileage: 24076km-14960mi   Repair Order:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
          47 4B 52 5F 6C A5 BB BC CF D6 D7
VIN WUABWGFF2J1907052    Mileage: 24076km-14960miles
Address 01: Engine (------DAZA)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404 G    HW: 07K 907 309 E
   Component: R5 2.5l TFSI  X22 0004
   Revision: 53X22000    CVN: A52877F5
   Coding: 0A250032246600053620
   ASAM Dataset: EV_ECM25TFS0118V0907404G 001004
   ROD: EV_ECM25TFS0118V0907404G.rod
   VCID: 3D273F6E2DF16163E49-8068
   VINID: 9E54529D759609A0490070050885DE1375
Readiness: 1110 0101
   Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2112
   Revision: 00H06V07    CVN: BDD0837F
   VCID: 2E050822F0978AFB6D3-807A
   Part No SW: 8V0 614 517 E    HW: 8V0 614 517 C
   Component: ESC           H25 0625
   Revision: 00000000    Serial number: 60808000000599
   Coding: 2EAA6B7DD4990BB089910B6981936974D62BD091D0819636184150D482A812
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   ROD: EV_Brake1UDSContiMK100IPB_035_SK37.rod
   VCID: 3B23317633E56F53DAD-806E
16388 - TPMS Display
          C1146 F0 [137] - Not Available
                    Reset counter: 81
                    Date: 2022.06.05
                    Time: 20:01:02
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0476408769
   Coding: 030C0C
   VCID: 3C21326A36EB686BD37-8068
   Part No SW: 8V0 820 043 AF    HW: 8V0 820 043 AF
   Component: AC Automat    H03 0150
   Revision: 20003000    Serial number: 00000001524468
   Coding: 03000015010000000000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
   VCID: 76B5E0424847F23BE53-8022
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 03E0512900PAG0MUFU03
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001809500601
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0655908238A7E2BBF53-8052
   Component: WWS371 180317  043 0585
   Serial number:         180322220937
   Coding: 0A47F7
   Serial number: 21295968X81A955547A0
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 17 01 2018  00001880
   Serial number: 00000000000010268540
   Sunroof control module:
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST002135DO00000
   Coding: 101F00
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418018083
   Coding: 0470155811
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4BC361B66345DFD36AD-801E
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: B50087C119FFC42474988055000026
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 H    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0083
   Serial number:       190318018
   ASAM Dataset: EV_AudiMagneRide 003007
   ROD: EV_AudiMagneRide_003.rod
   VCID: 46D55082782722BBB53-8012
   Serial number: 003GCR09ZJ4$
   Coding: 9DCCFCC0008000005000001AC24800000065
   VCID: 47CB5D867F2D3BB34E5-8012
   Left seat belt tensioner:
   Serial number: 34258931A21031820584
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34258932A13031830175
   Coding: 333135
   Serial number: 694000000000001R0W4/
   Coding: 303337
   Subsystem 4 - Part No SW: -----------    HW: 480 000 504 18
   Serial number: 3570000000028D681F2R
   Subsystem 5 - Part No SW: -----------    HW: 480 000 504 18
   Serial number: 3580000000067D681F2V
   Subsystem 6 - Part No SW: -----------    HW: 480 403 103 18
   Serial number: 3510001B92968244127W
   Subsystem 7 - Part No SW: -----------    HW: 480 400 304 18
   Serial number: 3520001A72A5B6B135B7
   Subsystem 8 - Part No SW: -----------    HW: 480 400 503 18
   Serial number: 3550002A52562991331S
   Subsystem 9 - Part No SW: -----------    HW: 480 401 302 18
   Serial number: 3560002A52562991233U
   Part No SW: 8V0 953 521 KT    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 02041804220193
   Coding: 6818
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 1675C0C26807523B053-8042
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 890 A    HW: 8V0 920 890 A
   Component: FBenUSA       H16 0066
   Coding: 084D18537F88CF050284EC041800001000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001027
   ROD: EV_DashBoardFPKAU37X.rod
   Component: GW MQB High   518 5323
   Serial number: 30031810520086
   Coding: 03010004340860005B00803EB80B00000001010000000000000000000000
   GVL: 01D63C000000060040CC80000002CC0000040000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 38292E7A02D3444B37F-806C
   Generator:
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20180406143259 31173
