Hi everyone,
I went to get my 2003 Eurovan smogged, and it failed due to the Secondary Air not being ready. I ran it through multiple days of start up cycles, and haven't been able to get it to read as ready. So I went ahead and connected VCDS (which I haven't used in several years), updated the software and firmware, and tried to run the Auto Scan. The only information I get is for the engine. I'm a VCDS neophyte, so hopefully this is just user error.
I was trying to figure out what might be causing the issue with the secondary air, but not sure how to proceed since I'm not getting any information.
My ECU was modified 4 years ago to bypass the immobilizer, but I've run a smog test in the interim and not had a problem with the 2nd air readiness, so hopefully can get some advice on next steps here to get this running correctly.
I also noticed the 7th/8th digits of my vin don't match the model of my Eurovan in VCDS. the "70" maps to the earlier van model, not my 2003 model. But I tried to scan it with both settings and had no luck.
I need some help trying to isolate what would be causing the 2nd air to not come ready.
Thanks for you help in advance.
Log file:
Saturday,25,June,2022,13:34:52:00895
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
VIN: WV2NB47043H0XXXXX License Plate: WAY3GO
Chassis Type: 7D - VW Transporter/Multivan (1996 > 2004)
Scan: 01 02 03 08 15 17 18 19 22 25 35 37 56
Address 01: Engine Labels: 022-906-032-AXK.lbl
Part No: 022 906 032 AF
Component: MOTRONIC ME7.1 G 0003
Coding: 00013
Shop #: WSC 03738
VCID: 4FFB8FBB7ECD1B83065-5184
Readiness: 0000 1000
End----(Elapsed Time: 03:26, VBatt start/end: 12.4V/12.4V. VIgn 0.0V)------
Log file:
Coding: 00013
Shop #: WSC 03738
