RHD Seat Ibiza 6J xenon headlights - to LHD TRAVEL MODE
Maligator
C?ID=508928
Dear knowledgeable VCDS experts,
I was hoping to find travel mode in the infotainment system like on my 2016 Skoda Octavia VRS on my friends Seat Ibiza FR 6J. It wasn't there.
I have found through Google that travel mode is possible to activate via this wonderful software I thankfully paid for so, can anyone tell me from the scan if module 55 is going to allow me?
Many thanks once again :)
PSB the scan:
Tuesday,28,June,2022,17:20:03:34356
VIN: VSSZZZ6JZGR098318   License Plate:
Mileage: 82542km-51289mi   Repair Order:
Chassis Type: 6J-SE26 (6C0)
Scan: 01 03 08 09 14 15 17 19 44 55 5F A9
VIN: VSSZZZ6JZGR098318   Mileage: 82542km-51289miles
Address 01: Engine (J623-DAJA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 6C0 906 264     HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---    CVN: 41AA0A42
   Coding: 0B1900122424010B0000
   Shop #: WSC 00049 770 00115
   ASAM Dataset: EV_ECM18TFS0206C0906264 001004
   ROD: EV_ECM18TFS020_SE26.rod
   VCID: 6490AE9D8ED3DC6B4B7-8030
   VINID: 9A38EAAAA19AA978802480C120E515D8A9
15101 - MAP/MAF <-> Throttle Position Correlation
          P0068 00 [096] - -
26372 - Leak in Air Intake System
          P2279 00 [096] - -
26370 - MAP/MAF <-> Throttle Position Correlation
          P0068 00 [096] - -
21406 - EVAP Emission Control Sys
          P0441 00 [096] - Incorrect Flow
21630 - No Communications with HVAC Control Module (J301)
          U0164 00 [032] - -
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08509227160209
   Coding: 14DD687D8B2C33C80917306A00592816D1CC900C0012CF098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 372A29D16FC5E7F33E5-8062
Address 08: Auto HVAC (J255)       Labels:| 6C0-907-044.clb
   Part No SW: 6P0 907 044 B    HW: 6P0 907 044 B
   Component: Climatronic   H02 0202
   Serial number:  1602091A-0810
   Coding: 000000001001000001
   Shop #: WSC 00049 770 00139
   ASAM Dataset: EV_ACClimaValeoPQ26 003001
   ROD: EV_ACClimaValeoPQ26.rod
   VCID: 303812CD8AAB30CB7FF-8064
590081 - Control Circuit for A/C Compressor
          B10A9 11 [008] - Short to Ground
                    Reset counter: 224
                    Mileage: 80075 km
                    Date: 2022.05.20
                    Time: 12:45:44
                    Compressor shut-off condition: Compressor activation: malfunction in activation path
                    Compressor current: actual value: 1.275 A
                    Compressor current: specified value: 0.000 A
                    Voltage terminal 30: 12.6 V
                    Outside temperature: 19.5 °C
                    Engine RPM: 1266 /min
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0087
   Serial number: 006098095700
   Coding: 0B000A4042132AFB0B244000B12F07180000690257010000000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005.rod
   Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S4Y16M02D10H11M27S49
   Coding: 00984D
   Driver door control module:
   Subsystem 2 - Part No SW: 6R0 959 802 EC    HW: 6R0 959 802 EC  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 0630
   Serial number: KU0KU014011660140634
   Coding: 0400B5
   Front passenger door control module:
   Subsystem 3 - Part No SW: 6R0 959 801 EB    HW: 6R0 959 801 EB  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 0630
   Serial number: KU0KU004021660355821
   Coding: 1400A5
   Subsystem 4 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY160191KPL
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000065047852
   Humidity sensor: interior:
6154 - Bulb for Rear Right Turn Signal
          B11EB 15 [008] - Open or Short to Plus
                    Reset counter: 226
                    Mileage: 81260 km
                    Date: 2022.05.30
                    Time: 22:49:02
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Stoerschutzzaehler: 29
                    Voltage: 12.3 V
                    Outside temperature: 17.5 °C
203016 - Unlock Switch in Rear Lid Handle
          B140B 29 [008] - Signal Implausible
                    Fault Frequency: 31
                    Reset counter: 244
                    Mileage: 74729 km
                    Date: 2021.12.19
                    Time: 14:22:01
                    OFF: Not operated
                    Stoerschutzzaehler: 19
                    Voltage: 12.4 V
                    Outside temperature: 4.0 °C
922631 - Indicator Lamp for Driving Profile Selection
          B1428 11 [008] - Short to Ground
                    Fault Frequency: 84