   Subsystem 3 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
   Serial number: 7814447304
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7762
   Serial number: HA1-00023.02.18
   Coding: 0601
   VCID: 4DC76FAE9D51D1E3749-8018
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H07 0022
   VCID: 42DD4C92540F1E9B99B-8016
   Revision: 00000000    Serial number: 18000107783010
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311A4A1EBBA02B1B7-8060
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 3Q0 907 566 F    HW: 3Q0 907 566
   Component: MRR1Rear      H21 0610
   Revision: --------
   Coding: 04C002
   ROD: EV_RearRadarS1BoschVW48X_AU37.rod
   Serial number: 200318ECJ3286A
   Coding: 005D1B205C00048000001003
   VCID: 43D349964B15179392D-8016
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 911E0000
   ROD: EV_SteerAssisMQB_015.rod
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAJ5F01HD6W
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 2411EA0AAE5B30AB8B7-8070
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 20031810522257
   Coding: 000000050100143206112300040000000000000000000000000000000000
   VCID: 72BDDC52242FEE1BC9B-8026
   Serial number: 210318EBQ0598A
   Coding: 005D13205E00048000000003
Address 5F: Information Electr. (J794)       Labels:* 8V0-035-MIB-HGH2.clb
   Part No SW: 8V1 035 880 D    HW: 8V1 035 880
   Component: MU-P-LNS-US   054 1196
   Serial number: A702C0JS008249
   Coding: 017361020000000011220002041A00102F0028E5017001047E
   Subsystem 1 - Part No SW: V03 959 803 AG    HW: -----------
   Component: NAR 2020/2021  --- 0079
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9J1Y09UFK
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL130011800050158
   Compact disc data bank:
   Component: Gracenote2  --- 3012
   Coding: 0273010102002001400040
   VCID: 392F2B7E39D95D43C81-806C
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 0272
   Serial number: 08031812P12522
   Coding: 040307010000020101222346814E490080000E200120
   ROD: EV_MFKBoschMQBB_VW46.rod
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 240318ECN31543
   Coding: 000C13204000048000000002
   Serial number: 240318ECN31442
   Part No SW: 3Q0 907 590 F    HW: 3Q0 907 590
   Revision: --------
   Coding: 04C002
   ROD: EV_RearRadarS2BoschVW48X_AU37.rod
   VCID: 176BCDC66F0D6B331E5-8042
End----------(Elapsed Time: 02:01, VBatt start/end: 12.1V/12.1V)-----------
etz2k
C?ID=69430
If you clear the DTC, how long, how fast, etc can you drive, till it comes up again.
What does the learning values of the iTPMS show (if you drive)?
I think we need some more info to pinpoint the error.
Bryandanger
C?ID=398421
After I clear it I can drive about 20mi before it comes back on. I’ve done city driving and highway driving. I’m don’t know how to access the learning values. I the 8v.5 and haven’t found anything on the inter webs about that. But I’ll take any advice you have.
HI, why did you edit out your VIN ? There are many knowledgeable forum members here who use that to look up information on your specific vehicle. It is certainly up to you, but I'll bet forum members who utilize that bit of information and do not see it, just move on to another question.
Bryandanger
C?ID=398421
Ah, you're right. I didn't think about that. I edited it back in. Thanks.
etz2k
C?ID=69430
Do you use the org. RS3 rim and tire size (different front and rear)?
Maybe a problem with the WSS or wheel bearing magnetic encoder (im not shure if you can see it with the wheel speed in vcds, because of the slow data rate).
Bryandanger
C?ID=398421
I bought the car with the reverse staggered setup. I now have a square setup but still oem spec tires on the original rims. Also I have an device where I can read all 4 wheel speed sensors in real time. They all seem to be reading fine. In an effort to fix my tpms issue I cleaned each wheel speed sensor as well. I’m assuming if I can read the speed at each wheel than the ring is working. I was also expecting to see an abs error, but maybe I’m wrong. I’m not sure what the wheel bearing magnetic encoder is, I’ll look into that.
etz2k
C?ID=69430
I would recommend to use the org. RS3 rims and tires with the different (front/rear) size to exclude this as problem.
The iTPMS use only the information from the WSS to calculate and compare the tire deflation (actions like accelerate and braking restrict the function, because it have an influence of the wheel speed)
You can see this in the learning values while you drive.
