Dotman auto
my name is dotun
to everyone pls i need EPB module that can work we my passat my old module part no= 3c0907801j
and my complain is parking brake light on always when i start the car with fault code 02847
and i try some module 3c89o7801 but refuse to accept module coding ,and 3aa907801b and module said wrong vehicle.
please any one with module chart or bulletin where i can find the compatible one that feet my car. auto scan below
Sunday,26,June,2022,20:45:36:25320
VCDS Version: 22.3.1.4 (x64)
Dealer/Shop Name: DOTMAN AUTO MECH
Workshop Code: 000 05311 000000
VIN: WVWZZZ3CZ8P055671 License Plate:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ8P055671 Mileage: 196840km-122310miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 06F 906 056 GL HW: 06F 906 056 FD
Component: MED9.5.10 G00 0186
Revision: 6AH03--- Serial number: VWZCZ000000000
Coding: 0000075
Shop #: WSC 00999 444 64523
VCID: 79F225A830BBBA4788-802C
VINID: 9E69EAAAA0D3A8880014518704B42BE2FC
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 - 004 - Malfunction / Open Circuit - MIL ON
Fault Status: 11100100
Mileage: 196845 km
Date: 2016.11.16
Time: 17:21:11
RPM: 720 /min
Load: 29.8 %
Temperature: 70.0°C
Readiness: 0010 0100
Address 02: Auto Trans
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000776175099
Coding: 0000384
Shop #: WSC 05311 000 00000
VCID: 1F462B30CEDF3477D6-804A
Part No SW: 1K0 820 047 FT HW: 1K0 820 047 FT
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
VCID: 7BFE3FA03A8788579A-802E
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000005180345
Coding: 0804020500041A00070A00000F000000000801405C000000000000000000
VCID: 6FE61BF07EFFE4F726-803A
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 060907 003 0205
Coding: 00046997
Shop #: WSC 05311
00156 - Control Circuit for Windshield Washer Pump
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 96
Mileage: 196845 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.55 V
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 0B AIRBAG VW8 032 2522
Revision: 12032000 Serial number: 003B1PKKUL9B
Coding: 0012354
Shop #: WSC 00028 028 00001
VCID: 3064D88CA341BB0F7F-8064
Subsystem 1 - Serial number: 6332MSME16567F08
Subsystem 2 - Serial number: 6342MSME0B401B24
Subsystem 3 - Serial number: 6351HTS61CG4TNE6
Subsystem 4 - Serial number: 6361HTS61CG4P4H6
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 H HW: 3C0 953 549 H
Component: J0527 0015
Revision: 00005000 Serial number: 3C5953507R
Coding: 0001011
VCID: 3162DD88A84BB20770-8064
Part No SW: 3C8 920 870 F HW: 3C8 920 870 F
Component: KOMBI H03 0305
Coding: 160A00
ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod (VIN: N/A)
VCID: 2E58C6F47175ADFF6D-807A
9453842 - Oil Level Thermal Sensor
B1041 35 [009] - Signal High Time > Maximum
Reset counter: 96
Mileage: 196845 km
Date: 2022.06.26
Time: 18:12:06
13639427 - Please Check Fault Codes in Engine Control Module
U101F 00 [009] - -
Reset counter: 96
Mileage: 196845 km
Date: 2022.06.26
Time: 20:30:36
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P0792004A3
Coding: FD807F060002021002
VCID: 234E27C0E2B71097F2-8076
01304 - Radio
Reset counter: 136
Mileage: 196845 km
Date: 2016.11.16
Time: 18:17:43
Reset counter: 136
Mileage: 196845 km
Date: 2016.11.16
Time: 18:18:41
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 3972E5A8703B7A47C8-806C
Component: ELV 027 0380
3C0905861G ELV 027 0380
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1131
Revision: 32008001 Serial number: 00000006279001
Coding: 0000181
VCID: 3B7EFFA07A074857DA-806E
00915 - Window Regulator Switch; Rear Right; Driver (E55)
Reset counter: 136
Mileage: 196845 km
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.137 H07 1806
VCID: 346CD49C5759872F1B-8060
02546 - Steering Limit Stop
Mileage: 196830 km
Temperature: 46.0°C
Voltage: 13.60 V
Voltage: 13.40 V
Component: KSG PQ46 ELV 042 0472
Coding: 01910A0001864E7730049F1FF0084F0E7078A0
Subsystem 1 - Component: Sounder No Answer
Reset counter: 96
Mileage: 196845 km
Date: 2016.11.16
Time: 18:17:37
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1131
Revision: 32008001 Serial number: 00000519478706
Coding: 0000180
VCID: 3C7CFCBC7F094F6FD3-8068
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000187373
Coding: 0000057
VCID: 295235E8809BCAC7B8-807C
02845 - Function Display in Instrument Cluster (!)
007 - Short to Ground - MIL ON
Fault Status: 11110111
Reset counter: 96
Mileage: 196845 km
Voltage: 13.30 V
Count: 78
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0101
Address 56: Radio
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1118
Revision: 11006001 Serial number: 00000002390882
Coding: 0000144
VCID: 3D7AF1B864134667E4-8068
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1118
Revision: 11006001 Serial number: 00000002420341
Coding: 0000144
VCID: 3E78F6B469155D7FFD-806A
End-------------------------(Elapsed Time: 02:36)--------------------------
