Hello!
I own a Golf VII GTI 2015 with Dynamic Light Assist (and, now, Lane Assist) and Discover Pro - hence it's got the high definition camera.
Dispite all the codification for this tweak seems to go well, we all in Brazil are getting this message:
The only thing that call my attention is that, when I check Bit 2 in Byte 5 on controller 17, I get this message, but it goes away quickly:
I think other brazilian mates had already asked for help here concerning this issue, but are there any news?
here is my log:
Thanks in advance.
here is my log:
Tuesday,16,June,2015,11:48:58:30049
VCDS Version: 15.6.1.0 (x64)
Data version: 20150612
VIN: WVWHE6AU1FW054034 License Plate: OKH6347
Mileage: 13372km-8308mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F A5 A9
VIN: WVWHE6AU1FW054034 Mileage: 13372km-8308miles
Address 01: Engine (J623-CHHB) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0010
Revision: --H13---
Coding: 091D00322464050B3000
ASAM Dataset: EV_ECM20TFS0215G0906259 001014
ROD: EV_ECM20TFS0215G0906259_VW37.rod
VCID: 6BD24E6F82F091673C-803E
Part No SW: 0D9 300 041 T HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4514
Revision: 03252204 Serial number: TFK01406231600
ROD: EV_TCMDQ250021_AU37.rod
VCID: 295E7467488C43778E-807C
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 M HW: 5Q0 907 379 H
Component: ESC H31 0571
Revision: 00000000 Serial number: 61834000000749
Coding: 01FA6BA13425297003770603C1C7A980D62C94C0608395F7F842503AC209
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 4684DFDBF9D28C0F83-8012
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0339795001
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A7CBB2BBD2AF8EFF7-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 AN HW: 5G0 907 044 AN
Component: Climatronic H03 0907
Revision: 00001K08
Coding: 00020014200100011105000000101000
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 73E2560FDAC049A7F4-8026
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011419200017
Coding: 00111E46C24122FB0BA44080B10C07281800000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 000809C39B76623FF9-8054
Slave 1:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A
Component: WWS 140702 043 0551
Serial number: 140704135529
Slave 2:
Component: RLHS 037 0059
Serial number: S5Y14M07D17H01M31S20
Coding: 06A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY141613J2N
Serial number: 00000000000030237040
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO30955624
Coding: 181901
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 F HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0047
Revision: -------- Serial number: 39431419001789
Coding: 0031161051
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_VW37.rod
VCID: 428CC3CBD5FAB02FAF-8016
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Serial number: 11071477031257
Coding: 001C1700FE0739
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 3878A1238326EAFF01-806C
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR06Z47$
VCID: 7F0A8A3FE6881DC780-802A
Seat belt tensioner; left:
Component: BeltPretRevFL H35 0341
Serial number: 34169667B10071440161
Coding: 333135
Seat belt tensioner; right:
Component: BeltPretRevFR H35 0341
Serial number: 34169668B10071471286
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 407 14
Serial number: 35767000000B0325301A
Subsystem 4 - Part No SW: ----------- HW: 480 000 707 14
Serial number: 3586700000068864401N
Subsystem 5 - Part No SW: ----------- HW: 480 400 907 14
Serial number: 35165029B1656B84A32C
Subsystem 6 - Part No SW: ----------- HW: 480 400 907 14
Serial number: 35265029B16569063171
Subsystem 7 - Part No SW: ----------- HW: 480 400 807 14
Serial number: 3556502B31656B80D318
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 EC HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 09071404220102
Coding: 0C10
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 7BF27E2FF29001E7AC-802E
Part No SW: 5G1 920 756 HW: 5G1 920 756
Component: KOMBI 301 4270
Coding: 07AC09186F94000800887A031400000000000000
VCID: 6ADC4B6B8D0A886F47-803E
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002225220
Coding: 030100042B085900FF00027E1C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear.rod
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N
Component: E221__MFL-DC1 H07 0038
Serial number: 29140001438080014276
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 3001113903
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000170910005
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 346095139F4E0E9F2D-8060
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 27061401100313
Coding: 003F1220D000048000000000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 4088C9C3DBF6A23FB9-8014
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000003224417
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 9303
ROD: EV_SteerAssisMQB.rod
VCID: 3566A817943417971A-8060
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 06071402090414
Coding: 003F1220DE00048000800000
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 3F8ACA3FA608DDC7C0-806A
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000003265331
Coding: 190000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 029A01104F010200
ROD: EV_HeadlRegulVWAFS_SE26.rod
Subsystem 1 - Part No SW: 3D0 941 329 D HW: 3D0 941 329 D
Component: LeiMo links H01 0002
Coding: 900000
Subsystem 2 - Part No SW: 3D0 941 329 D HW: 3D0 941 329 D
Component: LeiMo rechts H01 0002
Coding: 900000
Part No SW: 5G0 035 045 C HW: 5G0 035 045 C
Component: MU-H-N-RW H43 0363
Serial number: A311G0EB001691
Coding: 027300030000000011220002000900001F0203F401000100D7
Shop #: WSC 07706 002 104857
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_VW37.rod
VCID: 204869433BB6823FD9-8074
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H60 0030
Serial number: VWZ8Z9PS1005NV
Engine Control Module 2:
Subsystem 2 - Part No SW: V03 959 801 QH HW: -----------
Component: ROW 2015 --- 0039
Door Electronics Rear Left:
Component: Gracenote --- 4006
7179 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 71
Mileage: 13372 km
Date: 2015.06.16
Time: 11:42:04
7184 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 71
Mileage: 13372 km
Date: 2015.06.16
Time: 11:42:04
7194 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 71
Mileage: 13372 km
Date: 2015.06.16
Time: 11:42:04
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H06 0052
Serial number: 00000197343
Coding: 0101020000020303000401010100000100
ROD: EV_MFKBoschAU370_AU37.rod
VCID: 3B72BE2FB210C1E7EC-806E
1114112 - Databus
Reset counter: 71
Mileage: 13372 km
Date: 2015.06.16
Time: 11:43:01
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 140527201991
End-------------------------(Elapsed Time: 04:51)--------------------------
Thanks in advance.