I think you can select the sensitivity of the system a bit with VCDS. You can also compare the RS3 values with the S3 and test if it have an influence if you change them in "adaptation values".
I have a A3 2.0t quattro with MK60EC1 (where i can see many iTPMS learning values that show me the problem before a Warning Message goes on), but i don't know much about the rs3 mk100ipb.
Bryandanger
C?ID=398421
That makes sense. Do you know what that adaption setting that changes the sensitivity is a called? Is it in the abs module? Also where do you see adaption values on your a3? I’d like to check if I can see mine. Thanks for your help with all this.
etz2k
C?ID=69430
Bryandanger
C?ID=398421
Man, I sure appreciate you looking at this. Ive been at a loss for awhile now and I'm thankful for any new idea... and also your time.
ADPMAP
;SW:8V0-614-517-E   HW:8V0-614-517-C ---  ABS Brakes
;Component:ESC           H25 0625, Coding:2EAA6B7DD4990BB089910B6981936974D62BD091D0819636184150D482A812
;EV_Brake1UDSContiMK100IPB,070001,EV_Brake1UDSContiMK100IPB_035_SK37.rod
;Saturday,02,July,2022,20:15:06:03320
;VCDS Version: Release 22.3.1 (x64)  Data version: 20220407 DS337.0
;VCID: 3B23317633E56F53DAD-806E
IDE00252-Brake system vacuum pump,5 ,1
IDE00820-Activating and deactivating all development messages,0 ,1
IDE01763-Dimming,not activated ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE03493-Driver's door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04508-Hydraulic brake booster,8 ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-Electromechanical parking brake,not activated ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire Pressure Monitoring System (TPMS),2 ,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04949-Engine drag torque control,activated ,1
IDE04951-Brake Boost,4 ,1
IDE04952-Braking torque boost for distance regulation,6 ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,not activated ,1
IDE05337-Starting vibration reduction-,Deactivated ,1
IDE05337-MAS02653-Starting vibration reduction-Limited torque,Deactivated ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,1 ,1
IDE07292-Brake pre-filling,completed successfully ,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
IDE12030-Rough road optimization,activated ,1
MAS00122-Electronic Stability Program,not activated ,1
MAS00970-Running manufacturer number,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
MAS11606-Electromechanical parking brake: emergency braking,activated ,1
ENG118148-Developer_Function_1,0 ,1
ENG130301-Developer_Function_121,not activated ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,6 ,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 ,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,8 ,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,12 ,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 ,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,6 ,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,6 ,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,8 ,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,12 ,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,80 ,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
Elapsed Time: 00:16
BLOCKMAP
;Saturday,02,July,2022,20:14:52:03320
Group,Description,Actual
IDE00609-MAS01156,Communication status of data bus 1-Communication status,|Control module,Communication status|Engine Electronics,active|Transmission Electronics,active|Instrument cluster,active|Steering angle sensor,active|Power steering,active|Data Bus OBD Interface,active|Airbag,active|All-wheel drive electronics,active|Distance Regulation,active|Wheel Damping Electronics,active|Anti-Theft Immobilizer,active|Electronic central electric,active|,
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator pedal position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,Malfunction,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,Open,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,FF07052,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency braking display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,0.00000, m/s²
IDE02492,Start/Stop Function: coding information,Start-stop function in control module not active,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,On,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,Not available due to specific system,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,OFF,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,Not available due to specific system,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll back detection,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll back detection,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,0,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,3,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,0,
IDE03010-MAS04515,Number of prevented stop processes-Roll back detection,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,5,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,19,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04515,Number of requested start processes-Roll back detection,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2126,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,14,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,30,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,62,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,62,
IDE03127,Prevented stop processes (ring memory),Initial value,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2126,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,14,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,30,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,62,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,62,
IDE03128,Requested start processes (ring memory),Initial value,
IDE03207,Hardware version for suppliers,Freescale,
IDE03212,Start/stop conditions,System malfunction,
IDE03213,Start/stop enable,At least one release missing,
IDE03527-IDE02070,CAN signals-Wake-up cause,1,