                    Reset counter: 1
                    Mileage: 82279 km
                    Date: 2022.06.17
                    Time: 16:15:28
                    Terminal 15 status: On
                    OFF: Not operated
                    Voltage: 14.3 V
                    Outside temperature: 27.5 °C
Address 14: Susp. Elect. (J250)       Labels: 6C0-907-359.clb
   Part No SW: 6C0 907 359     HW: 6C0 907 359
   Component: DAEMPFUNGS-SG H04 0007
   Serial number: 15021602000060
   Coding: 80
   ASAM Dataset: EV_SwitcDampeContiTemic 001004
   ROD: EV_SwitcDampeContiTemic.rod
   VCID: 6A8CC0A56CF78A1B71B-803E
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 L    HW: 6C0 959 655 L
   Component: VW20Airbag005 002 0380
   Revision: --------    Serial number: 003TK00058S7
   Coding: 88C0C000008000005C0000CA008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3C2036FD56E3C4ABD37-8068
   Subsystem 1 - Part No SW: -----------    HW: 410 270 502 16
   Component: SideSensor_Df  15B 0148
   Serial number: 3495R00042951514B419
   Subsystem 2 - Part No SW: -----------    HW: 410 270 502 16
   Component: SideSensor_Pf  15B 0148
   Serial number: 3505R009D1CE85E651A9
   Part No SW: 6P0 920 946 A    HW: 6P0 920 946 A
   Component: KOMBI         208 1423
   Coding: 272D01003980260001082A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_SE26.rod
   VCID: 353623D975C915E32C9-8060
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 224
                    Mileage: 78713 km
                    Date: 2022.05.05
                    Time: 11:30:51
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 224
                    Mileage: 78713 km
                    Date: 2022.05.05
                    Time: 11:30:51
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0087
   Revision: --------    Serial number: 006098095700
   Coding: 030100046F00590071000028880000010001000000000000000000000000
   GVL: 01403C10000000004000100000004C0000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_VW26.rod
   VCID: 6596B39985E9A5635C9-8030
   Subsystem 1 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B  Labels: 3C8-959-537.CLB
   Serial number: 000000000A0689250116
   Coding: 002000
   Subsystem 2 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 53047906534351586258
131699 - Control unit for information electronics 1
          U1054 00 [009] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                    Reset counter: 216
                    Mileage: 78713 km
                    Date: 2022.05.05
                    Time: 11:30:43
                    Terminal 30 power supply: 12.2 V
                    Terminal 15: On
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 AG    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3232
   Serial number: CG2K0561
   Coding: 800700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6E84CCB5501F663B2D3-803A
   Coding: 058E010003000000
   VCID: 40D8420D3A0BA04B8FF-8014
   Subsystem 1 - Part No SW: 7L6 941 329 C    HW: 7L6 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 290000
   Subsystem 2 - Part No SW: 7L6 941 329 C    HW: 7L6 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 290000
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 6P0 907 159     HW: 4H0 907 159 A
   Serial number: 151212202203
   VCID: 75B6E3D9354955E3EC9-8020
End----------(Elapsed Time: 01:04, VBatt start/end: 12.3V/12.3V)-----------
55-Headlight Range. You should have this Adaptation channel:
IDE03787 -- Activate left/right hand drive switch-over.
Maligator
C?ID=508928
Legend! Many thanks, hopefully this works as if not it’s going to be expensive.
quailallstar
Ormond Beach, FL & Washington DC
C?ID=53119
Not trying to hijack the thread, but @Uwe does this coding enable the option to active the switch-over in the infotainment system? Asking because I may be taking my 2019 NAR GTI to the Caribbean, so I would need this option displayed in my MIB2 as well. Thank you!
Maligator
C?ID=508928
You can ‘hijack’, ‘post’, do what you like on this thread so long as it helps you my friend!
Ironically I just finished doing the rear lights on that Seat Ibiza tonight, what a PITA!! De pinning connectors, crossover cables and lots of swearing. Did it though.
With the infotainment system, the coding allowed the LHD option to be displayed on the computer screen but it still doesn’t show anything on the infotainment system screen, it’s just made the headlights switch over.
Hope that helps you.
A 2019 GTI is a very different animal than a 2016 Ibiza. Please do start your own thread.
