Vw polo abs coding ESP 5.7
vytosa
Lithuania
C?ID=356403
I have VW Polo 2003 1.2 vin number WVWZZZ9NZ4Y135439 abs bosch 5.7 6Q0907379Q
manual transition 5mt. no PR sticker on car. can anyone provide me with abs coding ?
2kaa52
C?ID=319193
I am sure,there is Somebody on the forum who can.
But first,pls post a Autoscan from this car.
JMR
EU
C?ID=432218
@Uwe @Boki Ar / feeliiiiiing ! Ive called it , got dibs on it !
vytosa
Lithuania
C?ID=356403
Cant post autoscan, doesnt have getaway old car…
Westbury, UK
That's not true, you can do an Auto-Scan on a car without a CAN gateway - you just have to manually select the platform type using the pulldown option box.
I've owned several B6/B7 platform cars which don't have a CAN gateway and done an Auto-Scan on all of them.
vytosa
Lithuania
C?ID=356403
Thanks for telling here is Auto-scan, i tried to code via odis, i put all what i found with 9N abs codings, so this coding is bad.
Friday,01,July,2022,09:53:52:31322
VCDS Version: 22.3.0.1 (x64)  HEX-V2 CB: 0.4613.4
Data version: 20220225 DS336.1
VIN: WVWZZZ9NZ4Y135439   License Plate:
Mileage: 162990km-101277mi   Repair Order:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ4Y135439   Mileage: 162990km-101277miles
Address 01: Engine        Labels: 03E-906-033-AZQ.lbl
   Part No: 03E 906 033 L
   Component: 1,2l/4V SIMOS3  00HS7001
   Coding: 00071
   Shop #: WSC 02965
   VCID: 290FFFDFB0EE87E3B8C-5184
   WVWZZZ9NZ4Y135439     VWZ7Z0C8288083
Readiness: 1010 0101
Address 03: ABS Brakes        Labels: 6Q0-907-37x-ESP.clb
   Part No: 6Q0 907 379 Q
   Component: ESP 5.7 front   H03 0000
   Shop #: WSC 00046 000 00000
   VCID: 4BC365571FD2B5F36A0-50F4
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
Address 08: Auto HVAC        Labels: 6Q0-820-045-V1.clb
   Part No: 6Q0 820 045
   Component: Klimaanlage        X0840
   VCID: 6A8DC0D375684CFB716-50F4
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 0000 BN-SG.         1S34
   Coding: 25790
   Shop #: WSC 00788
   VCID: 3C21368B4F7C024BD3A-50F4
01598 - Drive Battery Voltage
   Part No: 1C0 909 605 K
   Component: 0M AIRBAG VW51 0P   0008
   Coding: 12365
   Shop #: WSC 00788
   VCID: 2C0106CBBF1C92CB43A-50F4
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 800 P
   Component: KOMBI+WEGFAHRSP VDO V18
   Coding: 01131
   VCID: 3A2D309345483C7BC16-50F4
   Part No: 6N0 909 901
   Component: 0009 GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 00788
   VCID: 70B9D2BB53B4B62B3F2-50F4
   Part No: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 10140
   Shop #: WSC 00788
   VCID: 6FBBD1C74E8AA9D3268-50F4
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 6Q0 959 433 H
   Component: 1G Komfortgerбt     0002
   Coding: 00067
   Shop #: WSC 00788
   VCID: 40D9427B239466AB8F2-4B3C
   Subsystem 1 - Part No: 6Q2959802A
   Component: 1G Tхrsteuer.FS TFK 0004
   Subsystem 2 - Part No: 6Q2959801A
   Component: 1G Tхrsteuer.BF TFK 0004
End----(Elapsed Time: 02:53, VBatt start/end: 14.3V/14.5V. VIgn 0.0V)------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 44: DTCs cleared
Address 46: DTCs cleared
   Coding: 00071
   Shop #: WSC 02965
   VINID: 9E69EAAAA25EA84A410C5103242DDE9A64
Readiness: 1110 0101
   Coding: 0003374
   VCID: 4BC365571FD2B5F36A0-50D0
            P1647 - 000 -
   VCID: 6A8DC0D375684CFB716-50D0
   Coding: 25790
   Shop #: WSC 00788
   VCID: 3C21368B4F7C024BD3A-50D0
   Coding: 12365
   Shop #: WSC 00788
   VCID: 2C0106CBBF1C92CB43A-50D0
   Coding: 01131
   VCID: 3A2D309345483C7BC16-50D0
   Coding: 00014
   Shop #: WSC 00788
   VCID: 70B9D2BB53B4B62B3F2-50D0
   Coding: 10140
   Shop #: WSC 00788
   Coding: 00067
   Shop #: WSC 00788
End----(Elapsed Time: 02:38, VBatt start/end: 14.0V/14.3V. VIgn 0.0V)------
Reactions: JMR
As I saw @vytosa is regular member but not verified. ;) :cool:
Fixed. He joined the forum before he was a registered VCDS user, and also registered his system with a different e-mail address than the one he joined the forum with. Moving to Car Repair Support now.
Sometimes those "feelings" turn out to be incorrect. :facepalm:
Boki Ar
Arandjelovac, Serbia
C?ID=57300
VIS: 0003362
Give it try.
NEtech
Denmark
C?ID=56995
What is the background, changed anything, Cruise control, etc. ?
Erase all DTC, so there is only P1647 left ?
Do this:
[Options]
[User Interface and Identification]
write numbers for wsc, importer, device no.
For example 02345 123 23456
[Save]
[Close VCDS]
Start VCDS
Code ABS again.
Do Basic settings in ABS.
vytosa
Lithuania
C?ID=356403
will try tomorrow. Thank u. Original abs was faulty, owner changed electrical part of abs. And he didn’t check abs coding of old unit. After change abs coding was 0000000 not coded.
Do this:
[Options]
[Save]
[Close VCDS]
Start VCDS
Code ABS again.
vytosa
Lithuania
C?ID=356403
Hi guys, still same fault. Tried 0003362 and 0003419
Did like NEtech said still same :(
JMR
EU
C?ID=432218
Good info here ;
NEtech
Denmark
C?ID=56995
Try 0003416
Post new autoscan after this.
Maybe do coding in [01] and [19] with the orignal coding after ABS coding.
vytosa
Lithuania
C?ID=356403
Try 0003416
Thank u 🙏 0003416 did the job thank u guys for your help 🙃
vytosa
Lithuania
C?ID=356403
Post new Auto Scan, please.
Thursday,07,July,2022,09:33:19:31322
Workshop Code: 123 02345 023456
VIN: WVWZZZ9NZ4Y135439   License Plate: POLO OK
   Coding: 00071
   Shop #: WSC 02965
   Coding: 0003416
   Shop #: WSC 02345 000 00000
   Coding: 25790
   Shop #: WSC 00788
   Coding: 12365
   Shop #: WSC 00788
   Coding: 01131
   Coding: 00014
   Shop #: WSC 00788
   Coding: 10140
   Shop #: WSC 00788
   Coding: 00067
   Shop #: WSC 00788
End----(Elapsed Time: 02:35, VBatt start/end: 14.4V/14.2V. VIgn 0.0V)------