IDE03527-IDE02445,CAN signals-Transmission type,20,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.005, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,12.273, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,On,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-1, mbar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.20, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,Not available due to specific system,
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,Not operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,65535, mm
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,65535, mm
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,65535, mm
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,65535, mm
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04442-IDE00009,Vacuum sensor-Date of manufacture,ÿÿÿÿÿÿÿÿÿÿ,
IDE04442-IDE00010,Vacuum sensor-Serial number,FF FF FF FF FF,
IDE04442-IDE00104,Vacuum sensor-DTC,0,
IDE04442-IDE02955,Vacuum sensor-System status,Not available due to specific system,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,65535,
IDE04442,Vacuum sensor,-1, mbar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,65535,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,-0.04905, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,0.18639, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,-0.09810, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,0.00000, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,-0.034, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,-12.381, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,-12.381, °
IDE04446-IDE01599,Hill descent control-Incline,0, %
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not available due to specific system,
IDE04452-IDE03664,Brake system button-Button for driving program,Not available due to specific system,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not operated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE02955,Brake disk drying-System status,available.,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,20023, km
IDE04461-IDE03208,Internal measured values-Software version for suppliers,VAERAD00010,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,not completed successfully,
IDE04461-MAS01481,Internal measured values-Temperature in control module,28, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TSCBAB00008,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not detected,
IDE04508-IDE02955,Hydraulic brake booster-System status,Not available due to specific system,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,Malfunction,
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,0.20, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,Malfunction,
IDE04644-IDE02955,Roll-over protection-System status,available.,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,not activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,available.,
IDE04645-IDE03493,Electromechanical parking brake-Driver's door status,activated,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE04944,Electromechanical parking brake-Brake pedal evaluation,activated,
IDE04645-IDE04948,Electromechanical parking brake-Fall-back level,0,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,activated,
IDE04645-IDE06590,Electromechanical parking brake-Play protection counter: button for electromech. parking brake,0,
IDE04645-MAS02666,Electromechanical parking brake-Seat belt buckle scan,activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,6,
IDE04646-IDE02657,Electromechanical parking brake: parking brake motors-Cut-off current: left: reached,0.00, A
IDE04646-IDE02658,Electromechanical parking brake: parking brake motors-Cut-off current: right: reached,0.00, A
IDE04646-IDE04496,Electromechanical parking brake: parking brake motors-Left parking brake motor: status,Open,
IDE04646-IDE04497,Electromechanical parking brake: parking brake motors-Right parking brake motor: status,Open,
IDE04646-IDE04506,Electromechanical parking brake: parking brake motors-Calculated left rear brake temperature,29.0, °C
IDE04646-IDE04507,Electromechanical parking brake: parking brake motors-Calculated right rear brake temperature,29.0, °C
IDE04646-IDE04647,Electromechanical parking brake: parking brake motors-Left parking brake motor: current,0.00, A
IDE04646-IDE04648,Electromechanical parking brake: parking brake motors-Right parking brake motor: current,0.00, A
IDE04646-IDE05048,Electromechanical parking brake: parking brake motors-Left parking brake motor: actuation counter,1965,
IDE04646-IDE05049,Electromechanical parking brake: parking brake motors-Right parking brake motor: actuation counter,1962,
IDE04765-IDE02955,Counter steer support-System status,available.,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,24293, km
IDE04772-IDE03530,Indicator light in the button for electromech. parking brake-Monitoring status,7,
IDE04772-MAS03745,Indicator light in the button for electromech. parking brake-Function light,OFF,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04871-IDE01599,Dynamic starting assist-Incline,0, %
IDE04871-IDE02445,Dynamic starting assist-Transmission type,automatic,
IDE04871-MAS01447,Dynamic starting assist-Act.val.,normal,
IDE04871-MAS03995,Dynamic starting assist-Clutch pedal threshold: initial value,60, %
IDE04871-MAS03996,Dynamic starting assist-Clutch pedal threshold: learned value,0, %
IDE04871-MAS04734,Dynamic starting assist-Required engine torques: current slope (TARGET),0, Nm
IDE04871-MAS04735,Dynamic starting assist-Current engine torques (ACTUAL),0, Nm
IDE04871-MAS04736,Dynamic starting assist-Expected achievable engine torques,0, Nm
IDE04939-IDE02955,Tire Pressure Monitoring System (TPMS)-System status,available.,
IDE04939-IDE04248,Tire Pressure Monitoring System (TPMS)-Left front tire pressure diffusion indicator,255,
IDE04939-IDE04249,Tire Pressure Monitoring System (TPMS)-Right front tire pressure diffusion indicator,254,
IDE04939-IDE04250,Tire Pressure Monitoring System (TPMS)-Left rear tire pressure diffusion indicator,255,
IDE04939-IDE04251,Tire Pressure Monitoring System (TPMS)-Right rear tire pressure diffusion indicator,255,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,24417, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,22514, km
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,24346, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,24332, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,24332, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,20547, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,19231, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,18884, km
IDE04939-MAS04544,Tire Pressure Monitoring System (TPMS)-Left front flat tire indicator,255,
IDE04939-MAS04545,Tire Pressure Monitoring System (TPMS)-Right front flat tire indicator,255,
IDE04939-MAS04546,Tire Pressure Monitoring System (TPMS)-Left rear flat tire indicator,255,
IDE04939-MAS04547,Tire Pressure Monitoring System (TPMS)-Right rear flat tire indicator,255,
IDE05712-IDE02955,AUTO HOLD-System status,Not available due to specific system,
IDE05712-IDE03530,AUTO HOLD-Monitoring status,7,
IDE05712-IDE04498,AUTO HOLD--AUTO HOLD- Indicator Lamp,OFF,
IDE05712-IDE04561,AUTO HOLD-Switch-on and shut-off conditions,valid,
IDE05712-IDE05333,AUTO HOLD-Indicator light in AUTO HOLD button,OFF,
IDE05712-MAS00025,AUTO HOLD-Driver seat belt switch,not connected,
IDE05712-MAS03095,AUTO HOLD-Function status,not active,
IDE05712-MAS04006,AUTO HOLD-Operating mode,Last setting,
IDE05712-MAS04409,AUTO HOLD-Active hold,not active,
IDE05712-MAS04411,AUTO HOLD-Hydraulic pressure transfer to electro-mechanical parking brake,No,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,268429,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,2947924,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,69714,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,58581,
IDE07280-IDE04775,Multiple collision brake-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multiple collision brake-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multiple collision brake-Year,2127,
IDE07280-MAS00107,Multiple collision brake-Month,15,
IDE07280-MAS00108,Multiple collision brake-Day,0,
IDE07280-MAS00109,Multiple collision brake-Hours,31,
IDE07280-MAS00110,Multiple collision brake-Minutes,63,
IDE07280-MAS00111,Multiple collision brake-Seconds,63,
IDE07280-MAS07659,Multiple collision brake-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multiple collision brake-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multiple collision brake-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multiple collision brake-Mileage reading of the last deactivation by driver,0, km
IDE80101,Analysis 101,A3 32 38 35 31 35 37 38 38 32 33 33 30 30 30 30 36 31 38 33 32 31 30 30 32 35 37 2F 02 0D 1E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,87.885, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,94.1346, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,83.1978, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,702,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,86.7132, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,849,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,91.791, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,393,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,87.885, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,534,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,available.,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,29.0, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,29.0, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,29.0, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,29.0, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake lamp switch,Not operated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,available.,
MAS00121-MAS01854,Electronic Differential Lock-Right front,available.,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,available.,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,available.,
MAS00210-IDE80007,Parking Brake-Analysis 7,18795, km
MAS00210-IDE80008,Parking Brake-Analysis 8,24473, km
MAS00210-IDE80009,Parking Brake-Analysis 9,0, km
MAS00210-IDE80010,Parking Brake-Analysis 10,14795, km
MAS00210-IDE80011,Parking Brake-Analysis 11,24473, km
MAS00210-IDE80012,Parking Brake-Analysis 12,8F 0A 11 10 02 0C,
MAS00210-ENG36680,Parking Brake-ActDbg_ECR_EvCnt,0,
MAS00210-ENG36681,Parking Brake-ActDbg_ESA_EvCnt,0,
MAS00210-ENG36682,Parking Brake-ActDbg_OTH_EvCnt,0,
MAS00210-ENG36683,Parking Brake-ActDbg_SAR_EvCnt,0,
MAS00210-ENG36684,Parking Brake-ActDbg_UV_EvCnt,0,
MAS00210-ENG36685,Parking Brake-ActDbg_UVE_EvCnt,0,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,available.,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.0, %
MAS02138-IDE02955,Hill-start assistant-System status,available.,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,Open,
MAS02138-MAS03095,Hill-start assistant-Function status,Condition not met,
MAS02426-MAS00580,Text display in instrument cluster-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument cluster-Text,0,
MAS02672-IDE02955,Start-stop-System status,Not available due to specific system,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,0,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,0,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,0,
MAS08072-MAS13688,Driving profile selection-ESC actual value,0,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,0,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,0,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,0,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,0,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,available.,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,Not available,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,Not available,
MAS08072-MAS13700,Driving profile selection-ESC system status,available.,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
Elapsed Time: 00:13
etz2k
C?ID=69430
In the adaption values are this 2 settings:
IDE04939-Tire Pressure Monitoring System (TPMS),2 ,1 (default, sensitive, insensitive)
IDE07006-Tire pressure monitoring display: tire selection,1 ,1 (normal, unknown or SST-tires)
They are both 2 for a S3 8V (you can try SA-Code: 20103 if it's required)
In the measuring values this are for the iTPMS (i sorted it a bit):
I miss the low and high speed learning status (0-100%) that shows how well the system knows the tire parameters.
;shows the km-reading where you press RESET (relearn) button
;The flat tire indicator & tire pressure diffusion indicator values are set to 255 after a iTPMS reset. They moving in the range of 245 till 255 if all is OK, but ;if the system recognize a tire problem the value for this tire(s) is going down to 0, if the 0 is reached a warning message appears in the DIS.
Bryandanger
C?ID=398421
Awesome thanks for that. I changed it so they were both set to 2. I drove the car some today but need to drive it a bit more to get past the 20mi mark. I’ll report back tomorrow. Fingers crossed!
what does it mean on the report above for those adaption settings where it shows two numbers such as “2, 1” but on the VCDS I just see a “2”?
Bryandanger
C?ID=398421
Well, no dice. Malfunction came back on again. How would I change it it to insensitive?
my VCDS setting reads “2”. Would insensitve be 3?
etz2k
C?ID=69430
What are the possible settings 0, 1 & 2 ? I'm not shure what for a setting has which number for the ATE ABS, because the description is from a TRW ABS that don't use numbers for the same settings.
What are the iTPMS learning values for the wheels?
When did this error first ocurred?
Bryandanger
C?ID=398421
This started around 4 months ago and ive been trouble shooting it every since. Ill post the full measuring values, but i copied the TPMS to the top.
IDE04939-IDE04249,Tire Pressure Monitoring System (TPMS)-Right front tire pressure diffusion indicator,255,
;Tuesday,05,July,2022,11:29:02:03320
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.000, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,12.033, V
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.30, bar
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,-0.05886, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,0.21582, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,0.214, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,-5.294, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,-5.294, °
IDE04461-MAS01481,Internal measured values-Temperature in control module,24, °C
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,0.30, bar
IDE04646-IDE04506,Electromechanical parking brake: parking brake motors-Calculated left rear brake temperature,28.5, °C
IDE04646-IDE04507,Electromechanical parking brake: parking brake motors-Calculated right rear brake temperature,28.5, °C
IDE04646-IDE05048,Electromechanical parking brake: parking brake motors-Left parking brake motor: actuation counter,1969,
IDE04646-IDE05049,Electromechanical parking brake: parking brake motors-Right parking brake motor: actuation counter,1966,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,24512, km
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,24480, km
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,24480, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,24480, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,24480, km
IDE04939-MAS04546,Tire Pressure Monitoring System (TPMS)-Left rear flat tire indicator,246,
IDE04939-MAS04547,Tire Pressure Monitoring System (TPMS)-Right rear flat tire indicator,246,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,268497,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,2948137,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,58614,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,81.2448, %
IDE80102-ENG122582,Analysis 102-value_2_percentaged,84.3696, %
IDE80102-ENG122584,Analysis 102-value_3_percentaged,80.4636, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,709,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,83.5884, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,855,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,86.3226, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,397,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,84.7602, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,538,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,28.5, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,28.5, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,28.5, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,28.5, °C
MAS00210-IDE80008,Parking Brake-Analysis 8,24518, km
MAS00210-IDE80011,Parking Brake-Analysis 11,24523, km
Elapsed Time: 00:13
Bryandanger
C?ID=398421
Ill try the TPMS montoring system adaptation on setting 3. The measuring value still says diffusion indicator,255, but i'll try it and see
etz2k
C?ID=69430
Only the value of the rear tires drops (by the same value!?) and maybe a bit to much, if i compare it with my car. :confused:
Tire diffusion indicator is for longtime problem and not so relevant in this case. Flat tire indicator is where you should look.
